Latest update breaks sleep mode. Cannot get out of sleep mode, screen black , no keyboard response. I have remarked that when I enter sleep mode, the computer power led does not blink as before : maybe it cannot get into sleep mode after all and crash ?
Kernel: 5.15.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=95364f42-8a3e-44f9-a68c-ba2f4ef66b70 rw quiet apparmor=1
security=apparmor resume=UUID=5fa37652-10a5-40d9-9edf-0cba69b9e3c6
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Mobo: ASUSTeK model: TUF GAMING Z490-PLUS v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1208
date: 07/21/2020
Info: model: Intel Core i7-10700F bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 5 microcode: 0xEE
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 800 min/max: 800/4800 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800 15: 800 16: 800
bogomips: 92838
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: AMD Navi 14 [Radeon RX 5500/5500M / Pro 5500M] vendor: ASUSTeK
driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-3 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:7340
class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.1
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
alternate: fbdev,vesa gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.00x22.48")
s-diag: 1165mm (45.88")
Monitor-1: DP-3 mapped: DisplayPort-2 model: BenQ SW271 serial: <filter>
built: 2020 res: 3840x2160 hz: 60 dpi: 163 gamma: 1.2
size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9 modes:
max: 3840x2160 min: 720x400
OpenGL: renderer: AMD Radeon RX 5500 XT (navi14 LLVM 13.0.1 DRM 3.42
5.15.38-1-MANJARO)
v: 4.6 Mesa 22.0.3 direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
chip-ID: 8086:06c8 class-ID: 0403
Device-2: AMD Navi 10 HDMI Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1
chip-ID: 1002:ab38 class-ID: 0403
Sound Server-1: ALSA v: k5.15.38-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
type or paste code here
provide also logs:
journalctl --boot=0 --priority=3 --no-pager
and try switch kernels for example to 5.17-6.1 and try with it
Output of this command :
mai 19 13:01:30 antares kernel: x86/cpu: SGX disabled by BIOS.
mai 19 13:01:30 antares kernel: Spectre V2 : WARNING: Unprivileged eBPF is enabled with eIBRS on, data leaks possible via Spectre v2 BHB attacks!
mai 19 13:01:30 antares systemd-udevd[379]: /etc/udev/rules.d/40-libsane.rules:26: GOTO="libsane_rules_end" has no matching label, ignoring
mai 19 13:01:30 antares systemd-udevd[379]: /etc/udev/rules.d/S99-2000S1.rules:26: GOTO="libsane_rules_end" has no matching label, ignoring
mai 19 13:01:31 antares colord-sane[680]: io/hpmud/musb.c 2099: Invalid usb_open: Permission denied
mai 19 13:01:32 antares colord-sane[1016]: io/hpmud/musb.c 2099: Invalid usb_open: Permission denied
mai 19 13:01:32 antares colord-sane[1067]: io/hpmud/musb.c 2099: Invalid usb_open: Permission denied
mai 19 13:03:19 antares pulseaudio[1395]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
mai 19 13:09:35 antares nm-openvpn[1920]: event_wait : Interrupted system call (code=4)
mai 19 14:33:23 antares sudo[3286]: claude : a password is required ; PWD=/home/claude ; USER=root ; COMMAND=/usr/sbin/uptime
mai 19 16:33:11 antares systemd-coredump[7522]: Process 7520 (launcher) of user 2000 dumped core.
