Hi,
I have a hp zbook g5 studio laptop with a Conexant CX11970. When I boot the laptop, headphones are shown as sound device (speakers not available) - this only happens in Linux, not Windows. Sometimes it seems sound is activated (cannot reproduce reliably), but then only left top speaker works.
The device itself has 4 speakers (top left, top right, bottom left, bottom right). They work in windows.
I tried to start playing with hdajackretask but it doesn’t list any sources to connect to (only shows “Not connected” as a choice.
Sound used to work, but stopped a few updates ago (about a month, but didn’t really have time to investigate further. Sound works on 5.15.76 LTS kernel.
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.5.1
!!Script ran on: Sun Oct 30 15:28:36 UTC 2022
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: HP
Product Name: HP ZBook Studio G5
Product Version:
Firmware Version: Q71 Ver. 01.21.02
System SKU: 4NM08UT#ABA
Board Vendor: HP
Board Name: 8427
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI000C:00/status 15
/sys/bus/acpi/devices/HPQ6001:00/status 15
/sys/bus/acpi/devices/HPQ6007:00/status 15
/sys/bus/acpi/devices/INT0E0C:00/status 15
/sys/bus/acpi/devices/INT3400:00/status 15
/sys/bus/acpi/devices/INT3403:00/status 15
/sys/bus/acpi/devices/INT3403:01/status 15
/sys/bus/acpi/devices/INT340E:00/status 15
/sys/bus/acpi/devices/INT3450:00/status 15
/sys/bus/acpi/devices/INT3F0D:00/status 15
/sys/bus/acpi/devices/LNXPOWER:00/status 1
/sys/bus/acpi/devices/LNXPOWER:01/status 1
/sys/bus/acpi/devices/LNXPOWER:02/status 1
/sys/bus/acpi/devices/LNXPOWER:03/status 15
/sys/bus/acpi/devices/LNXPOWER:05/status 1
/sys/bus/acpi/devices/LNXPOWER:06/status 1
/sys/bus/acpi/devices/LNXPOWER:07/status 1
/sys/bus/acpi/devices/LNXPOWER:08/status 1
/sys/bus/acpi/devices/LNXPOWER:09/status 1
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0B00:00/status 15
/sys/bus/acpi/devices/PNP0C02:00/status 3
/sys/bus/acpi/devices/PNP0C02:01/status 3
/sys/bus/acpi/devices/PNP0C02:05/status 3
/sys/bus/acpi/devices/PNP0C02:07/status 15
/sys/bus/acpi/devices/PNP0C04:00/status 31
/sys/bus/acpi/devices/PNP0C09:00/status 15
/sys/bus/acpi/devices/PNP0C0A:00/status 31
/sys/bus/acpi/devices/PNP0C0C:00/status 11
/sys/bus/acpi/devices/PRP00001:00/status 11
/sys/bus/acpi/devices/SYNA307B:00/status 15
/sys/bus/acpi/devices/USBC000:00/status 15
/sys/bus/acpi/devices/device:04/status 15
/sys/bus/acpi/devices/device:2d/status 15
/sys/bus/acpi/devices/device:2e/status 15
!!Kernel Information
Kernel release: 6.0.6-1-MANJARO
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k6.0.6-1-MANJARO
Library version: 1.2.8
Utilities version: 1.2.8
!!Loaded ALSA modules
snd_hda_intel (card 0)
!!Sound Servers on this system
PipeWire:
Installed - Yes (/usr/bin/pipewire)
Running - Yes
No sound servers found.
