[Stable Update] 2024-06-10 - Kernels, Systemd, NVIDIA, Mesa, Qt5
Not without more information. Please create your own Support thread.
Not actually.
I didn’t remove any orphan packages. But for the sake of update, I removed following packages by pacman in order to resolve conflicts:
[2024-06-21T20:00:23+0330] [ALPM] removed plasma-integration (5.27.11-1)
[2024-06-21T20:00:23+0330] [ALPM] removed octopi-notifier-frameworks (0.15.0-3)
[2024-06-21T20:00:23+0330] [ALPM] removed plasma5-themes-breath (23.0.0-1)
[2024-06-21T20:00:23+0330] [ALPM] removed plasma5-themes-breath-migration (23.0.0-1)
[2024-06-21T20:00:23+0330] [ALPM] removed ksysguard (5.22.0-2)
[2024-06-21T20:00:23+0330] [ALPM] removed jre11-openjdk (11.0.22.u7-1)
[2024-06-21T20:00:24+0330] [ALPM] removed jre11-openjdk-headless (11.0.22.u7-1)
[2024-06-21T20:00:24+0330] [ALPM] removed kuserfeedback5 (1.3.0-4)
[2024-06-21T20:00:24+0330] [ALPM] removed breeze (5.27.11-1)
[2024-06-21T20:00:24+0330] [ALPM] removed baloo5 (5.115.0-1)
[2024-06-21T20:00:24+0330] [ALPM] removed backintime-cli (1.4.3-5)
[2024-06-21T20:00:24+0330] [ALPM] removed dbus-python (1.3.2-2)
I think none of them is related to touchpad.
@Yochanan
I was able to enable one-tap and double-tap for touchpad by creating following file:
cat /etc/X11/xorg.conf.d/70-synaptics.conf                                                     āœ”
Section "InputClass"
    Identifier "touchpad"
    Driver "synaptics"
    MatchIsTouchpad "on"
        Option "TapButton1" "1"
        Option "TapButton2" "3"
EndSection
It is now working but touchpad settings is still missing in System Settings program :smiling_face_with_tear:
As you told, I may create a separate support thread for this problem.
By the way, I liked this update and provide some cool features including default transparency.
Since this update, Plasma6 saved sessions don’t restore.
Not a Manjaro issue, it’s happening on other distros.
It was a surprise, coz I didn’t notice there were any KDE6 changes in this update.
Saved session is really important. I usually have about 20 Dolphin windows
on 6 ā€œdesktopsā€ (workspaces), and several tabs in each window.
This is how I find my way to the different things I’m working on.
Been using them like this for 7 years. Now they’ve all gone,
I have to think hard for a while to remember where to find each of my jobs.
I did make a Dolphin bookmark folder of each window,
but it’s a lot slower than just going to, say, desktop 4, window 3, tab 5,
which I remember spatially (like places around town), not as numbers, so it’s easy.
I just updated yesterday. Today only issue is that right clic doesn’t work. I dunno if it’s my laptop’s touch pad or due to the update.
Ran into errors importing new GPG keys. Was asking me if I wanted to import some new keys, but gave errors when doing so.
Ran sudo pacman-key --list and saw some errors from gpg about the key database.
Ran sudo mv /etc/pacman.d/gnupg /etc/pacman.d/gnupg.bak, then sudo pacman-key --init and sudo pacman-key --populate as suggested here.
Finally, ran sudo pacman -S manjaro-keyring archlinux-keyring before the final sudo pacman -Syu and update went smoothly.
FYI: With my Linux 6.6.32-1 kernel I also encounter a failed boot process that stops with a black screen and a visible X or Arrow (encountered both) mouse pointer. By using Kernel 6.1.92-1 instead the Manjaro startup fully succeeds and I can login. Please note that I have no NVIDIA graphics card but just use a mid-aged AMD Ryzen 3 2200G with Radeon Vega Graphics CPU.
Looking forward to get this boot issue (black screen with X cursor) fixed to switch back to the newest LTS Kernel 6.6.32-1
  Host: fidelis-pc Kernel: 6.1.92-1-MANJARO arch: x86_64 bits: 64
  Desktop: GNOME v: 46.2 Distro: Manjaro Linux
  Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-I GAMING v: Rev 1.xx
    serial: <superuser required> UEFI: American Megatrends v: 2801
    date: 09/18/2019
  Info: quad core model: AMD Ryzen 3 2200G with Radeon Vega Graphics bits: 64
    type: MCP cache: L2: 2 MiB
  Speed (MHz): avg: 2075 min/max: 1600/3500 cores: 1: 1600 2: 3500 3: 1600
    4: 1600
  Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series]
    driver: amdgpu v: kernel
  Device-2: Microsoft LifeCam HD-3000 driver: snd-usb-audio,uvcvideo
    type: USB
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0 driver: X:
    loaded: amdgpu unloaded: modesetting,radeon dri: radeonsi gpu: amdgpu
    resolution: 1920x1080~60Hz
  API: OpenGL Message: Unable to show GL data. glxinfo is missing.
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
  Device-2: AMD Family 17h/19h HD Audio driver: snd_hda_intel
  Device-3: Microsoft LifeCam HD-3000 driver: snd-usb-audio,uvcvideo
    type: USB
  API: ALSA v: k6.1.92-1-MANJARO status: kernel-api
  Server-1: PulseAudio v: 17.0 status: active
  Device-1: ASUSTek Bluetooth Radio driver: btusb type: USB
  Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
I had to change the /org/gnome/desktop/peripherals/touchpad/click-method to areas in dconf Editor after update using GNOME… maybe it helps you.
Electron (electron28?) atuoruns again and again even if disable autorun or delete autorun entity.
To me it looks like they are being influenced by the discord package.
