After updating two days ago, I noticed that if I open menus from steam friends, like changing my status from online to invisible, away, offline or right click a friend to open the popup menu to send message, open profile, join game etc, the menus, along with the entire steam friend window, become unresponsive and stuck on my screen permanently on top of other windows unless I exit steam. A little more explanation, I can move steam friends window around, but I can’t do anything other than that, it ignores all clicking. I can, however, close the window from taskbar, closing it doesn’t resolve the stuck popup menu. The rest of steam client is still working fine and as intended.
Kernel: 5.15.81-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/vmlinuz-5.15-x86_64
root=UUID=c9c37c7e-6f11-49ba-be3c-3b2cd7015bc0 rw quiet
cryptdevice=UUID=c33bd1cc-2a88-4ba0-b3fa-fdb5cff3e252:luks-c33bd1cc-2a88-4ba0-b3fa-fdb5cff3e252
root=/dev/mapper/luks-c33bd1cc-2a88-4ba0-b3fa-fdb5cff3e252
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: P5QD TURBO v: Rev 1.xx
serial: <superuser required> BIOS: American Megatrends v: 0301
date: 08/04/2009
Info: model: Intel Xeon X5460 bits: 64 type: MCP arch: Penryn level: v1
built: 2008 process: Intel 45nm family: 6 model-id: 0x17 (23) stepping: 6
microcode: 0x60F
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 12 MiB desc: 2x6 MiB
Speed (MHz): avg: 3166 min/max: N/A cores: 1: 3166 2: 3166 3: 3166 4: 3166
bogomips: 25339
Flags: ht lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx
Type: l1tf mitigation: PTE Inversion; VMX: EPT disabled
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT disabled
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: NVIDIA GK107 [GeForce GTX 650] vendor: Micro-Star MSI
driver: nvidia v: 470.161.03 alternate: nouveau,nvidia_drm non-free:
series: 470.xx+ status: legacy-active (EOL~2023/24) arch: Kepler
code: GKxxx process: TSMC 28nm built: 2012-18 pcie: gen: 2 speed: 5 GT/s
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:0fc6 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: N/A
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1280x1024 s-dpi: 95 s-size: 342x270mm (13.46x10.63")
s-diag: 436mm (17.15")
Monitor-1: VGA-0 res: 1280x1024 hz: 60 dpi: 96
size: 338x270mm (13.31x10.63") diag: 433mm (17.03") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 470.161.03 renderer: NVIDIA GeForce GTX
650/PCIe/SSE2 direct render: Yes
Device-1: Intel 82801JI HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3a3e class-ID: 0403
Device-2: NVIDIA GK107 HDMI Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
Device-3: Creative Labs CA0106/CA0111 [SB Live!/Audigy/X-Fi Series]
driver: snd_ca0106 v: kernel bus-ID: 04:00.0 chip-ID: 1102:0007
class-ID: 0401
Sound API: ALSA v: k5.15.81-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.61 running: yes
Device-1: Qualcomm Atheros AR8121/AR8113/AR8114 Gigabit or Fast Ethernet
vendor: ASUSTeK driver: ATL1E v: N/A modules: atl1e pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: dc00 bus-ID: 02:00.0 chip-ID: 1969:1026
class-ID: 0200
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 2.27 TiB used: 317 GiB (13.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX200SSD1
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: MU03 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EADS-00M2B0
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 1.5 Gb/s
type: N/A serial: <filter> rev: 0A01 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: HGST (Hitachi) model: HTS541010B7E610
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: 1A01 scheme: MBR
ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 30.8 GiB (31.5%)
fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-c33bd1cc-2a88-4ba0-b3fa-fdb5cff3e252
ID-2: /boot raw-size: 1022 MiB size: 987.4 MiB (96.62%)
used: 77.3 MiB (7.8%) fs: ext4 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-3cfeeb83-314b-4455-b048-f2047a401f75
ID-3: /home raw-size: 364.75 GiB size: 357.95 GiB (98.13%)
used: 131.51 GiB (36.7%) fs: ext4 dev: /dev/dm-2 maj-min: 254:2
mapped: luks-7c011dbe-6e94-4a73-87d7-1c41cd8ce19f
ID-1: swap-1 type: file size: 10 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 39.5 C mobo: 35.0 C gpu: nvidia temp: 37 C
Fan Speeds (RPM): cpu: 1259 psu: 0 case-1: 0 case-2: 0 gpu: nvidia fan: 40%
Power: 12v: 12.38 5v: N/A 3.3v: 3.33 vbat: N/A
Processes: 222 Uptime: 46m wakeups: 0 Memory: 7.76 GiB used: 2.72 GiB (35.0%)
Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1524 libs: 460
tools: pamac Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.24
