Everything seems to work again on wayland
Please do not post AUR problems in the update topic.
Qspectrumanalyzer has been thoroughly debugged in another topic - it is abandoned since years and can be made only halfway working as of now. Use the forum search.
Now back on the update topic:
@philm My 2 cents on the reported issues.
XFCE, X11, Kernel 6.6
inxi
inxi -zv8
Kernel: 6.6.54-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=cf8b53ae-432d-4976-a363-214a6ecc9d84 rw udev.log_priority=3
mem_sleep_default=s2idle resume=UUID=600cb33a-5cd6-4a40-85cd-75ad77b2d095
sysrq_always_enabled=1 nowatchdog modprobe.blacklist=iTCO_wdt
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: light-locker vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: LENOVO product: 82QY v: Lenovo V15 G2 IJL
serial: <superuser required> Chassis: type: 10 v: Lenovo V15 G2 IJL
Mobo: LENOVO model: LNVNB161216 v: SDK0T76465 WIN
serial: <superuser required> part-nu: LENOVO_MT_82QY_BU_idea_FM_V15 G2 IJL
uuid: <superuser required> UEFI: LENOVO v: HTCN42WW date: 07/15/2024
ID-1: BAT0 charge: 30.5 Wh (79.4%) condition: 38.4/38.0 Wh (101.0%)
volts: 8.0 min: 7.7 model: Celxpert L20C2PF0 type: Li-poly serial: <filter>
status: not charging cycles: 14
System RAM: total: 8 GiB available: 7.57 GiB used: 3.1 GiB (41.0%)
Array-1: capacity: 32 GiB slots: 1 modules: 1 EC: None
Device-1: Controller0-ChannelB type: DDR4 detail: synchronous size: 8 GiB
speed: 2933 MT/s volts: curr: 1 width (bits): data: 64 total: 64
manufacturer: Samsung part-no: M471A1G44BB0-CWE serial: <filter>
Info: model: Intel Pentium Silver N6000 bits: 64 type: MCP arch: Alder Lake
level: v2 built: 2021+ process: Intel 7 (10nm ESF) family: 6
model-id: 0x9C (156) stepping: 0 microcode: 0x24000026
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 smt: <unsupported> cache:
L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1.5 MiB desc: 1x1.5 MiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 762 min/max: 800/3300 scaling: driver: intel_pstate
governor: powersave cores: 1: 762 2: 762 3: 762 4: 762 bogomips: 8912
Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_capabilities
arch_perfmon art bts cat_l2 cdp_l2 clflush clflushopt clwb cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept ept_ad erms est flexpriority flush_l1d fpu fsgsbase fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri
msr mtrr nonstop_tsc nopl nx pae pat pbe pclmulqdq pdcm pebs pge pln pni
popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep
sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip vme vmx vnmi vpid waitpkg x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: SW loop, KVM:
SW loop
Type: srbds status: Vulnerable: No microcode
Device-1: Intel JasperLake [UHD Graphics] vendor: Lenovo driver: i915
v: kernel arch: Gen-11 process: Intel 10nm built: 2019-21 ports:
active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:4e71
class-ID: 0300
Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:2 chip-ID: 13d3:56ff
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.13 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x08d5 built: 2019 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 chroma: red: x: 0.576 y: 0.361 green: x: 0.349
y: 0.576 blue: x: 0.165 y: 0.125 white: x: 0.314 y: 0.329
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
modes: 1920x1080
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.4-arch1.0.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (JSL)
device-ID: 8086:4e71 memory: 3.7 GiB unified: yes
