I’m running Manjaro KDE Plasma. Snap is installed and I ran sudo snap install, no issues. When trying to run Spotify from the terminal I get Failed to load module "canberra-gtk-module" Trace/breakpoint trap (core dumped)
And nothing happens when I run Spotify from krunner or rofi.
How can I make Spotify launch?
After doing sudo pacman -Syu libcanberra it still gives me the same message. I’ve also tried pamac build spotify but it gives me the error ERROR: One or more PGP signatures could not be verified! Error: failed to build spotify
If you want to try the AUR version, please remove the spotify version first just to be on the safe side. You need to run curl -sS https://download.spotify.com/debian/pubkey.gpg | gpg --import - as per this pinned comment before you run pamac build spotify.
