Hello,
I haven’t updated my old laptop in a while. After doing so I got this error
when I launch Spotify (flatpak) and Kodi.
Spotify:
[jesuslinux@T2310 ~]$ flatpak run --branch=stable --arch=x86_64 --command=spotify --file-forwarding com.spotify.Client
[jesuslinux@T2310 ~]$ Gtk-Message: 20:30:09.350: Failed to load module "xapp-gtk3-module"
Gtk-Message: 20:30:09.350: Failed to load module "canberra-gtk-module"
libva error: /usr/lib/x86_64-linux-gnu/dri/intel-vaapi-driver/iHD_drv_video.so init failed
libva error: /usr/lib/x86_64-linux-gnu/dri/intel-vaapi-driver/i965_drv_video.so init failed
Kodi starts and crashes immediately:
[jesuslinux@T2310 ~]$ kodi
libva error: /usr/lib/dri/i965_drv_video.so init failed
terminate called after throwing an instance of 'fmt::v11::format_error'
what(): string pointer is null
/usr/bin/kodi: line 215: 2160 Aborted (core dumped) ${KODI_BINARY} ${ENV_ARGS} $SAVED_ARGS
Crash report available at /home/jesuslinux/kodi_crashlog-20241206_200816.log
System info:
[jesuslinux@T2310 ~]$ inxi -zv8
Kernel: 6.6.63-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
clocksource: hpet avail: acpi_pm
root=UUID=bcf193ee-4a85-4d7a-af9a-2608b263d116 rw apparmor=1
bootsplash.bootfile=/bootsplash-themes/manjaro/bootsplash
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: light-locker vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: TOSHIBA product: Satellite L40 v: PSL48E-01T00GPT
Mobo: TOSHIBA model: Satellite L40 v: 1.0 serial: <superuser required>
uuid: <superuser required> BIOS: American Megatrends v: 1.50
date: 08/21/2007
ID-1: BAT0 charge: 11.2 Wh (84.8%) condition: 13.2/44.0 Wh (30.0%)
volts: 9.9 min: 11.1 model: TOSASU NS2P3SZPHIWR type: Li-ion serial: N/A
status: not charging
System RAM: total: 3 GiB available: 2.9 GiB used: 1.37 GiB (47.4%)
Array-1: capacity: 8 GiB slots: 2 modules: 2 EC: None
max-module-size: 4 GiB note: est.
Device-1: SODIMM0 type: DDR2 detail: synchronous size: 1024 MiB speed: N/A
volts: N/A width (bits): data: 64 total: 64 manufacturer: N/A part-no: N/A
serial: <filter>
Device-2: SODIMM1 type: DDR2 detail: synchronous size: 2 GiB speed: N/A
serial: <filter>
Info: model: Intel Pentium Dual T2310 bits: 64 type: MCP arch: Core2 Merom
level: v1 built: 2006-09 process: Intel 65nm family: 6 model-id: 0xF (15)
stepping: 0xD (13) microcode: 0xA4
Topology: cpus: 1x dies: 1 clusters: 1 cores: 2 smt: <unsupported> cache:
L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 1024 KiB desc: 1x1024 KiB
Speed (MHz): avg: 798 min/max: 800/1467 scaling: driver: acpi-cpufreq
governor: schedutil cores: 1: 798 2: 798 bogomips: 5854
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc
cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts est fpu fxsr ht lahf_lm lm mca
mce mmx monitor msr mtrr nopl nx pae pat pbe pdcm pebs pge pni pse pse36
pti rep_good sep sse sse2 ssse3 syscall tm tm2 tsc vme xtpr
Type: itlb_multihit status: KVM: VMX unsupported
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT disabled
Type: spectre_v2 mitigation: Retpolines; STIBP: disabled; RSB filling;
Device-1: Intel Mobile GM965/GL960 Integrated Graphics vendor: Toshiba
driver: i915 v: kernel arch: Gen-4 process: Intel 65n built: 2006-07 ports:
active: LVDS-1 empty: VGA-1 bus-ID: 00:02.0 chip-ID: 8086:2a02
class-ID: 0300
Display: x11 server: X.Org v: 21.1.14 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1280x800 s-dpi: 96 s-size: 338x211mm (13.31x8.31")
s-diag: 398mm (15.69")
Monitor-1: LVDS-1 model: LG Philips 0xdd00 built: 2006 res: 1280x800
hz: 60 dpi: 98 gamma: 1.2 chroma: red: x: 0.600 y: 0.349 green: x: 0.325
y: 0.553 blue: x: 0.153 y: 0.145 white: x: 0.314 y: 0.329
size: 331x207mm (13.03x8.15") diag: 390mm (15.4") ratio: 16:10
modes: 1280x800
API: OpenGL Message: Unable to show GL data. glxinfo is missing.
