Static crackling noise in-ear headphones
Static crackling noise in wired in-ear headphones connected through audio jack to BenQ GC2870H monitor
I’ve recently reinstalled Manjaro on my system and I’m experiencing a static crackling noise in my headset speaker connected through the audio jack. I had this issue before and was able to resolve it by running yay -Sy sof-firmware. However, this time the same solution only works temporarily, and the issue returns after restarting the computer. I’m not sure how to troubleshoot this error and would appreciate any guidance. I don’t remember installing any other sound packages and I don’t know whether I’m using PipeWire, PulseAudio, ALSA or what. Here’s some system info for reference:
inxi -v7azy
  Kernel: 6.5.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
    root=UUID=baa9b4ca-d69c-4415-a122-a7b7ae627a58 rw quiet apparmor=1
    security=apparmor resume=UUID=e7067eb1-d67d-4439-b456-e20569f068e2
    udev.log_priority=3
  Desktop: Cinnamon v: 5.8.4 tk: GTK v: 3.24.38 vt: 7 dm: LightDM v: 1.32.0
  Type: Desktop System: Gigabyte product: B450M DS3H v: N/A
    serial: <superuser required>
  Mobo: Gigabyte model: B450M DS3H-CF v: x.x serial: <superuser required>
    UEFI: American Megatrends LLC. v: F61c date: 05/10/2021
  System RAM: total: 32 GiB note: est. available: 30.74 GiB
    used: 6.81 GiB (22.1%)
  Info: model: AMD Ryzen 7 5700G with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
    microcode: 0xA50000C
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
    desc: 1x16 MiB
  Speed (MHz): avg: 1046 high: 2994 min/max: 400/4673 scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
    5: 400 6: 400 7: 400 8: 400 9: 2983 10: 2994 11: 2993 12: 400 13: 400
    14: 400 15: 400 16: 2981 bogomips: 121428
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
  Type: spec_rstack_overflow mitigation: safe RET, no microcode
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
    vendor: Gigabyte driver: amdgpu v: kernel arch: GCN-5 code: Vega
    process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1 empty: DVI-D-1
    bus-ID: 07:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 35.0 C
  Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: amdgpu
    unloaded: modesetting alternate: fbdev,vesa dri: radeonsi gpu: amdgpu
    display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: BenQ GC2870 serial: <filter>
    built: 2017 res: 1920x1080 hz: 60 dpi: 79 gamma: 1.2
    size: 621x341mm (24.45x13.43") diag: 708mm (27.9") ratio: 16:9 modes:
    max: 1920x1080 min: 720x400
  API: OpenGL v: 4.6 Mesa 23.1.6-3 renderer: AMD Radeon Graphics (renoir
    LLVM 16.0.6 DRM 3.54 6.5.0-1-MANJARO) direct-render: Yes
  Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 07:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-2: AMD Family 17h/19h HD Audio vendor: Gigabyte
    link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.6 chip-ID: 1022:15e3
    class-ID: 0403
  API: ALSA v: k6.5.0-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.79 status: off tools: pw-cli
    type: plugin tools: pacat,pactl,pavucontrol
    lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 10.01 TiB used: 7.22 TiB (72.1%)
    model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 211210WD temp: 41.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: Expansion size: 4.55 TiB
    block-size: physical: 4096 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s
    lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: 0712
    scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: Portable size: 4.55 TiB
    scheme: GPT
  ID-1: / raw-size: 897.4 GiB size: 882.24 GiB (98.31%)
    used: 183.77 GiB (20.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: baa9b4ca-d69c-4415-a122-a7b7ae627a58
    used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 23E6-7A2B
  ID-3: /mnt/hdd1 raw-size: 4.55 TiB size: 4.51 TiB (99.19%)
    used: 2.87 TiB (63.6%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: S
    uuid: 1615d12a-a9fb-41a9-a84b-34c618f16832
  ID-4: /mnt/hdd2 raw-size: 4.55 TiB size: 4.51 TiB (99.19%)
    used: 4.17 TiB (92.4%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: T
    uuid: d605a480-f133-443c-8fe7-5b0a2d1c60c1
  ID-5: /mnt/storage raw-size: N/A size: 9.02 TiB used: 7.04 TiB (78.0%)
    fs: fuse.mergerfs source: ERR-102
  ID-1: swap-1 type: partition size: 33.82 GiB used: 1.2 MiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: e7067eb1-d67d-4439-b456-e20569f068e2
  Device-1: 4-1:2 info: Seagate RSS LLC Expansion type: mass storage
    driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
    mode: 3.2 gen-1x1 power: 896mA chip-ID: 0bc2:2343 class-ID: 0806
    serial: <filter>
  Device-2: 4-2:3 info: Seagate RSS LLC Portable type: mass storage
    mode: 3.2 gen-1x1 power: 896mA chip-ID: 0bc2:2344 class-ID: 0806
    serial: <filter>
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-6: 5-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1
  Device-1: 5-1.1:3 info: SONiX USB Keyboard type: keyboard
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 2efd:7812 class-ID: 0301
  Device-2: 5-1.2:4 info: Razer USA RZ01-0321 Gaming Mouse [DeathAdder V2]
    type: mouse,keyboard driver: hid-generic,usbhid interfaces: 4 rev: 2.0
    chip-ID: 1532:0084 class-ID: 0300
  Hub-7: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-8: 6-1:2 info: Genesys Logic Hub ports: 4 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0612
  System Temperatures: cpu: 41.2 C mobo: 37.0 C gpu: amdgpu temp: 37.0 C
  Fan Speeds (rpm): N/A
  Processes: 464 Uptime: 13h 15m wakeups: 0 Init: systemd v: 254
  Packages: pm: pacman pkgs: 2391 libs: 436 tools: pamac,yay pm: flatpak
  pkgs: 0 Shell: Zsh v: 5.9 running-in: tmux: inxi: 3.3.29
pacmd list-sinks
❯ pacmd list-sinks
2 sink(s) available.
