Hello there,
sorry i had to re-open a new thread.
This one was closed already
I worked my way through one of the many guides
And i achieved that watching youtube-videos hardware accelerated:
This is my chrome://gpu (on vivaldi)
### Graphics Feature Status
* Canvas: Hardware accelerated
* Compositing: Hardware accelerated
* Multiple Raster Threads: Enabled
* Out-of-process Rasterization: Hardware accelerated
* OpenGL: Enabled
* Rasterization: Hardware accelerated on all pages
* Skia Renderer: Enabled
* Video Decode: Hardware accelerated
* Vulkan: Disabled
* WebGL: Hardware accelerated
* WebGL2: Hardware accelerated
### Driver Bug Workarounds
* adjust_src_dst_region_for_blitframebuffer
* clear_uniforms_before_first_program_use
* disable_discard_framebuffer
* enable_webgl_timer_query_extensions
* exit_on_context_lost
* force_cube_complete
* init_gl_position_in_vertex_shader
* init_vertex_attributes
* pack_parameters_workaround_with_pack_buffer
* reset_base_mipmap_level_before_texstorage
* unpack_alignment_workaround_with_unpack_buffer
* unpack_overlapping_rows_separately_unpack_buffer
* use_virtualized_gl_contexts
* disabled_extension_GL_KHR_blend_equation_advanced
* disabled_extension_GL_KHR_blend_equation_advanced_coherent
* disabled_extension_GL_MESA_framebuffer_flip_y
### Problems Detected
* Program link fails in NVIDIA Linux if gl_Position is not set: [286468](http://crbug.com/286468)
*Applied Workarounds: init_gl_position_in_vertex_shader*
* Clear uniforms before first program use on all platforms: [124764](http://crbug.com/124764), [349137](http://crbug.com/349137)
*Applied Workarounds: clear_uniforms_before_first_program_use*
* Linux NVIDIA drivers don't have the correct defaults for vertex attributes: [351528](http://crbug.com/351528)
*Applied Workarounds: init_vertex_attributes*
* MakeCurrent is slow on Linux with NVIDIA drivers: [449150](http://crbug.com/449150), [514510](http://crbug.com/514510)
*Applied Workarounds: use_virtualized_gl_contexts*
* NVIDIA fails glReadPixels from incomplete cube map texture: [518889](http://crbug.com/518889)
*Applied Workarounds: force_cube_complete*
* Pack parameters work incorrectly with pack buffer bound: [563714](http://crbug.com/563714)
*Applied Workarounds: pack_parameters_workaround_with_pack_buffer*
* Alignment works incorrectly with unpack buffer bound: [563714](http://crbug.com/563714)
*Applied Workarounds: unpack_alignment_workaround_with_unpack_buffer*
* Framebuffer discarding can hurt performance on non-tilers: [570897](http://crbug.com/570897)
*Applied Workarounds: disable_discard_framebuffer*
* Unpacking overlapping rows from unpack buffers is unstable on NVIDIA GL driver: [596774](http://crbug.com/596774)
*Applied Workarounds: unpack_overlapping_rows_separately_unpack_buffer*
* Disable KHR_blend_equation_advanced until cc shaders are updated: [661715](http://crbug.com/661715)
*Applied Workarounds: disable(GL_KHR_blend_equation_advanced), disable(GL_KHR_blend_equation_advanced_coherent)*
* Expose WebGL's disjoint_timer_query extensions on platforms with site isolation: [808744](http://crbug.com/808744), [870491](http://crbug.com/870491)
*Applied Workarounds: enable_webgl_timer_query_extensions*
* glTexStorage* are buggy when base mipmap level is not 0: [877874](http://crbug.com/877874)
*Applied Workarounds: reset_base_mipmap_level_before_texstorage*
* Some drivers can't recover after OUT_OF_MEM and context lost: [893177](http://crbug.com/893177)
*Applied Workarounds: exit_on_context_lost*
* adjust src/dst region if blitting pixels outside framebuffer on Linux NVIDIA: [830046](http://crbug.com/830046)
*Applied Workarounds: adjust_src_dst_region_for_blitframebuffer*
* Disable GL_MESA_framebuffer_flip_y for desktop GL: [964010](http://crbug.com/964010)
*Applied Workarounds: disable(GL_MESA_framebuffer_flip_y)*
### Version Information
|Data exported|2021-11-07T12:39:41.536Z|
|Chrome version|Chrome/94.0.4606.114|
|Operating system|Linux 5.14.14-1-MANJARO|