!!Soundcards recognised by ALSA
0 [PCH ]: HDA-Intel - HDA Intel PCH
HDA Intel PCH at 0x404a108000 irq 165
!!PCI Soundcards installed in the system
00:1f.3 Audio device [0403]: Intel Corporation Cannon Lake PCH cAVS [8086:a348] (rev 10) (prog-if 80)
Subsystem: Hewlett-Packard Company Device [103c:8427]
01:00.1 Audio device [0403]: NVIDIA Corporation GP107GL High Definition Audio Controller [10de:0fb9] (rev a1)
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx+
!!Modprobe options (Sound related)
snd_hda_intel: power_save=1
snd_hda_intel: enable=1,0
!!Loaded sound module options
!!Module: snd_hda_intel
align_buffer_size : -1
bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
dmic_detect : Y
enable : Y,N,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : -1
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
pm_blacklist : Y
position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
power_save : 1
power_save_controller : Y
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : -1
snoop : -1
!!Sysfs card info
!!Card: /sys/class/sound/card0
Driver: /sys/bus/pci/drivers/snd_hda_intel
Tree:
|-- controlC0
| |-- dev
| |-- device -> ../../card0
| |-- led-mic -> ../../../../../virtual/sound/ctl-led/mic/card0
| |-- led-speaker -> ../../../../../virtual/sound/ctl-led/speaker/card0
| |-- power
| |-- subsystem -> ../../../../../../class/sound
| `-- uevent
|-- device -> ../../../0000:00:1f.3
|-- hwC0D0
| |-- afg
| |-- chip_name
| |-- clear
| |-- dev
| |-- driver_pin_configs
| |-- hints
| |-- init_pin_configs
| |-- init_verbs
| |-- mfg
| |-- modelname
| |-- power
| |-- power_off_acct
| |-- power_on_acct
| |-- reconfig
| |-- revision_id
| |-- subsystem_id
| |-- uevent
| |-- user_pin_configs
| |-- vendor_id
| `-- vendor_name
|-- hwC0D2
| |-- afg
| |-- chip_name
| |-- clear
| |-- dev
| |-- hints
| |-- init_pin_configs
| |-- init_verbs
| |-- mfg
| |-- modelname
| |-- power
| |-- power_off_acct
| |-- power_on_acct
| |-- reconfig
| |-- revision_id
| |-- subsystem_id
| |-- uevent
| |-- user_pin_configs
| |-- vendor_id
| `-- vendor_name
|-- id
|-- input12
| |-- capabilities
| |-- event11
| |-- id
| |-- inhibited
| |-- modalias
| |-- name
| |-- phys
| |-- power
| |-- properties
| |-- subsystem -> ../../../../../../class/input
| |-- uevent
| `-- uniq
|-- input13
| |-- capabilities
| |-- event12
| |-- id
| |-- inhibited
| |-- modalias
| |-- name
| |-- phys
| |-- power
| |-- properties
| |-- uevent
| `-- uniq
|-- input14
| |-- capabilities
| |-- event13
| |-- id
| |-- inhibited
| |-- modalias
| |-- name
| |-- phys
| |-- power
| |-- properties
| |-- uevent
| `-- uniq
|-- number
|-- pcmC0D0c
| |-- dev
| |-- pcm_class
| |-- power
| `-- uevent
|-- pcmC0D0p
| |-- dev
| |-- pcm_class
| |-- power
| `-- uevent
|-- pcmC0D3p
| |-- dev
| |-- pcm_class
| |-- power
| `-- uevent
|-- power
| |-- autosuspend_delay_ms
| |-- control
| |-- runtime_active_time
| |-- runtime_status
| `-- runtime_suspended_time
|-- subsystem -> ../../../../../class/sound
`-- uevent
!!HDA-Intel Codec information
--startcollapse--
Codec: Conexant CX11970
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x14f120d0
Subsystem Id: 0x103c8427
Revision Id: 0x100001
No Modem Function Group found
Default PCM:
N/A
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power: setting=UNKNOWN, actual=UNKNOWN, Error, Clock-stop-OK, Setting-reset
Invalid AFG subtree
Codec: Intel Generic HDMI
Address: 2
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x8086280b
Subsystem Id: 0x80860101
Revision Id: 0x100000
Default PCM:
N/A
Invalid AFG subtree
--endcollapse--
!!ALSA Device nodes
crw-rw----+ 1 root audio 116, 7 Oct 30 15:08 /dev/snd/controlC0
crw-rw----+ 1 root audio 116, 5 Oct 30 15:08 /dev/snd/hwC0D0
crw-rw----+ 1 root audio 116, 6 Oct 30 15:08 /dev/snd/hwC0D2
crw-rw----+ 1 root audio 116, 3 Oct 30 15:24 /dev/snd/pcmC0D0c
crw-rw----+ 1 root audio 116, 2 Oct 30 15:26 /dev/snd/pcmC0D0p
crw-rw----+ 1 root audio 116, 4 Oct 30 15:09 /dev/snd/pcmC0D3p
crw-rw----+ 1 root audio 116, 1 Oct 30 15:08 /dev/snd/seq
crw-rw----+ 1 root audio 116, 33 Oct 30 15:08 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 60 Oct 30 15:28 .
