after this update, my keyboard and mouse are not working so I cannot login into my system.
my kernel is 6.1.23, using kde, and cpu is amd 6800h
i could boot into cli mode, though. what should i do to recover my system?
A few details might help: is it a laptop? USB keyboard and Mouse? What Desktop Environment. Does the keyboard or mouse work when you are a terminal or in Grub before it loads?
Solved by comments here: AUR (en) - libinput-three-finger-drag
has problems with xf86-input-libinput 1.3.0-1
, so I followed the comment and installed libinput
, replacing libinput-three-finger-drag
Really miss the trackpad gestures, any replacement for libinput-three-finger-drag
I have the same problem as you, and it has been solved now. Thanks for your sharing.