|Software rendering list URL|https://chromium.googlesource.com/chromium/src/+/1d182193045c016c5079d6680d0137e3aca8533a/gpu/config/software_rendering_list.json|
|Driver bug list URL|https://chromium.googlesource.com/chromium/src/+/1d182193045c016c5079d6680d0137e3aca8533a/gpu/config/gpu_driver_bug_list.json|
|ANGLE commit id|unknown hash|
|2D graphics backend|Skia/94 bc94e71ede7c98dd5de2917bf01cbf38aba26e5a|
|Command Line|/usr/bin/vivaldi-stable --use-gl=desktop --enable-features=VaapiVideoDecoder --disable-features=UseOzonePlatform --enable-crashpad --flag-switches-begin --enable-gpu-rasterization --enable-zero-copy --ignore-gpu-blocklist --flag-switches-end --save-page-as-mhtml|
### Driver Information
|Initialization time|182|
|In-process GPU|false|
|Passthrough Command Decoder|false|
|Sandboxed|true|
|GPU0|VENDOR= 0x10de [NVIDIA Corporation], DEVICE=0x1c03 [NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2] *ACTIVE*|
|Optimus|false|
|AMD switchable|false|
|Driver vendor|Nvidia|
|Driver version|470.82.00|
|GPU CUDA compute capability major version|0|
|Pixel shader version|4.50|
|Vertex shader version|4.50|
|Max. MSAA samples|32|
|Machine model name||
|Machine model version||
|GL_VENDOR|NVIDIA Corporation|
|GL_RENDERER|NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2|
|GL_VERSION|4.5.0 NVIDIA 470.82.00|
|GL_EXTENSIONS|GL_AMD_multi_draw_indirect GL_AMD_seamless_cubemap_per_texture GL_AMD_vertex_shader_viewport_index GL_AMD_vertex_shader_layer GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_bindless_texture GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_clear_buffer_object GL_ARB_clear_texture GL_ARB_clip_control GL_ARB_color_buffer_float GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_compute_shader GL_ARB_compute_variable_group_size GL_ARB_conditional_render_inverted GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_cull_distance GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_derivative_control GL_ARB_direct_state_access GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_indirect GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_ES3_1_compatibility GL_ARB_ES3_2_compatibility GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_fragment_shader_interlock GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_get_texture_sub_image GL_ARB_gl_spirv GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_gpu_shader_int64 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_indirect_parameters GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multi_draw_indirect GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_parallel_shader_compile GL_ARB_pipeline_statistics_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_polygon_offset_clamp GL_ARB_post_depth_coverage GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_query_buffer_object GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_sample_locations GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counter_ops GL_ARB_shader_atomic_counters GL_ARB_shader_ballot GL_ARB_shader_bit_encoding GL_ARB_shader_clock GL_ARB_shader_draw_parameters GL_ARB_shader_group_vote GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_image_samples GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shader_viewport_layer_array GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_sparse_buffer GL_ARB_sparse_texture GL_ARB_sparse_texture2 GL_ARB_sparse_texture_clamp GL_ARB_spirv_extensions GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_barrier GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_filter_anisotropic GL_ARB_texture_filter_minmax GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transform_feedback_overflow_query GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_64bit GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_multiview_texture_multisample GL_EXT_multiview_timer_query GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_polygon_offset_clamp GL_EXT_post_depth_coverage GL_EXT_provoking_vertex GL_EXT_raster_multisample GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shader_image_load_formatted