Basically, a USB device is creating some problem here. Can anybody help me in debugging this? I think that this is the Bluetooth device…
inxi -v8 output here
~ inxi -v8 ✔
Host: ramoth Kernel: 6.12.20-2-MANJARO arch: x86_64 bits: 64 compiler: gcc
v: 14.2.1 clocksource: tsc avail: hpet,acpi_pm
root=UUID=51a3a5b3-a6d6-456e-bbe3-935c914bd2fe rw rootflags=subvol=@
Desktop: GNOME v: 48.0 tk: GTK v: 3.24.49 wm: gnome-shell
base: Arch Linux
Type: Desktop Mobo: N/A model: HX90 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: 5.19
date: 10/11/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
serial: 00-00-00-00 charge: 55% (should be ignored) rechargeable: yes
status: discharging
System RAM: total: 32 GiB available: 30.77 GiB used: 6.06 GiB (19.7%)
(unregistered) size: 16 GiB speed: 3200 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Kingston
part-no: CBD32D4S2S8MF-16 serial: FD9C42F5
part-no: CBD32D4S2S8MF-16 serial: FF9C48CF
Info: model: AMD Ryzen 9 5900HX with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22
microcode: 0xA500011
desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1099 min/max: 400/4680 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1099 2: 1099 3: 1099
4: 1099 5: 1099 6: 1099 7: 1099 8: 1099 9: 1099 10: 1099 11: 1099 12: 1099
13: 1099 14: 1099 15: 1099 16: 1099 bogomips: 105449
vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
xtopology
affected
Device-1: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
Radeon Mobile Series] driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1,HDMI-A-2
empty: DP-1,DP-2 bus-ID: 04:00.0 chip-ID: 1002:1638 class-ID: 0300
temp: 39.0 C
Device-2: Creative Live! Cam Sync 1080p V2 driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2.1:4
chip-ID: 041e:40a0 class-ID: 0102 serial: Creative Live! Cam Sync 1080p
V2 Audio
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
Monitor-1: HDMI-A-1 model: BenQ LCD serial: 65N01873019 built: 2022
res: 2560x1440 dpi: 123 gamma: 1.2 chroma: red: x: 0.663 y: 0.333 green:
x: 0.298 y: 0.631 blue: x: 0.145 y: 0.051 white: x: 0.314 y: 0.329
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9
modes: 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1600x900,
1280x1024, 1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 832x624,
800x600, 720x576, 720x480, 640x480, 720x400
Monitor-2: HDMI-A-2 model: LG (GoldStar) IPS224 built: 2011 res: 1920x1080
dpi: 102 gamma: 1.2 chroma: red: x: 0.631 y: 0.349 green: x: 0.341 y: 0.624
blue: x: 0.153 y: 0.055 white: x: 0.314 y: 0.329
size: 477x268mm (18.78x10.55") diag: 547mm (21.5") ratio: 16:9
modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800, 1152x864,
1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.2-arch1.2
renoir ACO DRM 3.61 6.12.20-2-MANJARO) device-ID: 1002:1638
memory: 500 MiB unified: no display-ID: :0.0
Info: Tools: api: clinfo, eglinfo, glxinfo gpu: amd-smi x11: xprop,xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
Audio driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.5 chip-ID: 1022:15e2
class-ID: 0480
vendor: Realtek driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6
chip-ID: 1022:15e3 class-ID: 0403
Device-4: C-Media Audio Adapter (Unitek Y-247A)
driver: cmedia_hs100b,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 0d8c:0014 class-ID: 0300
Device-5: Creative Live! Cam Sync 1080p V2 driver: snd-usb-audio,uvcvideo
V2 Audio
API: ALSA v: k6.12.20-2-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.1 status: off with: pipewire-media-session
status: active tools: pw-cat,pw-cli
Server-4: PulseAudio v: 17.0-43-g3e2bb status: active
with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
Device-1: Intel Ethernet I225-V driver: igc v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 02:00.0 chip-ID: 8086:15f3
class-ID: 0200
IF: eno1 state: up speed: 1000 Mbps duplex: full mac: 1c:83:41:29:f5:5a
IP v4: 192.168.1.122/24 type: dynamic noprefixroute scope: global
broadcast: 192.168.1.255
IP v6: fe80::cf88:48e3:3bff:cba9/64 type: noprefixroute scope: link
Device-2: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 14c3:0608
class-ID: 0280
