steam-runtime
steam.sh[5065]: Running Steam on manjarolinux 21.2.2 64-bit
steam.sh[5065]: STEAM_RUNTIME is enabled automatically
setup.sh[5138]: Steam runtime environment up-to-date!
steam.sh[5065]: Steam client's requirements are satisfied
max open descriptors set to 9216
[2022-01-26 12:34:39] Startup - updater built Jan 16 2022 17:34:43
Installing breakpad exception handler for appid(steam)/version(1642451672)
[2022-01-26 12:34:39] Loading cached metrics from disk (/home/adriik/.local/share/Steam/package/steam_client_metrics.bin)
[2022-01-26 12:34:39] Using the following download hosts for Public, Realm steamglobal
[2022-01-26 12:34:39] 1. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2022-01-26 12:34:39] 2. https://cdn.akamai.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2022-01-26 12:34:39] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2022-01-26 12:34:39] Verificando instalación...
[2022-01-26 12:34:39] Verification complete
Loaded SDL version 2.0.20-7009179
steamwebhelper.sh[5221]: Runtime for steamwebhelper: defaulting to /home/adriik/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
CAppInfoCacheReadFromDiskThread took 133 milliseconds to initialize
Proceed to auto login
Opted-in Controller Mask for AppId 0: 0
(steam:5201): Gtk-WARNING **: 12:34:41.814: gtk_disable_setlocale() must be called before gtk_init()
local (potentially out of sync) copy of roaming config loaded - 591 bytes.
MESA-INTEL: warning: Performance support disabled, consider sysctl dev.i915.perf_stream_paranoid=0
roaming config store loaded successfully - 591 bytes.
migrating temporary roaming config store
BRefreshApplicationsInLibrary 1: 20ms
Failed to init SteamVR because it isn't installed
ExecCommandLine: "'/home/adriik/.local/share/Steam/ubuntu12_32/steam' '%U'"
System startup time: 5.45 seconds
BuildCompleteAppOverviewChange: 308
RegisterForAppOverview 1: 20ms
RegisterForAppOverview 2: 21ms
GameAction [AppID 332200, ActionID 1] : LaunchApp changed task to ProcessingInstallScript with ""
GameAction [AppID 332200, ActionID 1] : LaunchApp changed task to SynchronizingCloud with ""
GameAction [AppID 332200, ActionID 1] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 332200, ActionID 1] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 332200, ActionID 1] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 332200, ActionID 1] : LaunchApp continues with user response "CreatingProcess"
Opted-in Controller Mask for AppId 332200: 0
/bin/sh\0-c\0/home/adriik/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=332200 -- '/home/adriik/.local/share/Steam/steamapps/common/Axiom Verge/AxiomVerge'\0
Game process added : AppID 332200 "/home/adriik/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=332200 -- '/home/adriik/.local/share/Steam/steamapps/common/Axiom Verge/AxiomVerge'", ProcID 5475, IP 0.0.0.0:0
chdir /home/adriik/.local/share/Steam/steamapps/common/Axiom Verge
ERROR: ld.so: object '/home/adriik/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
GameAction [AppID 332200, ActionID 1] : LaunchApp changed task to WaitingGameWindow with ""
ERROR: ld.so: object '/home/adriik/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
GameAction [AppID 332200, ActionID 1] : LaunchApp changed task to Completed with ""
2022-01-26 12:35:02,425 - Initializing SteamAPI.
[S_API] SteamAPI_Init(): Loaded '/home/adriik/.local/share/Steam/linux64/steamclient.so' OK.
Game process updated : AppID 332200 "/home/adriik/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=332200 -- '/home/adriik/.local/share/Steam/steamapps/common/Axiom Verge/AxiomVerge'", ProcID 5476, IP 0.0.0.0:0
Setting breakpad minidump AppID = 332200
SteamInternal_SetMinidumpSteamID: Caching Steam ID: 76561198435822637 [API loaded no]
2022-01-26 12:35:02,525 - SteamAPI Initialized.
2022-01-26 12:35:02,525 - Setting SDL Hint to Allow Joystick Background Events
2022-01-26 12:35:02,531 - RunGame() Begin
2022-01-26 12:35:02,760 - Creating Game.
2022-01-26 12:35:03,148 - Attempting to load Settings.xml
2022-01-26 12:35:03,201 - Couldn't deserialize xml; attempting to decrypt.
2022-01-26 12:35:03,242 - Done loading Settings.xml
2022-01-26 12:35:03,242 - Initializing settings data.
2022-01-26 12:35:03,243 - Initializing Settings Data.
2022-01-26 12:35:03,243 - Initializing control mappings.
2022-01-26 12:35:03,243 - Creating Graphics object.
2022-01-26 12:35:03,244 - Creating Graphics Device Manager.