Module /home/claude/.local/share/Steam/steamapps/common/War Thunder/launcher with build-id b61b1525eafa7fb958190342361094a1fcf0d654
Module /home/claude/.local/share/Steam/steamapps/common/War Thunder/libsciter-gtk.so with build-id a758b61c42b151d9f2ba658a5c9d8ada9e5a51d3
Module /home/claude/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so with build-id 2d83da4b165e02f4a1a28244e9badc34e115f061
Module linux-vdso.so.1 with build-id d3d3a1ec103a73e5e70f3a001cc6ee89a7e7deb9
Module libasound.so.2 with build-id b17fc1317a484842433c772360376623b64ec3d8
Module libcanberra-alsa.so with build-id 7feabc16799411290c44cc741ff4c69363a4b691
Module libopus.so.0 with build-id 35fafc4024675e9cfe57c7d50c3965eac6bac358
Module libFLAC.so.8 with build-id d3c01b1bab8e878ff3928ba64a5817506bad1aa6
Module libvorbisenc.so.2 with build-id 2b1ce7fcdcc925bc663ebe2c1c008c0dd96e5bd0
Module libasyncns.so.0 with build-id 6acff139d56b5139ce5eb50a66c62b215e1d332d
Module libsndfile.so.1 with build-id 407b2376cac1726631e3f7360a9337901be04ec0
Module libpulsecommon-15.0.so with build-id 1ff39f66b974fdf20be485f556b48ff4e6c33868
Module libpulse.so.0 with build-id b145e13bdb30c8327de7882ec9976fab38bc3e4a
Module libcanberra-pulse.so with build-id b5f3de06f296ad48cbcedce6946078916e1ec832
Module libcanberra-multi.so with build-id aca2d2a2b14920a199b728844c92dcf8d61a3480
Module libcolorreload-gtk-module.so with build-id aaf7cdbd6e1519bad2445c15a6d220bfdde7c0c6
Module libgvfscommon.so with build-id 5c6df2952527d8d19cfb9ba14ceb290a15d186f8
Module libgvfsdbus.so with build-id 2529d3764be816acfea14bd80db2c56c2cb7f024
Module libogg.so.0 with build-id ca0cae30a809f10db1f16e54a23b4e5ff7b2c54c
Module libvorbis.so.0 with build-id f4e086347f6c1a66eb73cfe13974a29bd39aabca
Module libltdl.so.7 with build-id d2c1c93609da7fc11a1c40381fea72634ad714ed
Module libtdb.so.1 with build-id 6c9ccf6d9a22d117d984d1666842a49fd7669f09
Module libvorbisfile.so.3 with build-id 45d2551167a616d448beb033ba49394831992887
Module libcanberra.so.0 with build-id 8ddef69c9b84a86062c88a59510639cd908fc6d3
Module libcanberra-gtk3.so.0 with build-id 2e99c78f79bea4bc67ccd9a9f8fed562f89599ee
Module libcanberra-gtk-module.so with build-id cc626937222c6ce3f7bb45dbe6e862d0b1efba01
Module libxkbfile.so.1 with build-id de5e415879c20263a8dd42f8cf2dd88107c2bfb2
Module libxklavier.so.16 with build-id cefd678b3d270e389f50a9686ad2db83a8c67494
Module libgnomekbd.so.8 with build-id 7a75c84337b94141ae6bdf56da86a5a6f72343bf
Module libgnomekbdui.so.8 with build-id eeb3039b3aa71b38849fb1b3d2e97acb9edab6d4
Module libxapp.so.1 with build-id 2d6867c3b087052ef8acd12a1a6c82b3c62b8f36
Module libxapp-gtk3-module.so with build-id 12b94957cbe0eb705d8e900c9006d5333846d4db
Module libnss_myhostname.so.2 with build-id fa3a6a8e479ed09d471832987b4510e6b3989cbb
Module libnss_resolve.so.2 with build-id 68dbf45b805b3ec7f46555032c6c8296c2072ef1
Module libresolv.so.2 with build-id 46ffdf3d477a170314060c26927470d7399bc900
