I recently installed spotify-launcher
When I try to start it for the first time, it tries to perform an update that cannot be downloaded
> spotify-launcher
[2024-06-04T12:45:30Z INFO spotify_launcher::config] Loading configuration file at "/etc/spotify-launcher.conf"
[2024-06-04T12:45:30Z INFO spotify_launcher::apt] Downloading release file...
[2024-06-04T12:45:30Z INFO spotify_launcher::apt] Downloading signature...
[2024-06-04T12:45:31Z INFO spotify_launcher::apt] Verifying pgp signature...
[2024-06-04T12:45:31Z INFO spotify_launcher::apt] Signature verified successfully!
[2024-06-04T12:45:31Z INFO spotify_launcher::apt] Downloading package index...
[2024-06-04T12:45:31Z INFO spotify_launcher::apt] Verifying with sha256sum hash...
[2024-06-04T12:45:31Z INFO spotify_launcher::apt] Downloading deb file for "spotify-client_1.2.37.701.ge66eb7bc_amd64.deb" version="spotify-client" ("1:1.2.37.701.ge66eb7bc")
[2024-06-04T12:45:31Z INFO spotify_launcher::apt] Retrying download...
This option is not available. Please see --help for all possible usages.
[2024-06-04T12:45:31Z WARN spotify_launcher::apt] Download has failed: Broken pipe (os error 32)
[2024-06-04T12:45:32Z WARN spotify_launcher::apt] Download has failed: Broken pipe (os error 32)
[2024-06-04T12:45:32Z INFO spotify_launcher::apt] Retrying download...
[2024-06-04T12:45:33Z WARN spotify_launcher::apt] Download has failed: Broken pipe (os error 32)
[2024-06-04T12:45:33Z INFO spotify_launcher::apt] Retrying download...
Error: Exceeded number of retries for download
> cat /etc/spotify-launcher.conf
[spotify]
## Pass extra arguments to the spotify executable
## You can test this with `spotify-launcher -v --skip-update --no-exec`
#extra_arguments = []
## On HiDPI displays spotify doesn't pick up the scale factor automatically
#extra_arguments = ["--force-device-scale-factor=2.0"]
## On wayland you might need
#extra_arguments = ["--enable-features=UseOzonePlatform", "--ozone-platform=wayland"]
## How often to try to resume the download until giving up (0 for unlimited)
#download_attempts = 5
[spotify]
#extra_arguments = ["--skip-update"]
still not working
spotify-launcher
[2024-06-04T13:37:08Z INFO spotify_launcher::config] Loading configuration file at "/etc/spotify-launcher.conf"
[2024-06-04T13:37:08Z INFO spotify_launcher::apt] Downloading release file...
[2024-06-04T13:37:09Z INFO spotify_launcher::apt] Downloading signature...
[2024-06-04T13:37:09Z INFO spotify_launcher::apt] Verifying pgp signature...
[2024-06-04T13:37:09Z INFO spotify_launcher::apt] Signature verified successfully!
[2024-06-04T13:37:09Z INFO spotify_launcher::apt] Downloading package index...
[2024-06-04T13:37:10Z INFO spotify_launcher::apt] Verifying with sha256sum hash...
[2024-06-04T13:37:10Z INFO spotify_launcher::apt] Downloading deb file for "spotify-client_1.2.37.701.ge66eb7bc_amd64.deb" version="spotify-client" ("1:1.2.37.701.ge66eb7bc")
[2024-06-04T13:37:10Z INFO spotify_launcher::apt] Retrying download...
[2024-06-04T13:37:10Z WARN spotify_launcher::apt] Download has failed: Broken pipe (os error 32)
[2024-06-04T13:37:11Z WARN spotify_launcher::apt] Download has failed: Broken pipe (os error 32)
[2024-06-04T13:37:11Z INFO spotify_launcher::apt] Retrying download...
[2024-06-04T13:37:12Z WARN spotify_launcher::apt] Download has failed: Broken pipe (os error 32)
i also tried
[spotify]
#extra_arguments = ["--force-device-scale-factor=2.0","--skip-update"]
#extra_arguments = ["--enable-features=UseOzonePlatform", "--ozone-platform=wayland","--skip-update"]
[spotify]
spotify-launcher
[2024-06-04T13:57:12Z INFO spotify_launcher::config] Loading configuration file at "/etc/spotify-launcher.conf"
[2024-06-04T13:57:12Z INFO spotify_launcher::apt] Downloading release file...
[2024-06-04T13:57:12Z INFO spotify_launcher::apt] Downloading signature...
[2024-06-04T13:57:13Z INFO spotify_launcher::apt] Verifying pgp signature...
[2024-06-04T13:57:13Z INFO spotify_launcher::apt] Signature verified successfully!
[2024-06-04T13:57:13Z INFO spotify_launcher::apt] Downloading package index...
[2024-06-04T13:57:13Z INFO spotify_launcher::apt] Verifying with sha256sum hash...
[2024-06-04T13:57:13Z INFO spotify_launcher::apt] Downloading deb file for "spotify-client_1.2.37.701.ge66eb7bc_amd64.deb" version="spotify-client" ("1:1.2.37.701.ge66eb7bc")
[2024-06-04T13:57:13Z INFO spotify_launcher::apt] Retrying download...
[2024-06-04T13:57:13Z WARN spotify_launcher::apt] Download has failed: Broken pipe (os error 32)
[2024-06-04T13:57:14Z WARN spotify_launcher::apt] Download has failed: Broken pipe (os error 32)
[2024-06-04T13:57:14Z INFO spotify_launcher::apt] Retrying download...
[2024-06-04T13:57:15Z WARN spotify_launcher::apt] Download has failed: Broken pipe (os error 32)
[2024-06-04T13:57:15Z INFO spotify_launcher::apt] Retrying download...
There would likely be related directories under ~/.config, but as I don’t use Spotify I’m hesitant to suggest deleting those; you might lose settings you want to keep; ofcourse, you could always recreate them. Again; not a Spotify user, so don’t take this as a recommendation.