Using EXT_swap_control_tear VSync!
FNA3D Driver: OpenGL
OpenGL Renderer: Mesa Intel(R) HD Graphics 520 (SKL GT2)
OpenGL Driver: 4.6 (Compatibility Profile) Mesa 21.3.4
OpenGL Vendor: Intel
MojoShader Profile: glsl120
2022-01-26 12:35:03,285 - Requesting fullscreen: 1366 x 768
2022-01-26 12:35:03,288 - Device Status: Normal
2022-01-26 12:35:03,288 - Presentation parameters: 1366 x 768
2022-01-26 12:35:03,288 - SurfaceFormat: Color, DepthStencilFormat: None
2022-01-26 12:35:03,288 - Presentation Interval: One, RenderTargetUsage: DiscardContents
2022-01-26 12:35:03,288 - VSync: True
2022-01-26 12:35:03,288 - Creating global Content Manager.
2022-01-26 12:35:03,289 - Initializing Trophy Manager.
2022-01-26 12:35:03,298 - Initializing Leaderboard Manager.
2022-01-26 12:35:03,306 - Initializing Factories.
2022-01-26 12:35:03,330 - Initializing Secret Worlds.
2022-01-26 12:35:03,355 - Initializing language.
2022-01-26 12:35:03,531 - Initializing Audio.
2022-01-26 12:35:03,545 - Done creating Game.
2022-01-26 12:35:03,555 - Loading content.
2022-01-26 12:35:03,556 - Loading audio content.
2022-01-26 12:35:03,836 - LoadContent: Reapplying Graphics Settings.
2022-01-26 12:35:03,837 - Requesting fullscreen: 1366 x 768
2022-01-26 12:35:03,837 - Device Status: Normal
2022-01-26 12:35:03,837 - Presentation parameters: 1366 x 768
2022-01-26 12:35:03,837 - SurfaceFormat: Color, DepthStencilFormat: None
2022-01-26 12:35:03,837 - Presentation Interval: One, RenderTargetUsage: DiscardContents
2022-01-26 12:35:03,837 - VSync: True
2022-01-26 12:35:03,837 - Creating sprite batch
2022-01-26 12:35:03,865 - Setting static data colors.
2022-01-26 12:35:03,865 - Done setting static data colors.
2022-01-26 12:35:03,866 - Creating render target PostBuffer1, 480 x 270
2022-01-26 12:35:03,868 - Creating render target PostBuffer2, 480 x 270
2022-01-26 12:35:03,868 - Creating render target PostBuffer3, 960 x 540
2022-01-26 12:35:03,869 - Creating render target PostBuffer4, 960 x 540
2022-01-26 12:35:03,869 - Creating render target FinalCompositeBuffer, 960 x 540
2022-01-26 12:35:03,870 - Creating render target UIBuffer, 480 x 270
2022-01-26 12:35:03,870 - Creating shader Shaders/THBlurShader
2022-01-26 12:35:03,872 - Creating shader Shaders/THColorCorrectionShader
2022-01-26 12:35:03,873 - Creating shader Shaders/THScanlineShader
2022-01-26 12:35:03,875 - Creating shader Shaders/THHallucinationShader
2022-01-26 12:35:03,915 - Creating shader Shaders/THBackgroundShader
2022-01-26 12:35:03,918 - Creating shader Shaders/THSpriteShader
2022-01-26 12:35:03,919 - Creating shader Shaders/THUIShader
2022-01-26 12:35:03,965 - (0): Void Initialize()(): Initializing save data.
2022-01-26 12:35:03,980 - Creating render target TitleState_DrawBuffer, 480 x 270
2022-01-26 12:35:04,101 - Initializing Input.
2022-01-26 12:35:04,126 - Initializing language.
2022-01-26 12:35:04,182 - Finished loading content.
2022-01-26 12:35:04,247 - [1104 - LeaderboardFindResult] - 753981 -- 1
2022-01-26 12:35:04,251 - Received stats and achievements from Steam.
2022-01-26 12:35:04,254 - Finished updating 29 trophies.
