Hi,
i use Manjaro LXQt (both last update). After QtWebEngine last update, Spyder fails to load.
Here the output:
File "/usr/bin/spyder", line 8, in <module>
sys.exit(main())
File "/usr/lib/python3.13/site-packages/spyder/app/start.py", line 281, in main
mainwindow.main(options, args)
File "/usr/lib/python3.13/site-packages/spyder/app/mainwindow.py", line 1400, in main
mainwindow = create_window(MainWindow, app, splash, options, args)
File "/usr/lib/python3.13/site-packages/spyder/app/utils.py", line 360, in create_window
main.setup()
File "/usr/lib/python3.13/site-packages/spyder/app/mainwindow.py", line 690, in setup
internal_plugins = find_internal_plugins()
File "/usr/lib/python3.13/site-packages/spyder/app/find_plugins.py", line 45, in find_internal_plugins
mod = importlib.import_module(entry_point.module)
File "/usr/lib/python3.13/importlib/__init__.py", line 88, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 1023, in exec_module
File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
File "/usr/lib/python3.13/site-packages/spyder/plugins/help/plugin.py", line 26, in <module>
from spyder.plugins.help.widgets import HelpWidget
File "/usr/lib/python3.13/site-packages/spyder/plugins/help/widgets.py", line 44, in <module>
from qtpy.QtWebEngineWidgets import WEBENGINE
File "/usr/lib/python3.13/site-packages/qtpy/QtWebEngineWidgets.py", line 28, in <module>
from PyQt5.QtWebEngineWidgets import (
...<5 lines>...
RuntimeError: PyQt5.QtWebEngineWidgets cannot import type '����' from PyQt5.QtCore
Anybody has a solution and can explain? Is this a problem have i to report to LXQt GitHub too?
Thanks.