API: Vulkan v: 1.3.295 layers: 4 device: 0 type: integrated-gpu name: Intel
UHD Graphics (JSL) driver: mesa intel v: 24.2.4-arch1.0.1
device-ID: 8086:4e71 surfaces: xcb,xlib
Device-1: Intel Jasper Lake HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_icl bus-ID: 00:1f.3
chip-ID: 8086:4dc8 class-ID: 0403
API: ALSA v: k6.6.54-2-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 6 AX201 160MHz driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:4df0 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:3
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 5.1
lmp-v: 10 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 238.47 GiB used: 89.06 GiB (37.3%)
model: MZAL4256HBJD-00BL2 size: 238.47 GiB block-size: physical: 512 B
fw-rev: 7L1QHXC7 temp: 32.9 C scheme: GPT
ID-1: / raw-size: 147.39 GiB size: 144.52 GiB (98.05%)
used: 89.06 GiB (61.6%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: cf8b53ae-432d-4976-a363-214a6ecc9d84
ID-2: /boot/efi raw-size: 270 MiB size: 269.5 MiB (99.80%)
used: 2.2 MiB (0.8%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: C557-4CD1
ID-1: swap-1 type: partition size: 11.23 GiB used: 512 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
uuid: 600cb33a-5cd6-4a40-85cd-75ad77b2d095
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 260 MiB fs: vfat label: SYSTEM_DRV
uuid: 56D9-9BAC
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 77.36 GiB fs: ntfs
label: Windows-SSD uuid: 10F2DBB4F2DB9C72
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 1.95 GiB fs: ntfs
label: WINRE_DRV uuid: 0EAEDD7CAEDD5D31
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 8 rev: 2.0
Device-1: 1-7:2 info: IMC Networks Integrated Camera type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 13d3:56ff class-ID: 0e02
Device-2: 1-8:3 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
System Temperatures: cpu: 54.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: 2434 pm: pacman pkgs: 2385 libs: 525 tools: octopi,pamac,yay
pm: flatpak pkgs: 49
1: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 234
1: cpu: 24.5% command: chromium pid: 2627 mem: 145.2 MiB (1.8%)
2: cpu: 12.4% command: chromium pid: 2432 mem: 313.2 MiB (4.0%)
3: cpu: 11.0% command: chromium pid: 1610 mem: 205.3 MiB (2.6%)
4: cpu: 6.2% command: Xorg pid: 568 mem: 93.9 MiB (1.2%)
5: cpu: 5.4% command: wireplumber pid: 1022 mem: 31.6 MiB (0.4%)
Memory top: 5 of 234
1: mem: 422.3 MiB (5.4%) command: chromium pid: 1575 cpu: 2.0%
2: mem: 313.2 MiB (4.0%) command: chromium pid: 2432 cpu: 12.4%
3: mem: 285.4 MiB (3.6%) command: pamac-checkupdates pid: 7335 cpu: 0.8%
4: mem: 276.0 MiB (3.5%) command: chromium pid: 6154 cpu: 4.8%
5: mem: 205.3 MiB (2.6%) command: chromium pid: 1610 cpu: 11.0%
Processes: 234 Power: uptime: 5h 20m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 3.02 GiB services: upowerd,xfce4-power-manager
Init: systemd v: 256 default: graphical tool: systemctl
Compilers: gcc: 14.2.1 Shell: dmenu-new2.sh default: Bash v: 5.2.37
running-in: xfce4-terminal inxi: 3.3.36
- i do not use steam
- Network manager works
- i use telegram from the repos, works
- my only electron app draw.io works
- SOME of the flatpak app work. So i am going to concentrate my reports on this for now
Mesa definitely is an issue of sort, but not the main issue (i see the error for the first time, it was not there last week)
A bigger issue seems to be libc:
For example io.github.amit9838.mousam Install Mousam on Linux | Flathub
Okt 10 22:39:41 teo-lenovo-v15 systemd-coredump[4905]: [đĄ] Process 4883 (mousam) of user 1000 dumped core.
