I tried Wayland again yesterday, still doesn’t since monitor, but I never added that kernel peramiter & I habe the same kernel I did last post (6.6). Anyway, when I try to start Spec. I get Failed to start & something about remote pear. Sorry didn’t write it down.
Sorry, didn’t read.
I rarely write things down… using my computer, I am able to simply copy them into clipboard, or even save text in Text files
As a new forum user, you should have been asked to take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit.
- Please read the information behind this link. It will help you to post necessary information.
- Please press the three dots … below your post and then press the
- If you give us information about your system, we can see what we’re talking about and make better suggestions.
- You can do this by using
inxiin a terminal or in console.
sudo inxi --verbosity=8 --filter --width
- Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
- Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
- Copy the output from inxi (including the command) and paste it into your post.
- To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
- Or we can try to play hide and seek
Have you already
for your problem in the forum ? (Wisdom lies in asking → listening → reading
When I had spectacle crashes with remote peer disconnect, the fix for me was to remove libva-vdpau-driver. Maybe check if that package is installed? I know it’s been removed from the repository but you may still have it installed (that is if you had installed it previously).
Thanks, odd it is fine under X11. Anyway, it still doesn’t sense my monitor & has that really low res. as the only choice. Why deos Nvidia hate Wayland? Is that fixed in the newer kernel?
A driver for hardware decoding of video files should have nothing to do with Spectacle.
@ben75 1If you’re referring to my comment, I had filed a bug report and the kde dev suggested I remove libva-vdpau-driver, and that’s what I did, and then Spectacle worked properly under Wayland.
My bug report here: 493553 – Spectacle crash, error message: remote peer disconnected
@Edward78 Yes Spectacle worked in X11 for me too, now it also works in Wayland.
Shouldn’t your question regarding detecting your monitor and resolution be a separate topic? You haven’t mentioned if Spectacle is still broken in Wayland or not?
As for Nvidia & Wayland, it’s working well on both my desktops, but keep in mind that I use the manjaro unstable branch - I’m using nvidia 565.77 and linux 6.12.
Open a Terminal, and in the terminal type
spectacle
Then using your mouse select and copy any error messages you get, and paste that copied content into your reply on this forum
don’t forget to use the </> button in the forum editor menu.
This is a local issue - possibly generated by invalid configuration.
Good advise …
I have been using Wayland for several years - Plasma 6 since Sep. 2023 - there was some point in the beta phase where spectacle didn’t work - but that was solved before the initial release of 6.0.
$ plasmashell --version
plasmashell 6.2.4
$ spectacle --version
spectacle 24.12.0
Relevant snip from Settings → About this System
KDE Plasma Version: 6.2.4
KDE Frameworks Version: 6.9.0
Qt Version: 6.8.1
Kernel Version: 6.13.0-rc4-1-MANJARO (64-bit)
Graphics Platform: Wayland
@Edward78
Search for the package
pamac search -q libva vdpau | grep 'Installed'
Then remove the named package
Says Launcing Spectacle failed Remote ppeer Disconnected.
Does the problem return after rebooting? ![]()
Did you try running it from command line to see if there are more details about the error?
Will do nw.
spectacle
zsh: segmentation fault (core dumped) spectacle
Could a reinstall fix it?
You could try refreshing mirrors in the process.
sudo pacman -Rns spectacle
sudo pacman-mirrors --continent
sudo pacman -S spectacle
Did you follow the instructions in the topic you created last December about this same issue?
The suggested fix was:
You never replied to advise if those packages were found on your system and to confirm that you had now removed them.
Removing “libva-vdpau-driver” solved the problem for me, thanks !
Seems to be good now, did nothing. I am in X again. Waiting on Nvidia to update the settings app for Wayland. Watched a vid. they said soon.
You did Something, you switched back to X11, where it seems nVidia is working fine, and not causing you problems.
I’m trying to subscribe to they - that’s where all the good answers come from.
They always know; unless they don’t.