Module libnss_mdns4_minimal.so.2 with build-id a6fde528b667185a18aca5be61727fb369423647
Module libnss_mymachines.so.2 with build-id 39e1b692e7c94a03eee1e7c114a552ddac8ef916
Module libgpg-error.so.0 with build-id f9aaa96d5ddf6f6872051ed7abcdfe6bdaff9b1c
Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
Module libcap.so.2 with build-id 21b00ab76bb16fde56fd741f07233c78069f0579
Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
Module libicudata.so.71 with build-id 4fef196388e678deb881978139e125e20ee2d94d
Module libsystemd.so.0 with build-id cdfc45d8f96e3af51b3d041c32f7899a93b86706
Module liblzma.so.5 with build-id 28b40c7af8098a66af6ee093b6986b91cad7694d
Module libzstd.so.1 with build-id 3bccb8fe08e48d5ea135b1d0f99de0d771dd752f
Module libbrotlidec.so.1 with build-id 66c54e9301f7e102ecc1d88547e5f0e8a056fe22
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libdatrie.so.1 with build-id 6fe3b6ece2c8e7d11869fa051375128d8f808f58
Module libblkid.so.1 with build-id 140694a62d8d4d07c6c320a501f948dd1b389d73
Module libxml2.so.2 with build-id 6b0ec2acdbc8f1a2255cc5e3e1258472cd99e272
Module libjson-glib-1.0.so.0 with build-id 58decebd2c409d59b07f926ae4c513281918bc4d
Module libsqlite3.so.0 with build-id a72506b3923739d1974e02062460a2720d4b3958
Module libicui18n.so.71 with build-id 6fd5c97fd2808ee29958bf809656d5885e7e8963
Module libicuuc.so.71 with build-id 633fdc0c5385d916571f6140e7a978ad0630ef55
Module libstemmer.so.0 with build-id 013b48e71279a5ec55e3021fc0bd8fb10a08bae5
Module libatspi.so.0 with build-id 87bca381f073faea3b0ffd1ab06f5f8f204e24cf
Module libdbus-1.so.3 with build-id 7f4b16b4b407cbae2d7118d6f99610e29a18a56a
Module libtiff.so.5 with build-id 9e8868622f8b7144fd82dabfa8ac2fcaf6d45a34
Module libjpeg.so.8 with build-id 324d9d66f01707241e31af5cc104db3c9122f4c4
Module libexpat.so.1 with build-id 113bb5a3e9ad856801bfcfc029102c9bdc13d67e
Module libpixman-1.so.0 with build-id 341f793dcada3a48a306a793d265a517e3f2e7d6
Module libxcb-shm.so.0 with build-id 828fec4d856e2710e732ea8d92c3f250c807b1c2
Module libxcb-render.so.0 with build-id b1ca498d665807ab0ccdafbe8070853efd058173
Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Module libgraphite2.so.3 with build-id 47761dc11e553f519cde97ed9ee985be12ccdae2
Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
Module libthai.so.0 with build-id a7ac5010b4275c49308021200d23690533952702
Module libXdmcp.so.6 with build-id 8ca0792d23c8b8b4c0864297512349292bea5955
Module libXau.so.6 with build-id 1c67764663e07bec24d8951e5fd93f4d165979ff
Module libGLX.so.0 with build-id 02bd4ac6acc4da9288c543ea1a0cdaa70c5e151a
Module libGLdispatch.so.0 with build-id de981c020bd9dbdc159b11f4a2a541310cc3b8d5
Module libXinerama.so.1 with build-id dbb6adece34ea2766d3efcd628af8f9757344dd6
Module libXcomposite.so.1 with build-id f1bb5ffb6203ab2907ac044a204ce3902a79f1c1
Module libXdamage.so.1 with build-id a1d867e093c16944b2c0083be98050ef35c9e5c2