Stack trace of thread 2:
#0 0x00007f8824ca3e84 n/a (/usr/lib/x86_64-linux-gnu/libc.so.6 + 0x90e84)
#1 0x00007f8824c51dce n/a (/usr/lib/x86_64-linux-gnu/libc.so.6 + 0x3edce)
#2 0x00007f8824c3983f n/a (/usr/lib/x86_64-linux-gnu/libc.so.6 + 0x2683f)
#3 0x00007f8824692fdb n/a (/usr/lib/x86_64-linux-gnu/libglib-2.0.so.0.8000.5 + 0x23fdb)
#4 0x00007f88246ff147 n/a (/usr/lib/x86_64-linux-gnu/libglib-2.0.so.0.8000.5 + 0x90147)
#5 0x00007f8822b1ddd3 n/a (/usr/lib/x86_64-linux-gnu/libgtk-4.so.1.1400.5 + 0x31ddd3)
#6 0x00007f8822b1cd5c n/a (/usr/lib/x86_64-linux-gnu/libgtk-4.so.1.1400.5 + 0x31cd5c)
#7 0x00007f8822ad5c8a n/a (/usr/lib/x86_64-linux-gnu/libgtk-4.so.1.1400.5 + 0x2d5c8a)
#8 0x00007f88245e5912 n/a (/usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0.8000.5 + 0x18912)
#9 0x00007f88245fceff n/a (/usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0.8000.5 + 0x2feff)
#10 0x00007f8824602e11 n/a (/usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0.8000.5 + 0x35e11)
#11 0x00007f8824602ed3 n/a (/usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0.8000.5 + 0x35ed3)
#12 0x00007f8822ab84a4 n/a (/usr/lib/x86_64-linux-gnu/libgtk-4.so.1.1400.5 + 0x2b84a4)
#13 0x00007f8822acdec3 n/a (/usr/lib/x86_64-linux-gnu/libgtk-4.so.1.1400.5 + 0x2cdec3)
#14 0x00007f88245c6056 n/a (/usr/lib/x86_64-linux-gnu/libffi.so.8.1.4 + 0x9056)
#15 0x00007fffff745238 n/a (n/a + 0x0)
UPDATE: OK, forget it. The latest-latest update (my mirrors have refreshed while posting) fixed everything on my flatpak side (at least those 2, have not tested all the rest). This one helped:
[2024-10-10T23:34:17+0200] [PACMAN] Running 'pacman -Syu'
[2024-10-10T23:34:17+0200] [PACMAN] synchronizing package lists
[2024-10-10T23:35:40+0200] [PACMAN] starting full system upgrade
[2024-10-10T23:43:15+0200] [ALPM] running '00-timeshift-autosnap.hook'...
[2024-10-10T23:43:15+0200] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2024-10-10T23:43:15+0200] [ALPM] transaction started
[2024-10-10T23:43:15+0200] [ALPM] upgraded adwaita-icon-theme-legacy (46.2-2 -> 46.2-3)
[2024-10-10T23:43:15+0200] [ALPM] upgraded libnm (1.48.10-1 -> 1.48.12-1)
[2024-10-10T23:43:16+0200] [ALPM] upgraded networkmanager (1.48.10-1 -> 1.48.12-1)
[2024-10-10T23:43:16+0200] [ALPM] transaction completed
[2024-10-10T23:43:16+0200] [ALPM] running '30-systemd-daemon-reload-system.hook'...
[2024-10-10T23:43:17+0200] [ALPM] running '30-systemd-udev-reload.hook'...
[2024-10-10T23:43:18+0200] [ALPM] running '30-systemd-update.hook'...
[2024-10-10T23:43:18+0200] [ALPM] running 'dbus-reload.hook'...
[2024-10-10T23:43:18+0200] [ALPM] running 'gtk-update-icon-cache.hook'...
[2024-10-10T23:43:18+0200] [ALPM] running 'networkmanager-connectivity.hook'...
[2024-10-10T23:43:19+0200] [ALPM] running 'rebuild-detector.hook'...
[2024-10-10T23:57:47+0200] [PACMAN] Running 'pacman -Syu'
[2024-10-10T23:57:47+0200] [PACMAN] synchronizing package lists
[2024-10-10T23:57:47+0200] [PACMAN] starting full system upgrade
Letâs have a little deep dive on why this icon theme may have broken things. More or less it was this change: Inherit from Adwaita (!3) · Merge requests · GNOME / Adwaita Legacy · GitLab
adwaita-icon-theme-legacy is a dependency adwaita-icon-theme which is a dependency of gtk3 and gtk4 - most likely is also installed on your system. Adding Inherits=Adwaita to a theme you may not use might create issues as in some implementations donât support circular inheritance. This happened with steam, electron or the flatpak apps. They looked for the Adwaita theme, which might not been active on your system. Before it only looked for hicolor. So they kept crashing cos the legacy theme depended on adwaita which itself depends on the legacy theme. So a non-working cycle was created.