    index: 1
        driver: <module-alsa-card.c>
        flags: HARDWARE HW_MUTE_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
        state: SUSPENDED
        suspend cause: IDLE
        priority: 9037
        volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB
                balance 0.00
        base volume: 65536 / 100% / 0.00 dB
        volume steps: 65537
        muted: no
        current latency: 0.00 ms
        max request: 0 KiB
        max rewind: 0 KiB
        monitor source: 1
        sample spec: s16le 2ch 44100Hz
        channel map: front-left,front-right
                     Stereo
        used by: 0
        linked by: 0
        configured latency: 0.00 ms; range is 0.50 .. 1999.82 ms
        card: 1 <alsa_card.pci-0000_07_00.6>
        module: 7
        properties:
                alsa.resolution_bits = "16"
                device.api = "alsa"
                device.class = "sound"
                alsa.class = "generic"
                alsa.subclass = "generic-mix"
                alsa.name = "ALC887-VD Digital"
                alsa.id = "ALC887-VD Digital"
                alsa.subdevice = "0"
                alsa.subdevice_name = "subdevice #0"
                alsa.device = "1"
                alsa.card = "1"
                alsa.card_name = "HD-Audio Generic"
                alsa.long_card_name = "HD-Audio Generic at 0xfca80000 irq 89"
                device.bus_path = "pci-0000:07:00.6"
                sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:07:00.6/sound/card1"
                device.bus = "pci"
                device.vendor.id = "1022"
                device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
                device.product.id = "15e3"
                device.product.name = "Family 17h/19h HD Audio Controller"
                device.string = "iec958:1"
                device.buffering.buffer_size = "352768"
                device.buffering.fragment_size = "176384"
                device.access_mode = "mmap+timer"
                device.profile.name = "iec958-stereo"
                device.profile.description = "Digital Stereo (IEC958)"
                device.description = "Family 17h/19h HD Audio Controller Digital Stereo (IEC958)"
                module-udev-detect.discovered = "1"
                device.icon_name = "audio-card-pci"
        ports:
                iec958-stereo-output: Digital Output (S/PDIF) (priority 0, latency offset 0 usec, available: unknown)
                        properties:
        active port: <iec958-stereo-output>
  * index: 3
        flags: HARDWARE DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
        state: RUNNING
        suspend cause: (none)
        priority: 9030
        volume: front-left: 42325 /  65% / -11.39 dB,   front-right: 42325 /  65% / -11.39 dB
                balance 0.00
        volume steps: 65537
        muted: no
        current latency: 2.02 ms
        max request: 0 KiB
        max rewind: 0 KiB
        monitor source: 3
                     Stereo
        used by: 1
        linked by: 2
        configured latency: 2.51 ms; range is 0.50 .. 1999.82 ms
        card: 0 <alsa_card.pci-0000_07_00.1>
        module: 6
        properties:
                device.api = "alsa"
                alsa.name = "BenQ GC2870"
                alsa.id = "HDMI 0"
                alsa.device = "3"
                alsa.card = "0"
                alsa.long_card_name = "HD-Audio Generic at 0xfca88000 irq 88"
                device.bus_path = "pci-0000:07:00.1"
                sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:07:00.1/sound/card0"
                device.bus = "pci"
                device.vendor.id = "1002"
                device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
                device.product.id = "1637"
                device.product.name = "Renoir Radeon High Definition Audio Controller"
                device.string = "hdmi:0"
                device.profile.name = "hdmi-stereo"
                device.profile.description = "Digital Stereo (HDMI)"
                device.description = "Renoir Radeon High Definition Audio Controller Digital Stereo (HDMI)"
        ports:
                hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: yes)
                        properties:
                                device.product.name = "BenQ GC2870"
        active port: <hdmi-output-0>
The first result I found when searching for static noise firmware site:https://forum.manjaro.org was this closed topic without any answers… You could remove it or rename it to make it clear it’s unsolved.
Since you are using Manjaro with the Cinnamon desktop environment, it is likely that you are using PulseAudio as the default sound server. To troubleshoot the static crackling noise issue, you can try the following steps:
  1. Check if you have the latest sof-firmware installed by running:
    sudo pacman -Syu sof-firmware
    This command will update the sof-firmware package if it’s not up-to-date.
  2. Check if PulseAudio is running and configured correctly by running:
    pacmd list-sinks
    This command will show the available audio sinks (output devices) and their configurations.
  3. If you see any issues with the configuration, you can try resetting PulseAudio settings by removing the user configuration folder:
    rm -r ~/.config/pulse
    After removing the folder, restart PulseAudio with:
    pulseaudio -k
    pulseaudio --start
  4. If the issue persists, you can try changing the audio output profile. Open the “Sound” settings in the Cinnamon settings menu, and try selecting a different profile for your audio output device.
  5. If none of the above steps resolve the issue, you can consider switching to PipeWire as an alternative to PulseAudio. To do this, first, remove PulseAudio and install PipeWire with the following commands:
    sudo pacman -Rns manjaro-pulse pulseaudio
    sudo pacman -S manjaro-pipewire
    Then, reboot your system for the changes to take effect.
Remember that these steps are specific to Manjaro with the Cinnamon desktop environment and PulseAudio as the default sound server. If you are using a different sound server, such as PipeWire or ALSA, the troubleshooting steps may differ.
This solved the issue but the error returns every time I restart.