GL_EXT_shader_image_load_store GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_sparse_texture2 GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_filter_minmax GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shadow_lod GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_R8 GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback2 GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_vertex_attrib_64bit GL_EXT_window_rectangles GL_EXT_x11_sync_object GL_EXT_import_sync_object GL_NV_robustness_video_memory_purge GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KHR_context_flush_control GL_KHR_debug GL_EXT_memory_object GL_EXT_memory_object_fd GL_NV_memory_object_sparse GL_KHR_parallel_shader_compile GL_KHR_no_error GL_KHR_robust_buffer_access_behavior GL_KHR_robustness GL_EXT_semaphore GL_EXT_semaphore_fd GL_NV_timeline_semaphore GL_KHR_shader_subgroup GL_KTX_buffer_region GL_NV_alpha_to_coverage_dither_control GL_NV_bindless_multi_draw_indirect GL_NV_bindless_multi_draw_indirect_count GL_NV_bindless_texture GL_NV_blend_equation_advanced GL_NV_blend_equation_advanced_coherent GL_NVX_blend_equation_advanced_multi_draw_buffers GL_NV_blend_minmax_factor GL_NV_blend_square GL_NV_clip_space_w_scaling GL_NV_command_list GL_NV_compute_program5 GL_NV_conditional_render GL_NV_conservative_raster GL_NV_conservative_raster_dilate GL_NV_conservative_raster_pre_snap_triangles GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_draw_texture GL_NV_draw_vulkan_image GL_NV_ES1_1_compatibility GL_NV_ES3_1_compatibility GL_NV_explicit_multisample GL_NV_feature_query GL_NV_fence GL_NV_fill_rectangle GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_coverage_to_color GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_fragment_shader_interlock GL_NV_framebuffer_mixed_samples GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_geometry_shader_passthrough GL_NV_gpu_program4 GL_NV_internalformat_sample_query GL_NV_gpu_program4_1 GL_NV_gpu_program5 GL_NV_gpu_program5_mem_extended GL_NV_gpu_program_fp64 GL_NV_gpu_shader5 GL_NV_half_float GL_NV_light_max_exponent GL_NV_memory_attachment GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_path_rendering_shared_edge GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_query_resource GL_NV_query_resource_tag GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_sample_locations GL_NV_sample_mask_override_coverage GL_NV_shader_atomic_counters GL_NV_shader_atomic_float GL_NV_shader_atomic_float64 GL_NV_shader_atomic_fp16_vector GL_NV_shader_atomic_int64 GL_NV_shader_buffer_load GL_NV_shader_storage_buffer_object GL_NV_shader_subgroup_partitioned GL_NV_stereo_view_rendering GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_rectangle_compressed GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_transform_feedback2 GL_NV_uniform_buffer_unified_memory GL_NV_vdpau_interop GL_NV_vdpau_interop2 GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_attrib_integer_64bit GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NV_viewport_array2 GL_NV_viewport_swizzle GL_NVX_conditional_render GL_NV_gpu_multicast GL_NVX_progress_fence GL_NVX_gpu_memory_info GL_NVX_nvenc_interop GL_NV_shader_thread_group GL_NV_shader_thread_shuffle GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent GL_OVR_multiview GL_OVR_multiview2 GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum|
|Disabled Extensions|GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent GL_MESA_framebuffer_flip_y|
|Disabled WebGL Extensions||
|Window system binding vendor|NVIDIA Corporation|
|Window system binding version|1.4|
|Window system binding extensions|GLX_ARB_get_proc_address GLX_ARB_multisample GLX_EXT_visual_info GLX_EXT_visual_rating GLX_EXT_import_context GLX_SGI_video_sync GLX_SGIX_fbconfig GLX_SGIX_pbuffer GLX_SGI_swap_control GLX_EXT_swap_control GLX_EXT_swap_control_tear GLX_EXT_buffer_age GLX_ARB_create_context GLX_ARB_create_context_profile GLX_NV_float_buffer GLX_ARB_fbconfig_float GLX_EXT_texture_from_pixmap GLX_EXT_framebuffer_sRGB GLX_NV_copy_image GLX_EXT_create_context_es_profile GLX_EXT_create_context_es2_profile GLX_ARB_create_context_no_error GLX_ARB_create_context_robustness GLX_NV_delay_before_swap GLX_EXT_stereo_tree GLX_ARB_context_flush_control GLX_NV_robustness_video_memory_purge GLX_NV_multigpu_context|