Device-1: Intel 82801H HD Audio vendor: Toshiba driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:284b class-ID: 0403
API: ALSA v: k6.6.63-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.2.7 status: off tools: pw-cli
Server-4: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
Device-1: Realtek RTL-8100/8101L/8139 PCI Fast Ethernet Adapter
vendor: Toshiba driver: 8139too v: 0.9.28 modules: 8139cp port: c800
bus-ID: 05:07.0 chip-ID: 10ec:8139 class-ID: 0200
IF: enp5s7 state: unknown speed: 100 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8187B Wireless Adapter driver: rtl8187 type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-2:2 chip-ID: 0bda:8197
class-ID: 0000 serial: <filter>
IF: wlp0s26f7u2 state: up mac: <filter>
Info: services: NetworkManager,wpa_supplicant
Local Storage: total: 111.79 GiB used: 48.12 GiB (43.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37120G
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: SSD serial: <filter> fw-rev: 61K1 scheme: MBR
Optical-1: /dev/sr0 vendor: ■■■■■■■■ model: DVD-RAM UJ-850S rev: 1.10
dev-links: cdrom
ID-1: / raw-size: 35.78 GiB size: 34.92 GiB (97.60%) used: 24.88 GiB (71.3%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: bcf193ee-4a85-4d7a-af9a-2608b263d116
ID-2: /mnt/0842f047-cca4-473d-9e04-ca63ff88dca6 raw-size: 35.75 GiB
size: 34.89 GiB (97.60%) used: 22.49 GiB (64.5%) fs: ext4 dev: /dev/sda1
maj-min: 8:1 label: N/A uuid: 0842f047-cca4-473d-9e04-ca63ff88dca6
ID-3: /mnt/6a948e29-789f-4b07-96f1-797aa68ce297 raw-size: 37.26 GiB
size: 36.38 GiB (97.63%) used: 24 KiB (0.0%) fs: ext4 dev: /dev/sda3
maj-min: 8:3 label: N/A uuid: 6a948e29-789f-4b07-96f1-797aa68ce297
ID-1: swap-1 type: partition size: 3 GiB used: 768.9 MiB (25.0%)
priority: -2 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 12caca66-24a5-4411-ba75-caf759eb2f9b
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 1.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001
Hub-2: 2-0:1 info: full speed or root hub ports: 4 rev: 2.0
Device-1: 2-2:2 info: Realtek RTL8187B Wireless Adapter type: Network
driver: rtl8187 interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 0bda:8197 class-ID: 0000 serial: <filter>
Hub-3: 3-0:1 info: full speed or root hub ports: 6 rev: 2.0
Hub-4: 4-0:1 info: full speed or root hub ports: 2 rev: 1.1
Hub-5: 5-0:1 info: full speed or root hub ports: 2 rev: 1.1
Hub-6: 6-0:1 info: full speed or root hub ports: 2 rev: 1.1
Device-1: 6-1:2 info: MosArt Full-Speed Mouse type: mouse
lanes: 1 mode: 1.1 power: 100mA chip-ID: 062a:6728 class-ID: 0301
Hub-7: 7-0:1 info: full speed or root hub ports: 2 rev: 1.1
System Temperatures: cpu: 60.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: 1399 pm: pacman pkgs: 1377 libs: 436 tools: pamac,yay pm: flatpak
pkgs: 22
1: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 175
1: cpu: 300% command: ps pid: 6202 mem: 3.38 MiB (0.1%)
2: cpu: 22.7% command: firefox pid: 5974 mem: 249.6 MiB (8.4%)
3: cpu: 19.7% command: firefox pid: 2269 mem: 359.9 MiB (12.1%)
4: cpu: 3.4% command: Xorg pid: 872 mem: 47.9 MiB (1.6%)
5: cpu: 2.4% command: [kswapd0] pid: 49 mem: 0.00 MiB (0.0%)
Memory top: 5 of 175
1: mem: 359.9 MiB (12.1%) command: firefox pid: 2269 cpu: 19.7%
2: mem: 249.6 MiB (8.4%) command: firefox pid: 5974 cpu: 22.7%
3: mem: 135.9 MiB (4.5%) command: firefox pid: 3395 cpu: 1.6%
4: mem: 98.9 MiB (3.3%) command: firefox pid: 2394 cpu: 1.1%
5: mem: 91.6 MiB (3.0%) command: firefox pid: 2608 cpu: 1.4%
Processes: 175 Power: uptime: 1h 9m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 1.15 GiB services: upowerd,xfce4-power-manager
Init: systemd v: 256 default: graphical tool: systemctl
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Bash v: 5.2.37
running-in: xfce4-terminal inxi: 3.3.36
Any help on this?
Thanks
