Hey! Just wanted to chime in that I was able to work around the missing keys issue by simply issuing
sudo pacman -Syvv manjaro-keyring and didn’t have to rm anything.
And, as noted in the other thread, fixing Steam is easy by opening it, going to settings->account->beta participation, and clicking “steam beta update”.
True, never had any serious problems aswell! It’s just awesome, I love Manjaro!!
oneno
9 September 2021 01:38
50
Having same problem…
inxi -Fazy
$ inxi -Fazy
Kernel: 5.10.61-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=28e31491-f18c-4a8f-a340-2c2a70429840 ro quiet udev.log_priority=3
snd_hda_intel.dmic_detect=0
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Desktop System: Gigabyte product: N/A v: N/A serial: Chassis:
type: 3 serial:
Mobo: Gigabyte model: F2A88XM-D3H serial: UEFI: American Megatrends
v: F8 date: 04/09/2015
Info: Dual Core model: AMD A6-6400K APU with Radeon HD Graphics bits: 64
type: MCP arch: Piledriver family: 15 (21) model-id: 13 (19) stepping: 1
microcode: 6001119 cache: L2: 1024 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 15576
Speed: 2980 MHz min/max: 1800/3900 MHz boost: enabled Core speeds (MHz):
1: 2980 2: 2768
Type: spectre_v2
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: AMD Richland [Radeon HD 8470D] vendor: Gigabyte driver: radeon
v: kernel bus-ID: 00:01.0 chip-ID: 1002:9996 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: ati,radeon unloaded: modesetting alternate: fbdev,vesa
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1600x1200 s-dpi: 96 s-size: 423x317mm (16.7x12.5")
s-diag: 529mm (20.8")
OpenGL: renderer: AMD ARUBA (DRM 2.50.0 / 5.10.61-1-MANJARO LLVM 12.0.1)
v: 4.3 Mesa 21.2.1 compat-v: 3.1 direct render: Yes
Device-1: AMD Trinity HDMI Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 00:01.1 chip-ID: 1002:9902 class-ID: 0403
Device-2: AMD FCH Azalia vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Sound Server-1: ALSA v: k5.10.61-1-MANJARO running: yes
vendor: Gigabyte driver: r8169 v: kernel port: e000 bus-ID: 01:00.0
IF: enp1s0 state: up speed: 100 Mbps duplex: full mac:
Local Storage: total: 1.14 TiB used: 29.21 GiB (2.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: TeamGroup model: T253X2256G
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: rev: 0A0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EZEX-75M2NA0
type: HDD rpm: 7200 serial: rev: 1A01 scheme: MBR
ID-1: / raw-size: 20 GiB size: 19.56 GiB (97.81%) used: 11.46 GiB (58.6%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 20 GiB size: 19.56 GiB (97.81%)
used: 17.75 GiB (90.7%) fs: ext4 dev: /dev/sda4 maj-min: 8:4
ID-1: swap-1 type: partition size: 24 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 27.0 C mobo: N/A
Fan Speeds (RPM): cpu: 1165 fan-2: 575 fan-3: 521 fan-4: 0 fan-5: 0
Power: 12v: N/A 5v: N/A 3.3v: N/A vbat: 3.26
Processes: 173 Uptime: 10m wakeups: 0 Memory: 22.75 GiB
used: 1.48 GiB (6.5%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1323 lib: 388 Shell: Bash v: 5.1.8
running-in: xfce4-terminal inxi: 3.3.06
Have to disconnect audio plug and reconnect after boot each and every time for sound to work.
System: Kernel: 5.10.61-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Laptop System: LENOVO product: 20HF0000MZ v: ThinkPad T470s serial: <filter> Chassis: type: 10
serial: <filter>
Mobo: LENOVO model: 20HF0000MZ v: SDK0J40697 WIN serial: <filter> UEFI: LENOVO v: N1WET56W (1.35 ) date: 08/30/2019
CPU: Info: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP arch: Amber/Kaby Lake note: check rev: 9 cache:
L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 21607
Speed: 700 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 700 2: 700 3: 700 4: 700
Graphics: Device-1: Intel HD Graphics 620 vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:5916
class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 1-8:4 chip-ID: 04f2:b5ab class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: intel unloaded: modesetting
alternate: fbdev,vesa resolution: 1: 1920x1080~60Hz 2: 3840x2160~60Hz s-dpi: 96
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.2.1 direct render: Yes
After the upgrade I was not longer able to use the compositor in KDE plasma. The desktop was very laggy and the system load was very high. This only happens when the external display is attached.
