I had to remove steam-manjaro because it was not running properly. I installed steam-native which runs properly but does not see my installed games. I should have uninstalled the games before removing steam-manjaro. I was wondering if anyone knows where steam-manjaro installs its games? I would like to manually remove them and reinstall.
By default Steam installs games to ~/.local/share/Steam/steamapps/common/ and Steam native is just a startup script that sets some variables for Steam I think. If you have games previously installed you should just have to indicate the library path to Steam for the games to be discovered.
