Sporadic I/O errors on NVME
I’ve been seeing these hangs for some time now. I did not post earlier, since I was still trying out suggestions I found online.
inxi -Fxz:
  Kernel: 6.6.40-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
  Desktop: KDE Plasma v: 6.0.5 Distro: Manjaro base: Arch Linux
  Type: Laptop System: LENOVO product: 21BVCTO1WW v: ThinkPad T16 Gen 1
    serial: <superuser required>
  Mobo: LENOVO model: 21BVCTO1WW v: SDK0T76463 WIN
    serial: <superuser required> UEFI: LENOVO v: N3MET20W (1.19 )
    date: 04/30/2024
  ID-1: BAT0 charge: 86.0 Wh (99.0%) condition: 86.9/86.0 Wh (101.0%)
    volts: 17.4 min: 15.5 model: Sunwoda 5B10W51873 status: full
  Info: 10-core (2-mt/8-st) model: 12th Gen Intel Core i5-1245U bits: 64
    type: MST AMCP arch: Alder Lake rev: 4 cache: L1: 928 KiB L2: 6.5 MiB
    L3: 12 MiB
  Speed (MHz): avg: 762 high: 1792 min/max: 400/4400:3300 cores: 1: 684
    2: 579 3: 1792 4: 400 5: 687 6: 1223 7: 400 8: 400 9: 400 10: 1789 11: 400
    12: 400 bogomips: 59916
  Device-1: Intel Alder Lake-UP3 GT2 [Iris Xe Graphics] vendor: Lenovo
    driver: i915 v: kernel arch: Gen-12.2 bus-ID: 00:02.0
  Device-2: Chicony Integrated Camera driver: uvcvideo type: USB
    bus-ID: 3-4:3
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1 driver: X:
    loaded: modesetting dri: iris gpu: i915 resolution: 1920x1200~60Hz
  API: EGL v: 1.5 drivers: iris,swrast platforms:
    active: x11,surfaceless,device inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.3-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
  API: Vulkan v: 1.3.279 drivers: intel surfaces: xcb,xlib devices: 1
  Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo
    driver: sof-audio-pci-intel-tgl bus-ID: 00:1f.3
  API: ALSA v: k6.6.40-1-MANJARO status: kernel-api
  Server-1: sndiod v: N/A status: off
  Server-2: EsounD v: 0.2.41 status: off
  Server-3: NAS v: 1.9.4 status: off
  Server-4: PipeWire v: 1.2.1 status: active
  Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3
  Device-2: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6
  IF: enp0s31f6 state: down mac: <filter>
  IF-ID-1: br-8e0e69574768 state: down mac: <filter>
  IF-ID-2: docker0 state: down mac: <filter>
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB
    bus-ID: 3-10:7
  Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.3
    lmp-v: 12
  Local Storage: total: 1.86 TiB used: 1004.66 GiB (52.7%)
  ID-1: /dev/nvme0n1 vendor: Lexar model: SSD NM790 2TB size: 1.86 TiB
    temp: 53.9 C
  ID-1: / size: 1.86 TiB used: 1004.66 GiB (52.7%) fs: btrfs
    dev: /dev/nvme0n1p2
  ID-2: /boot/efi size: 299.4 MiB used: 660 KiB (0.2%) fs: vfat
    dev: /dev/nvme0n1p1
  ID-3: /home size: 1.86 TiB used: 1004.66 GiB (52.7%) fs: btrfs
    dev: /dev/nvme0n1p2
  ID-1: swap-1 type: file size: 80 GiB used: 0 KiB (0.0%) file: /swap/swapfile
  System Temperatures: cpu: 42.0 C mobo: N/A
  Fan Speeds (rpm): fan-1: 1868
  Memory: total: 48 GiB note: est. available: 46.73 GiB used: 7.43 GiB (15.9%)
  Processes: 343 Uptime: 39m Init: systemd
  Packages: 4152 Compilers: clang: 18.1.8 gcc: 14.1.1 Shell: Zsh v: 5.9
    inxi: 3.3.35
At first, I got I/O errors several times in situations where the laptop was connected to a projector through HDMI. Suddenly, the only drive, an NVME SSD, became unavailable giving I/O errors with every access. But then I also saw similar situations without anything connected to HDMI, but less often.
Recently, it seemed to happen more often when resuming the laptop. In these cases I often was able to run mount and saw that the file systems from the SSD had all been degraded to read-only.
Following suggestions found in forums I set the BIOS sleep mode to “Linux S3” and also added nvme_core.default_ps_max_latency_us=0 to the boot parameters. So now I have cat /proc/cmdline
BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64 root=UUID=477c07a4-431c-49c7-90ee-31aa9350aa89 rw rootflags=subvol=@ quiet efi=runtime nvme_core.default_ps_max_latency_us=0
Of course, when this happens the log files do not contain any information, since they are on the SSD that becomes unavailable.
I had suspected that this might be because of the SSD becoming bad (even though it was still quite new) and I wanted to larger SSD, so I replaced the SSD, but the problem is still the same. It’s also the same with an up-to-date 6.1 kernel.
I do not know how to further investigate this and would very much appreciate any suggestions.
Hi @mszsm,
Sporadic, in my opinion, usually points to hardware. And since the disk had been replaced, my conclusion is that it’s either the connector, or the controller that’s faulty. I suspect you’ll need to take the laptop in for diagnostics and repairs.
You might also check your BIOS and see whether there’s a choice between AHCI and NVMe, for example, and that the correct one is selected, and compatible with your NVMe disk.
You’ll likely need to make that judgement call yourself, as there are many different BIOS implementations. Your mainboard manual will no doubt be helpful.
Did you was checking your journal for this I/O errors before?
I ask this because i dont know if this error’s maybe persist long time before you firstly saw them occurred.
Clean your connector with a Vacuum cleaner (watch out for Metal contact) or use Air Pressure.
Check if your Internal SDD screw fits and hold the device perfectly in place.
When you talk about sporadic, do you move your Laptop while using it? Use your Laptop static at one place, for a while and check for errors.
I do not move the laptop while it’s running.
No journal available since that’s on the same drive.
There’s no such choice for the drive in the BiOS.
Your filesystem is btrfs:
Btrfs is reset to read-only every time it detects that data in the file system is corrupted!!!
The reason for the corruption cannot be specified by btrfs. Because the way to detect it is the checksums of the blocks in the file system. Why they are wrong cannot be determined at the moment of discovery.
Possible causes:
  • Error in btrfs (not impossible, but unlikely)
  • Faulty disk (very likely if it is a hard disk). With an SSD, it is rather unlikely that you are experiencing this error pattern. If the SSD is defective, the error pattern usually looks very different.
  • Error in the RAM :+1: (All data is collected in RAM, then provided with checksums, and only written “later”)
  • Error in the CPU (unlikely)
  • Connectors (RAM?)
  • Cable ?
In any case, your system will collect damage with every single incident. btrfs without the RAID option cannot heal itself !!!
(Other file systems would not even notice the error :wink: )
You find good Information about Btrfs in the wiki
The other likely selection, along with the two previously mentioned, would be RAID. Most mainboards will have something similar; with laptops (intended for Windows) these settings may even be obfuscated to a degree.
