Hi everyone,
first of all I am a beginner and may have messed some stupid things up somewhere, so I hope I have not broken something completely obscure but anything is possible.
My problem is that while booting, I get a start job is running for /sys/subsystem/net/devices/eth0
, which times out after 90 seconds and makes for a very long boot. I’ve looked around for similar problems and the only thing I found was to disable the dhcpcd service for this device, or to look around in the etc/systemd/system
folder for anything suspicious.
However I could not find anything related to the name eth0
anywhere I looked, be it a dhcpcd service, a device name on ip addr
or in any config files or folder names I checked. So I’m guessing the start job is waiting for a device that does not exist? My ethernet network interface is called eno2
Basically, I don’t even know how to look for a solution here.
Hi @LinieKiste
Could you open a terminal and type:
systemd-analyze blame
and
systemd-analyze critical-chain
and post it here as code? That way you should see which service is running so long at booting.
How to format code
paste the code here
or
paste the code here
I’m assuming you mean dhcpcd@eth0 in this case, but I did it with the literal “interface_name” as well and they both returned something like this:
Loaded: loaded (/usr/lib/systemd/system/dhcpcd@.service; disabled; vendor >
Active: inactive (dead)```
systemd-analyze blame gives me this:
2.121s updatedb.service
739ms lvm2-monitor.service
675ms man-db.service
643ms dev-nvme0n1p3.device
582ms upower.service
569ms systemd-logind.service
483ms mnt-Storage.mount
388ms systemd-random-seed.service
278ms systemd-modules-load.service
253ms var-lib-snapd-snap-core18-1885.mount
251ms var-lib-snapd-snap-spotify-42.mount
243ms systemd-udevd.service
240ms systemd-journald.service
236ms apparmor.service
235ms var-lib-snapd-snap-core18-1932.mount
234ms var-lib-snapd-snap-snapd-9721.mount
228ms var-lib-snapd-snap-spotify-43.mount
214ms tlp.service
213ms systemd-timesyncd.service
131ms snapd.service
122ms udisks2.service
120ms systemd-tmpfiles-clean.service
101ms user@1000.service
systemd-analyze critical-chain gives me this:
The time when unit became active or started is printed after the "@" character.
The time the unit took to start is printed after the "+" character.
graphical.target @1min 30.471s
└─lightdm.service @1min 30.428s +42ms
└─systemd-user-sessions.service @1min 30.411s +16ms
└─nss-user-lookup.target @1min 30.439s
