Steam will launch normally, and games are even playable, but trying to use Big Picture mode will result in an immediate crash. I created a support ticket with Steam, but I’m starting to think the problem lies somewhere on my end, but I can’t seem to figure out exactly what’s going wrong.
I’ve tried reinstalling and downgrading my graphics drivers, to seemingly no effect. I’ve uninstalled, re-installed, and even reset Steam. There is no difference to running steam vs steam-native. The flatpak version works properly. And I discovered while trying to diagnose this myself that the normal version will even “work” if run through strace -f. I’m running into the limits of my knowledge here, so any help would be greatly appreciated.
output of steam -bigpicture:
steam.sh[985716]: Running Steam on manjarolinux 22.0.0 64-bit [18/3554]
steam.sh[985716]: STEAM_RUNTIME is enabled automatically
setup.sh[985800]: Steam runtime environment up-to-date!
steam.sh[985716]: Steam client's requirements are satisfied
[2022-09-10 22:29:35] Startup - updater built Aug 20 2022 01:16:55
[2022-09-10 22:29:35] Startup - Steam Client launched with: '/home/tamer/.local/share/Steam/ubuntu12_32/steam' '-bigpicture'
Installing breakpad exception handler for appid(steam)/version(1661825435)
Looks like steam didn't shutdown cleanly, scheduling immediate update check
[2022-09-10 22:29:35] Loading cached metrics from disk (/home/tamer/.local/share/Steam/package/steam_client_metrics.bin)
[2022-09-10 22:29:35] Using the following download hosts for Public, Realm steamglobal
[2022-09-10 22:29:35] 1. https://cdn.akamai.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2022-09-10 22:29:35] 2. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2022-09-10 22:29:35] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2022-09-10 22:29:35] Checking for update on startup
[2022-09-10 22:29:35] Checking for available updates...
[2022-09-10 22:29:35] Downloading manifest: https://cdn.akamai.steamstatic.com/client/steam_client_ubuntu12
[2022-09-10 22:29:35] Manifest download: send request
[2022-09-10 22:29:35] Manifest download: waiting for download to finish
[2022-09-10 22:29:35] Manifest download: finished
[2022-09-10 22:29:35] Download skipped: /client/steam_client_ubuntu12 version 1661825435, installed version 1661825435, existing pending version 0
[2022-09-10 22:29:35] Nothing to do
[2022-09-10 22:29:35] Verifying installation...
[2022-09-10 22:29:35] Performing checksum verification of executable files
[2022-09-10 22:29:36] Verification complete
Loaded SDL version 2.25.0-7450656
ComputeStartupMode: forcing big picturesteamwebhelper.sh[985910]: Runtime for steamwebhelper: defaulting to /home/tamer/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[985910]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
CAppInfoCacheReadFromDiskThread took 235 milliseconds to initialize
Fontconfig warning: "/home/tamer/.local/share/Steam/bin/panorama/etc/fonts/conf.d/41-repl-os-win.conf", line 148: Having multiple values in <test> isn't supported and may not work as expected
Fontconfig warning: "/home/tamer/.local/share/Steam/bin/panorama/etc/fonts/conf.d/41-repl-os-win.conf", line 160: Having multiple values in <test> isn't supported and may not work as expected
Compiled against SDL version 2.25.0 and linked against SDL version 2.25.0
COpenGLSurface::BInitialize: Current session is 2
defaultfocus=DummyInput not found within layout file for welcome_nocontroller
(steam:985884): GLib-CRITICAL **: 22:29:38.866: g_main_context_push_thread_default: assertion 'acquired_context' failed
(steam:985884): GLib-CRITICAL **: 22:29:38.866: g_main_context_pop_thread_default: assertion 'g_queue_peek_head (stack) == context' failed
DeleteFBOFreeList: Removing 7 FBO objects, total 1
Slow image load - /home/tamer/.local/share/Steam/tenfoot/resource/images/mainmenu_bg_2.png (dimensions 1920x1080, took 100 msec)
/home/tamer/.local/share/Steam/steam.sh: line 796: 985884 Killed "$STEAMROOT/$STEAMEXEPATH" "$@"
Just make sure you’ve updated everything and do another test launch. If that fails, I’d gonand submit an issue on their github page here:
Way ahead of you on that one:
I initially submitted that issue after doing a lot of testing myself. I just doubled back to post the issue here to make sure I wasn’t stupidly missing something. I would hate to have bothered them when it was a mistake on my end.
I’ll try that later and report back, thanks. In the meantime, I have tested it under xfce, just to make sure it wasn’t something with i3wm. Still no difference.
One of the steam developers has been able to pinpoint from my CrashID that the error occurs when trying to load panorama.so. Presumably, this actually is a problem on my machine and not steam.
Any ideas on what I can try to diagnose this further? Considering the flatpak works, can I try to use it to see what’s different between its runtime and mine?
