Newbie Here! I tried to open Far Cry 3 through steam proton .When I clicked play button, it seemed like it was running but nothing happened. What can I do?
Hello yayiz
Here is what I usually do when a game doesn’t start with steam automatically:
I had the same issue with CS:GO for some time. Restarting Steam one or two times solved the problem most the time. Maybe restart your computer.
Check ProtonDB
Entry for Far Cry 3: https://www.protondb.com/app/220240
Try the recommended settings or launch parameters (right click on game in your library → properties → general) -
Try different Proton versions (right click on the game in your library → properties → compatibility)
Since the ProtonDB entries for older Proton versions are quite positive, you can try Proton 5 first. -
Google search
Hope you can find a solution.
Launch steam from the terminal. Check the output there when you try to launch the game.
How can I fix this issues
(steam:4663): GLib-CRITICAL **: 10:15:04.204: g_main_context_pop_thread_default: assertion 'g_queue_peek_head (stack) == context' failed
Installing breakpad exception handler for appid(steam)/version(1647446817)
Vulkan missing requested extension 'VK_KHR_xlib_surface'.
BInit - Unable to initialize Vulkan!
GameAction [AppID 220240, ActionID 1] : LaunchApp changed task to ProcessingInstallScript with ""
GameAction [AppID 220240, ActionID 1] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 220240, ActionID 1] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 220240, ActionID 1] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 220240, ActionID 1] : LaunchApp continues with user response "CreatingProcess"
/bin/sh\0-c\0PROTON_USE_WINED3D=1 /home/yayiz/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=220240 -- '/home/yayiz/.local/share/Steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/yayiz/.local/share/Steam/steamapps/common/Proton 7.0'/proton waitforexitandrun '/home/yayiz/.local/share/Steam/steamapps/common/Far Cry 3/bin/FC3UpdaterSteam.exe' -uplay_steam_mode\0
Game process added : AppID 220240 "PROTON_USE_WINED3D=1 /home/yayiz/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=220240 -- '/home/yayiz/.local/share/Steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/yayiz/.local/share/Steam/steamapps/common/Proton 7.0'/proton waitforexitandrun '/home/yayiz/.local/share/Steam/steamapps/common/Far Cry 3/bin/FC3UpdaterSteam.exe' -uplay_steam_mode", ProcID 7949, IP 0.0.0.0:0
chdir /home/yayiz/.local/share/Steam/steamapps/common/Far Cry 3/bin
ERROR: ld.so: object '/home/yayiz/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
ERROR: ld.so: object '/home/yayiz/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
pid 7953 != 7950, skipping destruction (fork without exec?)
GameAction [AppID 220240, ActionID 1] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 220240, ActionID 1] : LaunchApp changed task to Completed with ""
CAPIJobRequestUserStats - Server response failed 2
fsync: up and running.
wine: RLIMIT_NICE is <= 20, unable to use setpriority safely
ThreadGetProcessExitCode: no such process 8111
ThreadGetProcessExitCode: no such process 8109
ThreadGetProcessExitCode: no such process 7951
ThreadGetProcessExitCode: no such process 8114
Game process updated : AppID 220240 "PROTON_USE_WINED3D=1 /home/yayiz/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=220240 -- '/home/yayiz/.local/share/Steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/yayiz/.local/share/Steam/steamapps/common/Proton 7.0'/proton waitforexitandrun '/home/yayiz/.local/share/Steam/steamapps/common/Far Cry 3/bin/FC3UpdaterSteam.exe' -uplay_steam_mode", ProcID 8110, IP 0.0.0.0:0
Setting breakpad minidump AppID = 220240
Steam_SetMinidumpSteamID: Caching Steam ID: 76561198080829970 [API loaded no]
ThreadGetProcessExitCode: no such process 8385
ThreadGetProcessExitCode: no such process 8366
ThreadGetProcessExitCode: no such process 8154
ThreadGetProcessExitCode: no such process 8148
ThreadGetProcessExitCode: no such process 8141
ThreadGetProcessExitCode: no such process 8119
ThreadGetProcessExitCode: no such process 8116
ThreadGetProcessExitCode: no such process 8107
pid 8112 != 8111, skipping destruction (fork without exec?)