drwxr-xr-x 3 root root 220 Oct 30 15:28 ..
lrwxrwxrwx 1 root root 12 Oct 30 15:08 pci-0000:00:1f.3 -> ../controlC0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: CX11970 Analog [CX11970 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card PCH
Card sysdefault:0 'PCH'/'HDA Intel PCH at 0x404a108000 irq 165'
Mixer name : 'Conexant CX11970'
Components : 'HDA:14f120d0,103c8427,00100001 HDA:8086280b,80860101,00100000'
Controls : 28
Simple ctrls : 11
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 74
Mono: Playback 57 [77%] [-17.00dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 74 [100%] [0.00dB] [on]
Front Right: Playback 74 [100%] [0.00dB] [on]
Simple mixer control 'Speaker',0
Mono:
Front Left: Playback 0 [0%] [-74.00dB] [off]
Front Right: Playback 0 [0%] [-74.00dB] [off]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 2 [67%] [24.00dB]
Front Right: 2 [67%] [24.00dB]
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Mono: Playback [off]
Simple mixer control 'Beep',0
Mono: Playback 7 [100%] [0.00dB] [on]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 80
Front Left: Capture 80 [100%] [6.00dB] [on]
Front Right: Capture 80 [100%] [6.00dB] [on]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Disabled'
Simple mixer control 'Digital',0
Limits: Capture 0 - 120
Front Left: Capture 62 [52%] [1.00dB]
Front Right: Capture 62 [52%] [1.00dB]
Simple mixer control 'Internal Mic Boost',0
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
!!Alsactl output
--startcollapse--
state.PCH {
control.1 {
iface MIXER
name 'Beep Playback Volume'
value 7
comment {
access 'read write'
type INTEGER
count 1
range '0 - 7'
dbmin -2800
dbmax 0
dbvalue.0 0
control.2 {
iface MIXER
name 'Beep Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.3 {
iface MIXER
name 'Headphone Playback Volume'
value.0 74
value.1 74
comment {
access 'read write'
type INTEGER
count 2
range '0 - 74'
dbmin -7400
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.4 {
iface MIXER
name 'Headphone Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.5 {
iface MIXER
name 'Speaker Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 74'
dbmin -7400
dbmax 0
dbvalue.0 -7400
dbvalue.1 -7400
control.6 {
iface MIXER
name 'Speaker Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.7 {
iface MIXER
name 'Auto-Mute Mode'
value Disabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.8 {
iface MIXER
name 'Capture Volume'
value.0 80
value.1 80
comment {
access 'read write'
type INTEGER
count 2
range '0 - 80'
dbmin -7400
dbmax 600
dbvalue.0 600
dbvalue.1 600
control.9 {
iface MIXER
name 'Capture Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.10 {
iface MIXER
name 'Internal Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3600
dbvalue.0 0
dbvalue.1 0
control.11 {
iface MIXER
name 'Mic Boost Volume'
value.0 2
value.1 2
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3600
dbvalue.0 2400
dbvalue.1 2400
control.12 {
iface MIXER
name 'Master Playback Volume'
value 57
comment {
access 'read write'
type INTEGER
count 1
range '0 - 74'
dbmin -7400
dbmax 0
dbvalue.0 -1700
control.13 {
iface MIXER
name 'Master Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.14 {
