when i try to lunch any game button just says running for a second and then it closes. i have isolated problem down to “hard drive” is ntfs and i cant “chown” directory that steam uses on hard drive where steam directory is. Gpt told me that i should edit fstab but said that its dangerous to do so. So before i do this i just wanted to ask here if its ok to do following ? :
UUID=C8E4AA15E4AA05B2 /media/boss ntfs-3g defaults,uid=YOUR_UID,gid=YOUR_GID,dmask=027,fmask=137 0 0
sudo mount -a
my Fazzy:
Kernel: 6.1.77-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64
root=UUID=9e40c458-fb8c-41c9-8473-df1d639a2bd6 rw rootflags=subvol=@ quiet
apparmor=1 security=apparmor
resume=UUID=e1098956-513c-4552-99e9-3066c75e8288 udev.log_priority=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: ASRock model: B460M-HDV serial: <superuser required>
uuid: <superuser required> BIOS: American Megatrends v: P1.60
date: 06/23/2020
Info: model: Intel Pentium Gold G6405 bits: 64 type: MT MCP arch: Comet Lake
level: v2 built: 2020 process: Intel 14nm family: 6 model-id: 0xA5 (165)
stepping: 3 microcode: 0xF8
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2450 high: 4100 min/max: 800/4100 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 4100 2: 4100 3: 800
4: 800 bogomips: 32813
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: AMD Cape Verde PRO [Radeon HD 7750/8740 / R7 250E]
vendor: Micro-Star MSI driver: radeon v: kernel alternate: amdgpu arch: GCN-1
code: Southern Islands process: TSMC 28nm built: 2011-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: DVI-I-1,HDMI-A-1 empty: DP-1
bus-ID: 01:00.0 chip-ID: 1002:683f class-ID: 0300 temp: 40.0 C
Display: x11 server: X.Org v: 21.1.11 compositor: kwin_x11 driver: X:
loaded: radeon unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: radeon display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
s-diag: 1055mm (41.54")
Monitor-1: DVI-I-1 mapped: DVI-0 pos: primary,right model: ASUS VA24E
serial: <filter> built: 2023 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-0 pos: left model: Asus VS229
serial: <filter> built: 2012 res: 1920x1080 hz: 60 dpi: 103 gamma: 1.2
size: 475x267mm (18.7x10.51") diag: 545mm (21.5") ratio: 16:9 modes:
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.5 vendor: amd mesa v: 23.3.5-manjaro1.1 glx-v: 1.4
direct-render: yes renderer: VERDE (radeonsi LLVM 16.0.6 DRM 2.50
6.1.77-2-MANJARO) device-ID: 1002:683f memory: 1.95 GiB unified: no
Device-1: Intel Comet Lake PCH-V cAVS vendor: ASRock driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a3f0
class-ID: 0403
Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
Series] vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aab0 class-ID: 0403
API: ALSA v: k6.1.77-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin tools: pactl,pw-cat,pw-cli
Device-1: Intel Ethernet I219-V vendor: ASRock driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0d55 class-ID: 0200
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10.3:7
chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 2.04 TiB used: 1.32 TiB (64.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Patriot model: Blast size: 223.57 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD
serial: <filter> fw-rev: 12.2 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HDS723020BLA642
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: AA10 scheme: MBR
ID-1: / raw-size: 214.77 GiB size: 214.77 GiB (100.00%)
used: 178.88 GiB (83.3%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 214.77 GiB size: 214.77 GiB (100.00%)
ID-3: /var/log raw-size: 214.77 GiB size: 214.77 GiB (100.00%)
ID-1: swap-1 type: partition size: 8.8 GiB used: 8 MiB (0.1%) priority: -2
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 35.0 C mobo: N/A gpu: radeon temp: 40.0 C
Fan Speeds (rpm): N/A
Memory: total: 16 GiB available: 15.55 GiB used: 4.95 GiB (31.8%)
Processes: 268 Power: uptime: 1d 5h 41m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 2 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 6.21 GiB
services: org_kde_powerdevil,upowerd Init: systemd v: 255
Packages: 2036 pm: pacman pkgs: 2019 libs: 566 tools: pamac pm: flatpak
pkgs: 0 pm: snap pkgs: 17 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh
v: 5.9 default: Bash v: 5.2.26 running-in: yakuake inxi: 3.3.33