The issue is due to xorg-server which I confirmed by manually downgrading the package to 1.20.13-2 from 1.20.13-3 (for xorg-server and xorg-server-common). With the version 1.20.13-2 everythings works as expected.
infabo
9 September 2021 13:12
52
agree man. ALL issues here reported regarding laggy graphics is all due to this whole “modesetting war”. Some l33t is arguing against intel driver - and therefore more or less forced modesetting by default. Just because some synthetic benchmarks outperform intel driver and/or someone does not like the code-base of intel driver.
See [patch] add some Debian patches (e3966f2b) · Commits · Packages / Extra / Xorg Packages v1.20 / xorg-server · GitLab
Isn’t this already the default in Fedora, Gentoo, Debian, Ubuntu and others? Would be curious to see if these same issues appear on those distros.
not to get off topic here but there are legitimate reasons to use modesetting rather than intel other than benchmarks - for me on an intel i5 laptop with i915 UHD graphics, i had a real nightmare with tearing during screensharing (a crucial part of my job) using the intel driver and that was fixed by switching to modesetting with no negative impact until now
vogu66
12 September 2021 07:19
55
Hello,
I did both this and the previous update at once, and now I seem to have issues with colors in some applications. The rofi launcher, which was alright, now has a light grey/white color scheme that is very hard to read, and in thunderbird the default system colors that I normally use for mails and the menus are now black on white instead of the previous dark theme.
Any idea how to fix this?
System info:
I think I was using the Adapta-maia-dark theme, and it now seems to be Adapta-nokto-eta-maia.
Using Awesome WM
Pictures of what’s wrong:
Similar issue.
With Rofi update, white text in themes before is now black !
lir5
13 September 2021 14:15
57
Hey, i’m a little bit clueless: no soundcards detectet anymore with kernel 5.14 in GNOME and KDE (in 5.13 and < it works like charm). Tried to deleting rm ~/.config/pulse/*.tdb ~/.config/pulse/cookie, was on testing and tried a lot of other possibilities, but no, nothing working; now i’m reinstalled system (with Gnome) new - same here. No soundcards detected, only shows dummy (now). Over amixer i get: asound
version-alsa k5.14.0.0-manjaro
cards also recognized (H-DSP / HDA Intel / HDA NVidia)
devices, timers, pcm still present.
I tried to get some inxi data but unfortunately there comes no output at all…
Then, also when i shutdown it takes miles of time and brings me systemd-shutdown sigkill to pid / shutdown waiting of processes pulseaudio messages… that’s all wrong
If someone has a good advice it would be much appreciated
I forgot: tried also with only pipewire / pulseaudio.
With 5.13 on KDE i get with inxi:
inxi --full --verbosity=7 --filter --no-host
Zusammenfassung
System: Kernel: 5.13.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2
Machine: Type: Desktop Mobo: MICRO-STAR model: P35 Platinum(MS-7345) v: 1.0 serial: <filter> BIOS: American Megatrends
v: 1.12 date: 12/30/2009
Battery: Message: No system battery data found. Is one present?
Memory: RAM: total: 7.77 GiB used: 4.39 GiB (56.5%)
CPU: Info: Quad Core model: Intel Core2 Quad Q9550 bits: 64 type: MCP arch: Penryn rev: 7 cache: L2: 6 MiB
bogomips: 27209
Speed: 3400 MHz min/max: N/A Core speeds (MHz): 1: 3400 2: 3400 3: 3400 4: 3400
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts
est flexpriority fpu fxsr ht lahf_lm lm mca mce mmx monitor msr mtrr nopl nx pae pat pbe pdcm pebs pge pni pse
pse36 pti rep_good sep smx sse sse2 sse4_1 ssse3 syscall tm tm2 tpr_shadow tsc vme vmx vnmi vpid xtpr
Graphics: Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: ZOTAC driver: nvidia v: 470.63.01 bus-ID: 01:00.0
chip-ID: 10de:13c2 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: nvidia resolution: 2560x1600~60Hz
s-dpi: 101
OpenGL: renderer: NVIDIA GeForce GTX 970/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Audio: Device-1: Intel 82801I HD Audio vendor: Micro-Star MSI MS-7345 : driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:293e class-ID: 0403
Device-2: NVIDIA GM204 High Definition Audio vendor: ZOTAC driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:0fbb class-ID: 0403
Device-3: Xilinx RME Hammerfall DSP driver: snd_hdsp v: kernel bus-ID: 05:00.0 chip-ID: 10ee:3fc5 class-ID: 0401
Sound Server-1: ALSA v: k5.13.13-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI RTL8111B on MS-7345
driver: r8168 v: 8.049.02-NAPI port: e800 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Bluetooth: Message: No bluetooth data found.
