Definitely something weird going on with that setting. I had it on Adaptive, it got changed to Flat after the update… but still feels the same as before.
gnome-icon-theme version is 3.12.0-7 on AUR. In my case this package was probaply installed with all others when I install Manjaro Linux, in 2021 December.
Have non-default path for docker engine, after the update the path was turned back to the default value which broke all my docker compose installations. Had to return data-path in /lib/systemd/system/docker.service back to my non-default value.
That command does not “turn off” Tracker. It only removes the filesystem and RSS indexer databases. They will be regenerated afterward. See tracker3 reset --help
After this update, I was unable to get KDE (on Wayland) to use all 3 of my 2160p monitors. Attempting to set up the display arrangement I had before was silently rejected without error, and only two could be enabled at a time, the last one always being left disabled regardless of config changes.
For the time being, I downgraded kwin, kscreen, and libkscreen to 5.27.3 from the last update, and my third monitor is working normally again.
Since the update yesterday my screen after a time intermittently tears with white & lines, flickering, then blank. Unable to use system. Press power button to poweroff, then Reboot.
I switched off power manager for display so it uses X11,
after changing display options to never blank screen had no effect. Since doing that, it does not appear to be happening, at the moment, so far.
I do not have timeshift installed, just waiting for new updates.
