Today I wanted to use my headphone by connecting it to my Asus X550LB, kernel 5.9.16-1, KDE laptop but I was greeted by static noise. I can use the headphones and e.g. listen to music but the static is there all time. The volume of the noise does not change by increasing/decreasing the general volume. Otherwise, the headphone works fine when connected to other devices (e.g. phone).
The “Audio” part of the output of inxi -Fazy
Device-1: Intel Haswell-ULT HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
Sound Server-1: ALSA v: k5.9.16-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.23 running: no
Please post full system information
inxi -Fazy
nik:
inxi -Fazy
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=bd95ae15-5be9-4441-9382-8843ab34b89c ro quiet apparmor=1
security=apparmor resume=UUID=a93c7ed8-a3dd-4fb7-b42f-cc9c03ae2fba
udev.log_priority=3 sysrq_always_enabled=1
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: X550LB v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X550LB v: 1.0 serial: <filter>
UEFI: American Megatrends v: X550LB.403 date: 06/26/2014
ID-1: BAT0 charge: 35.0 Wh (96.7%) condition: 36.2/44.2 Wh (81.9%)
volts: 14.4 min: 14.4 model: ASUSTeK X550A30 type: Li-ion serial: N/A
status: Unknown cycles: 432
Info: Dual Core model: Intel Core i7-4500U bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 45 (69) stepping: 1 microcode: 26 cache:
L2: 4 MiB
bogomips: 19167
Speed: 2162 MHz min/max: 800/3000 MHz Core speeds (MHz): 1: 2162 2: 2150
3: 2628 4: 2464
Type: l1tf
Device-1: Intel Haswell-ULT Integrated Graphics vendor: ASUSTeK driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0a16 class-ID: 0300
Device-2: NVIDIA GK208M [GeForce GT 740M] driver: N/A
alternate: nouveau, nvidia_drm, nvidia bus-ID: 04:00.0 chip-ID: 10de:1292
class-ID: 0302
Device-3: Chicony USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-5:5 chip-ID: 04f2:b40a class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: intel display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 507x285mm (20.0x11.2")
s-diag: 582mm (22.9")
Monitor-1: HDMI1 res: 1920x1080 hz: 60 dpi: 30 size: 1600x900mm (63.0x35.4")
diag: 1836mm (72.3")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2)
v: 4.5 Mesa 20.3.4 compat-v: 3.0 direct render: Yes
vendor: ASUSTeK driver: r8169 v: kernel port: e000 bus-ID: 02:00.1
IF: enp2s0f1 state: down mac: <filter>
Device-2: Qualcomm Atheros AR9485 Wireless Network Adapter
vendor: AzureWave AW-NE186H driver: ath9k v: kernel port: e000
bus-ID: 03:00.0 chip-ID: 168c:0032 class-ID: 0280
Local Storage: total: 1.82 TiB used: 565.5 GiB (30.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM024 HN-M101MBB
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 0002 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Seagate
model: ST1000LM035-1RK172 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B rotation: 5400 rpm serial: <filter> rev: 1053 scheme: MBR
ID-1: / raw-size: 49.61 GiB size: 48.58 GiB (97.93%) used: 27.63 GiB (56.9%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw-size: 201 MiB size: 197.9 MiB (98.45%)
used: 298 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 195.31 GiB size: 191.25 GiB (97.92%)
used: 124.16 GiB (64.9%) fs: ext4 dev: /dev/sda4 maj-min: 8:4
ID-1: swap-1 type: partition size: 2.8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 45.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2100
Processes: 196 Uptime: 6m wakeups: 1 Memory: 7.66 GiB used: 3.18 GiB (41.5%)
Init: systemd v: 247 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0
Packages: pacman: 1472 lib: 428 flatpak: 0 Shell: Zsh v: 5.8
running-in: konsole inxi: 3.3.03
Since the last kernel update, everything works fine.