Game process removed: AppID 220240 "PROTON_USE_WINED3D=1 /home/yayiz/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=220240 -- '/home/yayiz/.local/share/Steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/yayiz/.local/share/Steam/steamapps/common/Proton 7.0'/proton waitforexitandrun '/home/yayiz/.local/share/Steam/steamapps/common/Far Cry 3/bin/FC3UpdaterSteam.exe' -uplay_steam_mode", ProcID 8110
ThreadGetProcessExitCode: no such process 8127
ThreadGetProcessExitCode: no such process 8110
ThreadGetProcessExitCode: no such process 7950
Game 220240 created interface STEAMAPPLIST_INTERFACE_VERSION001 / AppList
Game 220240 created interface STEAMAPPS_INTERFACE_VERSION008 / Apps
Game 220240 created interface STEAMHTMLSURFACE_INTERFACE_VERSION_004 / HTMLSurface
Game 220240 created interface STEAMHTTP_INTERFACE_VERSION002 / HTTP
Game 220240 created interface STEAMINVENTORY_INTERFACE_V002 / Inventory
Game 220240 created interface STEAMMUSICREMOTE_INTERFACE_VERSION001 / MusicRemote
Game 220240 created interface STEAMMUSIC_INTERFACE_VERSION001 / Music
Game 220240 created interface STEAMPARENTALSETTINGS_INTERFACE_VERSION001 / ParentalSettings
Game 220240 created interface STEAMREMOTESTORAGE_INTERFACE_VERSION014 / RemoteStorage
Game 220240 created interface STEAMSCREENSHOTS_INTERFACE_VERSION003 / Screenshots
Game 220240 created interface STEAMUGC_INTERFACE_VERSION010 / UGC
Game 220240 created interface STEAMUSERSTATS_INTERFACE_VERSION011 / UserStats
Game 220240 created interface STEAMVIDEO_INTERFACE_V002 / Video
Game 220240 created interface SteamController006 / Controller
Game 220240 created interface SteamFriends015 / Friends
Game 220240 created interface SteamMatchMaking009 / Matchmaking
Game 220240 created interface SteamMatchMakingServers002 / MatchmakingServers
Game 220240 created interface SteamNetworking005 / Networking
Game 220240 created interface SteamUser019 / User
Game 220240 created interface SteamUtils009 / Utils
Game 220240 method call count for IClientAppManager::GetAppInstallState : 2
Game 220240 method call count for IClientUtils::RecordSteamInterfaceCreation : 22
Game 220240 method call count for IClientUtils::GetSteamUILanguage : 1
Game 220240 method call count for IClientUtils::GetAppID : 24
Game 220240 method call count for IClientUser::GetSteamID : 1
Uploaded AppInterfaceStats to Steam
This is the output I get when I try to launch the game
Not much clue about why it doesn’t want to start…
You can try setting a different Proton version from the game’s properties, as @sias suggested.
I’m fairly new linux user. I have several problems about nvidia graphics and steam. I though I solved the graphic card releted problems but I’m not sure now. This is the error I get when I launch Farc Cry 3. All suggestions are welcome
The error I get:
I don’t know if this would help or not but here is the whole terminal session:
[yayiz@milkyway ~]$ steam
steam.sh[14551]: Running Steam on manjarolinux 21.2.5 64-bit
steam.sh[14551]: STEAM_RUNTIME is enabled automatically
setup.sh[14625]: Steam runtime environment up-to-date!
steam.sh[14551]: Steam client's requirements are satisfied
[2022-03-20 16:59:14] Startup - updater built Mar 14 2022 19:48:46
[2022-03-20 16:59:14] Loading cached metrics from disk (/home/yayiz/.local/share/Steam/package/steam_client_metrics.bin)
[2022-03-20 16:59:14] Using the following download hosts for Public, Realm steamglobal
[2022-03-20 16:59:14] 1. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2022-03-20 16:59:14] 2. https://cdn.akamai.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2022-03-20 16:59:14] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2022-03-20 16:59:14] Verifying installation...
