[Stable Update] 2023-11-13 - Kernels, KDE Gear, LibreOffice, LXQt, Pipewire, Phosh, Firefox, Thunderbird
I am also running into the issue of java environments.
My starting point was that i had everything “jre11” and “jdk11” installed, after some suggestions i now have only “jdk11-openjdk” installed, but the upgrade pacman -Syu and pacman -Syu jdk-openjdk will still try to install “jre” packages, is this correct? Because from what i am reading about the change it should only use “jdk” now if jdk is needed and should actually conflicts, but they do not.
Package (130)                      Old Version          New Version          Net Change  Download Size
extra/jdk11-openjdk                11.0.21.u9-2         11.0.21.u9-3           0.01 MiB     307.56 MiB
extra/jre11-openjdk                                     11.0.21.u9-3           0.53 MiB       0.19 MiB
extra/jre11-openjdk-headless                            11.0.21.u9-3         159.98 MiB      36.02 MiB
My issue with the appindicator icons has escalated. It’s now the entire gnome-shell collapsing on me when trying to restart my nextcloud desktop client to display the proper icons.
Looking at the journalctl output, the following appears:
Nov 13 12:14:24 karolyi-desktop nextcloud[2093]: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Nov 13 12:14:28 karolyi-desktop nextcloud[4087]: qt.qpa.qgnomeplatform.theme: The desktop style for QtQuick Controls 2 applications is not available on the system (qqc2-desktop-style). The application may look broken.
Nov 13 12:14:29 karolyi-desktop gnome-shell[1771]: Object .Gjs_workspace-indicator_gnome-shell-extensions_gcampax_github_com_extension_WindowPreview (0x55d08578df00), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
                                                   == Stack trace for context 0x55d079e84d10 ==
                                                   #0   7ffdee5de640 b   resource:///org/gnome/shell/ui/layout.js:992 (10ad01dd7fb0 @ 32)
                                                   #1   55d079f4f2f0 i   file:///usr/share/gnome-shell/extensions/workspace-indicator@gnome-shell-extensions.gcampax.github.com/extension.js:77 (c1912c26ce0 @ 42)
                                                   #2   55d079f4f270 i   file:///usr/share/gnome-shell/extensions/workspace-indicator@gnome-shell-extensions.gcampax.github.com/extension.js:66 (c1912c26c40 @ 12)
                                                   #3   55d079f4f1e8 i   resource:///org/gnome/gjs/modules/esm/_timers.js:72 (10ad01d70510 @ 77)
                                                   #4   55d079f4f158 i   resource:///org/gnome/shell/ui/init.js:21 (10ad01d70ba0 @ 48)
                                                   #0   7ffdee5de640 b   resource:///org/gnome/shell/ui/layout.js:993 (10ad01dd7fb0 @ 231)
Nov 13 12:14:29 karolyi-desktop gnome-shell[1771]: st_widget_get_theme_node called on the widget [0x55d08578df00 Gjs_workspace-indicator_gnome-shell-extensions_gcampax_github_com_extension_WindowPreview.workspace-indicator-window-preview] which
 is not in the stage.
Nov 13 12:14:29 karolyi-desktop gnome-shell[1771]: st_widget_get_theme_node called on the widget [0x55d08578df00 Gjs_workspace-indicator_gnome-shell-extensions_gcampax_github_com_extension_WindowPreview.workspace-indicator-window-preview] which is not in the stage.
Nov 13 12:14:29 karolyi-desktop kernel: show_signal_msg: 59 callbacks suppressed
Nov 13 12:14:29 karolyi-desktop kernel: gnome-shell[1771]: segfault at 602400000000 ip 000011e3742a7c67 sp 00007ffdee5de5a8 error 4 likely on CPU 11 (core 11, socket 0)
Nov 13 12:14:29 karolyi-desktop kernel: Code: bf 28 ed ff 5a 48 89 1c 01 49 89 db 49 c1 eb 2f 41 81 fb f6 ff 01 00 0f 82 67 00 00 00 48 b8 00 00 f0 ff ff 7f 00 00 48 23 c3 <48> 83 38 00 0f 84 50 00 00 00 49 89 cb 49 81 e3 00 00 f0 ff 49 83
Nov 13 12:14:29 karolyi-desktop systemd[1]: Created slice Slice /system/systemd-coredump.
Nov 13 12:14:29 karolyi-desktop systemd[1]: Started Process Core Dump (PID 4106/UID 0).