iface CARD
name 'Internal Mic Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.15 {
iface CARD
name 'Mic Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.16 {
iface CARD
name 'Headphone Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.17 {
iface CARD
name 'Speaker Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.18 {
iface PCM
name 'Playback Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.19 {
iface PCM
name 'Capture Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.20 {
iface CARD
name 'HDMI/DP,pcm=3 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.21 {
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.22 {
iface MIXER
name 'IEC958 Playback Pro Mask'
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.23 {
iface MIXER
name 'IEC958 Playback Default'
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.24 {
iface MIXER
name 'IEC958 Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.25 {
iface PCM
device 3
name ELD
value ''
comment {
access 'read volatile'
type BYTES
count 0
control.26 {
iface PCM
device 3
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.27 {
iface MIXER
name 'PCM Playback Volume'
value.0 255
value.1 255
comment {
access 'read write user'
type INTEGER
count 2
range '0 - 255'
tlv '0000000100000008ffffec1400000014'
dbmin -5100
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.28 {
iface MIXER
name 'Digital Capture Volume'
value.0 62
value.1 62
comment {
type INTEGER
count 2
range '0 - 120'
tlv '0000000100000008fffff44800000032'
dbmin -3000
dbmax 3000
dbvalue.0 100
dbvalue.1 100
--endcollapse--
!!All Loaded Modules
ac97_bus
acpi_call
acpi_pad
acpi_thermal_rel
aesni_intel
af_alg
algif_hash
algif_skcipher
apple_mfi_fastcharge
asn1_encoder
atkbd
blake2b_generic
bluetooth
bnep
btbcm
btintel
btmtk
btrfs
btrtl
btusb
cbc
ccm
cec
cfg80211
cmac
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
dm_crypt
dm_mod
drm_buddy
drm_display_helper
ecdh_generic
ee1004
encrypted_keys
fat
fuse
ghash_clmulni_intel
hid_apple
hid_multitouch
hp_accel
hp_wmi
i2c_hid
i2c_hid_acpi
i2c_i801
i2c_smbus
i8042
i915
iTCO_vendor_support
iTCO_wdt
idma64
int3400_thermal
int3403_thermal
int340x_thermal_zone
intel_cstate
intel_gtt
intel_lpss
intel_lpss_pci
intel_pch_thermal
intel_pmc_bxt
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_soc_dts_iosf
intel_tcc_cooling
intel_uncore
intel_wmi_thunderbolt
ip6_tables
ip6table_filter
ip_tables
iptable_filter
irqbypass
iwlmvm
iwlwifi
joydev
kvm
kvm_intel
ledtrig_audio
libarc4
libcrc32c
libps2
lis3lv02d
loop
mac80211
mac_hid
mc
mei
mei_hdcp
mei_me
mei_pxp
mei_wdt
mmc_core
mousedev
mtd
mxm_wmi
nls_iso8859_1
nvidia
nvidia_drm
nvidia_modeset
nvidia_uvm
nvme
nvme_core
pcspkr
platform_profile
processor_thermal_device
processor_thermal_device_pci_legacy
processor_thermal_mbox
processor_thermal_rapl
processor_thermal_rfim
psmouse
qrtr
raid6_pq
rapl
rfcomm
rfkill
rng_core
roles
rtsx_pci
rtsx_pci_sdmmc
serio
serio_raw
snd
snd_compress
snd_ctl_led
snd_hda_codec
snd_hda_codec_conexant
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hrtimer
snd_hwdep
snd_intel_dspcfg
snd_intel_sdw_acpi
snd_pcm
snd_pcm_dmaengine
snd_rawmidi