Here an example for python code:
class A(B):
#body of class A
class B(A):
#body of class B
This code wonât work because B is not defined when class A got created. It proves the concept of circular inheritance. class A inherits from B and B from A⊠so youâre just creating a loop of inheritance, and python would not be able to evaluate this since thereâs no way to look at any class individually.
I only received a pacnew for /etc/makepkg.conf.d/rust.conf. Is that OK? I did miss the 2024-10-01 update if that makes a difference.
Besides that, everything is running smoothly.
If you do not get a .pacnew file during an update there is nothing to compare or merge
.pacnews are generally only created if you have made modifications to the file in question.
If you never touched, ex, makepkg.conf then you likely wont get a pacnew for it.
Confirm all electron based apps work again by only upgrading adwaita-icon-theme-legacy from 46.2-2 to 46.2-3. My setup is KDE Plasma on Wayland, NVIDIA card.
Now everything works great! Thank you!
electron apps now are OK! THX!
New ISOs are now online including the latest fixes âŠ
Xahea 24.1.1 (2024-10-11)
Download XFCE
Full
https://download.manjaro.org/xfce/24.1.1/manjaro-xfce-24.1.1-241011-linux610.iso
https://download.manjaro.org/xfce/24.1.1/manjaro-xfce-24.1.1-241011-linux610.iso.sig
https://download.manjaro.org/xfce/24.1.1/manjaro-xfce-24.1.1-241011-linux610.iso.sha1
https://download.manjaro.org/xfce/24.1.1/manjaro-xfce-24.1.1-241011-linux610.iso.sha256
https://download.manjaro.org/xfce/24.1.1/manjaro-xfce-24.1.1-241011-linux610.iso.torrent
https://download.manjaro.org/xfce/24.1.1/manjaro-xfce-24.1.1-241011-linux610.iso.pkgs
Minimal
https://download.manjaro.org/xfce/24.1.1/manjaro-xfce-24.1.1-minimal-241011-linux610.iso
https://download.manjaro.org/xfce/24.1.1/manjaro-xfce-24.1.1-minimal-241011-linux610.iso.sig
https://download.manjaro.org/xfce/24.1.1/manjaro-xfce-24.1.1-minimal-241011-linux610.iso.sha1
https://download.manjaro.org/xfce/24.1.1/manjaro-xfce-24.1.1-minimal-241011-linux610.iso.sha256
https://download.manjaro.org/xfce/24.1.1/manjaro-xfce-24.1.1-minimal-241011-linux610.iso.torrent
https://download.manjaro.org/xfce/24.1.1/manjaro-xfce-24.1.1-minimal-241011-linux610.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/xfce/24.1.1/manjaro-xfce-24.1.1-minimal-241011-linux66.iso
https://download.manjaro.org/xfce/24.1.1/manjaro-xfce-24.1.1-minimal-241011-linux66.iso.sig
https://download.manjaro.org/xfce/24.1.1/manjaro-xfce-24.1.1-minimal-241011-linux66.iso.sha1
https://download.manjaro.org/xfce/24.1.1/manjaro-xfce-24.1.1-minimal-241011-linux66.iso.sha256
https://download.manjaro.org/xfce/24.1.1/manjaro-xfce-24.1.1-minimal-241011-linux66.iso.torrent
https://download.manjaro.org/xfce/24.1.1/manjaro-xfce-24.1.1-minimal-241011-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/xfce/24.1.1/manjaro-xfce-24.1.1-minimal-241011-linux61.iso
https://download.manjaro.org/xfce/24.1.1/manjaro-xfce-24.1.1-minimal-241011-linux61.iso.sig
https://download.manjaro.org/xfce/24.1.1/manjaro-xfce-24.1.1-minimal-241011-linux61.iso.sha1
https://download.manjaro.org/xfce/24.1.1/manjaro-xfce-24.1.1-minimal-241011-linux61.iso.sha256
https://download.manjaro.org/xfce/24.1.1/manjaro-xfce-24.1.1-minimal-241011-linux61.iso.torrent
https://download.manjaro.org/xfce/24.1.1/manjaro-xfce-24.1.1-minimal-241011-linux61.iso.pkgs
Download GNOME
Full
https://download.manjaro.org/gnome/24.1.1/manjaro-gnome-24.1.1-241011-linux610.iso