[2022-03-20 16:59:14] Verification complete
Loaded SDL version 2.0.21-7140709
steamwebhelper.sh[14719]: Runtime for steamwebhelper: defaulting to /home/yayiz/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[14719]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
CAppInfoCacheReadFromDiskThread took 58 milliseconds to initialize
(steam:14689): GLib-CRITICAL **: 16:59:18.359: g_main_context_push_thread_default: assertion 'acquired_context' failed
(steam:14689): GLib-CRITICAL **: 16:59:18.359: g_main_context_pop_thread_default: assertion 'g_queue_peek_head (stack) == context' failed
(steam:14689): GLib-CRITICAL **: 16:59:18.464: g_main_context_push_thread_default: assertion 'acquired_context' failed
(steam:14689): GLib-CRITICAL **: 16:59:18.464: g_main_context_pop_thread_default: assertion 'g_queue_peek_head (stack) == context' failed
(steam:14689): Gtk-WARNING **: 16:59:18.708: gtk_disable_setlocale() must be called before gtk_init()
Connectivity test: result=Connected, in progress=0
BuildCompleteAppOverviewChange: 0
roaming config store loaded successfully - 430 bytes.
migrating temporary roaming config store
BRefreshApplicationsInLibrary 1: 8ms
Failed to init SteamVR because it isn't installed
ExecCommandLine: "'/home/yayiz/.local/share/Steam/ubuntu12_32/steam'"
System startup time: 8.49 seconds
BuildCompleteAppOverviewChange: 193
RegisterForAppOverview 1: 26ms
RegisterForAppOverview 2: 27ms
/bin/sh\0-c\0PROTON_USE_WINED3D=1 /home/yayiz/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=220240 -- '/home/yayiz/.local/share/Steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/yayiz/.local/share/Steam/steamapps/common/Proton 7.0'/proton waitforexitandrun '/home/yayiz/.local/share/Steam/steamapps/common/Far Cry 3/bin/FC3UpdaterSteam.exe' -uplay_steam_mode __NV_PRIME_RENDER_OFFLOAD=1 __VK_LAYER_NV_optimus=NVIDIA_only __GLX_VENDOR_LIBRARY_NAME=nvidia\0
Game process added : AppID 220240 "PROTON_USE_WINED3D=1 /home/yayiz/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=220240 -- '/home/yayiz/.local/share/Steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/yayiz/.local/share/Steam/steamapps/common/Proton 7.0'/proton waitforexitandrun '/home/yayiz/.local/share/Steam/steamapps/common/Far Cry 3/bin/FC3UpdaterSteam.exe' -uplay_steam_mode __NV_PRIME_RENDER_OFFLOAD=1 __VK_LAYER_NV_optimus=NVIDIA_only __GLX_VENDOR_LIBRARY_NAME=nvidia", ProcID 15435, IP 0.0.0.0:0
ThreadGetProcessExitCode: no such process 15636
ThreadGetProcessExitCode: no such process 15634
ThreadGetProcessExitCode: no such process 15437
Game process updated : AppID 220240 "PROTON_USE_WINED3D=1 /home/yayiz/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=220240 -- '/home/yayiz/.local/share/Steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/yayiz/.local/share/Steam/steamapps/common/Proton 7.0'/proton waitforexitandrun '/home/yayiz/.local/share/Steam/steamapps/common/Far Cry 3/bin/FC3UpdaterSteam.exe' -uplay_steam_mode __NV_PRIME_RENDER_OFFLOAD=1 __VK_LAYER_NV_optimus=NVIDIA_only __GLX_VENDOR_LIBRARY_NAME=nvidia", ProcID 15635, IP 0.0.0.0:0
ThreadGetProcessExitCode: no such process 15915
ThreadGetProcessExitCode: no such process 15639
Game process removed: AppID 220240 "PROTON_USE_WINED3D=1 /home/yayiz/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=220240 -- '/home/yayiz/.local/share/Steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/yayiz/.local/share/Steam/steamapps/common/Proton 7.0'/proton waitforexitandrun '/home/yayiz/.local/share/Steam/steamapps/common/Far Cry 3/bin/FC3UpdaterSteam.exe' -uplay_steam_mode __NV_PRIME_RENDER_OFFLOAD=1 __VK_LAYER_NV_optimus=NVIDIA_only __GLX_VENDOR_LIBRARY_NAME=nvidia", ProcID 15635
ThreadGetProcessExitCode: no such process 15898
ThreadGetProcessExitCode: no such process 15673
ThreadGetProcessExitCode: no such process 15667
ThreadGetProcessExitCode: no such process 15653
ThreadGetProcessExitCode: no such process 15644
ThreadGetProcessExitCode: no such process 15641
ThreadGetProcessExitCode: no such process 15635
ThreadGetProcessExitCode: no such process 15633
ThreadGetProcessExitCode: no such process 15436
Does the gameoverlay of steam work? If so, then this can be ignored.