|Direct rendering version|direct but version unknown|
|Reset notification strategy|0x8252|
|GPU process crash count|0|
|gfx::BufferFormats supported for allocation and texturing|R_8: not supported, R_16: not supported, RG_88: not supported, BGR_565: not supported, RGBA_4444: not supported, RGBX_8888: not supported, RGBA_8888: not supported, BGRX_8888: not supported, BGRA_1010102: not supported, RGBA_1010102: not supported, BGRA_8888: not supported, RGBA_F16: not supported, YVU_420: not supported, YUV_420_BIPLANAR: not supported, P010: not supported|
### Compositor Information
|Tile Update Mode|Zero-copy|
|Partial Raster|Enabled|
### GpuMemoryBuffers Status
|R_8|Software only|
|R_16|Software only|
|RG_88|Software only|
|BGR_565|Software only|
|RGBA_4444|Software only|
|RGBX_8888|Software only|
|RGBA_8888|Software only|
|BGRX_8888|Software only|
|BGRA_1010102|Software only|
|RGBA_1010102|Software only|
|BGRA_8888|Software only|
|RGBA_F16|Software only|
|YVU_420|Software only|
|YUV_420_BIPLANAR|Software only|
|P010|Software only|
### Display(s) Information
|Info|Display[1] bounds=[0,0 3440x1440], workarea=[0,0 3440x1440], scale=1, rotation=0, panel_rotation=0 external.|
|Color space (all)|{primaries:BT709, transfer:IEC61966_2_1, matrix:RGB, range:FULL}|
|Buffer format (all)|BGRA_8888|
|SDR white level in nits|100|
|Bits per color component|8|
|Bits per pixel|24|
|Refresh Rate in Hz|49|
### Video Acceleration Information
|Decoding (Legacy VideoDecodeAccelerator)||
|Decode h264 main|16x16 to 4096x4096 pixels|
|Decode h264 high|16x16 to 4096x4096 pixels|
|Encoding||
### Vulkan Information
### Device Performance Information
### Log Messages
* [181552:181552:1107/133611.634997:ERROR:gpu_init.cc(453)] : Passthrough is not supported, GL is desktop, ANGLE is
* [181552:181552:1107/133659.823689:ERROR:gles2_cmd_decoder.cc(18987)] : [.RendererMainThread-0x3500127e200]GL ERROR :GL_INVALID_OPERATION : DoBeginSharedImageAccessCHROMIUM: bound texture is not a shared image
* [181552:181552:1107/133659.824155:ERROR:gles2_cmd_decoder.cc(19016)] : [.RendererMainThread-0x3500127e200]GL ERROR :GL_INVALID_OPERATION : DoEndSharedImageAccessCHROMIUM: bound texture is not a shared image
This is my system:
ystem: Kernel: 5.14.14-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: awesome 4.3-1293-g2eb035e12 vt: 1
Machine: Type: Desktop Mobo: ASUSTeK model: Z170 PRO GAMING v: Rev X.0x serial: <filter> UEFI-[Legacy]: American Megatrends
v: 3805 date: 05/16/2018
CPU: Info: Quad Core model: Intel Core i7-6700K bits: 64 type: MT MCP arch: Skylake-S rev: 3 cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 64026
Speed: 800 MHz min/max: 800/4300 MHz Core speeds (MHz): 1: 800 2: 2764 3: 2390 4: 1666 5: 809 6: 800 7: 800 8: 800
Graphics: Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Gigabyte driver: nvidia v: 470.82.00 bus-ID: 01:00.0
chip-ID: 10de:1c03 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: picom v: git-dac85 driver: loaded: nvidia resolution: 3440x1440~50Hz
s-dpi: 109
OpenGL: renderer: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 470.82.00 direct render: Yes
Now i always start my browser via
also having the two plugins installed:
- Stadia enhanced
- enhanced-h264ify (default only allowing h264 and 60fps)
and the chrome://flags set as described in the several guides.
Everything above is the only combination working for me to achieve hardware-accelerated video decoding on youtube.
But as i start Stadia, Stadia enhanced only shows me
- “Software H264” if VP9 is disabled in enhanced-h264ify
- “Software VP9” if PV9 is not disabled in enhanced-h264ify
As you may notice, i dont know much about all of this and just want to play Stadia with good quality.
Does anyhone have a good advice for me what to try?
