Hi I am using arch Linux but would like to install the steam-deckify manjaro package. But when I look for it in the gitlab extra repo it’s not there. Can anyone link me to the repo as arch pamac won’t find the package ? Thanks
Yeah … the source is missing
But I do know you can still get things from the mirrors, ex;
The package has several dependencies - due caution is to be exercised - it may be very unstable based on sources in early development - and likely to change without notice.
$ pamac info steam-deckify
Version : 20240318-1
Description : Files for Steam Deck UI
URL : https://gitlab.manjaro.org/packages
Licenses : GPL
Repository : extra
Installed Size : 38,8 kB
Groups : --
Depends On : steam mangohud jq dmidecode gamescope-session-git glew glfw-x11 glxinfo curl tar
os-session-select
Optional Dependencies : os-session-select: Set default session to OpenGamePadUI with Overlay mode
os-session-select-hhd: Set default session to Handheld Daemon with Overlay
Provides : --
Replaces : --
Conflicts With : --
Packager : Philip Mueller <philm@manjaro.org>
Build Date : man 18 mar 2024 04:36:48 CET
Validated By : MD5 Sum SHA-256 Sum Signature
Thanks for the reply’s still a slight issues I can download the package and sig file but sudo pacman -U refuses to install bc of signature issues
