Hi all!
What’s about achievements on Steam? I can’t get them… Is there any solution?
Greetings
Eduard
Hi all!
Greetings
Eduard
What does this mean?
You dont know where to find them?
Or you do but there is some problem with the display?
Or ..?..
No difference compared to the Windows Steam Client.
They are listed if you hover your mouse above “your nickname” and then activities.
What about them? What does that have to do with Manjaro? ![]()
Well, I installed Steam on it. When I play a game and normally achievements must get open - here they don’t.
I was trying to find the solution, probably most of Linux versions have it. There was a solution with replacement of file in the map of Steam. But here is like unvisible when I open the map…
P.S. It’s not the end of the world but if somebody knows the solution of this problem ![]()
What map do you mean?
Usually, achievements work without problems. No need to replace a file with the games I played.
What game do you have the problem with?
Hi, Punch club ![]()
Hello, no, they don’t get unlock ![]()
I don’t play that game.
However, It seems that it could be a general bug of the game. Several people have the issue since many years: No Achievements are working :: Punch Club Bugs and issues
Unless, you don’t have an error message that shows that it is something on manjaro, it is more likely a bug of the game…
No problem. The reason must be probably the game, not OS.
So, you get your achievements - it must something to do with a game. Thanks for that. Because I was looking in Google before making this topic in begin and there were a lot of “old” topics about incapability with Linux ~ So that’s why I thought may be it was the same and asked you ![]()