Module libXcursor.so.1 with build-id f0525ae3715ac95f96a8cdb44795b03f831334b0
Module libwayland-egl.so.1 with build-id ac45e227422559ff92c4d04851fffb8452874713
Module libwayland-cursor.so.0 with build-id 647d92328111682fb15bff1c20a4c9368414857c
Module libwayland-client.so.0 with build-id 95e7368b400dd57e3db2a5c385de71c7dca08879
Module libxkbcommon.so.0 with build-id 3a9338b2085f0af41217bc0a90ffcc941938a16e
Module libmount.so.1 with build-id 4436aeea0cd8c01b5a77969e0531184f8b3513ce
Module libz.so.1 with build-id fefe3219a96d682ec98fcfb78866b8594298b5a2
Module libffi.so.8 with build-id f0a9586cf0f42d2b9971bd1065ca3a6b19f4a2c2
Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
Module libtracker-sparql-3.0.so.0 with build-id d03c91051f78975ac3f1d4732d1fecf70b32e709
Module libcloudproviders.so.0 with build-id ed1d9c9e60be4e858ad148484767249be1edf95f
Module libatk-bridge-2.0.so.0 with build-id 1161ebbcc5aa791075dfa026671875e5417287bd
Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
Module libepoxy.so.0 with build-id edc178a150c4255d124e1e1ecbdbecebd1a388cd
Module libatk-1.0.so.0 with build-id c2de8b4fcbd9681cef225fe3956a9608a2a664bb
Module libgdk_pixbuf-2.0.so.0 with build-id 5b8422ab971b1a8a8e1c43b88738d4ee217f609e
Module libcairo-gobject.so.2 with build-id 9927090dddfb180365695a8f37d1cac89463f109
Module libfribidi.so.0 with build-id fe9f35ac2a0074108c8306c517793f7279bd9b37
Module libfontconfig.so.1 with build-id 36be6951b8c1e42a7dd05684a37400fc8ef9147c
Module libpangoft2-1.0.so.0 with build-id c2c09f789578900f61b7fca4a4311d8b94d9a750
Module libcairo.so.2 with build-id a222d042e56108d2786ece7bf291b56ba2069591
Module libharfbuzz.so.0 with build-id a11faa61f71b258fb92b717723757fc7dd141c01
Module libpango-1.0.so.0 with build-id 7e27c1e46a1d958f6b16e1ba199f8bdb3f100566
Module libpangocairo-1.0.so.0 with build-id b65f507d9e33adfbd19369acef5e5a0a2422c6d1
Module libgmodule-2.0.so.0 with build-id c6df28882f153ee03d0fb33bb8aac2b219ebaacc
Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
Module libXrender.so.1 with build-id 97e0b9ab6ba96ebc86527cc2b3c3078aad8616b3
Module libXext.so.6 with build-id d70f24beb4fad748d6becffdcc13e51be0a2ebfa
Module libGL.so.1 with build-id b915a2e48be6c9fd3cc6f9f4c7aab1f7aeed8a4c
Module ld-linux-x86-64.so.2 with build-id c09c6f50f6bcec73c64a0b4be77eadb8f7202410
Module libc.so.6 with build-id 85766e9d8458b16e9c7ce6e07c712c02b8471dbc
Module libgcc_s.so.1 with build-id 5d817452a709ca3a213341555ddcf446ecee37fa
Module libm.so.6 with build-id 596b63a006a4386dcab30912d2b54a7a61827b07
Module libstdc++.so.6 with build-id 88ad4eff81a00c684abfe0f863e87434123d8943
Module libgdk-3.so.0 with build-id a5ab221b5bcc72cfbe848530bb952bddccccc654
Module libgio-2.0.so.0 with build-id 8c411770513e0bc758a1bbe661af14c972e2a3c4
Module libgobject-2.0.so.0 with build-id 4337ec84b2f33ec39a95863d47bfca0a28afd488
Module libglib-2.0.so.0 with build-id e268e80e668ce871312cf50e9969f88b086e33f2
Module libgtk-3.so.0 with build-id 650fd204299b7ee234f3152032bbc8ebc54a7e1d
