Linux 6.6.X and nouveau not working on NVIDIA 210.
As i mentioned 2 Threads ago, Linux 6.6.x no longer works on my system with nouveau drivers and nvidia Geforce 218. Kernel 6.1.67-2 still works:
[ 21.597130] nouveau 0000:01:00.0: vgaarb: deactivate vga console
[ 21.597167] nouveau 0000:01:00.0: NVIDIA GT218 (0a8280b1)
[ 21.605204] intel_powerclamp: No package C-state available
[ 21.717858] nouveau 0000:01:00.0: bios: version 70.18.a6.00.00
[ 21.719738] nouveau 0000:01:00.0: fb: 1024 MiB DDR3
[ 22.822886] nouveau 0000:01:00.0: DRM: VRAM: 1024 MiB
[ 22.822892] nouveau 0000:01:00.0: DRM: GART: 1048576 MiB
[ 22.822896] nouveau 0000:01:00.0: DRM: TMDS table version 2.0
[ 22.822898] nouveau 0000:01:00.0: DRM: DCB version 4.0
[ 22.822900] nouveau 0000:01:00.0: DRM: DCB outp 00: 01000302 00020030
[ 22.822903] nouveau 0000:01:00.0: DRM: DCB outp 01: 02000300 00000000
[ 22.822905] nouveau 0000:01:00.0: DRM: DCB outp 02: 02011362 00020010
[ 22.822907] nouveau 0000:01:00.0: DRM: DCB outp 03: 01022310 00000000
[ 22.822909] nouveau 0000:01:00.0: DRM: DCB conn 00: 00001030
[ 22.822911] nouveau 0000:01:00.0: DRM: DCB conn 01: 00002161
[ 22.822913] nouveau 0000:01:00.0: DRM: DCB conn 02: 00000200
[ 22.825102] nouveau 0000:01:00.0: DRM: MM: using COPY for buffer copies
[ 22.872098] nouveau 0000:01:00.0: DRM: allocated 1920x1080 fb: 0x70000, bo 00000000d8b34fcf
[ 22.874071] fbcon: nouveaudrmfb (fb0) is primary device
[ 22.963371] Console: switching to colour frame buffer device 240x67
[ 22.965707] nouveau 0000:01:00.0: [drm] fb0: nouveaudrmfb frame buffer device
[ 22.980563] [drm] Initialized nouveau 1.3.1 20120801 for 0000:01:00.0 on minor 0
[ 23.200295] EXT4-fs (sda3): mounted filesystem with ordered data mode. Quota mode: none.
[ 24.480714] RPC: Registered named UNIX socket transport module.
[ 24.480721] RPC: Registered udp transport module.
[ 24.480722] RPC: Registered tcp transport module.
[ 24.480723] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 26.334808] mousedev: PS/2 mouse device common for all mice
[ 32.413640] NET: Registered PF_QIPCRTR protocol family
[ 32.913729] ATL1E 0000:02:00.0 enp2s0: NIC Link is Up <1000 Mbps Full Duplex>
[ 32.913748] IPv6: ADDRCONF(NETDEV_CHANGE): enp2s0: link becomes ready
[ 88.840916] systemd-journald[231]: /var/log/journal/18af89b33ecf46d9b18af59e9a5e77ce/user-1000.journal: Journal file uses a different sequence number ID, rotating.
[ 89.500501] logitech-hidpp-device 0003:046D:406D.0006: HID++ 4.5 device connected.
On Kernel 6.6.6 it looks like this:
[ 23.484490] nouveau 0000:01:00.0: vgaarb: deactivate vga console
[ 23.484538] nouveau 0000:01:00.0: NVIDIA GT218 (0a8280b1)
[ 23.598926] nouveau 0000:01:00.0: bios: version 70.18.a6.00.00
[ 23.600269] nouveau 0000:01:00.0: fb: 1024 MiB DDR3
[ 24.200311] EXT4-fs (sda3): mounted filesystem 98893c76-e211-4a89-9cfb-e108f9f0ee6f r/w with ordered data mode. Quota mode: none.
[ 24.701255] nouveau 0000:01:00.0: DRM: VRAM: 1024 MiB
[ 24.701263] nouveau 0000:01:00.0: DRM: GART: 1048576 MiB
[ 24.701267] nouveau 0000:01:00.0: DRM: TMDS table version 2.0
[ 24.701269] nouveau 0000:01:00.0: DRM: DCB version 4.0
[ 24.701271] nouveau 0000:01:00.0: DRM: DCB outp 00: 01000302 00020030
[ 24.701274] nouveau 0000:01:00.0: DRM: DCB outp 01: 02000300 00000000
[ 24.701276] nouveau 0000:01:00.0: DRM: DCB outp 02: 02011362 00020010
[ 24.701278] nouveau 0000:01:00.0: DRM: DCB outp 03: 01022310 00000000
[ 24.701280] nouveau 0000:01:00.0: DRM: DCB conn 00: 00001030
[ 24.701282] nouveau 0000:01:00.0: DRM: DCB conn 01: 00002161
[ 24.701283] nouveau 0000:01:00.0: DRM: DCB conn 02: 00000200
[ 24.703122] nouveau 0000:01:00.0: DRM: MM: using COPY for buffer copies
[ 24.713114] [drm] Initialized nouveau 1.4.0 20120801 for 0000:01:00.0 on minor 0
[ 24.757702] fbcon: nouveaudrmfb (fb0) is primary device
[ 24.845619] Console: switching to colour frame buffer device 240x67
[ 24.852822] nouveau 0000:01:00.0: [drm] fb0: nouveaudrmfb frame buffer device
[ 26.578413] RPC: Registered named UNIX socket transport module.
