Steam recently did a sizable internal update and I’ve lost ability to connect, anyone with a similar problem
(Manjaro 6.4.3)
Try steam --reset
I’ve been using Steam on Linux since 2012. Connection issues aren’t that uncommon. Usually you just need to be patient and try again later.
That being said, how long have you not been able to connect?
You can test
steam %U --no-sandbox
Doing that lead in the total wipe of the Steam local folder, minus the steamapps folder basically (you will keep your game library). All the user data like the screenshots will be wiped. make sure to backup them first.
What’s the actual issue. Tell us the exact problem instead of a vague “guess game” post.
You can start Steam from the terminal to have the console output directly so we can see what is going on.
steam.sh[8855]: Running Steam on manjarolinux 23.0.0 64-bit
steam.sh[8855]: STEAM_RUNTIME is enabled automatically
setup.sh[8929]: Steam runtime environment up-to-date!
steam.sh[8855]: Steam client's requirements are satisfied
[2023-07-21 16:06:30] Startup - updater built Jul 20 2023 00:33:21
[2023-07-21 16:06:30] Startup - Steam Client launched with: '/home/richardh/.local/share/Steam/ubuntu12_32/steam'
[2023-07-21 16:06:30] Opted in to client beta 'publicbeta' via beta file
You are in the 'publicbeta' client beta.
07/21 16:06:30 Init: Installing breakpad exception handler for appid(steam)/version(1689814451)/tid(9007)
Looks like steam didn't shutdown cleanly, scheduling immediate update check
[2023-07-21 16:06:30] Loading cached metrics from disk (/home/richardh/.local/share/Steam/package/steam_client_metrics.bin)
[2023-07-21 16:06:30] Using the following download hosts for Public, Realm steamglobal
[2023-07-21 16:06:30] 1. https://client-update.akamai.steamstatic.com, /, Realm 'steamglobal', weight was 1000, source = 'update_hosts_cached.vdf'
[2023-07-21 16:06:30] 2. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 1, source = 'update_hosts_cached.vdf'
[2023-07-21 16:06:30] 3. https://cdn.steamstatic.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2023-07-21 16:06:30] Checking for update on startup
[2023-07-21 16:06:30] Checking for available updates...
[2023-07-21 16:06:30] Downloading manifest: https://client-update.akamai.steamstatic.com/steam_client_publicbeta_ubuntu12
[2023-07-21 16:06:30] Manifest download: send request
[2023-07-21 16:06:30] Manifest download: waiting for download to finish
[2023-07-21 16:06:31] Manifest download: finished
[2023-07-21 16:06:31] Download skipped: /steam_client_publicbeta_ubuntu12 version 1689814451, installed version 1689814451, existing pending version 0
[2023-07-21 16:06:31] Nothing to do
[2023-07-21 16:06:31] Verifying installation...
[2023-07-21 16:06:31] Performing checksum verification of executable files
[2023-07-21 16:06:31] Verification complete
/usr/share/themes/Breath/gtk-2.0/widgets/entry:70: error: unexpected identifier 'direction', expected character '}'
/usr/share/themes/Breath/gtk-2.0/widgets/styles:36: error: invalid string constant "combobox_entry", expected valid string constant
XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xf1031db0
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xf1030500
GetWin32Stats: display was not open yet, good
steamwebhelper.sh[9017]: Runtime for steamwebhelper: defaulting to /home/richardh/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[9017]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
CAppInfoCacheReadFromDiskThread took 35 milliseconds to initialize
Assertion 'device' failed at src/libsystemd/sd-device/device-private.c:103, function device_get_tags_generation(). Aborting.