snd_seq
snd_seq_device
snd_seq_dummy
snd_soc_acpi
snd_soc_acpi_intel_match
snd_soc_core
snd_soc_hdac_hda
snd_soc_skl
snd_soc_sst_dsp
snd_soc_sst_ipc
snd_sof
snd_sof_intel_hda
snd_sof_intel_hda_common
snd_sof_pci
snd_sof_pci_intel_cnl
snd_sof_utils
snd_sof_xtensa_dsp
snd_timer
snd_usb_audio
snd_usbmidi_lib
soundcore
soundwire_bus
soundwire_cadence
soundwire_generic_allocation
soundwire_intel
sparse_keymap
spi_intel
spi_intel_pci
spi_nor
squashfs
tee
tpm
trusted
ttm
typec
typec_ucsi
ucsi_acpi
uhid
uinput
usbhid
usbip_core
usbip_host
uvcvideo
vboxdrv
vboxnetadp
vboxnetflt
vfat
video
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
vivaldi_fmap
wireless_hotkey
wmi
wmi_bmof
x86_pkg_temp_thermal
x_tables
xhci_pci
xhci_pci_renesas
xor
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x16 0x04211040
0x17 0x40f001f0
0x18 0x40f001f0
0x19 0x04a11030
0x1a 0x95a60120
0x1d 0x91170110
0x1e 0x40f001f0
0x1f 0x40f001f0
0x21 0x40f001f0
0x26 0x40f001f0
0x27 0x40f001f0
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC0D2/init_pin_configs:
0x03 0x18560010
/sys/class/sound/hwC0D2/driver_pin_configs:
/sys/class/sound/hwC0D2/user_pin_configs:
/sys/class/sound/hwC0D2/init_verbs:
/sys/class/sound/hwC0D2/hints:
!!ALSA/HDA dmesg
[ 0.191392] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.191393] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.191394] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 3.663901] pci 0000:01:00.0: reg 0x30: [mem 0xfff80000-0xffffffff pref]
[ 3.663929] pci 0000:01:00.0: Enabling HDA controller
[ 3.668184] pci 0000:01:00.1: [10de:0fb9] type 00 class 0x040300
[ 10.109860] i2c i2c-9: Successfully instantiated SPD at 0x50
[ 10.122339] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
[ 10.122374] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[ 10.122602] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 10.123052] snd_hda_intel: probe of 0000:01:00.1 failed with error -2
[ 10.211020] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
[ 10.268076] input: ST LIS3LV02DL Accelerometer as /devices/platform/lis3lv02d/input/input11
[ 10.531340] snd_hda_codec_conexant hdaudioC0D0: CX11970: BIOS auto-probing.
[ 10.531654] intel_rapl_common: Found RAPL domain package
[ 10.531658] intel_rapl_common: Found RAPL domain psys
[ 10.532037] snd_hda_codec_conexant hdaudioC0D0: vmaster hook already present before cdev!
[ 10.532185] snd_hda_codec_conexant hdaudioC0D0: autoconfig for CX11970: line_outs=1 (0x1d/0x0/0x0/0x0/0x0) type:speaker
[ 10.532187] snd_hda_codec_conexant hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 10.532189] snd_hda_codec_conexant hdaudioC0D0: hp_outs=1 (0x16/0x0/0x0/0x0/0x0)
[ 10.532190] snd_hda_codec_conexant hdaudioC0D0: mono: mono_out=0x0
[ 10.532190] snd_hda_codec_conexant hdaudioC0D0: inputs:
[ 10.532191] snd_hda_codec_conexant hdaudioC0D0: Internal Mic=0x1a
[ 10.532192] snd_hda_codec_conexant hdaudioC0D0: Mic=0x19
[ 10.549878] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[ 10.668425] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input12
[ 10.668584] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input13
[ 10.668652] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input14