Nov 13 12:14:31 karolyi-desktop systemd-coredump[4109]: Process 1771 (gnome-shell) of user 1000 dumped core.
    Stack trace of thread 1771:
    #0  0x000011e3742a7c67 n/a (n/a + 0x0)
    #1  0x000011e37417a4e9 n/a (n/a + 0x0)
    #2  0x00007fb32999b593 n/a (libmozjs-115.so + 0x159b593)
    #3  0x00007fb3296211f4 n/a (libmozjs-115.so + 0x12211f4)
    #4  0x00007fb329613fdd n/a (libmozjs-115.so + 0x1213fdd)
    #5  0x00007fb329b5e9ee n/a (libmozjs-115.so + 0x175e9ee)
    #6  0x00007fb32999a948 n/a (libmozjs-115.so + 0x159a948)
    #7  0x00007fb3296212b6 n/a (libmozjs-115.so + 0x12212b6)
    #8  0x00007fb329613fdd n/a (libmozjs-115.so + 0x1213fdd)
    #9  0x00007fb329cb49f7 _Z20JS_CallFunctionValueP9JSContextN2JS6HandleIP8JSObjectEENS2_INS1_5ValueEEERKNS1_16HandleValueArrayENS1_13MutableHandleIS6_EE (libmozjs-115.so + 0x18b49f7)
    #10 0x00007fb32b3bbf87 n/a (libgjs.so.0 + 0x44f87)
    #11 0x00007fb32b3fb60d n/a (libgjs.so.0 + 0x8460d)
    #12 0x00007fb32bb566c0 g_closure_invoke (libgobject-2.0.so.0 + 0x146c0)
    #13 0x00007fb32bb76112 n/a (libgobject-2.0.so.0 + 0x34112)
    #14 0x00007fb32b5363ee n/a (libglib-2.0.so.0 + 0x5b3ee)
    #15 0x00007fb32b534f69 n/a (libglib-2.0.so.0 + 0x59f69)
    #16 0x00007fb32b593327 n/a (libglib-2.0.so.0 + 0xb8327)
    #17 0x00007fb32b535b97 g_main_loop_run (libglib-2.0.so.0 + 0x5ab97)
    #18 0x00007fb32aed829b meta_context_run_main_loop (libmutter-13.so.0 + 0xd829b)
    #19 0x00007fb32a4574f6 n/a (libffi.so.8 + 0x74f6)
    #20 0x00007fb32a453f5e n/a (libffi.so.8 + 0x3f5e)
    #21 0x00007fb32a456b73 ffi_call (libffi.so.8 + 0x6b73)
    #22 0x00007fb32b3bedc7 n/a (libgjs.so.0 + 0x47dc7)
    #23 0x00007fb32b3c99c8 n/a (libgjs.so.0 + 0x529c8)
    #24 0x00007fb32999a948 n/a (libmozjs-115.so + 0x159a948)
    #25 0x00007fb3296212b6 n/a (libmozjs-115.so + 0x12212b6)
    #26 0x00007fb329613fdd n/a (libmozjs-115.so + 0x1213fdd)
    #28 0x00007fb32b3fea92 n/a (libgjs.so.0 + 0x87a92)
    #29 0x00007fb32b40589f gjs_context_eval_module (libgjs.so.0 + 0x8e89f)
    #30 0x00007fb32b405ba1 gjs_context_eval_module_file (libgjs.so.0 + 0x8eba1)
    #31 0x000055d078d2357f n/a (gnome-shell + 0x357f)
    #32 0x00007fb32ac45cd0 n/a (libc.so.6 + 0x27cd0)
    #33 0x00007fb32ac45d8a __libc_start_main (libc.so.6 + 0x27d8a)
    #34 0x000055d078d239e5 n/a (gnome-shell + 0x39e5)
    Stack trace of thread 1781:
    #0  0x00007fb32ad20f6f __poll (libc.so.6 + 0x102f6f)
    #1  0x00007fb32b593276 n/a (libglib-2.0.so.0 + 0xb8276)
    #2  0x00007fb32b533162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
    #3  0x00007fb32bbadfde n/a (libdconfsettings.so + 0x5fde)
    #4  0x00007fb32b5669f5 n/a (libglib-2.0.so.0 + 0x8b9f5)
    #5  0x00007fb32acaa9eb n/a (libc.so.6 + 0x8c9eb)
    #6  0x00007fb32ad2e7cc n/a (libc.so.6 + 0x1107cc)
    Stack trace of thread 1782:
    #0  0x00007fb32aca74ae n/a (libc.so.6 + 0x894ae)
    #1  0x00007fb32aca9d40 pthread_cond_wait (libc.so.6 + 0x8bd40)
    #2  0x00007fb329904fa1 _ZN7mozilla6detail21ConditionVariableImpl8wait_forERNS0_9MutexImplERKNS_16BaseTimeDurationINS_27TimeDurationValueCalculatorEEE (libmozjs-115.so + 0x1504fa1)
    #3  0x00007fb329904e43 n/a (libmozjs-115.so + 0x1504e43)
    #4  0x00007fb329b5fe4e n/a (libmozjs-115.so + 0x175fe4e)
    Stack trace of thread 1777:
    #0  0x00007fb32ad2c73d syscall (libc.so.6 + 0x10e73d)
    #1  0x00007fb32b58e2b7 g_cond_wait (libglib-2.0.so.0 + 0xb32b7)
    #2  0x00007fb32b5001b4 n/a (libglib-2.0.so.0 + 0x251b4)
    #3  0x00007fb32b568a7e n/a (libglib-2.0.so.0 + 0x8da7e)
    Stack trace of thread 1780:
    #2  0x00007fb32b535b97 g_main_loop_run (libglib-2.0.so.0 + 0x5ab97)
    #3  0x00007fb32b73914c n/a (libgio-2.0.so.0 + 0x11214c)
    Stack trace of thread 1784:
    Stack trace of thread 1778:
    #3  0x00007fb32b5331b2 n/a (libglib-2.0.so.0 + 0x581b2)
    Stack trace of thread 1787:
    Stack trace of thread 1785:
    Stack trace of thread 1788:
    Stack trace of thread 1786:
    Stack trace of thread 2421:
    #0  0x00007fb32ad2ebf6 epoll_wait (libc.so.6 + 0x110bf6)
    #1  0x00007fb32003f859 n/a (libspa-support.so + 0x16859)
    #2  0x00007fb32003158d n/a (libspa-support.so + 0x858d)
    #3  0x00007fb32a6b0da2 n/a (libpipewire-0.3.so.0 + 0x45da2)
    #4  0x00007fb32acaa9eb n/a (libc.so.6 + 0x8c9eb)
    #5  0x00007fb32ad2e7cc n/a (libc.so.6 + 0x1107cc)
    Stack trace of thread 4080:
    #1  0x00007fb32b58ec93 g_cond_wait_until (libglib-2.0.so.0 + 0xb3c93)
    #2  0x00007fb32b500185 n/a (libglib-2.0.so.0 + 0x25185)
    #3  0x00007fb32b56952b n/a (libglib-2.0.so.0 + 0x8e52b)
    Stack trace of thread 4088:
    Stack trace of thread 1783:
    Stack trace of thread 1789:
Nov 13 12:14:31 karolyi-desktop systemd[1]: systemd-coredump@0-4106-0.service: Deactivated successfully.
Looks very ugly.
Also, when this crash happens, my gnome shell starts back with all the extensions disabled.
And, another gnome-shell crash when simply wanting to save a file in Librewolf, which is not even a Qt application:
journalctl logs:
Nov 13 12:38:36 karolyi-desktop gnome-shell[14119]: JS ERROR: TypeError: this._prepareStartupAnimation() is undefined
    _loadBackground/signalId</id<@resource:///org/gnome/shell/ui/layout.js:693:26
    @resource:///org/gnome/shell/ui/init.js:21:20
Nov 13 12:38:36 karolyi-desktop gnome-shell[14119]: Object .Gjs_workspace-indicator_gnome-shell-extensions_gcampax_github_com_extension_WindowPreview (0x55bfe74f29b0), has been already disposed — impossible to access it. Thi
    == Stack trace for context 0x55bfe1288f80 ==
    #0   7fff286cd690 b   resource:///org/gnome/shell/ui/layout.js:992 (1fa0a1ed7fb0 @ 32)
    #1   55bfe1353310 i   file:///usr/share/gnome-shell/extensions/workspace-indicator@gnome-shell-extensions.gcampax.github.com/extension.js:77 (307122a54ec0 @ 42)
    #2   55bfe1353290 i   file:///usr/share/gnome-shell/extensions/workspace-indicator@gnome-shell-extensions.gcampax.github.com/extension.js:66 (307122a54e20 @ 12)
    #3   55bfe1353208 i   resource:///org/gnome/gjs/modules/esm/_timers.js:72 (1fa0a1e70510 @ 77)
    #4   55bfe1353178 i   resource:///org/gnome/shell/ui/init.js:21 (1fa0a1e70ba0 @ 48)
Nov 13 12:38:36 karolyi-desktop gnome-shell[14119]: Object .Gjs_workspace-indicator_gnome-shell-extensions_gcampax_github_com_extension_WindowPreview (0x55bfe74f29b0), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
    #0   7fff286cd690 b   resource:///org/gnome/shell/ui/layout.js:993 (1fa0a1ed7fb0 @ 231)
Nov 13 12:38:36 karolyi-desktop gnome-shell[14119]: Window manager warning: Invalid WM_TRANSIENT_FOR window 0x1e00014 specified for 0x1e00016.