crash_20230721160632_27.dmp[9173]: Uploading dump (out-of-process)
/tmp/dumps/crash_20230721160632_27.dmp
crash_20230721160632_27.dmp[9173]: Finished uploading minidump (out-of-process): success = yes
crash_20230721160632_27.dmp[9173]: response: CrashID=bp-7147ca30-f8c8-4a55-aaf8-b04e82230721
crash_20230721160632_27.dmp[9173]: file ''/tmp/dumps/crash_20230721160632_27.dmp'', upload yes: ''CrashID=bp-7147ca30-f8c8-4a55-aaf8-b04e82230721''
/home/richardh/.local/share/Steam/steam.sh: line 798: 9007 Aborted (core dumped) "$STEAMROOT/$STEAMEXEPATH" "$@"
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
That’s not a connection problem, it’s crashing…
I suggest opting out. Find and delete the beta file, I think it’s at ~/.local/share/Steam/package/beta.
test
steam -no-cef-sandbox
steam -no-cef-sandbox ✔ 4s
steam.sh[12689]: Running Steam on manjarolinux 23.0.0 64-bit
steam.sh[12689]: STEAM_RUNTIME is enabled automatically
setup.sh[12763]: Steam runtime environment up-to-date!
steam.sh[12689]: Steam client's requirements are satisfied
[2023-07-21 17:16:47] Startup - updater built Jul 20 2023 00:33:21
[2023-07-21 17:16:47] Startup - Steam Client launched with: '/home/richardh/.local/share/Steam/ubuntu12_32/steam' '-no-cef-sandbox'
[2023-07-21 17:16:47] Opted in to client beta 'publicbeta' via beta file
07/21 17:16:47 Init: Installing breakpad exception handler for appid(steam)/version(1689814451)/tid(12841)
[2023-07-21 17:16:47] Loading cached metrics from disk (/home/richardh/.local/share/Steam/package/steam_client_metrics.bin)
[2023-07-21 17:16:47] Using the following download hosts for Public, Realm steamglobal
[2023-07-21 17:16:47] 1. https://client-update.akamai.steamstatic.com, /, Realm 'steamglobal', weight was 1000, source = 'update_hosts_cached.vdf'
[2023-07-21 17:16:47] 2. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 1, source = 'update_hosts_cached.vdf'
[2023-07-21 17:16:47] 3. https://cdn.steamstatic.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2023-07-21 17:16:47] Checking for update on startup
[2023-07-21 17:16:47] Checking for available updates...
[2023-07-21 17:16:47] Downloading manifest: https://client-update.akamai.steamstatic.com/steam_client_publicbeta_ubuntu12
[2023-07-21 17:16:47] Manifest download: send request
[2023-07-21 17:16:47] Manifest download: waiting for download to finish
[2023-07-21 17:16:47] Manifest download: finished
[2023-07-21 17:16:47] Download skipped: /steam_client_publicbeta_ubuntu12 version 1689814451, installed version 1689814451, existing pending version 0
[2023-07-21 17:16:47] Nothing to do
[2023-07-21 17:16:47] Verifying installation...
[2023-07-21 17:16:47] Performing checksum verification of executable files
[2023-07-21 17:16:48] Verification complete
XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xf0c06db0
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xf0c05500
steamwebhelper.sh[12852]: Runtime for steamwebhelper: defaulting to /home/richardh/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[12852]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
steamwebhelper.sh[12852]: CEF sandbox already disabled
CAppInfoCacheReadFromDiskThread took 36 milliseconds to initialize
crash_20230721171649_27.dmp[13008]: Uploading dump (out-of-process)
/tmp/dumps/crash_20230721171649_27.dmp
crash_20230721171649_27.dmp[13008]: Finished uploading minidump (out-of-process): success = yes
crash_20230721171649_27.dmp[13008]: response: CrashID=bp-15772831-73da-4ec8-b3d7-4e7b82230721
crash_20230721171649_27.dmp[13008]: file ''/tmp/dumps/crash_20230721171649_27.dmp'', upload yes: ''CrashID=bp-15772831-73da-4ec8-b3d7-4e7b82230721''
/home/richardh/.local/share/Steam/steam.sh: line 798: 12841 Aborted (core dumped) "$STEAMROOT/$STEAMEXEPATH" "$@"
Did you install libgudev ?
No, I did not install libgudev 238, this update was one of Steam’s automatic updates which seem to work
exactly the opposite of intended, the larger the update the more the problems.
