Issue Summary:
When running Steam, I consistently get “Steam is having trouble connecting to Steam Servers” with a “Retry Connection” and “Cancel” button.
Inxi Output:
❯ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.10.63-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=1cbcf1c0-ca88-4f96-a451-7bf5a4213134 rw quiet apparmor=1
security=apparmor resume=UUID=2478544d-3812-4597-866d-e7e8dafb4ea8
udev.log_priority=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Desktop System: ASUS product: N/A v: N/A serial: <filter>
Mobo: ASUSTeK model: ROG CROSSHAIR VIII IMPACT v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 3402 date: 03/22/2021
ID-1: hidpp_battery_0 charge: N/A condition: N/A volts: 4.1 min: N/A
model: Logitech G903 LIGHTSPEED Wireless Gaming Mouse w/ HERO type: N/A
serial: <filter> status: Discharging
RAM: total: 62.78 GiB used: 3.27 GiB (5.2%)
Info: 16-Core model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3
family: 19 (25) model-id: 21 (33) stepping: 0 microcode: A201009 cache:
L2: 8 MiB bogomips: 217723
Speed: 2905 MHz min/max: 2200/3400 MHz boost: disabled Core speeds (MHz):
1: 2905 2: 2711 3: 2196 4: 2198 5: 2200 6: 2191 7: 2198 8: 2190 9: 3173
10: 2708 11: 2709 12: 2712 13: 2711 14: 2713 15: 2702 16: 3399 17: 2720
18: 2197 19: 2198 20: 2199 21: 2198 22: 2198 23: 2198 24: 2712 25: 2198
26: 2199 27: 2716 28: 2717 29: 3396 30: 2712 31: 2194 32: 2200
cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rdpid rdpru
rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall
vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: always-on, RSB filling
Device-1: NVIDIA GA102 [GeForce RTX 3080 Ti] vendor: ASUSTeK driver: nvidia
v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 0a:00.0
chip-ID: 10de:2208 class-ID: 0300
Device-2: Logitech C922 Pro Stream Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 5-1.4:7 chip-ID: 046d:085c
class-ID: 0102 serial: <filter>
Screen-1: 0 s-res: 3440x1440 s-dpi: 109 s-size: 802x342mm (31.6x13.5")
s-diag: 872mm (34.3")
Monitor-1: DP-2 res: 3440x1440 dpi: 109 size: 798x335mm (31.4x13.2")
diag: 865mm (34.1")
OpenGL: renderer: NVIDIA GeForce RTX 3080 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: NVIDIA GA102 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0a:00.1 chip-ID: 10de:1aef
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0c:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: Logitech C922 Pro Stream Webcam type: USB
Device-4: Antlion Audio Antlion Wireless Microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-2:3 chip-ID: 2f96:0100
class-ID: 0300
Sound Server-1: ALSA v: k5.10.63-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.35 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 05:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp5s0 state: down mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
port: f000 bus-ID: 06:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-5:3
Local Storage: total: 3.68 TiB used: 702.4 GiB (18.6%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 type: SSD serial: <filter> rev: 2B2QGXA7 temp: 37.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Sabrent model: N/A size: 1.86 TiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
type: SSD serial: <filter> rev: RKT303.4 temp: 34.9 C scheme: GPT
ID-1: / raw-size: 1.75 TiB size: 1.72 TiB (98.37%) used: 576.53 GiB (32.7%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:4 label: N/A
uuid: 1cbcf1c0-ca88-4f96-a451-7bf5a4213134
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
label: NO_LABEL uuid: B1B8-4450
ID-3: /media/sabrent raw-size: 1.86 TiB size: 1.83 TiB (98.38%)
used: 125.87 GiB (6.7%) fs: ext4 dev: /dev/nvme1n1p1 maj-min: 259:1
label: N/A uuid: 180b9d2d-f865-4b97-8910-1b491928d6b8
ID-1: swap-1 type: partition size: 69.06 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:5 label: N/A
uuid: 2478544d-3812-4597-866d-e7e8dafb4ea8
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 1-3:2 info: NZXT USB Device type: HID driver: hid-generic,usbhid
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 1e71:2007
class-ID: 0300 serial: <filter>
Device-2: 1-5:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-3: 1-6:4 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-6: 5-1:2 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 5-1.1:4 info: ZSA Labs ErgoDox EZ Glow type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 3297:4976 class-ID: 0300
Device-2: 5-1.2:5 info: Logitech USB Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c539 class-ID: 0300
Device-3: 5-1.3:6 info: Logitech PowerPlay Wireless Charging System
type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 498mA chip-ID: 046d:c53a class-ID: 0300
Device-4: 5-1.4:7 info: Logitech C922 Pro Stream Webcam type: Video,Audio
power: 500mA chip-ID: 046d:085c class-ID: 0102 serial: <filter>
Device-5: 5-2:3 info: Antlion Audio Antlion Wireless Microphone
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 3
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 2f96:0100 class-ID: 0300
Hub-7: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 38.1 C mobo: N/A gpu: nvidia temp: 40 C
Processes: 501 Uptime: 15m wakeups: 2 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1511 pacman: 1503 lib: 431
flatpak: 8 Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.06
Output of Steam when run from command line:
❯ steam
Running Steam on manjarolinux 21.1.3 64-bit
STEAM_RUNTIME is enabled automatically
Steam runtime environment up-to-date!