I have these same error messages, but many games works fine. Just ignore these errors, they have nothing to do with your problem.
The specific messages have to do with your problem in the log, I guess:
Try to verify game files:
Steam → select game → properties → Local files → Click “verify integrity of games files” -
Check protonDB 6.3-8 (Many people said it works well in ProtonDB forum)
What is the output of
journalctl -p err -b
after checking when the issue is still there.
@Zesko output of journalctl -p err -b
[yayiz@milkyway ~]$ journalctl -p err -b
Mar 20 16:21:00 milkyway kernel: x86/cpu: SGX disabled by BIOS.
Mar 20 16:21:03 milkyway kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 510.54 Tue Feb 8 04:42:21 UTC 2022
Mar 20 16:21:05 milkyway kernel: nvidia 0000:01:00.0: can't change power state from D3cold to D0 (config space inaccessible)
Mar 20 16:21:05 milkyway gdm-launch-environment][761]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Mar 20 16:21:05 milkyway systemd-coredump[841]: [🡕] Process 753 (gdm) of user 0 dumped core.
Module linux-vdso.so.1 with build-id 6318c4a6aee96a4b3563df9857aef147f8c4bc48
Module libm.so.6 with build-id 596b63a006a4386dcab30912d2b54a7a61827b07
Module libnss_systemd.so.2 with build-id aa54bea74fb4d938f92ea6452d93d1f00201a8a0
Module librt.so.1 with build-id 4761858b348db8303e872e515aa8d56c046c921c
Module libblkid.so.1 with build-id 9e4bb910a2e63ba71cae0e3b89c07fdd45033ff2
Module libgpg-error.so.0 with build-id 82524ee3d1c4c2244d7cfdcc1e6eea5f9855f6c6
Module libpthread.so.0 with build-id 7fa8b52fae071a370ba4ca32bf9490a30aff31c4
Module libcrypt.so.2 with build-id a0a45f81771945f0559d04e93726d245159930da
Module libmount.so.1 with build-id 765508fe9812e693ac41fd3d0aedd65d7a78b287
Module libz.so.1 with build-id 0c1459c56513efd5d53eb3868290e9afee6a6a26
Module libgmodule-2.0.so.0 with build-id 0f0921c3ff98f0afe7fafbb123581acec5f7de29
Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
Module libffi.so.8 with build-id f90d8b734f6de9b25faedb8cbfab7054dafc0a42
Module ld-linux-x86-64.so.2 with build-id c09c6f50f6bcec73c64a0b4be77eadb8f7202410
Module libgcrypt.so.20 with build-id db45f5d5e0f7af1e77324fea1885f974619ad268
Module libcap.so.2 with build-id eb6dae97527fc89dbb0d5bb581a15acd02ae9f56
Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Module libzstd.so.1 with build-id 72f3511cba7db578f6a2647925f35664da6c838b
Module liblzma.so.5 with build-id 8b615460aa230708c5183f16bede67aa0437d95e
Module libc.so.6 with build-id 85766e9d8458b16e9c7ce6e07c712c02b8471dbc
Module libgcc_s.so.1 with build-id 5d817452a709ca3a213341555ddcf446ecee37fa
Module libXdmcp.so.6 with build-id 8ca0792d23c8b8b4c0864297512349292bea5955
Module libxcb.so.1 with build-id 0d1ef11740a5daad2ee331e812a51aa6574af222
Module libXau.so.6 with build-id 1c67764663e07bec24d8951e5fd93f4d165979ff
Module libaccountsservice.so.0 with build-id ad97a986ee9c35430be3bd49ead7caf1fed7e340
Module libgio-2.0.so.0 with build-id 8418b6a6a164774cde5db9d63d03911bb9823368
Module libglib-2.0.so.0 with build-id 0fcc81d3dfd68bddbf63423156549fc66939e8ca
Module libgobject-2.0.so.0 with build-id 1ab19051c262a2c995e86ea2b0af7e8ab70798f3
Module libsystemd.so.0 with build-id 05d0460efefd339d315812f9506aecc5a5d22200
Module gdm with build-id e7ec64119e1aab59b82fbd5b90936aba42c5f5a1
