[2024-05-29T22:44:45+0200] [ALPM-SCRIPTLET] WARNING: The 'plymouth-encrypt' and 'sd-plymouth' hooks are depreciated. You should replace them with 'encrypt' and 'plymouth' hooks in your 'mkinitcpio.conf'. The 'lxdm-plymouth.service', 'lightdm-plymouth.service' and 'sddm-plymouth.service' systemd service files are no longer recommended. You should enable 'lxdm.service', 'lightdm.service' or 'sddm.service' instead.
Updated within KDE GUI (Wayland). No Issues but Firefox acting weird like unclickable buttons until i min/maximize. But its not crashing anymore like it did on unstable.
Did you try booting from USB/disk into a rescue system and mounting the volume manually inside of that? Did that work? If yes, do you have the encrypt hook in /etc/mkinitcpio.conf?
I don’t use Wayland (maybe i should try it again, not sure) but no, i can not see the ink levels in the printer setting gui. No one has suggested a shell command to access it either, so i think i will have to buy a new printer. So now i start searching for that. Anyhow, screen shots here
I’m still working on the VPN, I’m starting to suspect its just a coincidence that it stopped working at the same time as the update. I’m waiting for a response from my vpn provider.
Yea i am watching it being worked on. As i say i wouldn’t say anything if kde had a working calendar of its own.
Sure i could, if i wanted it sometime this decade. I wouldn’t know where to even start.
I never reed the announcements before, i did not know how it was supposed to work. I suspected it was more likely a mistake on my part, so i asked.
After the update, the keyring database got corrupted, so that sudo mhwd-kernel -i linux69 wasn’t possible (The full error has scrolled off the recall in konsole but is was a corrupted (invalid or corrupted package (PGP signature) error.
After rummaging through the forums I found the following sequence that works:
the xz version 5.6.2 has been released that fix the malicious backdoor, while it’s still
xz 5.6.1-3. in stable. it’s worth to update it in the packages to fix the story finally.
Only one minor obvious issue; radicale now spams the journal with verbose messages. As there’s no obvious way to lower its verbosity level, I fixed this by creating a radicale.service override file redirecting its output to a log file.
Edit: this can be changed by editing the configuration file and adding the following line to the [logging] section: level = error
Just mentioning in case anyone else happens to be using it and wants a fix.
Tooltips do not appear when I mouse over buttons when I use the Qt6 version of Double Commander. When I use the Qt5-version, tooltips work. Maybe upgrading qt6-base has something to do with it. I have posted a report on the Double Commander forum. Tooltips not shown on Qt6, are OK on Qt5
Tooltips work fine in Dolphin and LibreOffice, so no worries.
I never was in that situation but I think the right way would be to chroot into your system and then run mkinitcpio. You could also try something along the lines of mkinitcpio --config /path/to/mkinitcpio.conf --generate initramfs-x.x-x86_64.img and then manually replace the image in /boot but I am not sure about that. Maybe somebody else can chime in? I think chroot is the “correct” way.
Hi everyone, sorry I’m new to manjaro and I hope you will have a little patience. I have a question regarding the latest update. After the update I started:
“pacnew-checker” and it reported the presence of mkinitcpio.conf.pacnew. With Meld I saw the differences between the two files. I never made any changes in the original mkinitcpio.conf file, can I replace the original file with the new one? I believe and correct me if I’m wrong that the spirit of “pacnew” is to prevent a configuration file, perhaps modified by the administrator, from being overwritten without first being checked and possibly reporting the changes to the new one?
Thank you for your availability
There seems to be a big problem with memory leaks with Plasma in this update.
Plasmashell starts up using about 250M, with kglobalacceld at about 8K.
After a period of editing photos in the Gimp, I noticed my RAM use had grown to nearly 100%. Closing Gimp reduced it a bit, but not much. Digging in, I could see that plasmashell was now using an insane 5G and kglobalacceld was using over 3G.
Trying plasmashell --replace
at first left me without plasmashell even running, but issuing that command again brought it back, but already using about 3G. Only logging out and back in again released the excess memory.