Yes, same for me. Removed jre-openjdk and jre-openjdk-headless, installed jre-openjdk again and update went through smoothly.
There is a problem with VLC. I use VLC player to watch IPTV channels. I don’t know if it’s related to the update, but everything worked before. I show the logs:
~> cvlc -vvv http://live-okkotv.cdnvideo.ru/okkotv/1tv.smil/tracks-v1a1/mono.m3u8
[0000562da137d550] main libvlc debug: VLC media player - 3.0.20 Vetinari
[0000562da137d550] main libvlc debug: Copyright © 1996-2023 the VideoLAN team
[0000562da137d550] main libvlc debug: revision 3.0.20-0-g6f0d0ab126b
[00007f0af4001620] http stream debug: resolving 127.0.0.1 ...
[00007f0af4001620] http stream debug: outgoing request:
GET http://live-okkotv.cdnvideo.ru/okkotv/1tv.smil/tracks-v1a1/mono.m3u8 HTTP/1.1
Host: live-okkotv.cdnvideo.ru
Accept: */*
Accept-Language: ru
User-Agent: VLC/3.0.20 LibVLC/3.0.20
Range: bytes=0-
[00007f0af4001620] http stream debug: connection failed
[00007f0af4001620] access stream error: HTTP connection failure
[00007f0af4001620] http stream debug: querying proxy for http://live-okkotv.cdnvideo.ru/okkotv/1tv.smil/tracks-v1a1/mono.m3u8
[00007f0af4001620] http stream debug: proxy: http://127.0.0.1:4444
[00007f0af4001620] http stream debug: http: server='live-okkotv.cdnvideo.ru' port=80 file='/okkotv/1tv.smil/tracks-v1a1/mono.m3u8'
[00007f0af4001620] http stream debug:       proxy 127.0.0.1:4444
[00007f0af4001620] main stream debug: net: connecting to 127.0.0.1 port 4444
[00007f0af4001620] main stream error: connection failed: Connection refused
[00007f0af4001620] http stream error: cannot connect to 127.0.0.1:4444
[00007f0af4001620] main stream debug: no access modules matched
[00007f0af0000c90] main input error: Этот источник не открывается
[00007f0af0000c90] main input error: VLC не может открыть MRL 'http://live-okkotv.cdnvideo.ru/okkotv/1tv.smil/tracks-v1a1/mono.m3u8'. Ищите более подробную информацию в лог-файле.
[0000562da142ca00] main playlist debug: dead input
there are no listeners on port 4444:
~> sudo netstat -tunlp|grep 4444
~ [0|1]>
All channels stopped working.
Kindly explain what dd option means.
@philm The linked Arch Linux announcement contains incorrect information, pacman -Syu jdk-openjdk DOES NOT WORK.
What does work is pacman -Sy jdk-openjdk followed by pacman -Syu.
https://bbs.archlinux.org/viewtopic.php?pid=2129801#p2129801
$ sudo pacman -Syu jdk-openjdk
:: Synchronising package databases...
 core is up to date
 extra is up to date
 multilib is up to date
:: Replace kdsoap with extra/kdsoap-qt5? [Y/n]
:: Replace kuserfeedback with extra/kuserfeedback5? [Y/n]
:: Replace libqaccessibilityclient with extra/libqaccessibilityclient-qt5? [Y/n]
resolving dependencies...