2022-01-26 12:35:04,254 - [1104 - LeaderboardFindResult] - 753982 -- 1
2022-01-26 12:35:04,254 - [1104 - LeaderboardFindResult] - 753983 -- 1
2022-01-26 12:35:04,255 - [1104 - LeaderboardFindResult] - 753984 -- 1
2022-01-26 12:35:04,255 - [1104 - LeaderboardFindResult] - 753985 -- 1
2022-01-26 12:35:04,256 - [1104 - LeaderboardFindResult] - 753987 -- 1
Installing breakpad exception handler for appid(gameoverlayui)/version(20220116173448)
Installing breakpad exception handler for appid(gameoverlayui)/version(1.0)
2022-01-26 12:35:13,559 - RunGame() End
Game process removed: AppID 332200 "/home/adriik/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=332200 -- '/home/adriik/.local/share/Steam/steamapps/common/Axiom Verge/AxiomVerge'", ProcID 5476
Game 332200 created interface STEAMAPPLIST_INTERFACE_VERSION001 / AppList
Game 332200 created interface STEAMAPPS_INTERFACE_VERSION008 / Apps
Game 332200 created interface STEAMHTMLSURFACE_INTERFACE_VERSION_005 / HTMLSurface
Game 332200 created interface STEAMHTTP_INTERFACE_VERSION003 / HTTP
Game 332200 created interface STEAMINVENTORY_INTERFACE_V003 / Inventory
Game 332200 created interface STEAMMUSICREMOTE_INTERFACE_VERSION001 / MusicRemote
Game 332200 created interface STEAMMUSIC_INTERFACE_VERSION001 / Music
Game 332200 created interface STEAMPARENTALSETTINGS_INTERFACE_VERSION001 / ParentalSettings
Game 332200 created interface STEAMREMOTEPLAY_INTERFACE_VERSION001 / RemotePlay
Game 332200 created interface STEAMREMOTESTORAGE_INTERFACE_VERSION014 / RemoteStorage
Game 332200 created interface STEAMSCREENSHOTS_INTERFACE_VERSION003 / Screenshots
Game 332200 created interface STEAMUGC_INTERFACE_VERSION015 / UGC
Game 332200 created interface STEAMUSERSTATS_INTERFACE_VERSION012 / UserStats
Game 332200 created interface STEAMVIDEO_INTERFACE_V002 / Video
Game 332200 created interface SteamController008 /
Game 332200 created interface SteamFriends017 / Friends
Game 332200 created interface SteamInput002 /
Game 332200 created interface SteamInput002 / Controller
Game 332200 created interface SteamMatchGameSearch001 / GameSearch
Game 332200 created interface SteamMatchMaking009 / Matchmaking
Game 332200 created interface SteamMatchMakingServers002 / MatchmakingServers
Game 332200 created interface SteamNetworking006 / Networking
Game 332200 created interface SteamNetworkingMessages002 /
Game 332200 created interface SteamNetworkingSockets009 /
Game 332200 created interface SteamNetworkingUtils003 /
Game 332200 created interface SteamParties002 / Parties
Game 332200 created interface SteamUser021 / User
Game 332200 created interface SteamUtils010 /
Game 332200 created interface SteamUtils010 / Utils
Game 332200 method call count for IClientNetworkingSocketsSerialized::GetSTUNServer : 2
Game 332200 method call count for IClientNetworkingSocketsSerialized::GetCachedRelayTicketCount : 1
Game 332200 method call count for IClientNetworkingSocketsSerialized::GetCertAsync : 1
Game 332200 method call count for IClientHTTP::ReleaseHTTPRequest : 2
Game 332200 method call count for IClientHTTP::GetHTTPResponseBodyData : 2
Game 332200 method call count for IClientHTTP::SendHTTPRequest : 2
Game 332200 method call count for IClientHTTP::SetHTTPRequestHeaderValue : 1
Game 332200 method call count for IClientHTTP::CreateHTTPRequest : 2
Game 332200 method call count for IClientRemoteStorage::FileExists : 1
Game 332200 method call count for IClientRemoteStorage::FileRead : 1
Game 332200 method call count for IClientUserStats::GetLeaderboardName : 6
Game 332200 method call count for IClientUserStats::FindLeaderboard : 6
Game 332200 method call count for IClientUserStats::GetAchievement : 29
Game 332200 method call count for IClientUserStats::RequestCurrentStats : 1
Game 332200 method call count for IClientUtils::RecordSteamInterfaceCreation : 32
Game 332200 method call count for IClientUtils::GetAPICallResult : 12
Game 332200 method call count for IClientUtils::GetAppID : 36
Game 332200 method call count for IClientUtils::GetServerRealTime : 3
Game 332200 method call count for IClientUtils::GetConnectedUniverse : 1
Game 332200 method call count for IClientUser::GetSteamID : 2
Game 332200 method call count for IClientUser::BLoggedOn : 1
Uploaded AppInterfaceStats to Steam
No cached sticky mapping in ActivateActionSet.
(process:5501): GLib-GObject-CRITICAL **: 12:35:14.820: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Exiting workitem thread
(steam:5201): GLib-GObject-CRITICAL **: 12:35:22.206: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
(steam:5201): GLib-GObject-WARNING **: 12:35:22.209: invalid (NULL) pointer instance
(steam:5201): GLib-GObject-CRITICAL **: 12:35:22.209: g_signal_handlers_disconnect_matched: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(steam:5201): GLib-GObject-CRITICAL **: 12:35:22.210: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
[2022-01-26 12:35:22] Shutdown
