Hi, I just switched out my motherboard, CPU and memory, but kept my GPU (GTX770).
I reinstalled Manjaro. Previously, I had been using proprietary drivers, but when I reinstalled, I found that if I selected proprietary drivers, although I could boot initially, after all the updates for some reason it would not boot. So I switched to the free drivers.
Looking at my system info, I can see that there is directx 11 support on the drivers, but when I try to open Witcher 3 on steam (manjaro various Proton versions) I get an error box saying that my card lacks direct11 support, and it will not load. I can get it to load if I put in the parameter PROTON_USE_WINED3D11=1, but it renders poorly all in red and black.
It is usually the case that when I run into a problem with Manjaro it is because I am overlooking some obvious thing. Especially since I could not find ther posts with this problem here or on the steam forum, I really hope I am just doing something stupid and someone will be kind enough to point it out to me,.
My system information is below:
> System:
> Kernel: 5.14.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
> parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
> root=UUID=a4677c34-08ee-4217-a8f8-04d583d29686 ro quiet apparmor=1
> security=apparmor resume=UUID=54b33f09-d1e4-45c1-85ed-60965f977595
> udev.log_priority=3
> Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
> Distro: Manjaro Linux base: Arch Linux
> Machine:
> Type: Desktop System: ASUS product: N/A v: N/A serial: <filter>
> Mobo: ASUSTeK model: TUF GAMING X570-PRO (WI-FI) v: Rev X.0x
> serial: <filter> UEFI: American Megatrends v: 4021 date: 08/10/2021
> Battery:
> Device-1: hidpp_battery_0 model: Logitech Wireless Illuminated Keyboard K800
> serial: <filter> charge: 55% (should be ignored) rechargeable: yes
> status: Discharging
> Device-2: hidpp_battery_1 model: Logitech MX Ergo Multi-Device Trackball
> status: Discharging
> Memory:
> RAM: total: 31.27 GiB used: 2.66 GiB (8.5%)
> RAM Report: permissions: Unable to run dmidecode. Root privileges required.
> CPU:
> Info: 6-Core model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3
> family: 19 (25) model-id: 21 (33) stepping: 0 microcode: A201016 cache:
> L2: 3 MiB bogomips: 88665
> Speed: 2196 MHz min/max: 2200/3700 MHz boost: enabled Core speeds (MHz):
> 1: 2196 2: 2371 3: 2240 4: 2868 5: 2412 6: 2874 7: 3205 8: 2874 9: 3593
> 10: 2697 11: 2650 12: 2875
> Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1
> bmi2 bpext cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov cmp_legacy
> constant_tsc cpb cpuid cqm cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc
> cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
> flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
> invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
> movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
> overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
> perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rapl rdpid
> rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep
> ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall
> tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vaes vgif
> vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec
> xsaveerptr xsaveopt xsaves
> Vulnerabilities: Type: itlb_multihit status: Not affected
> Type: l1tf status: Not affected
> Type: mds status: Not affected
> Type: meltdown status: Not affected
> Type: spec_store_bypass
> mitigation: Speculative Store Bypass disabled via prctl and seccomp
> Type: spectre_v1
> mitigation: usercopy/swapgs barriers and __user pointer sanitization
> Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
> STIBP: always-on, RSB filling
> Type: srbds status: Not affected
> Type: tsx_async_abort status: Not affected
> Graphics:
> Device-1: NVIDIA GK104 [GeForce GTX 770] vendor: eVga.com. driver: nouveau
> v: kernel bus-ID: 08:00.0 chip-ID: 10de:1184 class-ID: 0300
> Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver:
> loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
> Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2")
> s-diag: 582mm (22.9")
> Monitor-1: DVI-I-1 res: 1920x1080 hz: 60 dpi: 96
> size: 509x286mm (20.0x11.3") diag: 584mm (23")
> OpenGL: renderer: NVE4 v: 4.3 Mesa 21.2.1 direct render: Yes
> Audio:
> Device-1: NVIDIA GK104 HDMI Audio vendor: eVga.com. driver: snd_hda_intel
> v: kernel bus-ID: 08:00.1 chip-ID: 10de:0e0a class-ID: 0403
> Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
> driver: snd_hda_intel v: kernel bus-ID: 0a:00.4 chip-ID: 1022:1487
> class-ID: 0403
> Sound Server-1: ALSA v: k5.14.2-1-MANJARO running: yes
> Sound Server-2: JACK v: 1.9.19 running: no
> Sound Server-3: PulseAudio v: 15.0 running: yes
> Sound Server-4: PipeWire v: 0.3.35 running: yes
> Network:
> Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 03:00.0
> chip-ID: 8086:2723 class-ID: 0280
> IF: wlp3s0 state: down mac: <filter>
> Device-2: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
> port: N/A bus-ID: 04:00.0 chip-ID: 8086:15f3 class-ID: 0200
> IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
> IP v4: <filter> type: dynamic noprefixroute scope: global
> broadcast: <filter>
> IP v6: <filter> type: noprefixroute scope: link
> IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
> IP v4: <filter> scope: global
> IP v6: <filter> scope: global
> IP v6: <filter> virtual: stable-privacy scope: link
> WAN IP: <filter>
> Bluetooth:
> Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:2
> chip-ID: 8087:0029 class-ID: e001
> Report: rfkill ID: hci0 rfk-id: 1 state: up address: see --recommends
> Logical:
> Message: No logical block device data found.
> RAID:
> Message: No RAID data found.
> Drives:
> Local Storage: total: 1.82 TiB used: 72.23 GiB (3.9%)
> SMART Message: Unable to run smartctl. Root privileges required.
> ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DX001-1NS164
> size: 1.82 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
> type: HDD rpm: 7200 serial: <filter> rev: CC41 scheme: GPT
> Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH22LS50 rev: TL01
> dev-links: cdrom
> Features: speed: 48 multisession: yes audio: yes dvd: yes
> rw: cd-r,cd-rw,dvd-r,dvd-ram state: running
> Partition:
> ID-1: / raw-size: 1.81 TiB size: 1.78 TiB (98.38%) used: 72.23 GiB (4.0%)
> fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
> uuid: a4677c34-08ee-4217-a8f8-04d583d29686
> ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
> used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
> uuid: C48B-AD92
> Swap:
> Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
> ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2
> dev: /dev/sda3 maj-min: 8:3 label: N/A
> uuid: 54b33f09-d1e4-45c1-85ed-60965f977595
> Unmounted:
> Message: No unmounted partitions found.
> USB:
> Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
> speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
> Device-1: 1-4:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
> interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0029
> class-ID: e001
> Device-2: 1-6:3 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
> driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
> power: 98mA chip-ID: 046d:c52b class-ID: 0300
> Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
> chip-ID: 1d6b:0003 class-ID: 0900
> Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
> Device-1: 3-4:2 info: ASUSTek AURA LED Controller type: HID
> driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
> chip-ID: 0b05:1939 class-ID: 0300 serial: <filter>
> Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
> Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
> Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
> Sensors:
> System Temperatures: cpu: 35.0 C mobo: N/A gpu: nouveau temp: 32.0 C
> Fan Speeds (RPM): N/A gpu: nouveau fan: 1230
> Info:
> Processes: 281 Uptime: 1h 14m wakeups: 13 Init: systemd v: 249
> tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1353 lib: 433
> flatpak: 0 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
Thank you in advance!