Logical: Message: No logical block device data found.
RAID: Message: No RAID data found.
Drives: Local Storage: total: 7.28 TiB used: 2.64 TiB (36.3%)
ID-1: /dev/sda vendor: Western Digital model: WD1000DHTZ-04N21V0 size: 931.51 GiB speed: 3.0 Gb/s type: HDD
rpm: 10000 serial: <filter> rev: 6A00 scheme: MBR
ID-2: /dev/sdb vendor: Western Digital model: WD4000FYYZ-01UL1B1 size: 3.64 TiB speed: 3.0 Gb/s type: HDD rpm: 7200
serial: <filter> rev: 1K02 scheme: GPT
ID-3: /dev/sdc vendor: Seagate model: ST33000651AS size: 2.73 TiB speed: 3.0 Gb/s type: HDD rpm: 7200
serial: <filter> rev: CC44 scheme: GPT
Partition: ID-1: / size: 95.62 GiB used: 33.03 GiB (34.5%) fs: ext4 dev: /dev/sda5 label: N/A
uuid: a8d9defd-4544-4426-966b-1f0a27e3c35c
ID-2: /home size: 95.62 GiB used: 58.34 GiB (61.0%) fs: ext4 dev: /dev/sda6 label: N/A
uuid: 2018a174-755e-4340-bbf8-dddf10853574
ID-3: /run/media/lir/V4000NCC-1701-E size: 2.82 TiB used: 2.55 TiB (90.4%) fs: ext4 dev: /dev/sdb1
label: V4000NCC-1701-E uuid: edd2b198-413f-4a51-9436-34d8d36ac360
Swap: ID-1: swap-1 type: partition size: 10.74 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda1 label: N/A
uuid: 0af60276-aa9e-431e-930f-d3121a834191
Unmounted: ID-1: /dev/sda10 size: 188.34 GiB fs: ext4 label: N/A uuid: ad217a5f-ad73-4fc7-9f9d-41a39a081fa2
ID-2: /dev/sda2 size: 1 KiB fs: <superuser required> label: N/A uuid: N/A
ID-3: /dev/sda7 size: 146.48 GiB fs: ext4 label: root uuid: 2b009d62-c28c-48f7-adac-b7845dc2598a
ID-4: /dev/sda8 size: 146.48 GiB fs: ext4 label: home uuid: 59a14254-f216-4ab8-a989-286bc6381af8
ID-5: /dev/sda9 size: 244.14 GiB fs: ext4 label: N/A uuid: eb57394d-64a9-4bdf-b134-66710ccfc2cd
ID-6: /dev/sdb2 size: 789.92 GiB fs: ntfs label: W10-Games uuid: 3198E549588A1313
ID-7: /dev/sdc1 size: 2.73 TiB fs: ext4 label: V3OOO651ASMu-III uuid: aa504daa-6a0c-436a-89ba-ac02db867037
USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s chip-ID: 1d6b:0001 class-ID: 0900
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s chip-ID: 1d6b:0001 class-ID: 0900
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s chip-ID: 1d6b:0001 class-ID: 0900
Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s chip-ID: 1d6b:0001 class-ID: 0900
Device-1: 6-1:2 info: Kingston HyperX Alloy Elite type: Keyboard,HID driver: hid-generic,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 500mA chip-ID: 0951:16bf class-ID: 0301
Device-2: 6-2:3 info: SteelSeries ApS Mouse type: HID,Mouse driver: hid-generic,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 200mA chip-ID: 1038:1720 class-ID: 0300 serial: <filter>
Hub-7: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s chip-ID: 1d6b:0001 class-ID: 0900
Hub-8: 8-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s chip-ID: 1d6b:0001 class-ID: 0900
Sensors: System Temperatures: cpu: 44.0 C mobo: N/A gpu: nvidia temp: 41 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 23%
Info: Processes: 249 Uptime: 1h 4m wakeups: 0 Init: systemd v: 248 Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1742
pacman: 1734 flatpak: 8 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
inxi -A
Zusammenfassung
inxi -A
Audio: Device-1: Intel 82801I HD Audio driver: snd_hda_intel
Device-2: NVIDIA GM204 High Definition Audio driver: snd_hda_intel
Sound Server-2: PulseAudio v: 15.0 running: yes
Sound Server-3: PipeWire v: 0.3.34 running: yes
inxi -Fazy
Zusammenfassung
inxi -Fazy
root=UUID=a8d9defd-4544-4426-966b-1f0a27e3c35c rw quiet apparmor=1
security=apparmor resume=UUID=0af60276-aa9e-431e-930f-d3121a834191
udev.log_priority=3 sysrq_always_enabled=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
serial: <filter> BIOS: American Megatrends v: 1.12 date: 12/30/2009
arch: Penryn family: 6 model-id: 17 (23) stepping: 7 microcode: 70A cache:
L2: 6 MiB
flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx bogomips: 27209
4: 3400
Type: l1tf mitigation: PTE Inversion; VMX: EPT disabled
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2
