But,but, but… I can vote for only 1 computer. It doesn’t let me vote for the others
Thanks.
Have a clonezilla image to redo system partition.
This batch of updates seems to have severely crippled pulseaudio … having to restart the pulseaudio server every few minutes after the audio completely dies, then restart VLC, reload a YouTube video, etc, until the audio dies again, sometimes just from pausing YouTube or VLC playback. See this related thread:
You do know that ketnel is still in its rc phase, don’t you?
@winnie, @MirceaKitsune, @Begemoth
VLC, mpv, SMPlayer,Firefox and Chromium based browsers … use the dependence ffmpeg
by default. I think ffmpeg
supports H264 and H265 encoding and decoding. They do not need to use .mesa
Edit://
ffmpeg uses mesa for AMD GPU: Hardware/VAAPI – FFmpeg
I will test it later when I’m at home.
If you check how ffmpeg deals with hardware acceleration for encode/decode you will see that for AMD it uses va-api provided by mesa, that in this update was disabled for h264 and h265. Intel and NVIDIA are unaffected as they use different code/package.
The amdgpu-pro driver might be unaffected too but I haven’t researched it, so I don’t know.
To check whether hardware acceleration is currently running during playback (as root/sudo)
cat /sys/kernel/debug/dri/0/amdgpu_pm_info | grep VCN:
I’m still trying to figure out the reasoning for this change.
- Neither intel open source driver nor mesa driver is being developed by manjaro team, but included in manjaro repositories.
- Also, this won’t block anyone from encoding and decoding streams (so using MPEG-LA intellectual property) in software,
- Neither driver contains any patented code or logic, and only provides an API to EXTERNAL hardware that implements the function, that is developed, manufactured by legal companies, and bought and installed by the user or machine manufacturer. Not manjaro team.
- And the machine itself is being used by the user, and the user holds responsibility how it is using it. Not manjaro (or any other distro) team.
Isn’t it ironic, that large companies use free open source encoders like x265 to deliver often paid and copyrighted content to users who are going to be not allowed to decode it on expensive proprietary hardware they paid for?
Hi,
I don’t now if it’s link. It happened for me too with this update on a MSI laptop running on wayland and battery during the update.
Ctrl+alt+F3 (or other one) didn’t help but cap still respond.
I wait a few and hard reboot.
Wish You well
I noticed that now system monitor plasma-systemmonitor
does not display GPU (Nvidia gtx1060) informations anymore; eg the sensors for temperature, memory and gpu frequency, gpu usage and vram usage are all at zero.
I suspected the GPU was somehow not detected or something like it but nvidia-smi --loop
shows the GPU is correctly utilized and all of the related sensors work.
Just reporting here as before the update it was working correctly (Manjaro KDE, kernel 5.15.81, X11)
This is the second update that borked by Anki flatpak install somehow
Anki starting...
Initial setup...
Preparing to run...
Qt warning: qglx_findConfig: Failed to finding matching FBConfig for QSurfaceFormat(version 2.0, options QFlags<QSurfaceFormat::FormatOption>(), depthBufferSize -1, redBufferSize 1, greenBufferSize 1, blueBufferSize 1, alphaBufferSize -1, stencilBufferSize -1, samples -1, swapBehavior QSurfaceFormat::SingleBuffer, swapInterval 1, colorSpace QSurfaceFormat::DefaultColorSpace, profile QSurfaceFormat::NoProfile)
Qt fatal: Could not initialize GLX
Re-installing fixes it, but shouldn’t flatpaks be pretty immune to getting broken by system updates? Doesn’t make sense to me.
I’m having the same issue as well, plasma-systemmonitor
is unable to display any of the sensors/usage stats of my graphics card (Nvidia RTX3070Ti) but other programs such as Nvidia control panel, mangohud, etc are able to display these usage statistics just fine. I’m running kernel 6.0.11-1-MANJARO
and Nvidia driver version 525.60.11
It was also working just fine for me before the update, do we just need to wait for a plasma update, or is something else missing?
I cant find this stable update with my Laptop… with my PC it showed up.
They both using the same Kernel (5.15) and almost everything is identical.
I updated the mirrors with sudo pacman-mirrors --fasttrack
but Laptop just showed up to date in the Pamac UI
I just created a Topic:
Whats new since the Update
Airplay2 works great with raop-discover and raop.encryption.type = "auth_setup"
Tested with KEF-LSX
Firefox coredump systemd-coredump[2164]: [🡕] Process 2126 (firefox) of user 1000 dumped core
Have the exact same issue after update
It should be noted that this is still a deliberate choice the Manjaro team is doing here, as the functionality could stay enabled. E.g. (and so far at least) Arch is keeping it enabled. So personally I think it would be nice to have a somewhat better explanation of the reasons behind this decision than making it sound as if it’s something that can’t be helped as it’s happening outside of Manjaro’s sphere of influence.
Why is h.264 disabled? Is it going to be permanent?
philm already gave the link in the description of changes ! if you had taken only a single moment to read it you would know why ! your question is already answered so don’t waste our time.
Because h.264 and h.265 are proprietary video codecs, not free.
Some companies e.g. Amazon, Netflix, Apple … should pay for them.
Also, why cripple specifically hardware acceleration for only one brand, but leaving SOFTWARE acceleration by cpu in place?
If the former is allegedly a legally grey area, wouldn’t the latter surely put any distro far into sue-me country?
I would really be grateful for an explanation here…
That is not correct. Manjaro as a distro isn’t committed to only distribute free software.
The reason is stated in the very first post of this announcment: (IMHO unfounded) fear of patent violations and liability.