Only your system documentation would know for sure.
I had somehow missed that your system is running on BTRFS (I know little about it apart from basics).
@andreas85 mentions the most likely scenario(s). I’d strongly suggest you heed the advice given in his post.
Cheers.
The thing that makes me suspect that this might not be hardware after all is that it happens almost exclusively right after resume. I haven’t actually counted, but I’d say at least 19 out of 20 times that it happens is right after resume. That’s why I was suspecting that some (btrfs?) process was kicking in at a time the SSD was still “asleep”…
Please provide the output for:
journalctl --priority=warning..crit --no-pager --boot=0
Where:
  • The --priority=warning..err argument limits the output to warnings and errors only;
  • --no-pager formats the output nicely for use here, on the forum;
  • the --boot=0 argument limits the messages to be from the current boot.
It’s rather lengthy… but here it comes.
Jul 29 15:40:28 allofthis kernel:   #1  #3
Jul 29 15:40:28 allofthis kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Jul 29 15:40:28 allofthis kernel: pnp 00:04: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
Jul 29 15:40:28 allofthis kernel: pnp 00:05: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
Jul 29 15:40:28 allofthis kernel: pnp 00:08: disabling [mem 0x000c0000-0x000c3fff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Jul 29 15:40:28 allofthis kernel: pnp 00:08: disabling [mem 0x000c8000-0x000cbfff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Jul 29 15:40:28 allofthis kernel: pnp 00:08: disabling [mem 0x000d0000-0x000d3fff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Jul 29 15:40:28 allofthis kernel: pnp 00:08: disabling [mem 0x000d8000-0x000dbfff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Jul 29 15:40:28 allofthis kernel: pnp 00:08: disabling [mem 0x00000000-0x0009ffff] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit]
Jul 29 15:40:28 allofthis kernel: pnp 00:08: disabling [mem 0x000c0000-0x000c3fff disabled] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit]
Jul 29 15:40:28 allofthis kernel: pnp 00:08: disabling [mem 0x000c8000-0x000cbfff disabled] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit]
Jul 29 15:40:28 allofthis kernel: pnp 00:08: disabling [mem 0x000d0000-0x000d3fff disabled] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit]
Jul 29 15:40:28 allofthis kernel: pnp 00:08: disabling [mem 0x000d8000-0x000dbfff disabled] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit]
Jul 29 15:40:28 allofthis kernel: pnp 00:08: disabling [mem 0x000e0000-0x000e3fff] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit]
Jul 29 15:40:28 allofthis kernel: pnp 00:08: disabling [mem 0x000e8000-0x000ebfff] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit]
Jul 29 15:40:28 allofthis kernel: pnp 00:08: disabling [mem 0x000f0000-0x000fffff] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit]
Jul 29 15:40:28 allofthis kernel: pnp 00:08: disabling [mem 0x00100000-0xa07fffff] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit]
Jul 29 15:40:28 allofthis kernel: pnp 00:08: disabling [mem 0x00000000-0x0009ffff disabled] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
Jul 29 15:40:28 allofthis kernel: pnp 00:08: disabling [mem 0x000c0000-0x000c3fff disabled] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
Jul 29 15:40:28 allofthis kernel: pnp 00:08: disabling [mem 0x000c8000-0x000cbfff disabled] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
Jul 29 15:40:28 allofthis kernel: pnp 00:08: disabling [mem 0x000d0000-0x000d3fff disabled] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
Jul 29 15:40:28 allofthis kernel: pnp 00:08: disabling [mem 0x000d8000-0x000dbfff disabled] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
Jul 29 15:40:28 allofthis kernel: pnp 00:08: disabling [mem 0x000e0000-0x000e3fff disabled] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
Jul 29 15:40:28 allofthis kernel: pnp 00:08: disabling [mem 0x000e8000-0x000ebfff disabled] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
Jul 29 15:40:28 allofthis kernel: pnp 00:08: disabling [mem 0x000f0000-0x000fffff disabled] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
Jul 29 15:40:28 allofthis kernel: pnp 00:08: disabling [mem 0x00100000-0xa07fffff disabled] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
Jul 29 15:40:28 allofthis kernel: hpet_acpi_add: no address or irqs in _CRS
Jul 29 15:40:28 allofthis kernel: blacklist: Duplicate blacklisted hash bin:80b4d96931bf0d02fd91a61e19d14f1da452e66db2408ca8604d411f92659f0a
Jul 29 15:40:28 allofthis kernel: blacklist: Duplicate blacklisted hash bin:f52f83a3fa9cfbd6920f722824dbe4034534d25b8507246b3b957dac6e1bce7a
Jul 29 15:40:28 allofthis kernel: blacklist: Duplicate blacklisted hash bin:c5d9d8a186e2c82d09afaa2a6f7f2e73870d3e64f72c4e08ef67796a840f0fbd
Jul 29 15:40:28 allofthis kernel: blacklist: Duplicate blacklisted hash bin:1aec84b84b6c65a51220a9be7181965230210d62d6d33c48999c6b295a2b0a06
Jul 29 15:40:28 allofthis kernel: blacklist: Duplicate blacklisted hash bin:c3a99a460da464a057c3586d83cef5f4ae08b7103979ed8932742df0ed530c66
Jul 29 15:40:28 allofthis kernel: blacklist: Duplicate blacklisted hash bin:58fb941aef95a25943b3fb5f2510a0df3fe44c58c95e0ab80487297568ab9771
Jul 29 15:40:28 allofthis kernel: blacklist: Duplicate blacklisted hash bin:5391c3a2fb112102a6aa1edc25ae77e19f5d6f09cd09eeb2509922bfcd5992ea
Jul 29 15:40:28 allofthis kernel: blacklist: Duplicate blacklisted hash bin:d626157e1d6a718bc124ab8da27cbb65072ca03a7b6b257dbdcbbd60f65ef3d1
Jul 29 15:40:28 allofthis kernel: blacklist: Duplicate blacklisted hash bin:d063ec28f67eba53f1642dbf7dff33c6a32add869f6013fe162e2c32f1cbe56d
Jul 29 15:40:28 allofthis kernel: blacklist: Duplicate blacklisted hash bin:29c6eb52b43c3aa18b2cd8ed6ea8607cef3cfae1bafe1165755cf2e614844a44
Jul 29 15:40:28 allofthis kernel: blacklist: Duplicate blacklisted hash bin:90fbe70e69d633408d3e170c6832dbb2d209e0272527dfb63d49d29572a6f44c