mitigation: Full generic retpoline, STIBP: disabled, RSB filling
v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
Screen-1: 0 s-res: 2560x1600 s-dpi: 101 s-size: 644x402mm (25.4x15.8")
s-diag: 759mm (29.9")
Monitor-1: DVI-I-1 res: 2560x1600 hz: 60 dpi: 101
size: 641x401mm (25.2x15.8") diag: 756mm (29.8")
direct render: Yes
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:293e
class-ID: 0403
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fbb
class-ID: 0403
vendor: Micro-Star MSI RTL8111B on MS-7345 driver: r8168 v: 8.049.02-NAPI
modules: r8169 port: e800 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD1000DHTZ-04N21V0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 10000 serial: <filter>
model: WD4000FYYZ-01UL1B1 size: 3.64 TiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 7200 serial: <filter>
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST33000651AS
size: 2.73 TiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: CC44 scheme: GPT
ID-1: / raw-size: 97.66 GiB size: 95.62 GiB (97.92%) used: 33.03 GiB (34.5%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5
ID-2: /home raw-size: 97.66 GiB size: 95.62 GiB (97.92%)
used: 58.36 GiB (61.0%) fs: ext4 dev: /dev/sda6 maj-min: 8:6
System Temperatures: cpu: 45.0 C mobo: N/A gpu: nvidia temp: 48 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 25%
Processes: 246 Uptime: 1h 17m wakeups: 0 Memory: 7.77 GiB
used: 4.43 GiB (57.0%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 clang: 12.0.1 Packages: 1742 pacman: 1734 lib: 471 flatpak: 8
infabo
13 September 2021 17:20
58
the opposite here. I had massive scroll-tearing with modesetting driver. No issues with intel. So it depends.
winnie
13 September 2021 18:11
59
@areographe have you tried using Triple Buffering ? I find that it eliminates screen tearing with Intel GPUs, combined with vertical sync and/or additional options that may be unique in each desktop environment.
Enable vsync, and then see if adding this file in /etc/X11/xorg.conf.d/ helps with tearing. (You will either need to reboot or restart the display server for it to take effect.)
My contents of /etc/X11/xorg.conf.d/99-intel.conf
Section "Device"
Identifier "Intel Graphics"
Driver "intel"
Option "TripleBuffer" "true"
Option "TearFree" "true"
EndSection
All of my problems seem to be linked to a kernel change. All is good now on latest kernel. 5.14 I think? Whatever was being used, (5.13 I am guessing from memory,) left me with a black screen and a mouse cursor after login.
not work for me Steam is allready black with steam-runtime or steam-native beta and stable
papajoke
Split this topic
16 September 2021 13:40
62
A post was merged into an existing topic: Manjaro 21.1.2 Pahvo released!
I’m not sure if our issues are exactly the same, but the Rofi part certainly looks similar. For me, starting Rofi gave me errors, and when I fixed that, the theme was weird.
The errors happened because in my keybinding, I passed Rofi some options that… apparently don’t work that way anymore. I moved those settings out of the command and into my config file.
The theme issue was caused by a change in how Rofi handles default themes . Found here , where there is advice that I overlooked, too, in a comment, oops. As I understand it, settings from the default theme were now messing up the theme that I was actually using, and at the same time, I think other parts that were loaded from somewhere before were missing.
I fixed the first part by moving the theme parts to a separate mytheme.rasi file (for some reason it was all in one) and adding @theme "mytheme"in the configuration rasi. (For me, those files are in ~/.config/rofi.) After that, the basic shape and colors were right again, yay. For the second part, I had to look around and piece together what was missing, and add that to my theme file, too. I don’t remember what exactly, but it wasn’t a lot, I was surprised by how painless this was.
Yochanan
Split this topic
16 September 2021 17:08
64
