HI guys,
my start menu doesn’t show up when i press the meta key, I have to open it with my mouse.
I have two monitors, so I fear that the start menu doesn’t work because both of them have an application bar. How can I solve the problem? Thanks in advance
Hi @david_0,
On the monitor that you want the launcher to open, right-click on the launcher (“Start menu”) Icon → select Configure…. In the Keyboard shortcuts, available in the left of the window, set the value to open the menu to Alt+F1.
On the other monitor, you can go there, and remove the shortcut.
I, myself, have 2 monitors, and this works flawlessly.
It works perfectly. Thanks a lot.
