I am currently running into the following issue. I am a student at a university which provides a VPN. Due to my master thesis I need to work on a computer with much GPU power and the university therefore provides one which I can use via ssh. However this is just possible if I am inside the network of the university. Therefore when working form home I am using the university’s VPN.
This VPN is a using OpenConnect as protocol and it is working for me so far (I can access sites which can only be accesed via the internal network for example).
However, when I now try to connect to the remote desktop via ssh (which also works when I am inside the university network and not the VPN). I get the error
ssh: connect to host … port 209: No route to host
I tried to find a solution, however nothing suited my problem so far and I have no guess what I should try.
It’s anyone’s guess without knowing network topology. As error suggests there is a route missing.
On what subnet are reachable sites located? It’s not the same subnet as your “gpu-PC” I guess.
Why did you replace “gpu-PC” IP with 3 dots, is it not a private IP (ie. 192.168.x.x, 10.x.x.x, 172.16-31.x.x)?
I just drove to the university and now it does not even work when I am not using the VPN. It seems that something broke over the weekend, it worked with no problems before I tried to connect from home.
The remote desktop is used by several people and students via ssh and also from home via VPN so I guess if there is a problem it must be on my side. I can ping the server so it is not shut down I guess.
The ip does not start with 192.168.x.x, 10.x.x.x, 172.16-31.x.x, so I do not know about posting it here or not. My guess was it is not relevant for resolving the topic?
The output of
ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp8s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether 7c:d3:0a:82:b5:df brd ff:ff:ff:ff:ff:ff
3: wlp9s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 50:e0:85:b9:f7:99 brd ff:ff:ff:ff:ff:ff
inet 172.18.75.139/18 brd 172.18.127.255 scope global dynamic noprefixroute wlp9s0
valid_lft 2812sec preferred_lft 2812sec
inet6 2001:41b8:83c:fa01:17b3:faac:372e:edb8/64 scope global dynamic noprefixroute
valid_lft 86386sec preferred_lft 43186sec
inet6 fe80::b3e9:c78e:fa02:5385/64 scope link noprefixroute
4: vpn0: <NO-CARRIER,POINTOPOINT,MULTICAST,NOARP,UP> mtu 1356 qdisc fq_codel state DOWN group default qlen 500
link/none
inet6 fe80::2e08:826:d6cd:e736/64 scope link stable-privacy
and
ip r
default via 172.18.127.254 dev wlp9s0 proto dhcp metric 600
172.18.64.0/18 dev wlp9s0 proto kernel scope link src 172.18.75.139 metric 600
Well, it seems that it is really an internal problem of the university… I just called some people and and it seems that everybody else also has issues. I was told that I can ping since the router is available but the connection to the actual PCs is not working.
Still thanks for all the help, I will wait until the issues are resolved and see if the problem is gone!