Steam client's requirements are satisfied
WARNING: Using default/fallback debugger launch
/home/jake/.local/share/Steam/ubuntu12_32/steam
[2021-09-21 19:20:09] Startup - updater built Sep 17 2021 04:27:28
[2021-09-21 19:20:09] Opted in to client beta 'publicbeta' via beta file
You are in the 'publicbeta' client beta.
Installing breakpad exception handler for appid(steam)/version(1631912732)
[2021-09-21 19:20:09] Loading cached metrics from disk (/home/jake/.local/share/Steam/package/steam_client_metrics.bin)
[2021-09-21 19:20:09] Failed to load cached hosts file (File 'update_hosts_cached.vdf' not found), using defaults
[2021-09-21 19:20:09] Using the following download hosts for Public, Realm steamglobal
[2021-09-21 19:20:09] 1. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2021-09-21 19:20:09] Verifying installation...
[2021-09-21 19:20:09] Verification complete
Loaded SDL version 2.0.17-6744061
/usr/share/themes/Breath/gtk-2.0/widgets/entry:70: error: unexpected identifier 'direction', expected character '}'
(steam:3937): Gtk-WARNING **: 19:20:09.418: Unable to locate theme engine in module_path: "adwaita",
/usr/share/themes/Breath/gtk-2.0/widgets/styles:36: error: invalid string constant "combobox_entry", expected valid string constant
Runtime for steamwebhelper: defaulting to /home/jake/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
+ exec /home/jake/.local/share/Steam/ubuntu12_64/steam-runtime-heavy.sh --unpack-dir=/home/jake/.local/share/Steam/ubuntu12_64 --runtime=steam-runtime-heavy -- ./steamwebhelper -lang=en_US -cachedir=/home/jake/.local/share/Steam/config/htmlcache -steampid=3937 -buildid=1631912732 -steamid=0 -cachedir=/home/jake/.local/share/Steam/config/htmlcache -steamuniverse=Public -realm=Global -clientui=/home/jake/.local/share/Steam/clientui --enable-blink-features=ResizeObserver,Worklet,AudioWorklet --enable-media-stream --enable-smooth-scrolling --password-store=basic --log-file=/home/jake/.local/share/Steam/logs/cef_log.txt --disable-quick-menu
CAppInfoCacheReadFromDiskThread took 0 milliseconds to initialize
Proceed to auto login
No cached credentials
src/clientdll/cminterface.cpp (2910) : Assertion Failed: m_VecNetAdrNetFilterCMs.Count() > 0
assert_20210921192033_24.dmp[4046]: Uploading dump (out-of-process)
/tmp/dumps/assert_20210921192033_24.dmp
LogonFailure No Connection
assert_20210921192033_24.dmp[4046]: Finished uploading minidump (out-of-process): success = yes
assert_20210921192033_24.dmp[4046]: response: CrashID=bp-810c8248-58b2-457d-aac2-9259b2210921
assert_20210921192033_24.dmp[4046]: file ''/tmp/dumps/assert_20210921192033_24.dmp'', upload yes: ''CrashID=bp-810c8248-58b2-457d-aac2-9259b2210921''
^C^C^C^Csrc/clientdll/cminterface.cpp (2910) : Assertion Failed: m_VecNetAdrNetFilterCMs.Count() > 0
Exiting workitem thread
(steam:3937): GLib-GObject-CRITICAL **: 19:21:50.988: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
(steam:3937): GLib-GObject-WARNING **: 19:21:50.989: invalid (NULL) pointer instance
(steam:3937): GLib-GObject-CRITICAL **: 19:21:50.989: g_signal_handlers_disconnect_matched: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(steam:3937): GLib-GObject-CRITICAL **: 19:21:50.989: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
[2021-09-21 19:21:51] Shutdown
Things I have tried:
- Running steam --reset to reset my user and login. Had no effect.
- Changing my DNS resolution. Set them to google at 8.8.8.8 and 8.8.4.4
- Install lib32-systemd
- Installing the flatpak version of Steam and running it (same issue)
- Enabling sudo systemctl enable --now nscd.service
- I have reset my machine after the above steps with no effect.
If you want any additional info let me know. Just to clarify, this is not the black screen issue where you need to enable the Steam beta…I can’t even log in!
I was logged into Steam just fine last night. I have not made any system changes or updates today.
