aspiree5475g ~]$ prime-run steam
steam.sh[2255]: Running Steam on manjarolinux 21.2.6 64-bit
steam.sh[2255]: STEAM_RUNTIME is enabled automatically
setup.sh[2329]: Steam runtime environment up-to-date!
steam.sh[2255]: Steam client's requirements are satisfied
[2022-04-30 21:43:55] Startup - updater built Mar 14 2022 19:48:46
Installing breakpad exception handler for appid(steam)/version(1647446817)
[2022-04-30 21:43:57] Loading cached metrics from disk (/home/wellium/.local/share/Steam/package/steam_client_metrics.bin)
[2022-04-30 21:43:57] Using the following download hosts for Public, Realm steamglobal
[2022-04-30 21:43:57] 1. https://cdn.akamai.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2022-04-30 21:43:57] 2. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2022-04-30 21:43:57] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2022-04-30 21:43:57] Verifying installation...
[2022-04-30 21:43:57] Verification complete
Loaded SDL version 2.0.21-7140709
(steam:2414): Gtk-WARNING **: 21:44:00.200: Unable to locate theme engine in module_path: "adwaita",
/usr/share/themes/Matcha-sea/gtk-2.0/main.rc:1113: error: unexpected identifier 'direction', expected character '}'
/usr/share/themes/Matcha-sea/gtk-2.0/apps.rc:91: error: unexpected identifier 'direction', expected character '}'
steamwebhelper.sh[2420]: Runtime for steamwebhelper: defaulting to /home/wellium/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[2420]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
CAppInfoCacheReadFromDiskThread took 224 milliseconds to initialize
(steam:2414): Gtk-WARNING **: 21:44:14.676: gtk_disable_setlocale() must be called before gtk_init()
Connectivity test: result=Connected, in progress=0
roaming config store loaded successfully - 302 bytes.
migrating temporary roaming config store
BRefreshApplicationsInLibrary 1: 180ms
Fossilize INFO: Setting autogroup scheduling.
Failed to init SteamVR because it isn't installed
ExecCommandLine: "'/home/wellium/.local/share/Steam/ubuntu12_32/steam'"
System startup time: 62.06 seconds
BuildCompleteAppOverviewChange: 111
RegisterForAppOverview 1: 39ms
RegisterForAppOverview 2: 40ms
ExecuteSteamURL: "steam://open/downloads"
[2022-04-30 21:46:09] Background update loop checking for update. . .
[2022-04-30 21:46:10] Checking for available updates...
[2022-04-30 21:46:10] Downloading manifest: https://cdn.akamai.steamstatic.com/client/steam_client_ubuntu12
[2022-04-30 21:46:12] Download skipped: /client/steam_client_ubuntu12 version 1647446817, installed version 1647446817, existing pending version 0
[2022-04-30 21:46:12] Nothing to do
Connectivity test: result=Unknown, in progress=0
LogonFailure No Connection
[2022-04-30 21:46:52] Background update loop checking for update. . .
[2022-04-30 21:46:52] Downloading manifest: https://cdn.akamai.steamstatic.com/client/steam_client_ubuntu12
[2022-04-30 21:46:52] Download skipped by HTTP 304 Not Modified
[2022-04-30 21:46:52] Nothing to do
BRefreshApplicationsInLibrary 1: 1ms
CGlibContextManager: g_main_context_iteration() exceeded budget, deferring outstanding requests to the next frame
GameAction [AppID 774361, ActionID 1] : LaunchApp changed task to ProcessingInstallScript with ""
GameAction [AppID 774361, ActionID 1] : LaunchApp changed task to SynchronizingCloud with ""
GameAction [AppID 774361, ActionID 1] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 774361, ActionID 1] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 774361, ActionID 1] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 774361, ActionID 1] : LaunchApp continues with user response "CreatingProcess"
/bin/sh\0-c\0gamemoderun prime-run /home/wellium/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=774361 -- '/home/wellium/.local/share/Steam/steamapps/common/Blasphemous/Blasphemous.x86_64' systemctl --user status gamemoded.service\0
Game process added : AppID 774361 "gamemoderun prime-run /home/wellium/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=774361 -- '/home/wellium/.local/share/Steam/steamapps/common/Blasphemous/Blasphemous.x86_64' systemctl --user status gamemoded.service", ProcID 3395, IP 0.0.0.0:0
chdir /home/wellium/.local/share/Steam/steamapps/common/Blasphemous
ERROR: ld.so: object '/home/wellium/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
GameAction [AppID 774361, ActionID 1] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 774361, ActionID 1] : LaunchApp changed task to Completed with ""
(steam:2414): LIBDBUSMENU-GLIB-WARNING **: 21:52:13.247: Trying to remove a child that doesn't believe we're it's parent.
(steam:2414): LIBDBUSMENU-GLIB-WARNING **: 21:52:13.260: Trying to remove a child that doesn't believe we're it's parent.
(steam:2414): LIBDBUSMENU-GLIB-WARNING **: 21:52:13.261: Trying to remove a child that doesn't believe we're it's parent.