[ 10.751462] Bluetooth: Core ver 2.22
[ 11.826187] usb 1-4.1: 1:3 : unsupported format bits 0x100000000
[ 11.844093] usbcore: registered new interface driver snd-usb-audio
[ 11.868274] apple 0003:05AC:024F.0005: input,hidraw5: USB HID v1.11 Keyboard [Keychron Keychron K3] on usb-0000:00:14.0-4.3/input0
[ 13.621815] Bluetooth: hci0: Bad flag given (0x2) vs supported (0x1)
[ 13.944940] snd_hda_intel 0000:00:1f.3: azx_get_response timeout, switching to polling mode: last cmd=0x20270503
[ 14.841451] wlp0s20f3: authenticate with 48:8f:5a:38:46:89
[ 14.940215] wlp0s20f3: associated
[ 14.951316] snd_hda_intel 0000:00:1f.3: No response from codec, disabling MSI: last cmd=0x20270503
[ 15.068258] IPv6: ADDRCONF(NETDEV_CHANGE): wlp0s20f3: link becomes ready
[ 15.246316] rfkill: input handler disabled
[ 15.961343] snd_hda_intel 0000:00:1f.3: azx_get_response timeout, switching to single_cmd mode: last cmd=0x20270503
[ 16.054688] pci 0000:01:00.1: Unable to change power state from D3cold to D0, device inaccessible
[ 16.062211] pci 0000:01:00.1: Unable to change power state from D3cold to D0, device inaccessible
[ 16.536072] snd_hda_codec_conexant hdaudioC0D0: Unable to sync register 0x10b8000. -5
[ 16.537087] snd_hda_codec_conexant hdaudioC0D0: Unable to sync register 0x10b8000. -5
[ 16.895046] snd_hda_codec_hdmi hdaudioC0D2: Unable to sync register 0x2f0d00. -5
[ 16.895281] snd_hda_codec_hdmi hdaudioC0D2: HDMI: invalid ELD buf size -1
[ 17.167694] rfkill: input handler enabled
[ 49.018404] pci 0000:01:00.0: Max Payload Size set to 256 (was 128, max 256)
[ 49.018482] pci 0000:01:00.0: Enabling HDA controller
[ 49.021176] pci 0000:01:00.0: vgaarb: bridge control possible
[ 57.449732] rfkill: input handler disabled
[ 57.645874] snd_hda_codec_conexant hdaudioC0D0: Unable to sync register 0x10b8000. -5
[ 57.646808] snd_hda_codec_conexant hdaudioC0D0: Unable to sync register 0x10b8000. -5
[ 57.962155] snd_hda_codec_hdmi hdaudioC0D2: Unable to sync register 0x2f0d00. -5
[ 57.962413] snd_hda_codec_hdmi hdaudioC0D2: HDMI: invalid ELD buf size -1
[ 63.253861] rfkill: input handler enabled
[ 65.415045] azx_single_send_cmd: 711 callbacks suppressed
[ 65.683468] snd_hda_codec_conexant hdaudioC0D0: Unable to sync register 0x10b8000. -5
[ 65.684484] snd_hda_codec_conexant hdaudioC0D0: Unable to sync register 0x10b8000. -5
[ 66.039350] snd_hda_codec_hdmi hdaudioC0D2: Unable to sync register 0x2f0d00. -5
[ 66.039596] snd_hda_codec_hdmi hdaudioC0D2: HDMI: invalid ELD buf size -1
[ 67.165266] rfkill: input handler disabled
[ 284.346625] azx_single_send_cmd: 711 callbacks suppressed
[ 284.623571] snd_hda_codec_conexant hdaudioC0D0: Unable to sync register 0x10b8000. -5
[ 284.624601] snd_hda_codec_conexant hdaudioC0D0: Unable to sync register 0x10b8000. -5
[ 291.075766] azx_single_send_cmd: 245 callbacks suppressed
[ 322.315913] azx_single_send_cmd: 228 callbacks suppressed
[ 322.590197] snd_hda_codec_conexant hdaudioC0D0: Unable to sync register 0x10b8000. -5
[ 322.591213] snd_hda_codec_conexant hdaudioC0D0: Unable to sync register 0x10b8000. -5
[ 329.355791] azx_single_send_cmd: 249 callbacks suppressed
