Steam & Lutris not starting games after power outage
Hi guys,
**EDIT: I’m an idiot, this has nothing to do with the power outage, this was in fact the update. Mangohud is breaking steam and lutris at the moment, disabling the global enable in goverlay and removing the launch options in steam and in lutris will fix this. **
see thread: Problems with proton in steam when upgrading to the latest ( Manjaro 21.2.5 Qonos) - #5 by thepete
I’ve had a power outage mid gaming recently and after restarting the pc I did an update and after that all steam games are now stuck on “preparing to launch”.
On wayland, Lutris doesn’t even open anymore, on Xorg it launches, my games are there but I can’t launch them anymore.
P.s.: If I launch lutris with sudo on wayland (which you shouldn’t do) Lutris launches, but my games aren’t there.
Is there a way to fix this issue?
Troubleshooting
-Delete ./config/Lutris and ./cache/Lutris
-delete cache for steam
-reinstall steam
-reinstall games (also delte the prefix and shadercache)
-try different versions of proton ( also Proton GE)
  Kernel: 5.17.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
    root=UUID=d38aeabc-9f15-4876-be4b-2c05882c6433 rw quiet apparmor=1
    security=apparmor udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff
    video=HDMI-A-1:1920x1080@77
  Desktop: KDE Plasma 5.24.3 tk: Qt 5.15.3 info: latte-dock wm: kwin_wayland
    vt: 3 dm: SDDM Distro: Manjaro Linux base: Arch Linux
  Type: Desktop Mobo: ASRock model: B550 Extreme4 serial: <superuser required>
    UEFI: American Megatrends LLC. v: P2.20 date: 02/24/2022
  RAM: total: 15.54 GiB used: 3.15 GiB (20.2%)
  RAM Report:
  Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3
    family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
    L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 2193 high: 2196 min/max: 2200/4850 boost: enabled
    scaling: driver: acpi-cpufreq governor: ondemand cores: 1: 2193 2: 2195
    3: 2196 4: 2193 5: 2193 6: 2195 7: 2194 8: 2193 9: 2193 10: 2194 11: 2193
    12: 2195 13: 2193 14: 2191 15: 2193 16: 2193 bogomips: 121411
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
    invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
    movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
    overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
    perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rapl rdpid
    rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep
    ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall
    tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vaes vgif
    vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt x2apic xgetbv1 xsave xsavec
    xsaveerptr xsaveopt xsaves
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
    IBRS_FW, STIBP: always-on, RSB filling
  Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
    vendor: Sapphire Nitro+ driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 16 ports: active: HDMI-A-2 empty: DP-1, DP-2, DVI-D-1, HDMI-A-1
    bus-ID: 05:00.0 chip-ID: 1002:67df class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.0
    compositor: kwin_wayland driver: X: loaded: amdgpu,ati unloaded: modesetting
    alternate: fbdev,vesa gpu: amdgpu display-ID: 0
  Monitor-1: HDMI-A-2 res: 1920x1080 size: N/A
  OpenGL: renderer: AMD Radeon RX 580 Series (POLARIS10 DRM 3.44.0
    5.17.0-1-MANJARO LLVM 13.0.1)
    v: 4.6 Mesa 21.3.7 direct render: Yes
  Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
    vendor: Sapphire driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:aaf0 class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
    bus-ID: 07:00.4 chip-ID: 1022:1487 class-ID: 0403
  Sound Server-1: ALSA v: k5.17.0-1-MANJARO running: yes
  Sound Server-3: PulseAudio v: 15.0 running: no
  Sound Server-4: PipeWire v: 0.3.48 running: yes
  Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 03:00.0
  Device-2: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2725
    class-ID: 0280
  IF: wlp4s0 state: up mac: <filter>
  Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-9:4
    chip-ID: 8087:0032 class-ID: e001
  Report: bt-adapter ID: hci0 rfk-id: 1 state: down
    bt-service: enabled,running rfk-block: hardware: no software: yes
    address: <filter>
  Local Storage: total: 1.42 TiB used: 859.71 GiB (59.2%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
    type: SSD serial: <filter> rev: 3B6Q scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT240BX500SSD1
    size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: 052 scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
    model: WD3200BEVT-60ZCT1 size: 298.09 GiB block-size: physical: 512 B
    logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter>
    rev: 1A13 scheme: GPT
  ID-4: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST500LT012-9WS142
    size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
    type: HDD rpm: 5400 serial: <filter> rev: SDM1 scheme: GPT
  ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
    used: 315.31 GiB (69.0%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: d38aeabc-9f15-4876-be4b-2c05882c6433
    used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
    uuid: 887A-BAAC
  ID-3: /run/media/peter/HD3 raw-size: 298.09 GiB size: 298.09 GiB (100.00%)
    used: 49.7 GiB (16.7%) fs: ntfs dev: /dev/sdc1 maj-min: 8:33 label: HD3
    uuid: AC58F85758F821AE
  ID-4: /run/media/peter/InternHDD raw-size: 465.76 GiB
    size: 457.45 GiB (98.22%) used: 284.5 GiB (62.2%) fs: ext4 dev: /dev/sdd1
    maj-min: 8:49 label: InternHDD uuid: 07ad55d6-0713-4de9-b2a0-16f56e6392c0
  ID-5: /run/media/peter/externe SDD raw-size: 223.57 GiB
    size: 223.57 GiB (100.00%) used: 210.2 GiB (94.0%) fs: ntfs dev: /dev/sdb1
    maj-min: 8:17 label: externe SDD uuid: 17957C3A1E0E912F
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
  Device-1: 1-2:2 info: Microdia AK33 type: Keyboard,HID
    driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s
    power: 500mA chip-ID: 0c45:5104 class-ID: 0300
  Hub-2: 1-7:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
    power: 100mA chip-ID: 05e3:0610 class-ID: 0900
  Device-1: 1-9:4 info: Intel AX210 Bluetooth type: Bluetooth driver: btusb
    interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0032
    class-ID: e001
  Device-2: 1-10:5 info: ASRock LED Controller type: HID
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
    power: 100mA chip-ID: 26ce:01a2 class-ID: 0300 serial: <filter>
  Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-1:2 info: Logitech G203 Gaming Mouse type: Mouse,HID
    power: 300mA chip-ID: 046d:c084 class-ID: 0300 serial: <filter>
  Hub-5: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 57.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 154
  Processes: 447 Uptime: 1h 32m wakeups: 0 Init: systemd v: 250
  tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1523
  pacman: 1498 lib: 426 flatpak: 19 snap: 6 Shell: Zsh v: 5.8.1 default: Bash
  v: 5.1.16 running-in: konsole inxi: 3.3.13