https://download.manjaro.org/gnome/24.1.1/manjaro-gnome-24.1.1-241011-linux610.iso.sig
https://download.manjaro.org/gnome/24.1.1/manjaro-gnome-24.1.1-241011-linux610.iso.sha1
https://download.manjaro.org/gnome/24.1.1/manjaro-gnome-24.1.1-241011-linux610.iso.sha256
https://download.manjaro.org/gnome/24.1.1/manjaro-gnome-24.1.1-241011-linux610.iso.torrent
https://download.manjaro.org/gnome/24.1.1/manjaro-gnome-24.1.1-241011-linux610.iso.pkgs
Minimal
https://download.manjaro.org/gnome/24.1.1/manjaro-gnome-24.1.1-minimal-241011-linux610.iso
https://download.manjaro.org/gnome/24.1.1/manjaro-gnome-24.1.1-minimal-241011-linux610.iso.sig
https://download.manjaro.org/gnome/24.1.1/manjaro-gnome-24.1.1-minimal-241011-linux610.iso.sha1
https://download.manjaro.org/gnome/24.1.1/manjaro-gnome-24.1.1-minimal-241011-linux610.iso.sha256
https://download.manjaro.org/gnome/24.1.1/manjaro-gnome-24.1.1-minimal-241011-linux610.iso.torrent
https://download.manjaro.org/gnome/24.1.1/manjaro-gnome-24.1.1-minimal-241011-linux610.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/gnome/24.1.1/manjaro-gnome-24.1.1-minimal-241011-linux66.iso
https://download.manjaro.org/gnome/24.1.1/manjaro-gnome-24.1.1-minimal-241011-linux66.iso.sig
https://download.manjaro.org/gnome/24.1.1/manjaro-gnome-24.1.1-minimal-241011-linux66.iso.sha1
https://download.manjaro.org/gnome/24.1.1/manjaro-gnome-24.1.1-minimal-241011-linux66.iso.sha256
https://download.manjaro.org/gnome/24.1.1/manjaro-gnome-24.1.1-minimal-241011-linux66.iso.torrent
https://download.manjaro.org/gnome/24.1.1/manjaro-gnome-24.1.1-minimal-241011-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/gnome/24.1.1/manjaro-gnome-24.1.1-minimal-241011-linux61.iso
https://download.manjaro.org/gnome/24.1.1/manjaro-gnome-24.1.1-minimal-241011-linux61.iso.sig
https://download.manjaro.org/gnome/24.1.1/manjaro-gnome-24.1.1-minimal-241011-linux61.iso.sha1
https://download.manjaro.org/gnome/24.1.1/manjaro-gnome-24.1.1-minimal-241011-linux61.iso.sha256
https://download.manjaro.org/gnome/24.1.1/manjaro-gnome-24.1.1-minimal-241011-linux61.iso.torrent
https://download.manjaro.org/gnome/24.1.1/manjaro-gnome-24.1.1-minimal-241011-linux61.iso.pkgs
Download KDE
Full
https://download.manjaro.org/kde/24.1.1/manjaro-kde-24.1.1-241011-linux610.iso
https://download.manjaro.org/kde/24.1.1/manjaro-kde-24.1.1-241011-linux610.iso.sig
https://download.manjaro.org/kde/24.1.1/manjaro-kde-24.1.1-241011-linux610.iso.sha1
https://download.manjaro.org/kde/24.1.1/manjaro-kde-24.1.1-241011-linux610.iso.sha256
https://download.manjaro.org/kde/24.1.1/manjaro-kde-24.1.1-241011-linux610.iso.torrent
https://download.manjaro.org/kde/24.1.1/manjaro-kde-24.1.1-241011-linux610.iso.pkgs
Minimal
https://download.manjaro.org/kde/24.1.1/manjaro-kde-24.1.1-minimal-241011-linux610.iso
https://download.manjaro.org/kde/24.1.1/manjaro-kde-24.1.1-minimal-241011-linux610.iso.sig
https://download.manjaro.org/kde/24.1.1/manjaro-kde-24.1.1-minimal-241011-linux610.iso.sha1
https://download.manjaro.org/kde/24.1.1/manjaro-kde-24.1.1-minimal-241011-linux610.iso.sha256
https://download.manjaro.org/kde/24.1.1/manjaro-kde-24.1.1-minimal-241011-linux610.iso.torrent
https://download.manjaro.org/kde/24.1.1/manjaro-kde-24.1.1-minimal-241011-linux610.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/kde/24.1.1/manjaro-kde-24.1.1-minimal-241011-linux66.iso
https://download.manjaro.org/kde/24.1.1/manjaro-kde-24.1.1-minimal-241011-linux66.iso.sig