Jul 29 15:40:28 allofthis kernel: blacklist: Duplicate blacklisted hash bin:106faceacfecfd4e303b74f480a08098e2d0802b936f8ec774ce21f31686689c
Jul 29 15:40:28 allofthis kernel: blacklist: Duplicate blacklisted hash bin:174e3a0b5b43c6a607bbd3404f05341e3dcf396267ce94f8b50e2e23a9da920c
Jul 29 15:40:28 allofthis kernel: blacklist: Duplicate blacklisted hash bin:2b99cf26422e92fe365fbf4bc30d27086c9ee14b7a6fff44fb2f6b9001699939
Jul 29 15:40:28 allofthis kernel: blacklist: Duplicate blacklisted hash bin:2e70916786a6f773511fa7181fab0f1d70b557c6322ea923b2a8d3b92b51af7d
Jul 29 15:40:28 allofthis kernel: blacklist: Duplicate blacklisted hash bin:3fce9b9fdf3ef09d5452b0f95ee481c2b7f06d743a737971558e70136ace3e73
Jul 29 15:40:28 allofthis kernel: blacklist: Duplicate blacklisted hash bin:47cc086127e2069a86e03a6bef2cd410f8c55a6d6bdb362168c31b2ce32a5adf
Jul 29 15:40:28 allofthis kernel: blacklist: Duplicate blacklisted hash bin:71f2906fd222497e54a34662ab2497fcc81020770ff51368e9e3d9bfcbfd6375
Jul 29 15:40:28 allofthis kernel: blacklist: Duplicate blacklisted hash bin:82db3bceb4f60843ce9d97c3d187cd9b5941cd3de8100e586f2bda5637575f67
Jul 29 15:40:28 allofthis kernel: blacklist: Duplicate blacklisted hash bin:8ad64859f195b5f58dafaa940b6a6167acd67a886e8f469364177221c55945b9
Jul 29 15:40:28 allofthis kernel: blacklist: Duplicate blacklisted hash bin:8d8ea289cfe70a1c07ab7365cb28ee51edd33cf2506de888fbadd60ebf80481c
Jul 29 15:40:28 allofthis kernel: blacklist: Duplicate blacklisted hash bin:aeebae3151271273ed95aa2e671139ed31a98567303a332298f83709a9d55aa1
Jul 29 15:40:28 allofthis kernel: blacklist: Duplicate blacklisted hash bin:c409bdac4775add8db92aa22b5b718fb8c94a1462c1fe9a416b95d8a3388c2fc
Jul 29 15:40:28 allofthis kernel: blacklist: Duplicate blacklisted hash bin:c617c1a8b1ee2a811c28b5a81b4c83d7c98b5b0c27281d610207ebe692c2967f
Jul 29 15:40:28 allofthis kernel: blacklist: Duplicate blacklisted hash bin:c90f336617b8e7f983975413c997f10b73eb267fd8a10cb9e3bdbfc667abdb8b
Jul 29 15:40:28 allofthis kernel: blacklist: Duplicate blacklisted hash bin:64575bd912789a2e14ad56f6341f52af6bf80cf94400785975e9f04e2d64d745
Jul 29 15:40:28 allofthis kernel: blacklist: Duplicate blacklisted hash bin:45c7c8ae750acfbb48fc37527d6412dd644daed8913ccd8a24c94d856967df8e
Jul 29 15:40:28 allofthis kernel: blacklist: Duplicate blacklisted hash bin:47ff1b63b140b6fc04ed79131331e651da5b2e2f170f5daef4153dc2fbc532b1
Jul 29 15:40:28 allofthis kernel: blacklist: Duplicate blacklisted hash bin:992d359aa7a5f789d268b94c11b9485a6b1ce64362b0edb4441ccc187c39647b
Jul 29 15:40:28 allofthis kernel: blacklist: Duplicate blacklisted hash bin:c452ab846073df5ace25cca64d6b7a09d906308a1a65eb5240e3c4ebcaa9cc0c
Jul 29 15:40:28 allofthis kernel: blacklist: Duplicate blacklisted hash bin:e051b788ecbaeda53046c70e6af6058f95222c046157b8c4c1b9c2cfc65f46e5
Jul 29 15:40:28 allofthis kernel: i8042: Warning: Keylock active
Jul 29 15:40:28 allofthis kernel: nvme nvme0: missing or invalid SUBNQN field.
Jul 29 15:40:28 allofthis kernel: systemd[1]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
Jul 29 15:40:28 allofthis kernel: acpi_call: loading out-of-tree module taints kernel.
Jul 29 15:40:28 allofthis kernel: VBoxNetAdp: Successfully started.
Jul 29 15:40:28 allofthis kernel: VBoxNetFlt: Successfully started.
Jul 29 15:40:29 allofthis systemd-journald[355]: File /var/log/journal/805552c7b6f7411c9d5bf5a5a6a12624/system.journal corrupted or uncleanly shut down, renaming and replacing.
Jul 29 15:40:29 allofthis kernel: resource: resource sanity check: requesting [mem 0x00000000fedc0000-0x00000000fedcffff], which spans more than pnp 00:05 [mem 0xfedc0000-0xfedc7fff]
Jul 29 15:40:29 allofthis kernel: caller igen6_probe+0x197/0x8e0 [igen6_edac] mapping multiple BARs
Jul 29 15:40:29 allofthis kernel: i2c i2c-14: Systems with more than 4 memory slots not supported yet, not instantiating SPD
Jul 29 15:40:29 allofthis kernel: spi-nor spi0.0: unrecognized JEDEC id bytes: f6 f0 30 09 03 00
Jul 29 15:40:29 allofthis kernel: iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
Jul 29 15:40:29 allofthis kernel: ACPI Warning: \_SB.PC00.XHCI.RHUB.HS10._DSM: Argument #4 type mismatch - Found [Integer], ACPI requires [Package] (20230628/nsarguments-61)
Jul 29 15:40:29 allofthis kernel: thermal thermal_zone8: failed to read out thermal zone (-61)
Jul 29 15:40:29 allofthis kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
Jul 29 15:40:29 allofthis (udev-worker)[416]: cfg80211: Process '/usr/bin/set-wireless-regdom' failed with exit code 1.
Jul 29 15:40:30 allofthis kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: Parent card not yet available, widget card binding deferred
Jul 29 15:40:30 allofthis kernel: skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
Jul 29 15:40:30 allofthis (udev-worker)[436]: 0-0: Process '/usr/lib/udev/tbtacl change /devices/pci0000:00/0000:00:0d.2/domain0/0-0' failed with exit code 1.
Jul 29 15:40:30 allofthis (udev-worker)[426]: 1-0: Process '/usr/lib/udev/tbtacl change /devices/pci0000:00/0000:00:0d.3/domain1/1-0' failed with exit code 1.
Jul 29 15:40:30 allofthis (uetoothd)[902]: bluetooth.service: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Jul 29 15:40:30 allofthis bluetoothd[902]: src/plugin.c:init_plugin() System does not support ccp plugin
Jul 29 15:40:31 allofthis kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
Jul 29 15:40:31 allofthis kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Jul 29 15:40:31 allofthis bluetoothd[902]: profiles/audio/bap.c:bap_adapter_probe() BAP requires ISO Socket which is not enabled
Jul 29 15:40:31 allofthis bluetoothd[902]: bap: Operation not supported (95)
Jul 29 15:40:31 allofthis systemd-journald[355]: File /var/log/journal/805552c7b6f7411c9d5bf5a5a6a12624/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
Jul 29 15:40:31 allofthis bluetoothd[902]: src/device.c:device_set_wake_support() Unable to set wake_support without RPA resolution
Jul 29 15:40:31 allofthis systemd[1]: mbsync@marko.service: Failed with result 'exit-code'.
Jul 29 15:40:31 allofthis systemd[1]: Failed to start Mailbox synchronization service for user marko.