IF: wlp3s0 state: down mac: 7e:0b:8f:33:54:d8
IF-ID-1: gpd0 state: down mac: N/A
Info: services: httpd, NetworkManager, sshd, systemd-timesyncd,
wpa_supplicant
WAN IP: 80.26.183.247
Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 0e8d:0608
class-ID: e001 serial: 000000000
Local Storage: total: 3.64 TiB used: 1.62 TiB (44.5%)
model: WD Green SN350 2TB size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD serial: 21462F800730
fw-rev: 33006000 temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LX001-1RG174
tech: HDD rpm: 5400 serial: WDZBQLPG fw-rev: SDM1 scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.02 TiB (55.8%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 51a3a5b3-a6d6-456e-bbe3-935c914bd2fe
used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 37FC-2E88
ID-3: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 1.02 TiB (55.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 51a3a5b3-a6d6-456e-bbe3-935c914bd2fe
ID-4: /mnt/data raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 618.95 GiB (33.8%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: data
uuid: 22ba0a6a-ff75-47be-a46b-5b76e6f3e011
ID-5: /swap raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
ID-6: /var/cache raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
ID-7: /var/log raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
ID-1: swap-1 type: file size: 32 GiB used: 0 KiB (0.0%) priority: -2
file: /swap/swapfile
Device-1: 1-1:2 info: C-Media Audio Adapter (Unitek Y-247A)
type: audio,HID driver: cmedia_hs100b,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
Hub-2: 1-2:3 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2817
Device-1: 1-2.1:4 info: Creative Live! Cam Sync 1080p V2 type: video,audio
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 256mA
V2 Audio
Hub-3: 1-2.2:5 info: Genesys Logic USB 1.1 Hub ports: 4 rev: 1.0
chip-ID: 05e3:0604 class-ID: 0900
Device-1: 1-2.2.1:6 info: Logitech Nano Receiver type: keyboard,mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c534 class-ID: 0301
Device-2: 1-2.2.2:7 info: Trust Wireless Mouse type: mouse
lanes: 1 mode: 1.1 power: 100mA chip-ID: 145f:0263 class-ID: 0301
Hub-4: 2-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-5: 2-2:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0817
Hub-6: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-7: 3-2:2 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
Device-1: 3-4:3 info: MediaTek Wireless_Device type: bluetooth
mode: 2.0 power: 100mA chip-ID: 0e8d:0608 class-ID: e001 serial: 000000000
Hub-8: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-9: 4-2:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1
System Temperatures: cpu: 48.2 C mobo: 36.0 C gpu: amdgpu temp: 38.0 C
Fan Speeds (rpm): N/A
Packages: 2476 pm: pacman pkgs: 2406 libs: 522
tools: gnome-software,pamac,yay pm: flatpak pkgs: 56 pm: snap pkgs: 14
1: https://manjaro.kurdy.org/stable/$repo/$arch
2: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
3: https://mirror.23m.com/manjaro/stable/$repo/$arch
4: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
5: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
6: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
Processes:
CPU top: 5 of 432
1: cpu: 28.7% command: onedrive pid: 4503 mem: 141.6 MiB (0.4%)
2: cpu: 17.6% command: localsearch-extractor-3 pid: 11631
mem: 38.0 MiB (0.1%)
3: cpu: 10.2% command: gnome-shell pid: 2236 mem: 351.9 MiB (1.1%)
4: cpu: 7.0% command: firefox pid: 8595 mem: 721.8 MiB (2.2%)
5: cpu: 5.8% command: thunderbird pid: 6121 mem: 685.4 MiB (2.1%)
Memory top: 5 of 432
1: mem: 721.8 MiB (2.2%) command: firefox pid: 8595 cpu: 7.0%
2: mem: 685.4 MiB (2.1%) command: thunderbird pid: 6121 cpu: 5.8%
3: mem: 603.3 MiB (1.9%) command: firefox pid: 8800 cpu: 1.3%
4: mem: 470.8 MiB (1.4%) command: firefox pid: 9195 cpu: 5.4%
5: mem: 387.8 MiB (1.2%) command: celluloid pid: 11214 cpu: 3.8%
Processes: 432 Power: uptime: 16m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.29 GiB services: gsd-power,
tool: systemctl
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.37