Stack trace of thread 753:
#0 0x000055684f402101 n/a (gdm + 0x21101)
#1 0x000055684f402d8d n/a (gdm + 0x21d8d)
#2 0x00007fc090879ebf g_closure_invoke (libgobject-2.0.so.0 + 0x12ebf)
#3 0x00007fc090896188 n/a (libgobject-2.0.so.0 + 0x2f188)
#4 0x00007fc090897ba7 g_signal_emit_valist (libgobject-2.0.so.0 + 0x30ba7)
#5 0x00007fc090897e04 g_signal_emit (libgobject-2.0.so.0 + 0x30e04)
#6 0x00007fc090881736 n/a (libgobject-2.0.so.0 + 0x1a736)
#7 0x00007fc0908898d2 g_object_notify (libgobject-2.0.so.0 + 0x228d2)
#8 0x000055684f400f82 n/a (gdm + 0x1ff82)
#9 0x00007fc090879ebf g_closure_invoke (libgobject-2.0.so.0 + 0x12ebf)
#10 0x00007fc090896188 n/a (libgobject-2.0.so.0 + 0x2f188)
#11 0x00007fc090897ba7 g_signal_emit_valist (libgobject-2.0.so.0 + 0x30ba7)
#12 0x00007fc090897e04 g_signal_emit (libgobject-2.0.so.0 + 0x30e04)
#13 0x00007fc090879ebf g_closure_invoke (libgobject-2.0.so.0 + 0x12ebf)
#14 0x00007fc090896188 n/a (libgobject-2.0.so.0 + 0x2f188)
#15 0x00007fc090897ba7 g_signal_emit_valist (libgobject-2.0.so.0 + 0x30ba7)
#16 0x00007fc090897e04 g_signal_emit (libgobject-2.0.so.0 + 0x30e04)
#17 0x00007fc090084d4a n/a (libffi.so.8 + 0x6d4a)
#18 0x00007fc090084267 n/a (libffi.so.8 + 0x6267)
#19 0x00007fc09087ffce g_cclosure_marshal_generic (libgobject-2.0.so.0 + 0x18fce)
#20 0x00007fc090879ebf g_closure_invoke (libgobject-2.0.so.0 + 0x12ebf)
#21 0x00007fc090896188 n/a (libgobject-2.0.so.0 + 0x2f188)
#22 0x000055684f3f9134 n/a (gdm + 0x18134)
#23 0x00007fc090879ebf g_closure_invoke (libgobject-2.0.so.0 + 0x12ebf)
#24 0x00007fc090895b5e n/a (libgobject-2.0.so.0 + 0x2eb5e)
#25 0x00007fc090897ba7 g_signal_emit_valist (libgobject-2.0.so.0 + 0x30ba7)
#26 0x00007fc090897e04 g_signal_emit (libgobject-2.0.so.0 + 0x30e04)
#27 0x00007fc09066b27d n/a (libgio-2.0.so.0 + 0x10b27d)
#28 0x00007fc090657de8 n/a (libgio-2.0.so.0 + 0xf7de8)
#29 0x00007fc09077eee3 g_main_context_dispatch (libglib-2.0.so.0 + 0x54ee3)
#30 0x00007fc0907d50f9 n/a (libglib-2.0.so.0 + 0xab0f9)
#31 0x00007fc09077e433 g_main_loop_run (libglib-2.0.so.0 + 0x54433)
#32 0x000055684f3ef7c5 n/a (gdm + 0xe7c5)
#33 0x00007fc0902fc310 __libc_start_call_main (libc.so.6 + 0x2d310)
#34 0x00007fc0902fc3c1 __libc_start_main@@GLIBC_2.34 (libc.so.6 + 0x2d3c1)
#35 0x000055684f3efad5 n/a (gdm + 0xead5)
Stack trace of thread 763:
#0 0x00007fc0903daa9d syscall (libc.so.6 + 0x10ba9d)
#1 0x00007fc0907cf12f g_cond_wait_until (libglib-2.0.so.0 + 0xa512f)
#2 0x00007fc09074d963 n/a (libglib-2.0.so.0 + 0x23963)
#3 0x00007fc09074db18 g_async_queue_timeout_pop (libglib-2.0.so.0 + 0x23b18)
#4 0x00007fc0907b188a n/a (libglib-2.0.so.0 + 0x8788a)
#5 0x00007fc0907ae815 n/a (libglib-2.0.so.0 + 0x84815)
#6 0x00007fc09035c5c2 start_thread (libc.so.6 + 0x8d5c2)
#7 0x00007fc0903e1584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 754:
#0 0x00007fc0903d52af __poll (libc.so.6 + 0x1062af)
#1 0x00007fc0907d5086 n/a (libglib-2.0.so.0 + 0xab086)
#2 0x00007fc09077c455 g_main_context_iteration (libglib-2.0.so.0 + 0x52455)
#3 0x00007fc09077c4a2 n/a (libglib-2.0.so.0 + 0x524a2)
#4 0x00007fc0907ae815 n/a (libglib-2.0.so.0 + 0x84815)
#5 0x00007fc09035c5c2 start_thread (libc.so.6 + 0x8d5c2)
#6 0x00007fc0903e1584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 755:
#2 0x00007fc09077e433 g_main_loop_run (libglib-2.0.so.0 + 0x54433)