Jul 29 15:40:31 allofthis systemd[1]: postgresql.service: Failed with result 'exit-code'.
Jul 29 15:40:32 allofthis systemd[1]: Failed to start PostgreSQL database server.
Jul 29 15:40:32 allofthis systemd[1]: fangfrisch.service: Failed with result 'exit-code'.
Jul 29 15:40:32 allofthis boltd[949]: [33c58780-80db-domain0                    ] udev: failed to determine if uid is stable: unknown NHI PCI id '0x463e'
Jul 29 15:40:32 allofthis boltd[949]: [97ba8780-814f-domain1                    ] udev: failed to determine if uid is stable: unknown NHI PCI id '0x466d'
Jul 29 15:40:33 allofthis dbus-broker-launch[896]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Jul 29 15:40:33 allofthis dbus-broker-launch[1523]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Jul 29 15:40:33 allofthis dbus-broker-launch[1523]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Jul 29 15:40:33 allofthis dbus-broker-launch[1523]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Jul 29 15:40:33 allofthis kernel: block nvme0n1: No UUID available providing old NGUID
Jul 29 15:40:34 allofthis sddm-greeter-qt6[1519]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.22'
Jul 29 15:40:34 allofthis sddm-greeter-qt6[1519]: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.23'
Jul 29 15:40:37 allofthis sddm-greeter-qt6[1519]: file:///usr/share/sddm/themes/breath/Main.qml:241:17 Parameter "username" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
Jul 29 15:40:37 allofthis systemd-xdg-autostart-generator[1576]: /home/marko/.config/autostart/jami-gnome.desktop: stat() failed, ignoring: No such file or directory
Jul 29 15:40:37 allofthis systemd-xdg-autostart-generator[1576]: Configuration file /home/marko/.config/autostart/launchDavmail.sh.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Jul 29 15:40:37 allofthis dbus-broker-launch[1595]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Jul 29 15:40:37 allofthis dbus-broker-launch[1595]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Jul 29 15:40:37 allofthis dbus-broker-launch[1595]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Jul 29 15:40:37 allofthis NetworkManager[898]: <warn>  [1722260437.7386] device (wlp0s20f3): no secrets: No agents were available for this request.
Jul 29 15:40:37 allofthis NetworkManager[898]: <warn>  [1722260437.7388] device (wlp0s20f3): Activation: failed for connection 'ASUS'
Jul 29 15:40:37 allofthis systemd-xdg-autostart-generator[1612]: /home/marko/.config/autostart/jami-gnome.desktop: stat() failed, ignoring: No such file or directory
Jul 29 15:40:37 allofthis systemd-xdg-autostart-generator[1612]: Configuration file /home/marko/.config/autostart/launchDavmail.sh.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Jul 29 15:40:37 allofthis systemd[1568]: /run/user/1000/systemd/generator.late/app-launchDavmail.sh@autostart.service:18: WorkingDirectory= path is not absolute, ignoring:
Jul 29 15:40:38 allofthis xdg-desktop-por[1632]: Choosing gtk.portal for org.freedesktop.impl.portal.Lockdown as a last-resort fallback
Jul 29 15:40:38 allofthis xdg-desktop-por[1632]: The preferred method to match portal implementations to desktop environments is to use the portals.conf(5) configuration file
Jul 29 15:40:38 allofthis kwalletd6[1584]: kf.wallet.kwalletd: Wallet failed to get opened by PAM, error code is -9
Jul 29 15:40:38 allofthis ksplashqml[1604]: Texture 0x5654c9593fe0 () used with different accesses within the same pass, this is not allowed.
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:825:72: numeric keysym "0x1002039" (16785465)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:826:72: numeric keysym "0x100203a" (16785466)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:831:72: numeric keysym "0x1001e9e" (16785054)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:896:81: numeric keysym "0x1002039" (16785465)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:904:81: numeric keysym "0x100203a" (16785466)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1099:46: numeric keysym "0x1000300" (16777984)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1099:58: numeric keysym "0x1000300" (16777984)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1100:46: numeric keysym "0x1000301" (16777985)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1100:58: numeric keysym "0x1000301" (16777985)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1101:46: numeric keysym "0x1000306" (16777990)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1101:58: numeric keysym "0x1000306" (16777990)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1102:46: numeric keysym "0x100030a" (16777994)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1102:58: numeric keysym "0x100030a" (16777994)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1103:46: numeric keysym "0x1000302" (16777986)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1103:58: numeric keysym "0x1000302" (16777986)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1104:46: numeric keysym "0x100030c" (16777996)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1104:58: numeric keysym "0x100030c" (16777996)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1105:46: numeric keysym "0x1000307" (16777991)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1105:58: numeric keysym "0x1000307" (16777991)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1106:46: numeric keysym "0x1000308" (16777992)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1106:58: numeric keysym "0x1000308" (16777992)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1107:46: numeric keysym "0x1000304" (16777988)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1107:58: numeric keysym "0x1000304" (16777988)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1108:46: numeric keysym "0x1000303" (16777987)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1108:58: numeric keysym "0x1000303" (16777987)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1113:45: numeric keysym "0x1000327" (16778023)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1113:58: numeric keysym "0x1000327" (16778023)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1114:45: numeric keysym "0x100032e" (16778030)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1114:58: numeric keysym "0x100032e" (16778030)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1115:45: numeric keysym "0x1000325" (16778021)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1115:58: numeric keysym "0x1000325" (16778021)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1116:45: numeric keysym "0x100032d" (16778029)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1116:58: numeric keysym "0x100032d" (16778029)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1117:45: numeric keysym "0x100032c" (16778028)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1117:58: numeric keysym "0x100032c" (16778028)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1118:45: numeric keysym "0x1000323" (16778019)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1118:58: numeric keysym "0x1000323" (16778019)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1119:45: numeric keysym "0x1000324" (16778020)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1119:58: numeric keysym "0x1000324" (16778020)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1120:45: numeric keysym "0x1000331" (16778033)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1120:58: numeric keysym "0x1000331" (16778033)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1121:45: numeric keysym "0x1000330" (16778032)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1121:58: numeric keysym "0x1000330" (16778032)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1124:63: numeric keysym "0x1001e9e" (16785054)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1165:46: numeric keysym "0x1000300" (16777984)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1165:58: numeric keysym "0x1000300" (16777984)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1166:46: numeric keysym "0x1000301" (16777985)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1166:58: numeric keysym "0x1000301" (16777985)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1167:46: numeric keysym "0x1000306" (16777990)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1167:58: numeric keysym "0x1000306" (16777990)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1168:46: numeric keysym "0x100030a" (16777994)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1168:58: numeric keysym "0x100030a" (16777994)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1169:46: numeric keysym "0x1000302" (16777986)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1169:58: numeric keysym "0x1000302" (16777986)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1170:46: numeric keysym "0x100030c" (16777996)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1170:58: numeric keysym "0x100030c" (16777996)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1171:46: numeric keysym "0x1000307" (16777991)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1171:58: numeric keysym "0x1000307" (16777991)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1172:46: numeric keysym "0x1000308" (16777992)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1172:58: numeric keysym "0x1000308" (16777992)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1173:46: numeric keysym "0x1000304" (16777988)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1173:58: numeric keysym "0x1000304" (16777988)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1178:45: numeric keysym "0x1000327" (16778023)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1178:58: numeric keysym "0x1000327" (16778023)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1179:45: numeric keysym "0x100032e" (16778030)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1179:58: numeric keysym "0x100032e" (16778030)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1180:45: numeric keysym "0x1000325" (16778021)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1180:58: numeric keysym "0x1000325" (16778021)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1181:45: numeric keysym "0x100032d" (16778029)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1181:58: numeric keysym "0x100032d" (16778029)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1182:45: numeric keysym "0x100032c" (16778028)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1182:58: numeric keysym "0x100032c" (16778028)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1183:45: numeric keysym "0x1000323" (16778019)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1183:58: numeric keysym "0x1000323" (16778019)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1184:45: numeric keysym "0x1000324" (16778020)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1184:58: numeric keysym "0x1000324" (16778020)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1185:45: numeric keysym "0x1000331" (16778033)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1185:58: numeric keysym "0x1000331" (16778033)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1186:45: numeric keysym "0x1000330" (16778032)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1186:58: numeric keysym "0x1000330" (16778032)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1189:63: numeric keysym "0x1001e9e" (16785054)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1205:47: numeric keysym "0x1000303" (16777987)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1205:59: numeric keysym "0x1000303" (16777987)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1763:52: numeric keysym "0x1001e9e" (16785054)
Jul 29 15:40:38 allofthis kwin_x11[1665]: kwin_xkbcommon: XKB: [XKB-489] us:1812:52: numeric keysym "0x1001e9e" (16785054)
Jul 29 15:40:38 allofthis kded6[1664]: org.kde.wacomtablet.common: d->name.isEmpty? true
Jul 29 15:40:38 allofthis plasmashell[1729]: kde.plasmashell: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Jul 29 15:40:38 allofthis plasmashell[1729]: kde.plasmashell: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Jul 29 15:40:38 allofthis kded6[1664]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
Jul 29 15:40:38 allofthis kded6[1664]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
Jul 29 15:40:38 allofthis kconf_update[1796]: kf.config.kconf_update: /usr/share/kconf_update/ark.upd defined Version=5 but Version=6 was expected
Jul 29 15:40:38 allofthis kconf_update[1796]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_detailsmodesettings.upd defined Version=5 but Version=6 was expected
Jul 29 15:40:38 allofthis kconf_update[1796]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_directorysizemode.upd defined Version=5 but Version=6 was expected
Jul 29 15:40:38 allofthis kconf_update[1796]: kf.config.kconf_update: /usr/share/kconf_update/filepicker.upd defined Version=5 but Version=6 was expected
Jul 29 15:40:38 allofthis kconf_update[1796]: kf.config.kconf_update: /usr/share/kconf_update/konsole.upd defined Version=5 but Version=6 was expected
Jul 29 15:40:38 allofthis kconf_update[1796]: kf.config.kconf_update: /usr/share/kconf_update/okular.upd defined Version=5 but Version=6 was expected
Jul 29 15:40:38 allofthis xdg-desktop-por[1632]: Choosing kwallet.portal for org.freedesktop.impl.portal.Secret via the deprecated UseIn key
Jul 29 15:40:38 allofthis plasmashell[1729]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:196:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Jul 29 15:40:38 allofthis org_kde_powerdevil[1785]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Jul 29 15:40:39 allofthis DiscoverNotifier[1994]: couldn't load "/usr/lib/qt6/plugins/discover-notifier/DiscoverPackageKitNotifier.so" because "Cannot load library /usr/lib/qt6/plugins/discover-notifier/DiscoverPackageKitNotifier.so: libpackagekitqt6.so.1: cannot open shared object file: No such file or directory"
Jul 29 15:40:39 allofthis kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Jul 29 15:40:39 allofthis kdeconnectd[1954]: 2024-07-29T15:40:39 default: Error sending UDP packet: QAbstractSocket::NetworkError
Jul 29 15:40:39 allofthis kdeconnectd[1954]: 2024-07-29T15:40:39 kdeconnect.core: Failed to open any MDNS client sockets
Jul 29 15:40:39 allofthis fingerprint-polkit-agent[1986]: "Cannot register authentication agent: GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed: An authentication agent already exists for the given subject"
Jul 29 15:40:39 allofthis fingerprint-polkit-agent[1986]: Could not register listener "/fingerprintgui/PolicyKit1/AuthenticationAgent". Aborting.
Jul 29 15:40:39 allofthis systemd[1568]: app-fingerprint\x2dpolkit\x2dagent@autostart.service: Failed with result 'exit-code'.
Jul 29 15:40:39 allofthis kded6[1664]: kf.bluezqt: PendingCall Error: "The name is not activatable"
Jul 29 15:40:39 allofthis kwalletd6[1584]: Application ' "Chromium" ' using kwallet without parent window!
Jul 29 15:40:39 allofthis akonadi_control[2354]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Jul 29 15:40:40 allofthis plasmashell[1729]: org.kde.plasma.kicker: Entry is not valid "kontact.desktop" 0x55fc1b30f220
Jul 29 15:40:40 allofthis plasmashell[1729]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" 0x55fc1b30f220
Jul 29 15:40:40 allofthis plasmashell[1729]: org.kde.plasma.kicker: Entry is not valid "kontact.desktop" 0x55fc1b337c60
Jul 29 15:40:40 allofthis plasmashell[1729]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" 0x55fc1b366290
Jul 29 15:40:40 allofthis kded6[1664]: colord: EDID ICC Profile already exists "/home/marko/.local/share/icc/edid-5f60c06e1355a0c077461d1d862e9cb3.icc"
Jul 29 15:40:40 allofthis kded6[1664]: colord: Failed to register device: "device id 'xrandr-BOE' already exists"
Jul 29 15:40:40 allofthis plasmashell[1729]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:162:21: QML KSortFilterProxyModel: Binding loop detected for property "sourceModel"
Jul 29 15:40:40 allofthis plasmashell[1729]: qml: SystemTray ItemLoader: Invalid state, cannot determine source!
Jul 29 15:40:40 allofthis kbuildsycoca6[2652]: kf.config.core: "KConfigIni: In file /usr/share/applications/carla-control.desktop, line 1:" Invalid entry (missing '=')
Jul 29 15:40:40 allofthis kbuildsycoca6[2652]: kf.service.services: The desktop entry file "/usr/share/applications/carla-control.desktop" does not have a "Type=Application" set.
Jul 29 15:40:40 allofthis kbuildsycoca6[2652]: kf.config.core: "KConfigIni: In file /usr/share/applications/carla-jack-multi.desktop, line 1:" Invalid entry (missing '=')
Jul 29 15:40:40 allofthis kbuildsycoca6[2652]: kf.service.services: The desktop entry file "/usr/share/applications/carla-jack-multi.desktop" does not have a "Type=Application" set.
Jul 29 15:40:40 allofthis kbuildsycoca6[2652]: kf.config.core: "KConfigIni: In file /usr/share/applications/carla-jack-single.desktop, line 1:" Invalid entry (missing '=')
Jul 29 15:40:40 allofthis kbuildsycoca6[2652]: kf.service.services: The desktop entry file "/usr/share/applications/carla-jack-single.desktop" does not have a "Type=Application" set.
Jul 29 15:40:40 allofthis kbuildsycoca6[2652]: kf.config.core: "KConfigIni: In file /usr/share/applications/carla-patchbay.desktop, line 1:" Invalid entry (missing '=')
Jul 29 15:40:40 allofthis kbuildsycoca6[2652]: kf.service.services: The desktop entry file "/usr/share/applications/carla-patchbay.desktop" does not have a "Type=Application" set.
Jul 29 15:40:40 allofthis kbuildsycoca6[2652]: kf.config.core: "KConfigIni: In file /usr/share/applications/carla-rack.desktop, line 1:" Invalid entry (missing '=')
Jul 29 15:40:40 allofthis kbuildsycoca6[2652]: kf.service.services: The desktop entry file "/usr/share/applications/carla-rack.desktop" does not have a "Type=Application" set.
Jul 29 15:40:40 allofthis kbuildsycoca6[2652]: kf.config.core: "KConfigIni: In file /usr/share/applications/carla.desktop, line 1:" Invalid entry (missing '=')
Jul 29 15:40:40 allofthis kbuildsycoca6[2652]: kf.service.services: The desktop entry file "/usr/share/applications/carla.desktop" does not have a "Type=Application" set.
Jul 29 15:40:40 allofthis kbuildsycoca6[2652]: kf.service.services: The action "new-window" in the desktop file "/usr/share/applications/rustdesk.desktop" has no Name or no Exec key
Jul 29 15:40:40 allofthis kbuildsycoca6[2652]: kf.service.services: The desktop entry file "/home/marko/.local/share/applications/WoPeD Manual-1520275975959.desktop" has Type= "Link" instead of "Application" or "Service"
Jul 29 15:40:40 allofthis kbuildsycoca6[2652]: kf.service.sycoca: Invalid Service :  "/home/marko/.local/share/applications/WoPeD Manual-1520275975959.desktop"
Jul 29 15:40:40 allofthis kbuildsycoca6[2652]: kf.service.services: The desktop entry file "/home/marko/.local/share/applications/WoPeD Docs-1520275975962.desktop" does not have a "Type=Application" set.
Jul 29 15:40:40 allofthis kbuildsycoca6[2652]: kf.service.services: The desktop entry file "/home/marko/.local/share/applications/WoPeD Manual-1520340860965.desktop" has Type= "Link" instead of "Application" or "Service"
Jul 29 15:40:40 allofthis kbuildsycoca6[2652]: kf.service.sycoca: Invalid Service :  "/home/marko/.local/share/applications/WoPeD Manual-1520340860965.desktop"
Jul 29 15:40:40 allofthis kbuildsycoca6[2652]: kf.service.services: The desktop entry file "/home/marko/.local/share/applications/WoPeD Docs-1520340860980.desktop" does not have a "Type=Application" set.
Jul 29 15:40:40 allofthis kbuildsycoca6[2652]: kf.service.services: The desktop entry file "/home/marko/.local/share/applications/WoPeD Manual-1539304511463.desktop" has Type= "Link" instead of "Application" or "Service"
Jul 29 15:40:40 allofthis kbuildsycoca6[2652]: kf.service.sycoca: Invalid Service :  "/home/marko/.local/share/applications/WoPeD Manual-1539304511463.desktop"
Jul 29 15:40:40 allofthis kbuildsycoca6[2652]: kf.service.services: The desktop entry file "/home/marko/.local/share/applications/WoPeD Docs-1539304511478.desktop" does not have a "Type=Application" set.
Jul 29 15:40:40 allofthis plasmashell[1729]: qt.dbus.integration: Could not connect "org.cups.cupsd.Notifier" to PrinterFinishingsChanged(QString, QString, QString, uint, QString, bool) :
Jul 29 15:40:40 allofthis kded6[1664]: colord: Output not found
Jul 29 15:40:40 allofthis kbuildsycoca6[2853]: kf.config.core: "KConfigIni: In file /usr/share/applications/carla-control.desktop, line 1:" Invalid entry (missing '=')
Jul 29 15:40:40 allofthis kbuildsycoca6[2853]: kf.service.services: The desktop entry file "/usr/share/applications/carla-control.desktop" does not have a "Type=Application" set.
Jul 29 15:40:40 allofthis kbuildsycoca6[2853]: kf.config.core: "KConfigIni: In file /usr/share/applications/carla-jack-multi.desktop, line 1:" Invalid entry (missing '=')
Jul 29 15:40:40 allofthis kbuildsycoca6[2853]: kf.service.services: The desktop entry file "/usr/share/applications/carla-jack-multi.desktop" does not have a "Type=Application" set.
Jul 29 15:40:40 allofthis kbuildsycoca6[2853]: kf.config.core: "KConfigIni: In file /usr/share/applications/carla-jack-single.desktop, line 1:" Invalid entry (missing '=')
Jul 29 15:40:40 allofthis kbuildsycoca6[2853]: kf.service.services: The desktop entry file "/usr/share/applications/carla-jack-single.desktop" does not have a "Type=Application" set.
Jul 29 15:40:40 allofthis kbuildsycoca6[2853]: kf.config.core: "KConfigIni: In file /usr/share/applications/carla-patchbay.desktop, line 1:" Invalid entry (missing '=')
Jul 29 15:40:40 allofthis kbuildsycoca6[2853]: kf.service.services: The desktop entry file "/usr/share/applications/carla-patchbay.desktop" does not have a "Type=Application" set.
Jul 29 15:40:40 allofthis kbuildsycoca6[2853]: kf.config.core: "KConfigIni: In file /usr/share/applications/carla-rack.desktop, line 1:" Invalid entry (missing '=')
Jul 29 15:40:40 allofthis kbuildsycoca6[2853]: kf.service.services: The desktop entry file "/usr/share/applications/carla-rack.desktop" does not have a "Type=Application" set.
Jul 29 15:40:40 allofthis kbuildsycoca6[2853]: kf.config.core: "KConfigIni: In file /usr/share/applications/carla.desktop, line 1:" Invalid entry (missing '=')
Jul 29 15:40:40 allofthis kbuildsycoca6[2853]: kf.service.services: The desktop entry file "/usr/share/applications/carla.desktop" does not have a "Type=Application" set.
Jul 29 15:40:40 allofthis kbuildsycoca6[2853]: kf.service.services: The action "new-window" in the desktop file "/usr/share/applications/rustdesk.desktop" has no Name or no Exec key
Jul 29 15:40:40 allofthis kbuildsycoca6[2853]: kf.service.services: The desktop entry file "/home/marko/.local/share/applications/WoPeD Manual-1520275975959.desktop" has Type= "Link" instead of "Application" or "Service"
Jul 29 15:40:40 allofthis kbuildsycoca6[2853]: kf.service.sycoca: Invalid Service :  "/home/marko/.local/share/applications/WoPeD Manual-1520275975959.desktop"
Jul 29 15:40:40 allofthis kbuildsycoca6[2853]: kf.service.services: The desktop entry file "/home/marko/.local/share/applications/WoPeD Docs-1520275975962.desktop" does not have a "Type=Application" set.
Jul 29 15:40:40 allofthis kbuildsycoca6[2853]: kf.service.services: The desktop entry file "/home/marko/.local/share/applications/WoPeD Manual-1520340860965.desktop" has Type= "Link" instead of "Application" or "Service"
Jul 29 15:40:40 allofthis kbuildsycoca6[2853]: kf.service.sycoca: Invalid Service :  "/home/marko/.local/share/applications/WoPeD Manual-1520340860965.desktop"
Jul 29 15:40:40 allofthis kbuildsycoca6[2853]: kf.service.services: The desktop entry file "/home/marko/.local/share/applications/WoPeD Docs-1520340860980.desktop" does not have a "Type=Application" set.
Jul 29 15:40:40 allofthis kbuildsycoca6[2853]: kf.service.services: The desktop entry file "/home/marko/.local/share/applications/WoPeD Manual-1539304511463.desktop" has Type= "Link" instead of "Application" or "Service"
Jul 29 15:40:40 allofthis kbuildsycoca6[2853]: kf.service.sycoca: Invalid Service :  "/home/marko/.local/share/applications/WoPeD Manual-1539304511463.desktop"
Jul 29 15:40:40 allofthis kbuildsycoca6[2853]: kf.service.services: The desktop entry file "/home/marko/.local/share/applications/WoPeD Docs-1539304511478.desktop" does not have a "Type=Application" set.
Jul 29 15:40:40 allofthis plasmashell[1729]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Jul 29 15:40:40 allofthis kbuildsycoca6[2969]: kf.config.core: "KConfigIni: In file /usr/share/applications/carla-control.desktop, line 1:" Invalid entry (missing '=')
Jul 29 15:40:40 allofthis kbuildsycoca6[2969]: kf.service.services: The desktop entry file "/usr/share/applications/carla-control.desktop" does not have a "Type=Application" set.
Jul 29 15:40:40 allofthis kbuildsycoca6[2969]: kf.config.core: "KConfigIni: In file /usr/share/applications/carla-jack-multi.desktop, line 1:" Invalid entry (missing '=')
Jul 29 15:40:40 allofthis kbuildsycoca6[2969]: kf.service.services: The desktop entry file "/usr/share/applications/carla-jack-multi.desktop" does not have a "Type=Application" set.
Jul 29 15:40:40 allofthis kbuildsycoca6[2969]: kf.config.core: "KConfigIni: In file /usr/share/applications/carla-jack-single.desktop, line 1:" Invalid entry (missing '=')
Jul 29 15:40:40 allofthis kbuildsycoca6[2969]: kf.service.services: The desktop entry file "/usr/share/applications/carla-jack-single.desktop" does not have a "Type=Application" set.
Jul 29 15:40:40 allofthis kbuildsycoca6[2969]: kf.config.core: "KConfigIni: In file /usr/share/applications/carla-patchbay.desktop, line 1:" Invalid entry (missing '=')
Jul 29 15:40:40 allofthis kbuildsycoca6[2969]: kf.service.services: The desktop entry file "/usr/share/applications/carla-patchbay.desktop" does not have a "Type=Application" set.
Jul 29 15:40:40 allofthis kbuildsycoca6[2969]: kf.config.core: "KConfigIni: In file /usr/share/applications/carla-rack.desktop, line 1:" Invalid entry (missing '=')
Jul 29 15:40:40 allofthis kbuildsycoca6[2969]: kf.service.services: The desktop entry file "/usr/share/applications/carla-rack.desktop" does not have a "Type=Application" set.
Jul 29 15:40:40 allofthis kbuildsycoca6[2969]: kf.config.core: "KConfigIni: In file /usr/share/applications/carla.desktop, line 1:" Invalid entry (missing '=')
Jul 29 15:40:40 allofthis kbuildsycoca6[2969]: kf.service.services: The desktop entry file "/usr/share/applications/carla.desktop" does not have a "Type=Application" set.
Jul 29 15:40:40 allofthis kbuildsycoca6[2969]: kf.service.services: The action "new-window" in the desktop file "/usr/share/applications/rustdesk.desktop" has no Name or no Exec key
Jul 29 15:40:40 allofthis kbuildsycoca6[2969]: kf.service.services: The desktop entry file "/home/marko/.local/share/applications/WoPeD Manual-1520275975959.desktop" has Type= "Link" instead of "Application" or "Service"
Jul 29 15:40:40 allofthis kbuildsycoca6[2969]: kf.service.sycoca: Invalid Service :  "/home/marko/.local/share/applications/WoPeD Manual-1520275975959.desktop"
Jul 29 15:40:40 allofthis kbuildsycoca6[2969]: kf.service.services: The desktop entry file "/home/marko/.local/share/applications/WoPeD Docs-1520275975962.desktop" does not have a "Type=Application" set.
Jul 29 15:40:40 allofthis kbuildsycoca6[2969]: kf.service.services: The desktop entry file "/home/marko/.local/share/applications/WoPeD Manual-1520340860965.desktop" has Type= "Link" instead of "Application" or "Service"
Jul 29 15:40:40 allofthis kbuildsycoca6[2969]: kf.service.sycoca: Invalid Service :  "/home/marko/.local/share/applications/WoPeD Manual-1520340860965.desktop"
Jul 29 15:40:40 allofthis kbuildsycoca6[2969]: kf.service.services: The desktop entry file "/home/marko/.local/share/applications/WoPeD Docs-1520340860980.desktop" does not have a "Type=Application" set.
Jul 29 15:40:40 allofthis kbuildsycoca6[2969]: kf.service.services: The desktop entry file "/home/marko/.local/share/applications/WoPeD Manual-1539304511463.desktop" has Type= "Link" instead of "Application" or "Service"
Jul 29 15:40:40 allofthis kbuildsycoca6[2969]: kf.service.sycoca: Invalid Service :  "/home/marko/.local/share/applications/WoPeD Manual-1539304511463.desktop"
Jul 29 15:40:40 allofthis kbuildsycoca6[2969]: kf.service.services: The desktop entry file "/home/marko/.local/share/applications/WoPeD Docs-1539304511478.desktop" does not have a "Type=Application" set.
Jul 29 15:40:40 allofthis plasmashell[1729]: qrc:/qt/qml/org/kde/kirigamiaddons/components/Avatar.qml:201:9: QML QQuickImage: Error decoding: qrc:/qt/qml/org/kde/kirigamiaddons/components/Avatar.qml?timestamp=1722260440976: Unsupported image format
Jul 29 15:40:41 allofthis plasmashell[1729]: QString::arg: Argument missing: *.png, plover
Jul 29 15:40:41 allofthis plasmashell[1729]: QString::arg: Argument missing: *.svg, plover
Jul 29 15:40:45 allofthis akonadiserver[2457]: org.kde.pim.akonadiserver: database server stopped unexpectedly
Jul 29 15:40:45 allofthis akonadiserver[2457]: org.kde.pim.akonadiserver: Database process exited unexpectedly during initial connection!
Jul 29 15:40:45 allofthis akonadiserver[2457]: org.kde.pim.akonadiserver: executable: "/usr/bin/mysqld"
Jul 29 15:40:45 allofthis akonadiserver[2457]: org.kde.pim.akonadiserver: arguments: QList("--defaults-file=/home/marko/.local/share/akonadi/mysql.conf", "--datadir=/home/marko/.local/share/akonadi/db_data/", "--socket=/run/user/1000/akonadi/mysql.socket", "--pid-file=/run/user/1000/akonadi/mysql.pid")
Jul 29 15:40:45 allofthis akonadiserver[2457]: org.kde.pim.akonadiserver: stdout: ""
Jul 29 15:40:45 allofthis akonadiserver[2457]: org.kde.pim.akonadiserver: stderr: "/usr/bin/mysqld: Deprecated program name. It will be removed in a future release, use '/usr/bin/mariadbd' instead\n"
Jul 29 15:40:45 allofthis akonadiserver[2457]: org.kde.pim.akonadiserver: exit code: 1
Jul 29 15:40:45 allofthis akonadiserver[2457]: org.kde.pim.akonadiserver: process error: "Unknown error"
Jul 29 15:40:45 allofthis kalendarac[1996]: org.kde.pim.akonadicore: Job error:  "" for collection: QList()
Jul 29 15:40:51 allofthis kded6[1664]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
Jul 29 15:40:51 allofthis plasmashell[1729]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
Jul 29 15:40:51 allofthis dbus-broker-launch[896]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Jul 29 15:40:51 allofthis kdeconnectd[1954]: 2024-07-29T15:40:51 kdeconnect.core: Failed to send mDNS query: Cannot assign requested address
Jul 29 15:45:52 allofthis plasmashell[1729]: QString::arg: Argument missing: *.png, plover
Jul 29 15:45:52 allofthis plasmashell[1729]: QString::arg: Argument missing: *.svg, plover
Jul 29 15:51:35 allofthis systemd[1]: fangfrisch.service: Failed with result 'exit-code'.
Jul 29 15:58:15 allofthis plasmashell[1729]: QDBusObjectPath: invalid path ""
Jul 29 15:58:15 allofthis plasmashell[1729]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
Jul 29 15:58:19 allofthis plasmashell[1729]: qrc:/qt/qml/org/kde/plasma/components/ScrollView.qml:53:29: QML ScrollBar: Binding loop detected for property "visible"
Jul 29 16:00:01 allofthis systemd[1]: fangfrisch.service: Failed with result 'exit-code'.
Jul 29 16:00:01 allofthis pinentry-qt[6260]: qt.qpa.xcb: could not connect to display localhost:0.0
Jul 29 16:00:01 allofthis pinentry-qt[6260]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
Jul 29 16:00:01 allofthis systemd-coredump[6265]: Process 6260 (pinentry-qt) of user 1000 terminated abnormally without generating a coredump.
Jul 29 16:00:02 allofthis pinentry-qt[6277]: qt.qpa.xcb: could not connect to display localhost:0.0
Jul 29 16:00:02 allofthis pinentry-qt[6277]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
Jul 29 16:00:02 allofthis systemd-coredump[6282]: Process 6277 (pinentry-qt) of user 1000 terminated abnormally without generating a coredump.
Jul 29 16:00:02 allofthis pinentry-qt[6299]: qt.qpa.xcb: could not connect to display localhost:0.0
Jul 29 16:00:02 allofthis pinentry-qt[6299]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
Jul 29 16:00:02 allofthis systemd-coredump[6304]: Process 6299 (pinentry-qt) of user 1000 terminated abnormally without generating a coredump.
Jul 29 16:00:03 allofthis systemd[1]: mbsync@marko.service: Failed with result 'exit-code'.
Jul 29 16:00:03 allofthis systemd[1]: Failed to start Mailbox synchronization service for user marko.
Jul 29 16:05:33 allofthis kdeconnectd[1954]: 2024-07-29T16:05:33 default: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Jul 29 16:07:11 allofthis pipewire[1859]: pw.node: (alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__Speaker__sink-49) xrun state:0x7fc4116ae008 pending:2/2 s:1605325128696 a:1605320148224 f:1605320157312 waiting:18446744073704571144 process:9088 status:triggered (2 suppressed)
Jul 29 16:07:11 allofthis pipewire[1859]: spa.alsa: hw:sofhdadspp: (0 suppressed) snd_pcm_avail after recover: Broken pipe
Jul 29 16:07:55 allofthis pipewire[1859]: pw.node: (alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__Speaker__sink-49) graph xrun (3 suppressed)
Jul 29 16:09:47 allofthis kernel: .....ready
Jul 29 16:09:47 allofthis kernel: sd 0:0:0:0: [sda] No Caching mode page found
Jul 29 16:09:47 allofthis kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Jul 29 16:09:47 allofthis kernel: scsi 0:0:0:1: Wrong diagnostic page; asked for 1 got 8
Jul 29 16:09:47 allofthis kernel: scsi 0:0:0:1: Failed to get diagnostic page 0x1
Jul 29 16:09:47 allofthis kernel: scsi 0:0:0:1: Failed to bind enclosure -19
Jul 29 16:09:48 allofthis udisksd[1531]: Error probing device: Error sending ATA command IDENTIFY DEVICE to '/dev/sda': Unexpected sense data returned:
                                         0000: f0 00 01 00  50 00 00 0a  80 00 00 00  00 1d 00 00    ....P...........
                                         0010: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
                                          (g-io-error-quark, 0)
Jul 29 16:10:33 allofthis systemd[1]: fangfrisch.service: Failed with result 'exit-code'.
I also ran btrfs check --readonly --force on the mounted filesystem after I had rebooted the system. At first it found lots of errors, but then when I thought I’d redirect all these errors into a file, no errors were found, so I guess those that I saw had something to do with the unclean file system.
When I looked over the log before submitting it here, I felt I should have fixed some of these errors and warnings some time ago. So, I went ahead and fixed some now.
I had one systemd unit that was intended to sync some mailboxes to my machine. That used mbsync, pass and then eventually pinentry-qt. I changed this to a user unit and the problem has not yet reappeared. It might be too early to draw any conclusions…
Some NVMe disks may overheat and fail. Check temperature with “smartctl -a” command or hddtemp command to be sure that’s not the cause.
Okay, that was not the solution either: it happened again. Also, smartctl -a shows that temperatures are rather low: 50-55C where the warning threshold starts at 90C.
I’ll try cleaning the connector as soon as I get some small enough screwdrivers, but honestly I have doubts that that’s it…
Another thought: could this be iwlwifi with wireguard related?
Any- and everything is possible.
However, I highly doubt it…
I’m still puzzled over this. Sometime in August I had stopped using the kitty terminal emulator in one specific way (I’m still using it in other ways) and after that I had not had a single one of these issues occur. If I have
kitty --detach --class ploverkitty sh -c "tail -f ~/.config/plover/clippy_2.org | sed -e 's/^.*\[0m \(.*\[0m .*\) < .*$/\1/g'" &
running then the freezes sporadically occur, but if I use
konsole --separate --hide-tabbar --hide-menubar -e sh -c "tail -f ~/.config/plover/clippy_2.org | sed -e 's/^.*\[0m \(.*\[0m .*\) < .*$/\1/g'" &
instead, then they do not. I know it sounds strange…
