Question about boost-libs=1.74.0 and vpn-unlimited
I have installed the current version of manjaro mate on two computers. Using the AUR, I was able to install vpn-unlimited without any problems on one computer, but the dependencies refuse to work on the other.
Before I go searching for a wolf, I thought I’d ask the professionals.
Well there’s not much information to go on, please post any errors you get.
For now I’ll suggest that you may need to install base-devel.
sudo pacman -S base-devel
https://wiki.archlinux.org/title/Arch_User_Repository
base-devel is installed
Warnung: vpn-unlimited ist nur vom AUR verfügbar
Vorbereitung...
Klone vpn-unlimited Build-Dateien...
Generiere vpn-unlimited Informationen...
Überprüfe vpn-unlimited Abhängigkeiten...
Überprüfe qt5-webkit Abhängigkeiten...
Abhängigkeiten werden aufgelöst...
Warnung: Kann "boost-libs=1.74.0" nicht auflösen (eine Abhängigkeit von "vpn-unlimited")
Fehler: Vorgang konnte nicht erfolgreich vorbereitet werden:
Kann Abhängigkeiten nicht erfüllen:
- nicht vorhandene Abhängigkeit 'boost-libs=1.74.0' benötigt von vpn-unlimited
Build-Dateien bearbeiten : [e]
Transaktion anwenden ? [e/j/N] j
Vorgang abgebrochen.
It seems to be relying on an outdated version, that is no longer available in either the repos or the AUR.
You could try changing this line
boost-libs=1.74.0
to this
boost174-libs
However there's this comment on the AUR page:
No workaround for boost-libs=1.74 in near sight, though?
Not to my knowledge. They’ve linked to version 1.74 because that’s what’s available on Debian Bullseye. I don’t think it’s possible patch the executable to use 1.81 so’s, but I’d be happy to do so if there was a way. Debian Experimental has 1.81 but I guess that’s years away.
The only think I can think of would be to reach out to them and ask them to not link explicitly to version 1.74, or to statically link Boost.
EDIT:
Corrected.
The package maintainer should be notified so they can correct the PKGBUILD.
Try this:
pamac build boost174-libs vpn-unlimited
I will try to change the entry to boost-libs. The crazy thing is that it worked under the same distribution on one computer and not on the other. That’s what puzzles me.
Oops missed that one.
Ok … looks good … will check back after compiling on an old macmini … think in 3 hours ^^
ThankYou!
Thank You All! Problem is solved. Great work.
I tried about 5 years to get that to work before under Linux.