[ 26.578418] RPC: Registered udp transport module.
[ 26.578419] RPC: Registered tcp transport module.
[ 26.578420] RPC: Registered tcp-with-tls transport module.
[ 26.578421] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 28.280165] mousedev: PS/2 mouse device common for all mice
[ 39.203133] NET: Registered PF_QIPCRTR protocol family
[ 39.362684] ATL1E 0000:02:00.0 enp2s0: NIC Link is Up <1000 Mbps Full Duplex>
[ 69.984286] sddm-greeter[984]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[ 77.405521] nouveau 0000:01:00.0: fifo: DMA_PUSHER - ch 4 [sddm-greeter[984]] get 000021e004 put 000021e088 ib_get 00000007 ib_put 00000008 state 800081a4 (err: INVALID_CMD) push 00400040
[ 80.892922] nouveau 0000:01:00.0: fifo: DMA_PUSHER - ch 4 [sddm-greeter[984]] get 000021e008 put 000021e088 ib_get 0000000b ib_put 0000000c state 80000ac8 (err: INVALID_CMD) push 00400040
[ 81.016391] nouveau 0000:01:00.0: fifo: DMA_PUSHER - ch 4 [sddm-greeter[984]] get 000021e090 put 000021f6d8 ib_get 0000000d ib_put 0000000e state 80000000 (err: INVALID_CMD) push 00400040
[ 108.043289] systemd-journald[181]: /var/log/journal/18af89b33ecf46d9b18af59e9a5e77ce/user-1000.journal: Journal file uses a different sequence number ID, rotating.
Nobody have a clue? The last 5 rows are the error i got on 6.6.6.
My system:
Host: rich-pc Kernel: 6.1.67-2-MANJARO arch: x86_64 bits: 64 compiler: gcc
v: 13.2.1 Desktop: KDE Plasma v: 5.27.10 Distro: Manjaro Linux
base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: P5Q v: Rev 1.xx
serial: <superuser required> BIOS: American Megatrends v: 2209
date: 03/11/2010
Device-1: hidpp_battery_0 model: Logitech MK700
charge: 55% (should be ignored) status: discharging
Device-2: hidpp_battery_1 model: Logitech Marathon Mouse/Performance Plus
M705 charge: 55% (should be ignored) status: discharging
Info: dual core model: Intel Core2 Duo E8400 bits: 64 type: MCP arch: Penryn
rev: A cache: L1: 128 KiB L2: 6 MiB
Speed (MHz): avg: 2000 min/max: 2003/3003 cores: 1: 2000 2: 2000
bogomips: 12002
Flags: ht lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx
Device-1: NVIDIA GT218 [GeForce 210] vendor: Micro-Star MSI N210
driver: nouveau v: kernel arch: Tesla bus-ID: 01:00.0 temp: 53.0 C
Display: x11 server: X.Org v: 21.1.9 driver: X: loaded: modesetting
dri: nouveau gpu: nouveau resolution: 1920x1080~60Hz
API: OpenGL v: 4.5 compat-v: 3.3 vendor: mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: NVA8
Device-1: Qualcomm Atheros AR8121/AR8113/AR8114 Gigabit or Fast Ethernet
vendor: ASUSTeK driver: ATL1E v: N/A port: cc00 bus-ID: 02:00.0
IF: enp2s0 state: up speed: 1000 Mbps duplex:
Local Storage: total: 931.51 GiB used: 358.59 GiB (38.5%)
ID-1: /dev/sda vendor: Seagate model: ST1000DM003-1ER162 size: 931.51 GiB
ID-1: / size: 210.41 GiB used: 60.51 GiB (28.8%) fs: ext4 dev: /dev/sda2
ID-2: /home size: 702.38 GiB used: 298.09 GiB (42.4%) fs: ext4
dev: /dev/sda3
ID-3: swap-1 size: 2 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda1
Processes: 182 Uptime: 9m Memory: total: 4 GiB available: 3.83 GiB
used: 2.31 GiB (60.4%) Init: systemd Compilers: gcc: 13.2.1 clang: 16.0.6
Packages: 1721 Shell: Bash v: 5.2.21 inxi: 3.3.31
