Spotifyd and spotifyd.service
Hello guys,
Something I don’t understand: I’ve installed spotifyd which is in community repository.
The files are:
/usr/bin/spotifyd
/usr/lib/systemd/user/spotifyd.service
With the terminal when I launch spotifyd: nothing happen.
When I want launch it by systemctl:
sudo systemctl start spotifyd.service
The answer is:
Failed to start spotifyd.service: Unit spotifyd.service not found.
On github, there is no explanation. How can I use this?
Thanks for helping
systemctl doesnt need sudo .. and
Looks like you should use it as a user unit .. ie:
systemctl --user start spotifyd
True. Check app’s wiki. You will need to configure it.
