Try it with
//192.168.1.2/home /mnt/NAS_home cifs defaults,vers=2.0,uid=1000,credentials=/home/carsten/nascred 0 0
That worked for me.
Try it with
That worked for me.
Thanks, it worked. It also works with vers=3, since my NAS supports it and I donât want to use âoldâ protocol versions if I can avoid it.
But it seems, that you have to explicitly set the protocol version now for whatever reason.
Yes, except that the browser is hard crashing because of this setting, so you have to create a new profile, and when you go to about:config on a new profile, that would toggle the setting for that new profile, but you need to change the setting in the old profile. Therefore, the setting has to be edited manually inside prefs.js.
Thanks @GokuSan & @flux for your input.
Iâve decided to:
keymap
)HOOKS=(base udev autodetect modconf block keyboard keymap filesystems fsck)
MODULES_DECOMPRESS
section remmed as it was introduced in the pacnew for now$ sudo rm /etc/mkinitcpio.conf.pacnew
$ sudo mkinitcpio -P
and rebootedall is well as expected as really the only changes made were altered syntax and more remmed lines
# vim:set ft=sh
# MODULES
# The following modules are loaded before any boot hooks are
# run. Advanced users may wish to specify all system modules
# in this array. For instance:
# MODULES=(piix ide_disk reiserfs)
MODULES=()
# BINARIES
# This setting includes any additional binaries a given user may
# wish into the CPIO image. This is run last, so it may be used to
# override the actual binaries included by a given hook
# BINARIES are dependency parsed, so you may safely ignore libraries
BINARIES=()
# FILES
# This setting is similar to BINARIES above, however, files are added
# as-is and are not parsed in any way. This is useful for config files.
FILES=()
# HOOKS
# This is the most important setting in this file. The HOOKS control the
# modules and scripts added to the image, and what happens at boot time.
# Order is important, and it is recommended that you do not change the
# order in which HOOKS are added. Run 'mkinitcpio -H <hook name>' for
# help on a given hook.
# 'base' is _required_ unless you know precisely what you are doing.
# 'udev' is _required_ in order to automatically load modules
# 'filesystems' is _required_ unless you specify your fs modules in MODULES
# Examples:
## This setup specifies all modules in the MODULES setting above.
## No raid, lvm2, or encrypted root is needed.
# HOOKS=(base)
## This setup will autodetect all modules for your system and should
## work as a sane default
# HOOKS=(base udev autodetect block filesystems)
## This setup will generate a 'full' image which supports most systems.
## No autodetection is done.
# HOOKS=(base udev block filesystems)
## This setup assembles a pata mdadm array with an encrypted root FS.
## Note: See 'mkinitcpio -H mdadm' for more information on raid devices.
# HOOKS=(base udev block mdadm encrypt filesystems)
## This setup loads an lvm2 volume group on a usb device.
# HOOKS=(base udev block lvm2 filesystems)
## NOTE: If you have /usr on a separate partition, you MUST include the
# usr, fsck and shutdown hooks.
# COMPRESSION
# Use this to compress the initramfs image. By default, gzip compression
# is used. Use 'cat' to create an uncompressed image.
#COMPRESSION="gzip"
#COMPRESSION="bzip2"
#COMPRESSION="lzma"
#COMPRESSION="xz"
#COMPRESSION="lzop"
#COMPRESSION="lz4"
#COMPRESSION="zstd"
# COMPRESSION_OPTIONS
# Additional options for the compressor
#COMPRESSION_OPTIONS=()
# MODULES_DECOMPRESS
# Decompress kernel modules during initramfs creation.
# Enable to speedup boot process, disable to save RAM
# during early userspace. Switch (yes/no).
#MODULES_DECOMPRESS="yes"
Youâre right. Seems to be an upstream bug in a kernel patch in v5.18.8
Hi winnie,
thx for the confirmation. I was really wondering, what the heck I again did âdestroyâ. So I will stick of with LTS, as I have no fancy new hardware no other known thing for which I actually would need newer kernel. Thx for the hint.
What does âremmedâ mean? âCommentedâ? I have the same HOOKS
line, I havenât inserted the MODULES_DECOMPRESS
section (yet), because itâs just a bunch of comments, that is, I havenât changed anything at all, but Manjaro doesnât boot anymore with any kernel 5.x I have (5.4, 5.10, 5.15), only with 4.19, where I ironically(?) got the errors/warnings during the installation of the update. What can I do?
Iâm no expert but check this out. It seems like they do the same thing. You can replace it with udev
as long as you donât mount /usr
on a separate partition.
This update is no fun. It feels like a regression on a regression.
The previous update caused a non-working Virtualbox and now this:
After updating, the boot process âhangsâ. I do not get a login screen.
It chokes on failed loading kernel modules. could not load module nvidia_uvm (or similair, I can not find it anymore in journalctl. Sigh, those times when you could just find stuff in /var/log).
But the module is still there. Iâm able to boot and work fine on kernel 5.4.204.1. But no luck with other kernels (eg. 5.18.10-1. 5.15.53-1 5.10.129-1).
Any pointers or ideas?
Also grrrrrr, why does mkinitcpio.conf lacks a comment like âOh BTW, after editing this file, run mkinitcpio -P and reboot to get the changes in effectâ. Such a comment could reduce headaches. Also, why doesnât mkinitcpio patch its config file on its own to the right format? The devs of mkinitcpio suck.
/rant
System froze after this line: [ALPM] upgraded linux419-nvidia (515.57-1 -> 515.57-3)
This was on tty 6 btw, not in GUI. I running 5.4, but it never got to those packages as best I can tell.
Tried a restart but grub complained there were no vmlinuz file for any entry.
