Hello
When I launch a game from Windows that requires the dGPU it crash, I tested with League of Legends(LoL) on Lutris( here output on Lutris ) and Darwing Project on Steam ( here output on Steam ).
I testing with a hybrid laptop(AMD Radeon R7 260 and Intel) the output of lspci -k | grep -EA3 'VGA|3D|Display'
is:
00:02.0 VGA compatible controller: Intel Corporation Haswell-ULT Integrated Graphics Controller (rev 0b)
Subsystem: Toshiba Corporation Device f903
Kernel driver in use: i915
Kernel modules: i915
03:00.0 Display controller: Advanced Micro Devices, Inc. [AMD/ATI] Topaz XT [Radeon R7 M260/M265 / M340/M360 / M440/M445 / 530/535 / 620/625 Mobile]
Subsystem: Toshiba Corporation Radeon R7 M260
Kernel driver in use: amdgpu
Kernel modules: amdgpu
When I run LoL on Lutris it crash before lauching the client and Darwing on Steam it crash after accepted the window of “Easy Anti-cheat”, those errors and some research make me thing of a possible gpu problem but I already check amdgpu driver and the support of vulkan for my dGPU which belong to Sea Island card(CIK) and both brings with support for my dGPU.
I’m executing the apps or games with this command:
DRI_PRIME=1 VK_ICD_FILENAMES=/usr/share/vulkan/icd.d/amd_icd32.json:/usr/share/vulkan/icd.d/amd_icd64.json [program]
Here are some dmesg from journalctl -a
Here is the output of Xorg.conf and some relevant point is:
[ 43.458] (II) AMDGPU(G0): [DRI2] Setup complete
[ 43.458] (II) AMDGPU(G0): [DRI2] DRI driver: radeonsi
[ 43.458] (II) AMDGPU(G0): [DRI2] VDPAU driver: radeonsi
There point the successful setup of DRI2 and before DRI3 is loaded but never shows “Setup complete”
System info inxi -Fxxxz:
System: Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2
wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: TOSHIBA product: N/A v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: TOSHIBA model: CA10SU serial: <filter> UEFI: TOSHIBA v: 1.40 date: 12/05/2014
Battery: ID-1: BAT0 charge: 25.6 Wh condition: 25.6/44.7 Wh (57%) volts: 16.1/14.8 model: PEGA G71C000HS110 type: Li-ion
serial: N/A status: Not charging
CPU: Info: Dual Core model: Intel Core i5-4210U bits: 64 type: MT MCP arch: Haswell rev: 1 L2 cache: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19162
Speed: 1696 MHz min/max: 800/2700 MHz Core speeds (MHz): 1: 1696 2: 1696 3: 1696 4: 1696
Graphics: Device-1: Intel Haswell-ULT Integrated Graphics vendor: Toshiba driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:0a16
Device-2: Chicony TOSHIBA Web Camera - HD type: USB driver: uvcvideo bus ID: 2-6:3 chip ID: 04f2:b446
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: amdgpu,intel resolution: 1366x768~60Hz s-dpi: 96
OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2) v: 4.5 Mesa 20.3.1 compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel Haswell-ULT HD Audio vendor: Toshiba driver: snd_hda_intel v: kernel bus ID: 00:03.0
chip ID: 8086:0a0c
Device-2: Intel 8 Series HD Audio vendor: Toshiba driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:9c20
Sound Server: ALSA v: k5.9.16-1-MANJARO
Network: Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter vendor: Lite-On driver: ath9k v: kernel
port: f040 bus ID: 02:00.0 chip ID: 168c:0036
Drives: Local Storage: total: 298.09 GiB used: 43.03 GiB (14.4%)
ID-1: /dev/sda vendor: Western Digital model: WD3200BEKT-60PVMT0 size: 298.09 GiB speed: 3.0 Gb/s serial: <filter>
rev: 1A01
Partition: ID-1: / size: 292.12 GiB used: 43.03 GiB (14.7%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 43.0 C mobo: N/A gpu: amdgpu temp: 40.0 C
Info: Processes: 218 Uptime: 6h 57m wakeups: 1 Memory: 7.69 GiB used: 5.82 GiB (75.7%) Init: systemd v: 247 Compilers:
gcc: 10.2.0 clang: 11.0.0 Packages: 1319 pacman: 1310 snap: 9 Shell: Bash v: 5.1.0 running in: konsole inxi: 3.2.01
So I been doing some research work for too long and config the gpu but now I run out of ideas, any help would be great, thanks.
EDIT: By the way I already try LoL with snap and crash in the same way as lutris the output is less detailed