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
:: jdk-openjdk and jre-openjdk are in conflict
$ sudo pacman -Sy jdk-openjdk
 core is up to date
 extra is up to date
:: jdk-openjdk and jre-openjdk are in conflict. Remove jre-openjdk? [y/N] y
:: jdk-openjdk and jre-openjdk-headless are in conflict. Remove jre-openjdk-headless? [y/N] y
Packages (3) jre-openjdk-21.u35-3 [removal]  jre-openjdk-headless-21.u35-3 [removal]
             jdk-openjdk-21.u35-8
Total Download Size:    457.46 MiB
Total Installed Size:  1136.47 MiB
Net Upgrade Size:       634.32 MiB
:: Proceed with installation? [Y/n] Y
I sort of was hoping the Manjaro team would downgrade these 2 files with this upgrade, looks like they didn’t as the issue persists. I will use the downgrade tool.
After the last update (or possibly the one on November 6, not 100% sure) I have experienced problems with my Wacom Intuos Pros. I have two different computers (an HP laptop/i7 and a Lenovo desktop/Ryzen), both running Manjaro/Gnome/X11 and having identical Wacom Intuos Pro pen tablets. On both systems any use of the Wacom tablets seems to freeze the application I’m trying to interact with (in particular, both Inkscape and Xournal++). These apps work fine when using the mouse or trackpad as input device.
Any ideas on what could have gone wrong?
I Did:
(said Yes to remove packages in conflict)
then:
sudo pacman -Syu
Update went well on my main machine, gonna do this on another pc.
I get a conflicting error message when I try to update pamac.
Error: unresolvable package conflicts detected
Error: Failed to prepare transaction:
conflicting dependencies:
Both are installed by default.
What do need to do?
Please look for the known issues above.
Try Either
Or
$ manly pacman -R -dd jre-openjdk-headless
pacman - package manager utility
-R, --remove
Remove package(s) from the system. Groups can also be specified to
be removed, in which case every package in that group will be
removed. Files belonging to the specified package will be deleted,
and the database will be updated. Most configuration files will be
saved with a .pacsave extension unless the --nosave option is used.
See Remove Options below.
TRANSACTION OPTIONS (APPLY TO -S, -R AND -U)
-d, --nodeps
Skips dependency version checks. Package names are still checked.
Normally, pacman will always check a package’s dependency fields to
ensure that all dependencies are installed and there are no package
conflicts in the system. Specify this option twice to skip all
dependency checks.
TRANSACTION OPTIONS (APPLY TO -S,-R AND -U)
-d, --nodeps
conflicts in the system. **Specify this option twice to skip all**
**dependency checks.**
-d, --deps
Restrict or filter output to packages installed as dependencies.
This option can be combined with -t for listing real orphans -
packages that were installed as dependencies but are no longer
required by any installed package.
That worked, and thanks for that quick response.
Manjaro absolutely has the BEST community of all distros! :slightly_smiling_face:
Did the same thing on the other machine, the update was done correctly as well, it’s always nice to read the update announcement thread!
Same issue
Experienced the jdk-openjdk issue myself, resolved by running pacman -S jdk-openjdk then pacman -Syu normally. Hope future updates can avoid being as rushed to avoid situations like this, otherwise everything’s running normally after restart so the update itself is good.
It’s a Nvidia issue and cuda-12.3.0-4 includes a workaround, but Manjaro Stable branch has cuda-12.3.0-1. In the meantime you could do just do export NVCC_PREPEND_FLAGS='-ccbin /opt/cuda/bin' yourself.
cuda has been updated from 12.2.2-1 to 12.3.0-4. Unfortunately, cuda 12.2 is not compatible with gcc 13. cuda 12.3 even more so. I can’t compile anything with nvcc at the moment.
/usr/include/bits/floatn-common.h(251): error: invalid combination of type specifiers
  typedef double _Float64;
/usr/include/bits/floatn-common.h(268): error: invalid combination of type specifiers
  typedef double _Float32x;
sudo pacman -U https://europe.archive.pkgbuild.com/packages/c/cuda/cuda-12.2.2-1-x86_64.pkg
.tar.zst https://europe.archive.pkgbuild.com/packages/c/cuda-tools/cuda-tools-12.2.2-1-x86_64.pkg.tar.zst
Since the Nvidia drivers remained on version 535 anyway, I downgraded cuda to version 12.2. Now it works again.
I would only update cuda to 12.3 when nvidia 545 is in the stable branch.
i tried cuda-12.3.0-4 with that workaround, but it do not work. I compile mpv-build-git with ffmpeg/cuda support and the compilation stops with the same error with cuda-12.3.0-4.
