Hi
Cannot upgrade, linux58-ndiswrapper is needed but I cant find it., as known, it is required by linux-latest-ndiswrapper…
Anyone have a clever trick?
Thanks
Melissa
Edit - upon close inspection, I noticed that L58 is not installed. So…I can “gloss” over this?
How did you survive the update problem? The one where ndiswrapper is missing?
Super workaround! Thanks
I’ve know it but I couldn’t resolve keyboard issue so had to revoke new update.
Manjaro team, you rock!
TTY does not work here… Before doing the update I tried to log in via Ctrl+Alt+F3, as usual, though the TV kept the “No Video Input” signal. So I’ve updated on TTY1 editing the grub menu.
I can tell it was the previous update that removed the option to go to TTY3, and that this update did not change that.
I’ve found very weird that Ctrl+Alt+F3 would stop working, maybe it’s an easy fix, so any help is appreciated.
Everything else on the OS is fine.
(5.4.64-1 Gnome)
Thanks!
(This page could be helpful, that is, if I could access it…
https://forum.manjaro.org/t/cannot-open-virtual-console-tty-on-manjaro-budgie/5350
▶ xmodmap -pke | grep Switch
keycode 67 = F1 F1 F1 F1 F1 F1 XF86Switch_VT_1
keycode 68 = F2 F2 F2 F2 F2 F2 XF86Switch_VT_2
keycode 69 = F3 F3 F3 F3 F3 F3 XF86Switch_VT_3
keycode 70 = F4 F4 F4 F4 F4 F4 XF86Switch_VT_4
keycode 71 = F5 F5 F5 F5 F5 F5 XF86Switch_VT_5
keycode 72 = F6 F6 F6 F6 F6 F6 XF86Switch_VT_6
keycode 73 = F7 F7 F7 F7 F7 F7 XF86Switch_VT_7
keycode 74 = F8 F8 F8 F8 F8 F8 XF86Switch_VT_8
keycode 75 = F9 F9 F9 F9 F9 F9 XF86Switch_VT_9
keycode 76 = F10 F10 F10 F10 F10 F10 XF86Switch_VT_10
keycode 95 = F11 F11 F11 F11 F11 F11 XF86Switch_VT_11
keycode 96 = F12 F12 F12 F12 F12 F12 XF86Switch_VT_12
▶ systemctl list-units | grep getty
getty@tty2.service
loaded active running Getty on tty2
getty@tty3.service
loaded active running Getty on tty3
getty@tty4.service
loaded active running Getty on tty4
getty@tty5.service
loaded active running Getty on tty5
getty@tty6.service
loaded active running Getty on tty6
system-getty.slice
loaded active active system-getty.slice
getty.target
loaded active active Login Prompts
It’s been two weeks and no issues with this update - thank you