#3 0x00007fc09066814c n/a (libgio-2.0.so.0 + 0x10814c)
Mar 20 16:21:07 milkyway kernel: nvidia 0000:01:00.0: can't change power state from D3cold to D0 (config space inaccessible)
Mar 20 16:21:09 milkyway kernel: nvidia 0000:01:00.0: can't change power state from D3cold to D0 (config space inaccessible)
lines 54-106
Mar 20 16:21:09 milkyway gnome-session-binary[921]: GLib-GIO-CRITICAL: g_bus_get_sync: assertion 'error == NULL || *error == NULL' failed
Mar 20 16:21:15 milkyway gdm-password][1465]: gkr-pam: unable to locate daemon control file
Mar 20 16:21:17 milkyway kernel: nvidia 0000:01:00.0: can't change power state from D3cold to D0 (config space inaccessible)
Mar 20 16:21:20 milkyway systemd[1480]: Failed to start Application launched by gnome-session-binary.
Mar 20 16:21:22 milkyway kernel: nvidia 0000:01:00.0: can't change power state from D3cold to D0 (config space inaccessible)
Mar 20 16:21:23 milkyway gdm-launch-environment][850]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Mar 20 16:21:34 milkyway kernel: nvidia 0000:01:00.0: can't change power state from D3cold to D0 (config space inaccessible)
Mar 20 16:21:41 milkyway kernel: nvidia 0000:01:00.0: can't change power state from D3cold to D0 (config space inaccessible)
Mar 20 16:22:36 milkyway kernel: nvidia 0000:01:00.0: can't change power state from D3cold to D0 (config space inaccessible)
Mar 20 16:26:10 milkyway kernel: nvidia 0000:01:00.0: can't change power state from D3cold to D0 (config space inaccessible)
It does not show error of steam
, but gdm
and nvidia driver
what should I do?
I do not know because it lacks some error information that you need to know. I am not Nvidia user.
But I have some questions:
- Did this game “Far Cry 3” work well before update? If so when is the update?
- If no, is this game new to you?
- Do all games not work? (You wrote “Steam games wont launch”)
There are multiple suggestions up this thread, on which you haven’t replied how well they worked or not. Have you tried them?
I tried different proton versions (not all of them) but the result was same.
I bought the game 2 days ago. Well I am not a gamer person but abouth a month ago I downloaded StarWars The CloneWars game. It didn’t open that time either. I thought maybe there was a problem with the game so I didn’t pursue this issue. I didn’t try another game
I am currently using nvidia-intel hybrid gpu. I have downloaded optimus-manager when I install manjaro. Maybe problem is related to this
Hybrid graphics often cause issues yes, also make sure that hdd or sdd your installing the game on is formated as ext4 or btrfs, many games don’t launch on an NTFS drive!
i had a very similar problem i had my steam library of games on a ntfs drive and even though i had the drive mounted at boot through manjaro the games still wouldn’t boot from steam/proton, i had to edit the fstab file under /etc/fstab and add the following line
UUID=“uuid-of-the-ntfs-partition” /run/media/“username”/“mountname” ntfs uid=1000,gid=1000,rw,user,exec,umask=000 0 0
example:
UUID=F048C17348C346DC /run/media/joconnell/Data ntfs uid=1000,gid=1000,rw,user,exec,umask=000 0 0
find your uuid by typing this in a terminal
sudo blkid
Be sure and check if you have installed steam multiple times on your pc on different drives.
