My System Info
Kernel: 6.1.9-x64v1-xanmod1-MANJARO arch: x86_64 bits: 64 compiler: gcc
v: 12.2.1 parameters: BOOT_IMAGE=/boot/vmlinuz-manjaro-xanmod
root=/dev/mapper/ssdvg-rootlv rw quiet splash udev.log_priority=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: xinit
Type: Desktop System: Gigabyte product: B450 AORUS PRO WIFI v: N/A
serial: <superuser required>
Mobo: Gigabyte model: B450 AORUS PRO WIFI-CF v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F60
date: 02/24/2021
RAM: total: 15.57 GiB used: 4.81 GiB (30.9%)
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 32 MiB
desc: 1x32 MiB
Speed (MHz): avg: 4349 high: 4350 min/max: 2200/5552 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4350 2: 4350
3: 4344 4: 4346 5: 4349 6: 4350 7: 4350 8: 4350 9: 4350 10: 4350 11: 4350
12: 4350 13: 4350 14: 4350 15: 4350 16: 4350 bogomips: 139196
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: Gigabyte driver: nvidia
v: 525.85.05 alternate: nvidiafb,nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 06:00.0
chip-ID: 10de:1c02 class-ID: 0300
Device-2: Logitech C922 Pro Stream Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-2:3 chip-ID: 046d:085c
class-ID: 0102 serial: <filter>
Display: server: X.Org v: 21.1.6 with: Xwayland v: 22.1.7
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
s-diag: 777mm (30.58")
Monitor-1: DP-0 res: 2560x1440 hz: 60 dpi: 105
size: 621x341mm (24.45x13.43") diag: 708mm (27.89") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.85.05 renderer: NVIDIA GeForce GTX 1060
3GB/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GP106 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel bus-ID: 3-2:3 v: kernel pcie: chip-ID: 046d:085c gen: 3
class-ID: 0102 speed: 8 GT/s serial: <filter> lanes: 16 bus-ID: 06:00.1
chip-ID: 10de:10f1 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
bus-ID: 08:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech C922 Pro Stream Webcam type: USB
Device-4: Blue Microphones Yeti Stereo Microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-3:4 chip-ID: b58e:9e84
class-ID: 0300 serial: <filter>
Sound API: ALSA v: k6.1.9-x64v1-xanmod1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.65 running: yes
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 03:00.0
IP v6: <filter> type: dynamic mngtmpaddr noprefixroute scope: global
Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2526 class-ID: 0280
IF: wlp4s0 state: down mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-5:3 chip-ID: 8087:0025 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address: <filter>
Message: Unable to run lvs. Root privileges required.
Local Storage: total: 3.15 TiB used: 547.83 GiB (17.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM001-1ER164
type: HDD rpm: 7200 serial: <filter> rev: CC25 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37960G
size: 894.25 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: Z1.3 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Yeyian model: VALK 4200
type: SSD serial: <filter> rev: 0A0 scheme: GPT
ID-1: / raw-size: 1.33 TiB size: 1.31 TiB (98.35%) used: 547.83 GiB (41.0%)
fs: ext4 dev: /dev/dm-0 maj-min: 253:0 mapped: ssdvg-rootlv label: N/A
uuid: N/A
used: 360 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: D8E5-2A07
ID-3: /hdd raw-size: 983.67 GiB size: 967.16 GiB (98.32%)
used: 36 KiB (0.0%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 0c13b270-ea44-4bb0-84aa-2f1409584596
Kernel: swappiness: 30 (default 60) cache-pressure: 50 (default 100)
ID-1: swap-1 type: file size: 15.56 GiB used: 1.16 GiB (7.5%) priority: -2
file: /swapfile
ID-1: /dev/sda2 maj-min: 8:2 size: 879.34 GiB fs: ext4 label: RESTORE_HDD
uuid: 2c2d10ae-cc04-46d5-b90e-7ed8f412664a
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-5:3 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0025 class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:2 info: Cooler Master MasterKeys Pro L type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s power: 100mA
chip-ID: 2516:003b class-ID: 0300
Device-2: 3-2:3 info: Logitech C922 Pro Stream Webcam type: Video,Audio
power: 500mA chip-ID: 046d:085c class-ID: 0102 serial: <filter>
Device-3: 3-3:4 info: Blue Microphones Yeti Stereo Microphone
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: b58e:9e84 class-ID: 0300
serial: <filter>
Device-4: 3-4:6 info: Holtek Gaming Mouse [Redragon M711]
type: Mouse,Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 04d9:fc30 class-ID: 0300
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 33.5 C mobo: 30.0 C gpu: nvidia temp: 50 C
Fan Speeds (RPM): cpu: 0 fan-1: 0 fan-3: 0 gpu: nvidia fan: 0%
Power: 12v: N/A 5v: N/A 3.3v: 1.68 vbat: 1.66
Processes: 376 Uptime: 5h 9m wakeups: 360 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 alt: 11
clang: 15.0.7 Packages: 4075 pm: nix-default pkgs: 0 pm: nix-sys pkgs: 0
pm: nix-usr pkgs: 0 pm: pacman pkgs: 4065 libs: 691 tools: pamac,yay
pm: flatpak pkgs: 10 Shell: Bash v: 5.1.16 running-in: terminator
inxi: 3.3.25
Summary
I’m a semi-advanced user, currently diving into the Linux Kernel itself, including modules, compilation and technical details.
I’m curious about the following topics:
- Is the
ryzen_smu-dkmspackage any good for this specific CPU?
- Is the
zenpower3-dkmspackage any good? - Are there any kernel variables and/or build settings that might be worthy of notice?
- Are there any specific performance/tinkering/curious bits of info I should('nt) be aware of?
This is low-level stuff that I know I need to be careful with, and so most of this is me trying to understand very specific details. I’ll most definetly not play around with this uninformed, so I’m asking the experts around here.
