Hello,
I’ve had this problem for a few weeks now. I can connect via SSH over my LAN which uses just a password, and it works fine. When I try to SSH to my Digital Ocean droplet, the SSH command just hangs. I can connect to the droplet via the portal interface on their website, and all the services are up on its end. I’ve tried creating a new droplet and I cannot connect from my laptop, but can still get to it from their interface. I’m using Yaquake if that matters.
ssh -vvv user@ip.add.ress
shows the server accepting the public key, but then stops at debug3: sign_and_send_pubkey: signing using rsa-sha2-512 SHA256
and never prompts for the passphtase. I am using key-based authentication and not logging in as root (as that’s disabled). Any thoughts?
Without further information, such as the full debug log, I would assume that it is sshd on the server that is blocking the client. After the mentioned line, the client usually sends a packet of type 50. If this does not happen, the server is incorrectly configured.
What can I check on server? This is a connection that’s worked for 2+ years that suddenly stopped.
The config of the sshd server sshd_config
? Probably the path to authorized_keys
is wrong or alternated… However, if the password authentication works, then it is strictly the config of public key authentication.
Thanks!
- Key from Digital Ocean exactly matches my
id_rsa.pub
- Firewall is allowing port 22
- Restarted VM and thus SSH, same problem occurs
- Trying with Konsole hangs at the same portion
Checking /var/log/auth.log
on the server shows this line whenever I disconnect from the hung SSH connection in my terminal window - it does not show any sort of connection information.
Connection closed by authenticating user user@ip.add.ress port xxxxx [preauth]
where the xxxxx
is a port number that varies.
