Hi all,
I am wondering if I can install stacer on my Pinebook Pro ?
Trying to do so I get a message saying : stacer is not available for the ‘aarch64’ architecture.
Excuse my noob questions, I am fairly new to this. I am double checking if there isn’t a workaround.
Would there be an alternative to stacer for the Pinebook Pro ?
Thanks folks
Hello,
Have you checked this?
http://archive.raspbian.org/raspbian/pool/main/s/stacer/
Cool thanks.
Here is what I had done based on instructions I found on the net
git clone [LINK] aur archlinux org stacer.git
cd stacer
makepkg -si
which gave me
==> ERROR: stacer is not available for the ‘aarch64’ architecture.
can you walk me through how go about installing from your link?
You need to do something like this before makepkg -si
but not sure it will work tho … @Strit has definitely a good answer on the way
Looks easy enough. Here’s what you do:
- Git clone the AUR repo.
cd stacer
nano PKGBUILD
- Add
aarch64
to thearch=()
line. Save and close nano - run
makepkg -si
Ok, now I am in over my head …
I can imagine your time is shorthanded, however can you spell this out for me?
Ideally to something I can grab copy and paste
I did spell it out.
It’s even a point form guide.
The text in the code blocks
are commands or text in a file.
You did indeed …
here is what I am trying to do
[jens@Manjaro stacer]$ git clone [link] archive raspbian org/raspbian/pool/
main/s/stacer/
Cloning into ‘stacer’…
fatal: repository 'archive raspbian org/raspbian/pool/main/s/stacer/
’ not found
No. I said clone the AUR repo. Like you did the first time.
hm
getting the following
==> ERROR: Cannot find the fakeroot binary.
Please make sure you have all the packages installed, that is needed for building software.
sudo pacman -Syu base-devel --needed
@Strit thank you so much for your help and patience with me! I am learning step by step here. Above was the missing information needed to get Stacer up and running.
I need to make sure I honor all of your hard work with a donation !
