SSD Meldet E/A Fehler
Hallo zusammen,
meine SSD lässt sich nicht mehr partitionieren. Bekomme jedes Mal E/A Fehler. Egal welches Tool oder an welchem PC ich die Festplatte anschließe.
Vorher war Windows 10 mit Bitlocker drauf. Hat bis dato einwandfrei funktioniert.
Anbei mal die Ausgabe von smartctl --all:
smartctl 7.0 2018-12-30 r4883 [x86_64-linux-5.1.8-1-MANJARO] (local build)
Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Crucial/Micron BX/MX1/2/3/500, M5/600, 1100 SSDs
Device Model: Crucial_CT500MX200SSD1
LU WWN Device Id: 5 00a075 112465418
Firmware Version: MU05
User Capacity: 500.107.862.016 bytes [500 GB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-3 T13/2161-D revision 4
SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Thu Jun 20 12:36:57 2019 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x80) Offline data collection activity
was never started.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 1325) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 7) minutes.
Conveyance self-test routine
recommended polling time: ( 3) minutes.
SCT capabilities: (0x0035) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 100 100 000 Pre-fail Always - 75
5 Reallocate_NAND_Blk_Cnt 0x0032 100 100 010 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 4921
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 1253
171 Program_Fail_Count 0x0032 100 100 000 Old_age Always - 0
172 Erase_Fail_Count 0x0032 100 100 000 Old_age Always - 0
173 Ave_Block-Erase_Count 0x0032 100 100 000 Old_age Always - 16
174 Unexpect_Power_Loss_Ct 0x0032 100 100 000 Old_age Always - 110
180 Unused_Reserve_NAND_Blk 0x0033 000 000 000 Pre-fail Always - 5566
183 SATA_Interfac_Downshift 0x0032 100 100 000 Old_age Always - 8
184 Error_Correction_Count 0x0032 100 100 000 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
194 Temperature_Celsius 0x0022 073 058 000 Old_age Always - 27 (Min/Max 14/42)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 100 100 000 Old_age Always - 0
202 Percent_Lifetime_Remain 0x0030 100 100 001 Old_age Offline - 0
206 Write_Error_Rate 0x000e 100 100 000 Old_age Always - 0
210 Success_RAIN_Recov_Cnt 0x0032 100 100 000 Old_age Always - 0
246 Total_Host_Sector_Write 0x0032 100 100 000 Old_age Always - 12378755815
247 Host_Program_Page_Count 0x0032 100 100 000 Old_age Always - 387450792
248 FTL_Program_Page_Count 0x0032 100 100 000 Old_age Always - 182086009
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Ich brauche mehr Details :slight_smile: (Didi Hallervorden)
Welche tools?
gparted?
gnome-laufwerke (gnome-disk-utility)?
Laufwerk ausgehängt?
Erst löschen,formatieren dann partitionieren.
Tools: gdfisk, fdisk und gparted
SSD war immer ausgehängt
Ich habe keine Fehler gemacht. Was sagt mir der Fehler? Ist die SSD defekt oder kann ich die noch irgendwie fixen?
Dann mal folgendes durcharbeiten.
Danke für nichts.
Irgendwelche Meldungen in journalctl -g ata ?
Hast du auch die SATA- und Stromkabel überprüft?
Bitte ausserdem Code Tags (das </> Symbol in der Toolbar) für die Ausgabe verwenden, ist sonst nur sehr schwer zu lesen.
Zum schnellen Löschen der SSD kannst du
blkdiscard /dev/sdX
verwenden (Achtung, Daten sind dann weg!).
Ob das Teil defekt ist, kann ich nicht sagen, wenn sie aber gleich an mehreren PCs nicht funktioniert, könnte es durchaus der Fall sein.
Denke auch, dass sie defekt ist.
fdisk /dev/sdb und dann mit o eine neue Partitionstabelle schreiben geht, aber eine Partition anlegen schlägt immer fehl.
Hi! Hast du auch ein Dateisystem formatiert bzw. erstellt mit z.B. mkfs.ext4 ? Das habe ich schon öfters vergessen und bekam dann das große Wundern. :sweat_smile:
Ja, habe ich. Sie ist anscheinend wirklich defekt. Habe mir mittlerweile eine neue SSD bestellt. :frowning_face:
Trotzdem Danke für deinen Tipp!
Ich habe eben nochmal das Manjaro- USB geladen. Da ist doch tatsächlich das S.m.a.r.t- Tool installiert. Mit "smartctl " kannst du vielleicht den Fehlerspeicher der SSD auslesen, falls die so etwas hat. Ich bin mir aber zu 90% sicher,dass die defekt ist. :confused:
Das SATA Kabel könnte auch defekt sein.
