Starting full system upgrade...there's nothing to do
Hi all,
I thing that I have just wrecked my system.
When I try to update I get the message “Starting full system upgrade…there’s nothing to do”.
That happened after an update where accidentally i deleted the /var/lib/pacman/db.lck file.
I then tried to update again and got the message Synchronizing package databases…unable to lock database and a solution I found online was to delete the pacman/db.lck…which does not exist!
rm: cannot remove ‘/var/lib/pacman/db.lck’: No such file or directory
Please, can you help me fix my system? No matter command I tried, I always end up to a dead end and the upgrade is stuck.
Thank you all,
Eddie
refresh your mirrors:
sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syyu
Thank you.
I did as you suggested but again I end up with the same error:
 core                  164.1 KiB   121 KiB/s 00:01 [######################] 100%
 extra                1839.6 KiB   662 KiB/s 00:03 [######################] 100%
 community               7.4 MiB   887 KiB/s 00:09 [######################] 100%
 multilib              175.5 KiB   133 KiB/s 00:01 [######################] 100%
 there is nothing to do
i dont see any error, your system is up to date
sudo rm /var/lib/pacman/db.lck                               INT ✘
rm: cannot remove '/var/lib/pacman/db.lck': No such file or directory
i dont see any lock database output from the post above, and the cannot remove is normal if the db.lck file isnt there…
So this is normal?
How can I correct now the error
whenever I try to update?
I am trying to delete the /var/lib/pacman/db.lck (the method I tried succesfully many times in the past) but the file now can not be found.
Is this normal?
Please help me for the last time :slight_smile:
run these:
If you get: cannot remove ‘/var/lib/pacman/db.lck’: No such file or directory; use this:
sudo rm /var/tmp/pamac/dbs/db.lck
then provide output from:
uname -r
Thank you my friend.
I tried your suggestion with the new command, but again I got the “no such file or directory error”
The output of uname -r is
5.15.72-1-MANJARO
I mean I tried both commands but in every case I get “no such file or directory” like so:
sudo rm /var/tmp/pamac/dbs/db.lck                                ✔
[sudo] password for phil:
rm: cannot remove '/var/tmp/pamac/dbs/db.lck': No such file or directory
you are up to date, you are running the latest kernel…
try rebooting after you run the commands, and then test if the message appears again
You don’t need to remove the locks if everything is working. They are removed automatically.
I would link to the Wikipedia entry what a lock is but I don’t think the vocabulary is not very useful for you.
Pamac creates it’s own working folder /var/tmp/pamac which contains a folder dbs where the ocntent of dbs/sync is a separate copy of the the pacman databases and dbs/local is a symlink to /var/lib/pacman/local.
Pamac does not create it’s own lock-file - it uses the libalpm lockfile located in /var/lib/pacman to avoid collision with pacman.
As the advise appears pointing to an non existing file - where and from whom does this advise originate?
Thank you sir for your kindness.
The forum’s support is the best :slight_smile:
