Spectacle causes my display to cut out
After updating, Spectacle now causes my display to cut out while I’m cropping the rectangular region. Also, fullscreen games have the display flicker out.
System information:
KDE Plasma Version: 6.5.3
KDE Frameworks Version: 6.20.0
Qt Version: 6.10.1
Kernel Version: 6.17.11-1-MANJARO (64-bit)
Graphics Platform: Wayland
Processors: 12 × AMD Ryzen 5 5600X 6-Core Processor
Memory: 16 GiB of RAM (15.5 GiB usable)
Graphics Processor: AMD Radeon RX 9060 XT
Manufacturer: ASUS
Your post has been moved to a dedicated topic.
Please provide your system information as described (below). I’m sure someone will help when they are able.
What follows is from a standard template.
As a new or infrequent forum user, please take some time to familiarise yourself with forum requirements, and the many ways to use the forum to your benefit.
Note: By virtue of using the Manjaro forum you acknowledge and agree to follow Rules and Guidelines outlined; so, you really should read them:
Required Reading
Highly Recommended
Work with us, not against us
It is important to provide as much actionable information as possible in your first post, rather than simply indicating there is a problem. Please also be prepared to provide output from commands if/when asked.
Simply waiting for others to ask you questions is counter-productive – typically, nobody has a :crystal_ball: at their disposal – and your clear, concise and accurate input is often relied upon in order to help you.
Please help others to make informed suggestions based on information you provide.
System Information
inxi -zv8 (short-form)
inxi man pages (manual)
If running `inxi` within a `chroot` environment
Your privacy is respected
Update Announcements
Technical Resources
Could it be that you previously used X11 and now the default is Wayland?
If so - try wiping the content of local user’s cache in ~/.cache
Something like this should do
rm -rf ~/.cache/*
Sorry for the reply TWO WEEKS LATER. I made this post, then the forums crashed, then I forgot I made the post until I googled the problem again.
I have run the command you posted this and it it still occurring. :frowning:
here’s the inxi output:
  Kernel: 6.17.13-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.17-x86_64
    root=UUID=246a4db0-4152-46c2-94e0-79b1495fe607 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A info: frameworks v: 6.21.0
  Mobo: ASUSTeK model: TUF GAMING B550M-PLUS WIFI II v: Rev X.0x
    Firmware: UEFI vendor: American Megatrends v: 2806 date: 10/27/2022
  Device-1: hidpp_battery_0 model: Logitech G305 Lightspeed Wireless Gaming
    Mouse serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  System RAM: total: 16 GiB available: 15.52 GiB used: 3.28 GiB (21.2%)
  Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 8 GiB speed: 2133 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: G-Skill
    part-no: F4-3200C16-8GVKB serial: N/A
  Device-2: DIMM_A2 type: no module installed
  Device-3: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
  Device-4: DIMM_B2 type: no module installed
  Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 2 microcode: 0xA201211
    desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3834 min/max: 561/4654 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3834 2: 3834 3: 3834
    4: 3834 5: 3834 6: 3834 7: 3834 8: 3834 9: 3834 10: 3834 11: 3834 12: 3834
    bogomips: 88632
    xsaves xtopology
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 44 [Radeon RX 9060 XT]
    vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-4 code: Navi-4x
    process: TSMC n4 (4nm) built: 2025+ pcie: gen: 5 speed: 32 GT/s lanes: 16
    ports: active: HDMI-A-2 empty: DP-1,HDMI-A-1,Writeback-1 bus-ID: 0a:00.0
    chip-ID: 1002:7590 class-ID: 0300
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: 0
  Monitor-1: HDMI-A-2 model: Acer V227Q serial: <filter> built: 2020 res:
    mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 102 gamma: 1.2 chroma: red:
    x: 0.647 y: 0.333 green: x: 0.322 y: 0.627 blue: x: 0.153 y: 0.047 white:
    x: 0.314 y: 0.329 size: 476x268mm (18.74x10.55") diag: 546mm (21.5")
    ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960,
    1280x800, 1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576,
    720x480, 640x480, 720x400
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.1-arch1.2
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 9060 XT (radeonsi
    gfx1200 LLVM 21.1.6 DRM 3.64 6.17.13-1-MANJARO) device-ID: 1002:7590
    memory: 15.62 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.335 layers: 6 device: 0 type: discrete-gpu name: AMD
    Radeon RX 9060 XT (RADV GFX1200) driver: mesa radv v: 25.3.1-arch1.2
    device-ID: 1002:7590 surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 HDMI/DP Audio
    driver: snd_hda_intel v: kernel pcie: gen: 5 speed: 32 GT/s lanes: 16
    bus-ID: 0a:00.1 chip-ID: 1002:ab40 class-ID: 0403
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.17.13-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
  Device-1: MEDIATEK MT7921 802.11ax PCIe Wireless Network Adapter [Filogic
    330] vendor: AzureWave driver: mt7921e v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 14c3:7961 class-ID: 0280
  IF: wlp6s0 state: up mac: <filter>
  Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0
  IF: enp7s0 state: down mac: <filter>
  Device-1: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 13d3:3563
  Local Storage: total: 2.73 TiB used: 493.31 GiB (17.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Western Digital
    model: WD BLACK SN750 SE 1TB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 711130WD temp: 38.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
    model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 4B2QEXM7 temp: 38.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC46 scheme: MBR
  ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
    used: 269.86 GiB (29.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:6
    label: N/A uuid: 246a4db0-4152-46c2-94e0-79b1495fe607
    used: 652 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:5 label: N/A
    uuid: 9DA5-A68D
  ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
  ID-4: /mnt/668EB1FA8EB1C2BB raw-size: 931.51 GiB
    size: 931.51 GiB (100.00%) used: 223.45 GiB (24.0%) fs: ntfs dev: /dev/sda1
    maj-min: 8:1 label: ShareAndBackup uuid: 668EB1FA8EB1C2BB
  ID-5: /var/cache raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
  ID-6: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
  ID-1: /dev/nvme1n1p1 maj-min: 259:1 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme1n1p2 maj-min: 259:2 size: 900.25 GiB fs: ntfs label: N/A
    uuid: CAD8CA28D8CA129D
  ID-3: /dev/nvme1n1p3 maj-min: 259:3 size: 100 MiB fs: vfat label: N/A
    uuid: EE7B-F740
  Device-1: 1-5:2 info: IMC Networks Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
  Device-2: 1-6:3 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:1939 class-ID: 0300
    serial: <filter>
  Hub-2: 1-7:4 info: Genesys Logic Hub ports: 4 rev: 2.0
  Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-2:2 info: Logitech USB Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046d:c53f class-ID: 0300
  Device-2: 3-4:3 info: Ducky One 3 TKL RGB type: HID,keyboard,mouse
    driver: hid-generic,usbhid interfaces: 5 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 3233:8311 class-ID: 0300
    serial: <filter>
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 54.0 C mobo: 38.0 C gpu: amdgpu temp: 42.0 C
    mem: 39.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 7
  Packages: 1556 pm: pacman pkgs: 1549 libs: 479 tools: pamac pm: flatpak
    pkgs: 7
    1: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    4: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    5: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    6: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    7: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    8: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 379
  1: cpu: 11.8% command: firefox pid: 1832 mem: 639.7 MiB (4.0%)
  2: cpu: 10.0% command: exe pid: 1617 mem: 495.9 MiB (3.1%)
  3: cpu: 7.2% command: firefox pid: 2295 mem: 274.2 MiB (1.7%)
  4: cpu: 6.9% command: vesktop pid: 1536 mem: 261.0 MiB (1.6%)
  5: cpu: 6.2% command: konsole pid: 2596 mem: 218.9 MiB (1.3%)
  Memory top: 5 of 379
  1: mem: 639.7 MiB (4.0%) command: firefox pid: 1832 cpu: 11.8%
  2: mem: 495.9 MiB (3.1%) command: exe pid: 1617 cpu: 10.0%
  3: mem: 411.5 MiB (2.5%) command: plasmashell pid: 1052 cpu: 1.4%
  4: mem: 274.2 MiB (1.7%) command: firefox pid: 2295 cpu: 7.2%
  5: mem: 272.3 MiB (1.7%) command: vesktop pid: 1487 cpu: 4.0%
  Processes: 379 Power: uptime: 3m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.18 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
    tool: systemctl
  Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole
    inxi: 3.3.40
Mod edit:- inxi output added to benefit those wishing to help. No charge.
Kernel 6.17 has reached EOL within the past week – updates are no longer available from the Manjaro repositories – 6.17 is no longer supported, and should be removed at your earliest convenience.
Either (or both) of kernels 6.18 (LTS) and 6.12 (LTS) are currently suggested.
I am now running the 6.18.1 kernel but still experiencing the same issues. However, 6.17 seems to be unwilling to uninstall. It gives the following statement:
Starting
checking dependencies…
:: removing linux617 breaks dependency ‘linux617’ required by linux-meta
Remove linux-meta first.
Quick tip: Always show the complete command output, including the command(s) that were used…
…and place the output in a pre-formatted scrollable text box (use the </> button) and not a quote box.
Thanks, I will keep that in mind. However, this last time I didn’t use a command, I used the GUI Method of Manjaro Settings Manager.
I did some research on linux-meta, and isn’t it, uh, important? And supposed to prevent scenarios precisely like this one and upgrade kernels when they’re outdated?
Yes, it’s supposed to ensure you’re not left without a kernel, but sometimes, it just gets in the way.
Additionally, you cannot uninstall a kernel if it’s active (if it’s being used currently), and according to your inxi output, 6.17 is active.
Which kernels do you currently have installed apart from 6.17?
Ah, I see.
If 6.18 (LTS) is currently active, you can remove linux-meta followed by 6.17 – then install 6.12 (LTS) as a fallback.
I was GOING to use the command to make a list but the documentation posted above appears to be outdated…
~ user $ mhwd-kernel -li
zsh: correct 'user' to 'users' [nyae]? n
zsh: command not found: user
zsh: correct 'user' to 'users' [nyae]? y
users: invalid option -- 'l'
Try 'users --help' for more information.
The settings manager shows that I have 6.18.2-1 (which is currently active), 6.17.13-1, and 6.12.63-1.
UPDATE:
I have removed linux-meta and removed 6.17, then rebooted. Fullscreen apps are still making the display cut out though. :confused:
Mod edit:- Removed garbage characters from command output. No charge.
Please avoid posting garbage characters – all it takes is a little care when selecting the text to copy – thanks.
The user failed to use sudo. :slight_smile:
  • mhwd-kernel requires elevated privileges.
Plus, it looks like you also typed user $ as part of the command – that only indicated a prompt (thus the different colour). Example: fred $ command-here.
Also install kernel 6.12 (LTS) – you must have a secondary fallback kernel.
I just copied the complete log, like I was asked to… will delete in the future.
I just copy/pasted the command as it was written into the console. I am relatively new to linux and barely know what I’m doing. The linked wiki page didn’t tell me I needed to run sudo, or that I needed to substitute “user” with my username. It just said that running this command would give me a list of kernels installed.
In my previous post I stated that 6.12 is already installed. It was the default kernel when I installed manjaro, but a friend told me that my gpu wouldn’t be as supported with that one and to upgrade to a different one, so I did. Never uninstalled the other one.
In fact, every example on that page (with the exception of the first mhwd-kernel -li which didn’t require sudo) clearly lists sudo before each command given.
No, it didn’t tell you that, and neither did I.
I gave an example “fred” of what the “user” implied as part of a prompt (the green text in the commands) – that should not be included as part of the actual command.
Yes, I had missed that. Then, you currently have 6.18 (LTS) and 6.12 (LTS) installed as a fallback. All good.
Oh. OH! Okay I get what you’re saying now. (Also, if I had actually clicked “copy to clipboard” it would’ve been fine. I’m gonna blame this head cold on my stupidity. /j)
mhwd-kernel -li         ✔
Currently running: 6.18.2-1-MANJARO (linux618)
   * linux612
   * linux618
Problem still exists, though. Is it maybe a driver issue? I’m not seeing a driver manager on manjaro like there was on kubuntu…
It might be. You’re not using Nvidia, so the current issues with Nvidia drivers don’t apply.
  • Does the issue happen when using Wayland?
  • Does the issue persist in a new User account?
Creating a new User account (for testing) helps to isolate a problem; to discover whether it’s local or system wide.
That knowledge alone can help narrow it down.
Created new user, can confirm the problem was not on testuser’s account, only mine.
I… Am I not already using wayland? System Settings says I am…
(googles how to check, runs given command)
echo $XDG_SESSION_TYPE         ✔
wayland
Even worse, when attempting to get back to my own user account, the display shut off and remained that way until I forced shutdown with the power button. Ugh.
Well, that will give others a place to start.
I believe I meant to ask if the issue was on both Wayland and X11; some restored X11 after KDE disabled it. No matter.
There is a safer way:
REISUB/REISUO needs to be configured before it can be used - From memory, it might not be clear in the tutorial. If it isn’t, I’m sure someone will help out.
Okay so, after much research, I eventually found a post on the arch forums that had the fix: turning Adaptive Sync in Display & Monitor to “Never” now allows me to open fullscreen programs. YAY!
