I am trying to fix some critical errors that appears when using steam, may someone can help me ? I am tryin to fix it cause hogwarts legacy keep crashing on loading shaders … and that is annoying
Kernel: 6.1.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=0b0dab9c-2bd0-4300-b392-f4c896f27086 rw quiet splash
udev.log_priority=3 amdgpu.freesync_video=1
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASRock model: B450 Steel Legend
serial: <superuser required> UEFI: American Megatrends v: P4.60
date: 10/20/2022
RAM: total: 15.54 GiB used: 2.62 GiB (16.8%)
Info: model: AMD Ryzen 5 3600X bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB
desc: 2x16 MiB
Speed (MHz): avg: 2348 high: 2800 min/max: 2200/4409 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200
3: 2200 4: 2200 5: 2200 6: 2800 7: 2787 8: 2200 9: 2200 10: 2800 11: 2200
12: 2200 bogomips: 91244
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 23 [Radeon RX 6650 XT] vendor: Micro-Star MSI
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-3,HDMI-A-1 empty: DP-1,DP-2 bus-ID: 0c:00.0 chip-ID: 1002:73ef
class-ID: 0300
Device-2: Logitech Webcam C300 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-10:3 chip-ID: 046d:0805 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.7 with: Xwayland v: 22.1.8
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3000x1920 s-dpi: 96 s-size: 791x506mm (31.14x19.92")
s-diag: 939mm (36.97")
Monitor-1: DP-3 mapped: DisplayPort-2 pos: primary,bottom-l
model: AOC 24G2W1G4 serial: <filter> built: 2020 res: 1920x1080 dpi: 93
gamma: 1.2 size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9
modes: max: 1920x1080 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: top-right model: HP E273
serial: <filter> built: 2018 res: 1080x1920 hz: 60 dpi: 82 gamma: 1.2
size: 336x598mm (13.23x23.54") diag: 686mm (27") ratio: 16:9 modes:
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: AMD Radeon RX 6650 XT (navi23
LLVM 15.0.7 DRM 3.49 6.1.12-1-MANJARO) direct-render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 1-10:3 pcie: chip-ID: 046d:0805 gen: 4 class-ID: 0102 speed: 16 GT/s
serial: <filter> lanes: 16 bus-ID: 0c:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech Webcam C300 type: USB driver: snd-usb-audio,uvcvideo
Device-4: Logitech Logitech G PRO X Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-2.1:6 chip-ID: 046d:0aaa
class-ID: 0300 serial: <filter>
Sound API: ALSA v: k6.1.12-1-MANJARO running: yes
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-3: PipeWire v: 0.3.65 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp7s0 state: up mac: <filter>
vendor: ASRock driver: r8168 v: 8.050.03-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 09:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp9s0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-5:2
Local Storage: total: 1.36 TiB used: 227.2 GiB (16.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT500P3SSD8
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: P9CR30A temp: 29.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZRZ-00HTKB0
type: HDD rpm: 5400 serial: <filter> rev: 1A01 scheme: GPT
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
used: 112.81 GiB (24.7%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 0b0dab9c-2bd0-4300-b392-f4c896f27086
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 401C-304D
ID-3: /mnt/hdd raw-size: 931.51 GiB size: 915.82 GiB (98.31%)
used: 114.39 GiB (12.5%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: Blue WD
uuid: 70b4a0f8-a5ae-43e9-95ff-45ec4f454209
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-5:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-2: 1-10:3 info: Logitech Webcam C300 type: Video,Audio
power: 500mA chip-ID: 046d:0805 class-ID: 0102 serial: <filter>
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:2 info: SHARKOON GmbH 2.4GHz Wireless rechargeable vertical
mouse [More&Better] type: Mouse driver: hid-generic,usbhid interfaces: 1
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 1ea7:0064 class-ID: 0301
Hub-4: 3-2:3 info: HP USB2.1 Hub ports: 2 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 03f0:1847 class-ID: 0900
Device-1: 3-2.1:6 info: Logitech Logitech G PRO X Gaming Headset
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 046d:0aaa class-ID: 0300
serial: <filter>
Device-2: 3-3:4 info: Holtek USB Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 04d9:a0cd class-ID: 0300
Device-3: 3-4:5 info: Logitech G502 Proteus Spectrum Optical Mouse
type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 300mA chip-ID: 046d:c332 class-ID: 0300
serial: <filter>
Hub-5: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 45.6 C mobo: N/A gpu: amdgpu temp: 55.0 C
mem: 58.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 311 Uptime: 7m wakeups: 0 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1412
pm: pacman pkgs: 1397 libs: 437 tools: pamac,yay pm: flatpak pkgs: 15
Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.25