Module libX11.so.6 with build-id d8e0be8e0323aa421366f19065ecd1c76405c130
Module libdl.so.2 with build-id bb9bd2657bfba9f60bd34d2050cc63a7eb024bc4
Module libpthread.so.0 with build-id 7fa8b52fae071a370ba4ca32bf9490a30aff31c4
Module librt.so.1 with build-id 4761858b348db8303e872e515aa8d56c046c921c
Module libXrandr.so.2 with build-id d4e869b5c72541e1de8f96b456248987ea52d51b
Stack trace of thread 7520:
#0 0x00007f514be3334c __pthread_kill_implementation (libc.so.6 + 0x8f34c)
#1 0x00007f514bde64b8 raise (libc.so.6 + 0x424b8)
#2 0x00007f514bdd0534 abort (libc.so.6 + 0x2c534)
#3 0x00007f514be27397 __libc_message (libc.so.6 + 0x83397)
#4 0x00007f514be3d33c malloc_printerr (libc.so.6 + 0x9933c)
#5 0x00007f514be3ddbc unlink_chunk.constprop.0 (libc.so.6 + 0x99dbc)
#6 0x00007f514be3df65 malloc_consolidate (libc.so.6 + 0x99f65)
#7 0x00007f514be40103 _int_malloc (libc.so.6 + 0x9c103)
#8 0x00007f514be41629 __libc_malloc (libc.so.6 + 0x9d629)
#9 0x00007f514bed3479 __check_pf (libc.so.6 + 0x12f479)
#10 0x00007f514be9f7c3 getaddrinfo (libc.so.6 + 0xfb7c3)
#11 0x0000000000ec874b n/a (/home/claude/.local/share/Steam/steamapps/common/War Thunder/launcher + 0xac874b)
#12 0x0000000000ec9138 n/a (/home/claude/.local/share/Steam/steamapps/common/War Thunder/launcher + 0xac9138)
#13 0x00000000007bfff3 n/a (/home/claude/.local/share/Steam/steamapps/common/War Thunder/launcher + 0x3bfff3)
#14 0x00000000007c1e79 n/a (/home/claude/.local/share/Steam/steamapps/common/War Thunder/launcher + 0x3c1e79)
#15 0x00000000006991ab n/a (/home/claude/.local/share/Steam/steamapps/common/War Thunder/launcher + 0x2991ab)
#16 0x0000000000661511 n/a (/home/claude/.local/share/Steam/steamapps/common/War Thunder/launcher + 0x261511)
#17 0x00000000007c5aec n/a (/home/claude/.local/share/Steam/steamapps/common/War Thunder/launcher + 0x3c5aec)
#18 0x0000000000b70bbb n/a (/home/claude/.local/share/Steam/steamapps/common/War Thunder/launcher + 0x770bbb)
#19 0x0000000000b70e41 n/a (/home/claude/.local/share/Steam/steamapps/common/War Thunder/launcher + 0x770e41)
#20 0x0000000000b70f96 n/a (/home/claude/.local/share/Steam/steamapps/common/War Thunder/launcher + 0x770f96)
#21 0x00007f514bde6560 __restore_rt (libc.so.6 + 0x42560)
#22 0x00007f514bde837d getenv (libc.so.6 + 0x4437d)
#23 0x00007f513c309df9 pa_in_valgrind (libpulsecommon-15.0.so + 0x24df9)
#24 0x00007f513c37c02e n/a (libpulse.so.0 + 0xd02e)
#25 0x00007f514d107c8e _dl_fini (ld-linux-x86-64.so.2 + 0x5c8e)
#26 0x00007f514bde8c05 __run_exit_handlers (libc.so.6 + 0x44c05)
#27 0x00007f514bde8d80 exit (libc.so.6 + 0x44d80)
#28 0x00007f514bdd1317 __libc_start_call_main (libc.so.6 + 0x2d317)
#29 0x00007f514bdd13c1 __libc_start_main@@GLIBC_2.34 (libc.so.6 + 0x2d3c1)
#30 0x0000000000654235 n/a (/home/claude/.local/share/Steam/steamapps/common/War Thunder/launcher + 0x254235)
mai 19 16:54:27 antares systemd-coredump[8303]: Process 7429 (aces) of user 2000 dumped core.