(steam:2414): LIBDBUSMENU-GLIB-WARNING **: 21:52:13.262: Trying to remove a child that doesn't believe we're it's parent.
gamemodeauto:
ERROR: ld.so: object '/home/wellium/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
Found path: /home/wellium/.local/share/Steam/steamapps/common/Blasphemous/Blasphemous.x86_64
Mono path[0] = '/home/wellium/.local/share/Steam/steamapps/common/Blasphemous/Blasphemous_Data/Managed'
Mono config path = '/home/wellium/.local/share/Steam/steamapps/common/Blasphemous/Blasphemous_Data/Mono/etc'
Preloaded 'ScreenSelector.so'
Preloaded 'libfmod.so'
Preloaded 'libfmodL.so'
Preloaded 'libfmodstudio.so'
Preloaded 'libfmodstudioL.so'
Preloaded 'libgvraudio.so'
Preloaded 'libresonanceaudio.so'
Preloaded 'libsteam_api.so'
Loading player data from /home/wellium/.local/share/Steam/steamapps/common/Blasphemous/Blasphemous_Data/data.unity3dLogging to /home/wellium/.config/unity3d/TheGameKitchen/Blasphemous/Player.log
Installing breakpad exception handler for appid(gameoverlayui)/version(20220314194902)
Installing breakpad exception handler for appid(gameoverlayui)/version(1.0)
Game process updated : AppID 774361 "gamemoderun prime-run /home/wellium/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=774361 -- '/home/wellium/.local/share/Steam/steamapps/common/Blasphemous/Blasphemous.x86_64' systemctl --user status gamemoded.service", ProcID 3406, IP 0.0.0.0:0
Setting breakpad minidump AppID = 774361
Steam_SetMinidumpSteamID: Caching Steam ID: 76561198967515139 [API loaded no]
(process:3447): GLib-GObject-CRITICAL **: 21:54:45.447: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Game process removed: AppID 774361 "gamemoderun prime-run /home/wellium/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=774361 -- '/home/wellium/.local/share/Steam/steamapps/common/Blasphemous/Blasphemous.x86_64' systemctl --user status gamemoded.service", ProcID 3406
ThreadGetProcessExitCode: no such process 3488
ThreadGetProcessExitCode: no such process 3483
ThreadGetProcessExitCode: no such process 3453
ThreadGetProcessExitCode: no such process 3451
ThreadGetProcessExitCode: no such process 3449
ThreadGetProcessExitCode: no such process 3406
ThreadGetProcessExitCode: no such process 3404
Game 774361 created interface STEAMAPPLIST_INTERFACE_VERSION001 / AppList
Game 774361 created interface STEAMAPPS_INTERFACE_VERSION008 / Apps
Game 774361 created interface STEAMHTMLSURFACE_INTERFACE_VERSION_004 / HTMLSurface
Game 774361 created interface STEAMHTTP_INTERFACE_VERSION002 / HTTP
Game 774361 created interface STEAMINVENTORY_INTERFACE_V002 / Inventory
Game 774361 created interface STEAMMUSICREMOTE_INTERFACE_VERSION001 / MusicRemote
Game 774361 created interface STEAMMUSIC_INTERFACE_VERSION001 / Music
Game 774361 created interface STEAMPARENTALSETTINGS_INTERFACE_VERSION001 / ParentalSettings
Game 774361 created interface STEAMREMOTESTORAGE_INTERFACE_VERSION014 / RemoteStorage
Game 774361 created interface STEAMSCREENSHOTS_INTERFACE_VERSION003 / Screenshots
Game 774361 created interface STEAMUGC_INTERFACE_VERSION010 / UGC
Game 774361 created interface STEAMUSERSTATS_INTERFACE_VERSION011 / UserStats
Game 774361 created interface STEAMVIDEO_INTERFACE_V002 / Video
Game 774361 created interface SteamController006 / Controller
Game 774361 created interface SteamFriends015 / Friends
Game 774361 created interface SteamMatchMaking009 / Matchmaking
Game 774361 created interface SteamMatchMakingServers002 / MatchmakingServers
Game 774361 created interface SteamNetworking005 / Networking
Game 774361 created interface SteamUser019 / User
Game 774361 created interface SteamUtils009 / Utils
Game 774361 method call count for IClientUtils::RecordSteamInterfaceCreation : 22
Game 774361 method call count for IClientUtils::GetAppID : 23
Game 774361 method call count for IClientUser::GetSteamID : 1
Uploaded AppInterfaceStats to Steam
src/steamexe/main.cpp (253) : Assertion Failed: reaping pid: 3447 -- gameoverlayui
assert_20220430215502_32.dmp[3638]: Uploading dump (out-of-process)
/tmp/dumps/assert_20220430215502_32.dmp
assert_20220430215502_32.dmp[3638]: Finished uploading minidump (out-of-process): success = no
assert_20220430215502_32.dmp[3638]: error: HTTP response code said error
assert_20220430215502_32.dmp[3638]: file ''/tmp/dumps/assert_20220430215502_32.dmp'', upload no: ''HTTP response code said error''
I run prime-run steam command and set launch options with
gamemoderun prime-run %command% systemctl --user status gamemoded.service
It didn’t freeze the OS this time, just not responding