Booted latest xfce manjaro iso & manjaro-chroot -a
Had to delete /var/lib/pacman/db.lck
then was able to finish the update.
my panel is wigging out now. all my widgets in the panel are freezing and glitching. If you click on them and show the tooltips(?) above they will all run fine though. and they are all affected at same time. also had some weird issues where screens would clip through each other randomly for a split second
Why doesnât /etc/default/grub
have a comment âOh BTW, after editing this file, run update-grub
and reboot to get the changes in effectâ?
Yeah, those pesky devs⌠hiding crucial information.
Soon weâll need signs to look left and right before you cross the road or else it will be othersâ fault if hit by a car. Oh waitâŚthey actually exist alreadyâŚ
Kernel 4.19 is an old one which doesnât ship that modules.builtin.modinfo file as you can see here:
[phil@infinitybook iso-info]$ pacman -Fl linux419 | grep modinfo
[phil@infinitybook iso-info]$ pacman -Fl linux54 | grep modinfo
linux54 usr/lib/modules/5.4.203-1-MANJARO/modules.builtin.modinfo
There were changes to mkinitcpio to look for that file. We can try to ship an empty file with one of the next kernel builds of that series to avoid that warning. Since it is a warning the kernel will still boot as the file doesnât exist to begin with âŚ
Had the same issue here.
As chris_d mentioned this seems to be a bug with the recent kernel v5.18.8.
As I actually as far as I see do anyway not needed new Kernel stuff, I switched to the most recent LTS Kernel and everything is up and running again
Just updated everything went well, except for rendering subtitles in Arabic language.
ASS subtitles are rendered fine, but other types are displayed in wrong way.
From left to right rendering it unreadable.
My guess itâs some issue with harfbuzz?
To elaborate
Ů
ŘąŘبا
is rendered like this
اب Ř ŘąŮ
Hi, been using Manjaro for ~2 years but this if first time Iâve run into an issue I could not find other people posting about so this is my first time on this forum.
I have an issue updating, seems an issue with a python library: python-ifaddr
when I run pacman -Syu
python-ifaddr-0.1.7-5-any.pkg.tar.zst failed to download
Total (14/15) 119.9 MiB 4.38 MiB/s 00:27 [###########################################################################] 100%
error: failed retrieving file 'python-ifaddr-0.1.7-5-any.pkg.tar.zst' from mirror.arvancloud.com : The requested URL returned error: 404
warning: too many errors from mirror.arvancloud.com, skipping for the remainder of this transaction
error: failed retrieving file 'python-ifaddr-0.1.7-5-any.pkg.tar.zst' from mirror.koddos.net : The requested URL returned error: 404
error: failed retrieving file 'python-ifaddr-0.1.7-5-any.pkg.tar.zst' from ftp.lysator.liu.se : The requested URL returned error: 404
error: failed retrieving file 'python-ifaddr-0.1.7-5-any.pkg.tar.zst' from ftp.psnc.pl : The requested URL returned error: 404
error: failed retrieving file 'python-ifaddr-0.1.7-5-any.pkg.tar.zst' from quantum-mirror.hu : The requested URL returned error: 404
error: failed retrieving file 'python-ifaddr-0.1.7-5-any.pkg.tar.zst' from mirror.bardia.tech : The requested URL returned error: 404
error: failed retrieving file 'python-ifaddr-0.1.7-5-any.pkg.tar.zst' from muug.ca : The requested URL returned error: 404
error: failed retrieving file 'python-ifaddr-0.1.7-5-any.pkg.tar.zst' from mirrors.ucr.ac.cr : The requested URL returned error: 404
warning: failed to retrieve some files
error: failed to commit transaction (failed to retrieve some files)
I get a similar result going through Pamac:
Checking inter-conflicts...
https://mirror.arvancloud.com/manjaro/stable/community/x86_64/python-ifaddr-0.1.7-5-any.pkg.tar.zst: Error 404
https://mirror.koddos.net/manjaro/stable/community/x86_64/python-ifaddr-0.1.7-5-any.pkg.tar.zst: Error 404
Download of manjaro-release (21.3.3-1) started
Download of manjaro-release (21.3.3-1) finished
https://ftp.lysator.liu.se/pub/manjaro/stable/community/x86_64/python-ifaddr-0.1.7-5-any.pkg.tar.zst: Error 404
https://ftp.psnc.pl/linux/manjaro/stable/community/x86_64/python-ifaddr-0.1.7-5-any.pkg.tar.zst: Error 404
https://quantum-mirror.hu/mirrors/pub/manjaro/stable/community/x86_64/python-ifaddr-0.1.7-5-any.pkg.tar.zst: Error 404
https://mirror.bardia.tech/manjaro/stable/community/x86_64/python-ifaddr-0.1.7-5-any.pkg.tar.zst: Error 404
https://muug.ca/mirror/manjaro/stable/community/x86_64/python-ifaddr-0.1.7-5-any.pkg.tar.zst: Error 404
https://mirrors.ucr.ac.cr/manjaro/stable/community/x86_64/python-ifaddr-0.1.7-5-any.pkg.tar.zst: Error 404
Failed to commit transaction:
It is not a package I installed explicitly, in fact going through Pamac it does not appear on the âUpdatesâ list, instead only showing up as a dependency in the popup after clicking on âApplyâ.
Iâve checked and it looks like ifaddr had a 0.2.0
release last month, their last release before that was 0.1.7
in 2020. I was able to pip install
both versions without a problem, but that did not help in getting it installed from the manjaro repos/mirrors. If someone can help me point my system at a repo with the correct version that would be much appreciated.
Thank you
Are you sure, you used -Syu
? Because it tries to download older version, which isnât present anymore. Refresh/change mirrors and retry. If it still doesnât work, open new topic.
Also⌠pip
or any other package manager for that matter, isnât for installing packages system-wide.