https://download.manjaro.org/kde/24.1.1/manjaro-kde-24.1.1-minimal-241011-linux66.iso.sha1
https://download.manjaro.org/kde/24.1.1/manjaro-kde-24.1.1-minimal-241011-linux66.iso.sha256
https://download.manjaro.org/kde/24.1.1/manjaro-kde-24.1.1-minimal-241011-linux66.iso.torrent
https://download.manjaro.org/kde/24.1.1/manjaro-kde-24.1.1-minimal-241011-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/kde/24.1.1/manjaro-kde-24.1.1-minimal-241011-linux61.iso
https://download.manjaro.org/kde/24.1.1/manjaro-kde-24.1.1-minimal-241011-linux61.iso.sig
https://download.manjaro.org/kde/24.1.1/manjaro-kde-24.1.1-minimal-241011-linux61.iso.sha1
https://download.manjaro.org/kde/24.1.1/manjaro-kde-24.1.1-minimal-241011-linux61.iso.sha256
https://download.manjaro.org/kde/24.1.1/manjaro-kde-24.1.1-minimal-241011-linux61.iso.torrent
https://download.manjaro.org/kde/24.1.1/manjaro-kde-24.1.1-minimal-241011-linux61.iso.pkgs
Updating the adwaita-icon-theme-legacy package also fixed the Electron app issues for me! Thanks very much for your work @philm!
Updating the adwaita-icon-theme-legacy package also fixes the issue with my crashing Vivaldi.
Thanks for the hard work.
I havenât had the issue related to this adwaita-icon-theme-legacy 46.2-2 though.
It DOES occur if I change to default icons/themes, at least for me on XFCE.
Thank you very much from my side as well - after updating the icons it works for me again as well.
All your hard work is very much appreciated.
For some reason, after this update and a few extra steps, KDE / SDDM and the console didnât allow me to sign in anymore.
It seems like the /etc/shadow file was changed, and my password hash was replaced with something like âusername:pend[âŠsome other characters]â (canât tell exactly anymore).
I donât know exactly how this happened, but I can tell that before I rebooted after the upgrade, I tried to add my user to another group.
I logged out and in again, but I couldnât see myself in the new group when I executed groups.
So I tried it again, and this time my sudo password wasnât accepted anymore.
So I tried changing my password using the KDE settings which wasnât working as well and the dialog told me that I have to wait for 10 minutes, before I can try again.
In the end, this comment helped me to fix the situation: Locked out of account - please help! - #6 by linux-aarhus
The passwd file wasnât changed, but the shadow file was and I was able to restore my hash (?) using the /etc/shadow- backup
I didnât use any tool to merge pacnew files, nor did I manually edit passwd/ shadow file before.
Yes i am currently experiencing an issue due to the update. (Please post about it)
Posted here about it:
A post was split to a new topic: Problems printing out certain .pdf files
I only got the rust.conf pacnew myself
From doing a little research, it looks like some lines were removed from makepkg.conf and moved over to this one so taking the changes looks all fine and dandy!
I have mesa held back from updating. No hurry on it if I do not use mesa anyway and the system is working fine otherwise. I think I will try it. Wish me luck. ![]()
No go. I got a gray screen with a cursor. Journalctl says plasma was not loaded. So I did a timeshift restore.
I have plasma commented out in pacman.conf, but I have not tried updating again.
I got two rust.conf and pacman.conf, where is rust.conf BTW? I forgot to write down the path for them.