[ 556.643936] azx_single_send_cmd: 228 callbacks suppressed
[ 556.920457] snd_hda_codec_conexant hdaudioC0D0: Unable to sync register 0x10b8000. -5
[ 556.921477] snd_hda_codec_conexant hdaudioC0D0: Unable to sync register 0x10b8000. -5
[ 557.192617] snd_hda_codec_hdmi hdaudioC0D2: Unable to sync register 0x2f0d00. -5
[ 557.192876] snd_hda_codec_hdmi hdaudioC0D2: HDMI: invalid ELD buf size -1
[ 597.047847] azx_single_send_cmd: 570 callbacks suppressed
[ 597.320629] snd_hda_codec_conexant hdaudioC0D0: Unable to sync register 0x10b8000. -5
[ 597.321645] snd_hda_codec_conexant hdaudioC0D0: Unable to sync register 0x10b8000. -5
[ 597.599817] snd_hda_codec_hdmi hdaudioC0D2: Unable to sync register 0x2f0d00. -5
[ 597.600080] snd_hda_codec_hdmi hdaudioC0D2: HDMI: invalid ELD buf size -1
[ 922.444194] azx_single_send_cmd: 570 callbacks suppressed
[ 922.714322] snd_hda_codec_conexant hdaudioC0D0: Unable to sync register 0x10b8000. -5
[ 922.715352] snd_hda_codec_conexant hdaudioC0D0: Unable to sync register 0x10b8000. -5
[ 932.009280] azx_single_send_cmd: 245 callbacks suppressed
[ 963.764552] azx_single_send_cmd: 228 callbacks suppressed
[ 964.043663] snd_hda_codec_conexant hdaudioC0D0: Unable to sync register 0x10b8000. -5
[ 964.044725] snd_hda_codec_conexant hdaudioC0D0: Unable to sync register 0x10b8000. -5
[ 977.596034] azx_single_send_cmd: 249 callbacks suppressed
[ 989.434350] azx_single_send_cmd: 239 callbacks suppressed
[ 989.706768] snd_hda_codec_conexant hdaudioC0D0: Unable to sync register 0x10b8000. -5
[ 989.707751] snd_hda_codec_conexant hdaudioC0D0: Unable to sync register 0x10b8000. -5
[ 1003.152398] usb 1-5: USB disconnect, device number 3
[ 1042.631949] azx_single_send_cmd: 228 callbacks suppressed
[ 1042.903526] snd_hda_codec_conexant hdaudioC0D0: Unable to sync register 0x10b8000. -5
[ 1042.904544] snd_hda_codec_conexant hdaudioC0D0: Unable to sync register 0x10b8000. -5
[ 1043.172790] snd_hda_codec_hdmi hdaudioC0D2: Unable to sync register 0x2f0d00. -5
[ 1043.173059] snd_hda_codec_hdmi hdaudioC0D2: HDMI: invalid ELD buf size -1
[ 1079.085426] azx_single_send_cmd: 570 callbacks suppressed
[ 1079.353693] snd_hda_codec_conexant hdaudioC0D0: Unable to sync register 0x10b8000. -5
[ 1079.354705] snd_hda_codec_conexant hdaudioC0D0: Unable to sync register 0x10b8000. -5
[ 1079.622989] snd_hda_codec_hdmi hdaudioC0D2: Unable to sync register 0x2f0d00. -5
[ 1079.623252] snd_hda_codec_hdmi hdaudioC0D2: HDMI: invalid ELD buf size -1
[ 1095.898986] azx_single_send_cmd: 570 callbacks suppressed
[ 1096.173723] snd_hda_codec_conexant hdaudioC0D0: Unable to sync register 0x10b8000. -5
[ 1096.174711] snd_hda_codec_conexant hdaudioC0D0: Unable to sync register 0x10b8000. -5
[ 1102.734863] azx_single_send_cmd: 245 callbacks suppressed
[ 1197.230213] azx_single_send_cmd: 228 callbacks suppressed
[ 1197.503972] snd_hda_codec_conexant hdaudioC0D0: Unable to sync register 0x10b8000. -5
[ 1197.504938] snd_hda_codec_conexant hdaudioC0D0: Unable to sync register 0x10b8000. -5
[ 1197.773010] snd_hda_codec_hdmi hdaudioC0D2: Unable to sync register 0x2f0d00. -5
[ 1197.773280] snd_hda_codec_hdmi hdaudioC0D2: HDMI: invalid ELD buf size -1