Module /home/claude/.local/share/Steam/steamapps/common/War Thunder/linux64/aces with build-id 75841618b2ac2aae2d380a896f297606da1cba79
Module libXrandr.so with build-id d4e869b5c72541e1de8f96b456248987ea52d51b
Module libncursesw.so.6 with build-id b9917757481e6fa6097e2a1f31f5bb5eaf138c4e
Module libedit.so.0 with build-id 4b0babfcad161c2ad0af6e59e2493258db23a331
Module libLLVM-13.so with build-id 76d1fe97dbdca6d6891c6a1a7c06a388aa247154
Module UTF-32.so with build-id 3adc4549f915681bbafce32e22ddd79eb1ef7e89
Stack trace of thread 7429:
#0 0x00007f223bc5837d getenv (libc.so.6 + 0x4437d)
#1 0x00007f21fc047df9 pa_in_valgrind (libpulsecommon-15.0.so + 0x24df9)
#2 0x00007f21fc0ba02e n/a (libpulse.so.0 + 0xd02e)
#3 0x00007f223c363c8e _dl_fini (ld-linux-x86-64.so.2 + 0x5c8e)
#4 0x00007f223bc58c05 __run_exit_handlers (libc.so.6 + 0x44c05)
#5 0x00007f223bc58d80 exit (libc.so.6 + 0x44d80)
#6 0x0000000001562c72 n/a (/home/claude/.local/share/Steam/steamapps/common/War Thunder/linux64/aces + 0x1162c72)
#7 0x0000000000936171 n/a (/home/claude/.local/share/Steam/steamapps/common/War Thunder/linux64/aces + 0x536171)
#8 0x0000000001573e35 n/a (/home/claude/.local/share/Steam/steamapps/common/War Thunder/linux64/aces + 0x1173e35)
#9 0x00000000017182fd n/a (/home/claude/.local/share/Steam/steamapps/common/War Thunder/linux64/aces + 0x13182fd)
#10 0x000000000093e615 n/a (/home/claude/.local/share/Steam/steamapps/common/War Thunder/linux64/aces + 0x53e615)
#11 0x00000000004200b4 n/a (/home/claude/.local/share/Steam/steamapps/common/War Thunder/linux64/aces + 0x200b4)
#12 0x00007f223bc41310 __libc_start_call_main (libc.so.6 + 0x2d310)
#13 0x00007f223bc413c1 __libc_start_main@@GLIBC_2.34 (libc.so.6 + 0x2d3c1)
#14 0x0000000000497f1a n/a (/home/claude/.local/share/Steam/steamapps/common/War Thunder/linux64/aces + 0x97f1a)
Stack trace of thread 8292:
#0 0x00007f223bc9e15a __futex_abstimed_wait_common (libc.so.6 + 0x8a15a)
#1 0x00007f223bca0c64 pthread_cond_timedwait@@GLIBC_2.3.2 (libc.so.6 + 0x8cc64)
#2 0x00007f223bcaab28 handle_fildes_io (libc.so.6 + 0x96b28)
#3 0x00007f223bca15c2 start_thread (libc.so.6 + 0x8d5c2)
#4 0x00007f223bd26584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 8300:
i’ll try to switch kernel
Tried Kernel 5.17.6.
Kernel: 5.17.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
udev.log_priority=3
Seems to work (I tried just once) ! I will retry several time today and report the result here in order to see if it has a reproducible correct behavior.
No idea why changing the kernel from 5.15 to 5.17 makes the problem disappear…
THX !
BG405
21 May 2022 02:59
5
The drivers tend to be included with the kernel. I’ve seen improvements and regressions with different kernel versions (I can’t use the previous LTS 5.10 (IIRC) due to trackpad issues, which also prevent the laptop from entering sleep state). The current ones I’m at least able to use my “workaround” with. 5.17 seems to work better for me, at least.
