Hi
I installed Stata16 and cannot execute it.
sudo /usr/local/stata16/xstata-se [sudo] password for : /usr/local/stata16/xstata-se: error while loading shared libraries: libgtk-x11-2.0.so.0: cannot open shared object file: No such file or directory
Does anybody have any idea why this happens?
How did you install it? It looks like proprietary software, which is not in the repostory.
This site suggest it needs GTK 2.24. Make sure you install gtk2 , which contains libgtk-x11-2.0.so.0.
gtk2
libgtk-x11-2.0.so.0
Thanks a lot!
